mimozin
December 21, 2022, 10:22am
1
Hi everyone!
I have a Slimbook ProX15 AMD (2020) with Manjaro Plasma y W11 (dualboot).
Everything ok except that in Manjaro it does not detect a bluetooth headset (Mixcder E9). On Windows, android etc. YES. The fact is that, previously, with Ubuntu this problem did not exist. I understand that it is not a problem with the headphones because I can see them with Windows, on the same PC, and on other devices.
Kernel: 5.15.81-1-MANJARO
Any ideas??
More information:
mimozin:
Fexa
December 21, 2022, 12:01pm
2
can you connect other bluetooth devices?
Some laptops have wifi and Bluetooth in same wifi card so make sure to have wifi drivers installed
I had same problem on my old laptop and installing wifi driver which was rtl8821ce for me worked you can find your driver and install it
mimozin
December 21, 2022, 12:12pm
3
Yes, in fact I have a razer mouse and it works perfectly.
I’ll try it.
So far, wifi and bluetooth have worked with normal but who knows…
If it doesn’t work, could be the kernel??
Thanks!!!
Fexa
December 21, 2022, 1:27pm
4
It could be kernel u can try installing latest kernel and kernel header
mimozin
December 21, 2022, 4:44pm
5
I’ve tried 6.1.0-1 version and nothing has changed.
herbie
December 21, 2022, 9:00pm
6
I did a ‘Google’ and came up with this
Did you
systemctl enable bluetooth.service
and
(1) run the following command in terminal:
sudo setfacl -m u:gdm:r /usr/bin/pulseaudio
(2) reboot or restart the pulseaudio by running the following command in terminal:
sudo pkill pulseaudio
Worth a shot?
mimozin
December 22, 2022, 7:36am
7
herbie:
sudo setfacl -m u:sddm:r /usr/bin/pulseaudio
Worth a shot?
(sddm instead of gdm )
I tried it and no, nothing changes.
mimozin
December 23, 2022, 8:13am
8
Some system imformation:
output:
Kernel: 6.1.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7fed8359-6cfc-4797-b1eb-e7ee9a9f6cce rw udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: SLIMBOOK product: PROX15-AMD v: Standard
serial: <superuser required>
Mobo: SLIMBOOK model: PROX15-AMD v: Standard serial: <superuser required>
UEFI: American Megatrends v: N.1.07GRP05 date: 07/28/2022
ID-1: BAT0 charge: 57.5 Wh (84.1%) condition: 68.4/91.6 Wh (74.7%)
volts: 12.5 min: 11.6 model: standard type: Li-ion serial: <filter>
status: charging
RAM: total: 15.05 GiB used: 6.93 GiB (46.0%)
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1400 high: 1422 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1422 2: 1400
3: 1400 4: 1400 5: 1400 6: 1397 7: 1400 8: 1400 9: 1400 10: 1395 11: 1397
12: 1400 13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 92657
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: Tongfang Hongkong driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 33.0 C
Device-2: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 04f2:b68b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: left model: LG (GoldStar) FULL HD
serial: <filter> built: 2020 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: primary,right model: Sharp LQ156M1JW01
built: 2019 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.0-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Tongfang Hongkong
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Tongfang Hongkong
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Tongfang Hongkong
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.0-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
vendor: Tongfang Hongkong driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4.4:6 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 931.51 GiB used: 521.29 GiB (56.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR013 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 121.01 GiB size: 118.55 GiB (97.97%) used: 44.4 GiB (37.4%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 7fed8359-6cfc-4797-b1eb-e7ee9a9f6cce
used: 33.2 MiB (34.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: F442-AC33
ID-3: /mnt/DATOS raw-size: 658.76 GiB size: 658.76 GiB (100.00%)
used: 389.28 GiB (59.1%) fs: ntfs dev: /dev/nvme0n1p9 maj-min: 259:9
label: DATOS uuid: F098A2F298A2B70E
ID-4: /mnt/SO raw-size: 134.6 GiB size: 134.6 GiB (100.00%)
used: 87.58 GiB (65.1%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: SO
uuid: 08B69AE5B69AD294
ID-1: swap-1 type: partition size: 15.42 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: cf155454-7d0b-4dfb-a764-27beb6525d95
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs label: N/A
uuid: A65C39B15C397CDD
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 637 MiB fs: ntfs label: N/A
uuid: C02CEB4C2CEB3C52
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 1024 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 513 MiB fs: vfat label: N/A
uuid: 6F2A-E0D4
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:2 info: BY Tech Usb Gaming Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 258a:0016 class-ID: 0300
Device-2: 1-3:3 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b68b
Hub-2: 1-4:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4.3:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-4.4:6 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.6 C mobo: N/A gpu: amdgpu temp: 34.0 C
Processes: 374 Uptime: 1h 9m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1507 pm: dpkg pkgs: 0 pm: pacman pkgs: 1500 libs: 398
tools: pamac,yay pm: flatpak pkgs: 7 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
rfkill list
output
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Fri 2022-12-23 07:53:19 CET; 1h 19min ago
Docs: man:bluetoothd(8)
Main PID: 826 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18470)
Memory: 3.1M
CPU: 30.632s
CGroup: /system.slice/bluetooth.service
└─826 /usr/lib/bluetooth/bluetoothd
dic 23 07:53:29 Manjaro bluetoothd[826]: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSink/aptx
dic 23 07:53:29 Manjaro bluetoothd[826]: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSource/aptx
dic 23 07:53:29 Manjaro bluetoothd[826]: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSink/sbc
dic 23 07:53:29 Manjaro bluetoothd[826]: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSource/sbc
dic 23 07:53:29 Manjaro bluetoothd[826]: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSink/sbc_xq_453
dic 23 07:53:29 Manjaro bluetoothd[826]: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSource/sbc_xq_453
dic 23 07:53:29 Manjaro bluetoothd[826]: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSink/sbc_xq_512
dic 23 07:53:29 Manjaro bluetoothd[826]: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSource/sbc_xq_512
dic 23 07:53:29 Manjaro bluetoothd[826]: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSink/sbc_xq_552
dic 23 07:53:29 Manjaro bluetoothd[826]: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSource/sbc_xq_552
There are others with this wireless card and similar problems…
Error “Bluetooth: hci0: Malformed MSFT vendor event: 0x02”
… any idea???
mimozin
January 24, 2023, 7:48am
10
[SOLVED]
There was an entry in bluetooth directory with the same MAC address that que headset (I don´t know why…)
Delete it, restart the service and rescan again solved the problem with the headset.
system
Closed
January 26, 2023, 9:49pm
11
