Thanks for your reply @Mirdarthos . The outputs are:
# /usr/lib/systemd/system/bluetooth.service
[Unit]
Description=Bluetooth service
Documentation=man:bluetoothd(8)
ConditionPathIsDirectory=/sys/class/bluetooth
[Service]
Type=dbus
BusName=org.bluez
ExecStart=/usr/lib/bluetooth/bluetoothd
NotifyAccess=main
#WatchdogSec=10
#Restart=on-failure
CapabilityBoundingSet=CAP_NET_ADMIN CAP_NET_BIND_SERVICE
LimitNPROC=1
# Filesystem lockdown
ProtectHome=true
ProtectSystem=strict
PrivateTmp=true
ProtectKernelTunables=true
ProtectControlGroups=true
StateDirectory=bluetooth
StateDirectoryMode=0700
ConfigurationDirectory=bluetooth
ConfigurationDirectoryMode=0555
# Execute Mappings
MemoryDenyWriteExecute=true
# Privilege escalation
NoNewPrivileges=true
# Real-time
RestrictRealtime=true
[Install]
WantedBy=bluetooth.target
Alias=dbus-org.bluez.service
$ journalctl --priority=warning..err --no-pager --boot=0
Apr 14 05:39:00 5600H kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
Apr 14 05:39:00 5600H kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
Apr 14 05:39:01 5600H kernel: ACPI Error: No handler for Region [ECRM] (0000000094cbe773) [EmbeddedControl] (20230628/evregion-130)
Apr 14 05:39:01 5600H kernel: ACPI Error: Region EmbeddedControl (ID=3) has no handler (20230628/exfldio-261)
Apr 14 05:39:01 5600H kernel: ACPI Error: Aborting method \_SB.GPIO._EVT due to previous error (AE_NOT_EXIST) (20230628/psparse-529)
Apr 14 05:39:01 5600H systemd-fstab-generator[239]: Mount point is not a valid path, ignoring.
Apr 14 05:39:01 5600H kernel: vboxdrv: loading out-of-tree module taints kernel.
Apr 14 05:39:01 5600H kernel: VBoxNetAdp: Successfully started.
Apr 14 05:39:01 5600H kernel: VBoxNetFlt: Successfully started.
Apr 14 05:39:02 5600H kernel: sd 3:0:0:0: [sda] No Caching mode page found
Apr 14 05:39:02 5600H kernel: sd 3:0:0:0: [sda] Assuming drive cache: write through
Apr 14 05:39:02 5600H kernel: sd 2:0:0:0: [sdb] No Caching mode page found
Apr 14 05:39:02 5600H kernel: sd 2:0:0:0: [sdb] Assuming drive cache: write through
Apr 14 05:39:03 5600H kernel: scsi 2:0:0:1: Wrong diagnostic page; asked for 1 got 8
Apr 14 05:39:03 5600H kernel: scsi 2:0:0:1: Failed to get diagnostic page 0x1
Apr 14 05:39:03 5600H kernel: scsi 2:0:0:1: Failed to bind enclosure -19
Apr 14 05:39:03 5600H bluetoothd[618]: src/plugin.c:plugin_init() System does not support csip plugin
Apr 14 05:39:03 5600H bluetoothd[618]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Apr 14 05:39:03 5600H bluetoothd[618]: src/plugin.c:plugin_init() System does not support micp plugin
Apr 14 05:39:03 5600H bluetoothd[618]: src/plugin.c:plugin_init() System does not support vcp plugin
Apr 14 05:39:03 5600H bluetoothd[618]: src/plugin.c:plugin_init() System does not support mcp plugin
Apr 14 05:39:03 5600H bluetoothd[618]: src/plugin.c:plugin_init() System does not support bass plugin
Apr 14 05:39:03 5600H bluetoothd[618]: src/plugin.c:plugin_init() System does not support bap plugin
Apr 14 05:39:03 5600H systemd[1]: Cannot find unit for notify message of PID 660, ignoring.
Apr 14 05:39:03 5600H systemd[1]: Cannot find unit for notify message of PID 663, ignoring.
Apr 14 05:39:03 5600H systemd[1]: Cannot find unit for notify message of PID 697, ignoring.
Apr 14 05:39:03 5600H systemd[1]: Cannot find unit for notify message of PID 698, ignoring.
Apr 14 05:39:03 5600H systemd[1]: snapd.service: Got notification message from PID 735, but reception only permitted for main PID 620
Apr 14 05:39:05 5600H kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Apr 14 05:39:08 5600H dbus-broker-launch[610]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Apr 14 05:39:09 5600H kernel: kauditd_printk_skb: 55 callbacks suppressed
Apr 14 05:39:09 5600H rpc.statd[2718]: Flags: TI-RPC
Apr 14 05:39:09 5600H systemd-fstab-generator[2752]: Mount point is not a valid path, ignoring.
Apr 14 05:39:10 5600H dbus-broker-launch[610]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Apr 14 05:39:11 5600H dbus-broker-launch[2818]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Apr 14 05:39:11 5600H dbus-broker-launch[2818]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Apr 14 05:39:11 5600H dbus-broker-launch[2818]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Apr 14 05:39:11 5600H kernel: sddm-greeter[2814]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Apr 14 05:39:11 5600H sddm-greeter[2814]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffcfc56ec40), parent's thread is QThread(0x561c1f006ba0), current thread is QThread(0x561c1f3d6e20)
Apr 14 05:39:11 5600H sddm-greeter[2814]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Apr 14 05:39:11 5600H udisksd[2832]: Error probing device: Error sending ATA command IDENTIFY DEVICE to '/dev/sda': Unexpected sense data returned:
0000: f0 00 01 00 00 00 00 0a 00 00 00 00 00 1d 00 00 ................
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
(g-io-error-quark, 0)
Apr 14 05:39:11 5600H udisksd[2832]: Error probing device: Error sending ATA command IDENTIFY DEVICE to '/dev/sdb': Unexpected sense data returned:
0000: f0 00 01 00 50 00 01 0a 80 00 00 00 00 1d 00 00 ....P...........
Apr 14 05:39:11 5600H kernel: block nvme0n1: No UUID available providing old NGUID
Apr 14 05:39:11 5600H sddm-greeter[2814]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Apr 14 05:39:11 5600H sddm-greeter[2814]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Apr 14 05:39:11 5600H sddm-greeter[2814]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Apr 14 05:39:11 5600H sddm-greeter[2814]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Apr 14 05:39:11 5600H sddm-greeter[2814]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.22'
Apr 14 05:39:11 5600H sddm-greeter[2814]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.23'
Apr 14 05:39:16 5600H dbus-broker-launch[2896]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Apr 14 05:39:16 5600H dbus-broker-launch[2896]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Apr 14 05:39:16 5600H dbus-broker-launch[2896]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Apr 14 05:39:16 5600H kwin_wayland[2909]: No backend specified, automatically choosing drm
Apr 14 05:39:17 5600H ksplashqml[2912]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Apr 14 05:39:17 5600H ksplashqml[2912]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Apr 14 05:39:17 5600H ksmserver[3014]: Qt: Session management error: networkIdsList argument is NULL
Apr 14 05:39:17 5600H kernel: warning: `kded5' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Apr 14 05:39:17 5600H plasmashell[3080]: Checking screens: available: (QScreen(0x5596d049f3e0, name="HDMI-A-2")) redundant: QHash() fake: QSet() all: (QScreen(0x5596d049f3e0, name="HDMI-A-2"))
Apr 14 05:39:17 5600H kded5[3016]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
Apr 14 05:39:17 5600H plasmashell[3080]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Apr 14 05:39:17 5600H plasmashell[3080]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Apr 14 05:39:17 5600H kded5[3016]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Apr 14 05:39:17 5600H kded5[3016]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Apr 14 05:39:17 5600H kded5[3016]: kscreen.kded: PowerDevil SuspendSession action not available!
Apr 14 05:39:17 5600H polkit-kde-authentication-agent-1[3126]: KXMessages used on non-X11 platform! This is an application bug.
Apr 14 05:39:18 5600H backlighthelper[3236]: org.kde.powerdevil: no kernel backlight interface found
Apr 14 05:39:18 5600H org_kde_powerdevil[3127]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Apr 14 05:39:18 5600H org_kde_powerdevil[3127]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Apr 14 05:39:18 5600H org_kde_powerdevil[3127]: ddca_get_display_info_list2 called before ddca_init2() or ddca_init()
Apr 14 05:39:18 5600H plasmashell[3080]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Apr 14 05:39:18 5600H plasmashell[3080]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Apr 14 05:39:18 5600H plasmashell[3080]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Apr 14 05:39:18 5600H kioslave5[3257]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Apr 14 05:39:18 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:325:17: QML Label: Binding loop detected for property "width"
Apr 14 05:39:18 5600H plasmashell[3080]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Apr 14 05:39:18 5600H bluetoothd[618]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Apr 14 05:39:19 5600H kioslave5[3287]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Apr 14 05:39:19 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.kscreen/contents/ui/main.qml:30:5: Unable to assign [undefined] to bool
Apr 14 05:39:19 5600H org_kde_powerdevil[3127]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Apr 14 05:39:19 5600H org_kde_powerdevil[3127]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Apr 14 05:39:19 5600H zeitgeist-datah[3465]: zeitgeist-datahub.vala:224: Unable to get name "org.gnome.zeitgeist.datahub" on the bus!
Apr 14 05:39:19 5600H megasync[3343]: QSettings::value: Empty key passed
Apr 14 05:39:19 5600H plasmashell[3080]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Apr 14 05:39:19 5600H plasmashell[3080]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Apr 14 05:39:19 5600H pulseaudio[3294]: module-combine is deprecated: Please use module-combine-sink instead of module-combine!
Apr 14 05:39:19 5600H pulseaudio[3294]: We will now load module-combine-sink. Please make sure to remove module-combine from your configuration.
Apr 14 05:39:19 5600H bluetoothd[618]: Failed to add UUID: Failed (0x03)
Apr 14 05:39:19 5600H yakuake[3349]: org.kde.konsole.profile: "/home/tpb/.local/share/konsole/Empty.profile" does not have a valid name, ignoring.
Apr 14 05:39:19 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
Apr 14 05:39:19 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:18:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Apr 14 05:39:19 5600H plasmashell[3080]: Both point size and pixel size set. Using pixel size.
Apr 14 05:39:19 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:78:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Apr 14 05:39:19 5600H plasmashell[3080]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Apr 14 05:39:19 5600H plasmashell[3080]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Apr 14 05:39:19 5600H plasmashell[3080]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Apr 14 05:39:20 5600H kioslave5[3301]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Apr 14 05:39:21 5600H plasmashell[3080]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Apr 14 05:39:21 5600H plasmashell[3080]: kf5idletime_wayland: This plugin does not support polling idle time
Apr 14 05:39:21 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:61:17: Unable to assign [undefined] to int
Apr 14 05:39:21 5600H plasmashell[3080]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Apr 14 05:39:21 5600H kioslave5[3257]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Apr 14 05:39:21 5600H kioslave5[3287]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Apr 14 05:39:21 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:36:5: Unable to assign [undefined] to bool
Apr 14 05:39:21 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:35:5: Unable to assign [undefined] to bool
Apr 14 05:39:21 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:325:17: QML Label: Binding loop detected for property "width"
Apr 14 05:39:21 5600H plasmashell[3080]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:291: TypeError: Cannot read property 'enabled' of null
Apr 14 05:39:21 5600H kioslave5[3301]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Apr 14 05:39:21 5600H plasmashell[3080]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_04_00.1.hdmi-stereo-extra1.monitor"
Apr 14 05:39:22 5600H kioslave5[3257]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Apr 14 05:39:22 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:22:5: Unable to assign [undefined] to bool
Apr 14 05:39:22 5600H systemd[2865]: app-bluemail@autostart.service: Main process exited, code=dumped, status=5/TRAP
Apr 14 05:39:22 5600H systemd[2865]: app-bluemail@autostart.service: Failed with result 'core-dump'.
Apr 14 05:39:24 5600H plasmashell[3080]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Apr 14 05:39:24 5600H plasmashell[3080]: trying to show an empty dialog
Apr 14 05:39:25 5600H systemd[2865]: app-dropbox@autostart.service: Main process exited, code=killed, status=9/KILL
Apr 14 05:39:25 5600H plasmashell[3080]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Apr 14 05:39:30 5600H plasmashell[3080]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5596d1026540) QQmlContext(0x5596d1f704c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Apr 14 05:39:32 5600H kded5[3016]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Apr 14 05:39:34 5600H plasmashell[3080]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/AppletConfiguration.qml:126:5: QML ScrollView: Binding loop detected for property "implicitWidth"
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Apr 14 05:39:34 5600H plasmashell[3080]: kf.coreaddons: "Could not find plugin org.kde.plasma.folder"
Apr 14 05:39:34 5600H plasmashell[3080]: Error loading KCM: "Could not find plugin org.kde.plasma.folder"
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationContainmentAppearance.qml:210: TypeError: Cannot read property 'objectName' of null
Apr 14 05:39:34 5600H plasmashell[3080]: kf.coreaddons: "Could not find plugin org.kde.haenau"
Apr 14 05:39:34 5600H plasmashell[3080]: Error loading KCM: "Could not find plugin org.kde.haenau"
Apr 14 05:39:34 5600H plasmashell[3080]: kf.coreaddons: "Could not find plugin org.kde.slideshow"
Apr 14 05:39:34 5600H plasmashell[3080]: Error loading KCM: "Could not find plugin org.kde.slideshow"
Apr 14 05:39:34 5600H plasmashell[3080]: kf.coreaddons: "Could not find plugin org.kde.hunyango"
Apr 14 05:39:34 5600H plasmashell[3080]: Error loading KCM: "Could not find plugin org.kde.hunyango"
Apr 14 05:39:34 5600H plasmashell[3080]: kf.coreaddons: "Could not find plugin org.kde.color"
Apr 14 05:39:34 5600H plasmashell[3080]: Error loading KCM: "Could not find plugin org.kde.color"
Apr 14 05:39:34 5600H plasmashell[3080]: kf.coreaddons: "Could not find plugin org.kde.image"
Apr 14 05:39:34 5600H plasmashell[3080]: Error loading KCM: "Could not find plugin org.kde.image"
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationContainmentAppearance.qml:138:9: QML StackView: Binding loop detected for property "implicitHeight"
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationAppletPage.qml:38:5: QML Loader: Binding loop detected for property "height"
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationContainmentAppearance.qml:51:5: QML ColumnLayout: Binding loop detected for property "height"
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/lib/qt/qml/org/kde/kcm/SettingHighlighter.qml:0: ReferenceError: kcm is not defined
Apr 14 05:39:34 5600H plasmashell[3080]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:61:17: Unable to assign [undefined] to int
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:22:5: Unable to assign [undefined] to bool
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:36:5: Unable to assign [undefined] to bool
Apr 14 05:39:34 5600H plasmashell[3080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:35:5: Unable to assign [undefined] to bool
Apr 14 05:39:35 5600H plasmashell[3080]: Both point size and pixel size set. Using pixel size.
Apr 14 05:39:35 5600H plasmashell[3080]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Apr 14 05:39:35 5600H plasmashell[3080]: file:///usr/lib/qt/qml/org/kde/kcm/SettingHighlighter.qml:0: ReferenceError: kcm is not defined
Apr 14 05:39:35 5600H kioslave5[3257]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Apr 14 05:39:35 5600H plasmashell[3080]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Apr 14 05:39:39 5600H plasmashell[3080]: kf.coreaddons: "Could not find plugin org.kde.slideshow"
Apr 14 05:39:39 5600H plasmashell[3080]: Error loading KCM: "Could not find plugin org.kde.slideshow"
Apr 14 05:39:39 5600H plasmashell[3080]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/SlideshowComponent.qml: No such file or directory
Apr 14 05:39:39 5600H plasmashell[3080]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Apr 14 05:39:39 5600H plasmashell[3080]: file:///usr/lib/qt/qml/org/kde/kcm/SettingHighlighter.qml:0: ReferenceError: kcm is not defined
Apr 14 05:39:45 5600H plasmashell[3080]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Apr 14 05:39:45 5600H plasmashell[3080]: QString::arg: 2 argument(s) missing in org.mozilla.Thunderbird
Apr 14 05:40:10 5600H zeitgeist-datah[3364]: zeitgeist-datahub.vala:207: Error during inserting events: GDBus.Error:org.gnome.zeitgeist.EngineError.InvalidArgument: Incomplete event: interpretation, manifestation and actor are required
Apr 14 05:40:21 5600H plasmashell[3080]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Apr 14 05:40:21 5600H plasmashell[3080]: QString::arg: 2 argument(s) missing in org.kde.konsole
Apr 14 05:40:21 5600H konsole[5075]: org.kde.konsole.profile: "/home/tpb/.local/share/konsole/Empty.profile" does not have a valid name, ignoring.
Apr 14 05:40:47 5600H plasmashell[3080]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Apr 14 05:40:47 5600H plasmashell[3080]: QString::arg: 2 argument(s) missing in leafpad
Apr 14 05:40:48 5600H plasmashell[3080]: kpipewire_logging: PipeWire remote error: -2 unknown resource 2 op:4
Apr 14 05:40:48 5600H plasmashell[3080]: kpipewire_logging: PipeWire remote error: -2 unknown resource 3 op:4
Apr 14 05:40:48 5600H plasmashell[3080]: kpipewire_logging: PipeWire remote error: -2 unknown resource 2 op:7
Apr 14 05:40:48 5600H plasmashell[3080]: kpipewire_logging: PipeWire remote error: -2 unknown resource 3 op:7
sudo systemctl enable bluetooth.service (No output)
