Hello
I’m experiencing strange behavior with my bluetooth earbuds. For example I’m listening to a video and after I pause it several times the earbuds stop listening and the bluetooth icon on my panel disappears. The service is running and everything seems to be ok but no audio. Then I close the laptop screen, wait for 3 seconds, open it, login to the system and the bluetooth icon is there and I can connect the earbuds again, and if the time is fast they connect automatically, as if anything happened.
this is the output of my system
Kernel: 5.13.0-176-tkg-bmq x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: intel_pstate=passive BOOT_IMAGE=/boot/vmlinuz-linux-tkg-bmq
root=UUID=40f5b289-abc6-4f15-922a-a6915ac9cfd4 rw quiet apparmor=1
security=apparmor udev.log_priority=3 lsm=lockdown,yama,apparmor,bpf
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: plank wm: kwin_x11 vt: 1
Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 84A6 v: 80.38 serial: <filter> UEFI: Insyde v: F.17
date: 01/18/2019
ID-1: BAT1 charge: 34.3 Wh (100.0%) condition: 34.3/41.9 Wh (81.7%)
volts: 12.9 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Full
RAM: total: 11.61 GiB used: 7.75 GiB (66.8%)
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 cache: L2: 6 MiB bogomips: 28824
Speed: 798 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 798 2: 1226
3: 785 4: 868 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04f2:b65d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.13.0-176-tkg-bmq running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlo1 state: down mac: <filter>
IF-ID-1: br-201b31e9839c state: down mac: <filter>
IF-ID-11: enp0s20f0u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-6:12 chip-ID: 8087:0aa7 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 15 state: up address: <filter>
Permissions: Unable to run lvs. Root privileges required.
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 21 class-ID: 0104
Local Storage: total: 1.93 TiB used: 1.57 TiB (81.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX900 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: S0614B0 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
rotation: 5400 rpm serial: <filter> rev: RDM4 scheme: GPT
ID-1: / raw-size: 111.49 GiB size: 109.24 GiB (97.98%)
used: 101.57 GiB (93.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 40f5b289-abc6-4f15-922a-a6915ac9cfd4
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:8 info: Xiaomi Mi/Redmi series (RNDIS) type: CDC-Data
driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
Device-2: 1-5:3 info: Chicony HP TrueVision HD Camera type: Video
Device-3: 1-6:12 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 47.0 C mobo: 29.8 C
Processes: 316 Uptime: 21h 40m wakeups: 28 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1671 lib: 421
rpm: 0 flatpak: 0 Shell: fish v: 3.2.2 running-in: yakuake inxi: 3.3.04
