Hi
After last update I have strange problem with Bluetooth. I have two main Bluetooth devices - Keychron keyboard and Google home speaker. After reboot my keyboard automatically connect and after login I can manually connect to speaker. And at this point, everything is fine. When I watch something, my keyboard goes to stand by and disconnect. After touch key it reconnects but at this moment my speaker disconnects and also sometimes Bluetooth icon disappear from system tray. I need to look Bluetooth in settings and there reconnect speaker.
Someone have some solution for this problem? Before the update, everything was fine.
inxi -Fazy
Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0e29e511-636a-4682-b390-d0a1719fc5fa rw quiet splash
resume=UUID=3840c8a8-99a1-4664-9bc4-cec909efa34a udev.log_priority=3
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
Type: Desktop System: Micro-Star product: MS-7D32 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: MAG Z690 TOMAHAWK WIFI DDR4 (MS-7D32) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.E0 date: 09/14/2023
Device-1: hid-dc:2c:26:0c:d8:13-battery model: Keychron K4 serial: N/A
charge: N/A status: discharging
Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x34
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 1147 high: 4041 min/max: 800/4900:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 963
5: 4041 6: 800 7: 801 8: 800 9: 2887 10: 800 11: 800 12: 800 13: 800
14: 800 15: 860 16: 800 bogomips: 118000
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel AlderLake-S GT1 vendor: Micro-Star MSI driver: i915 v: kernel
ports: active: HDMI-A-1 empty: DP-1, DP-2, HDMI-A-2, HDMI-A-3, HDMI-A-4
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 res: 1920x1200 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 770 (ADL-S
GT1) device-ID: 8086:4680 memory: 30.41 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
name: Intel UHD Graphics 770 (ADL-S GT1) driver: mesa intel
v: 24.0.6-manjaro1.1 device-ID: 8086:4680 surfaces: xcb,xlib,wayland
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4
chip-ID: 0db0:b202 class-ID: 0300
API: ALSA v: k6.6.30-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
Device-2: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
chip-ID: 8086:15f3 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 1.16 TiB used: 187.09 GiB (15.7%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Seagate
model: XPG GAMMIX S70 BLADE size: 953.87 GiB block-size: physical: 512 B
fw-rev: 3.2.F.83 temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: MZVL2256HCHQ-00BH1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: HPS2NGXH temp: 42.9 C
scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 50.63 GiB (51.7%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:9
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:12
ID-3: /home raw-size: 199.26 GiB size: 195.07 GiB (97.90%)
used: 133.11 GiB (68.2%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:10
ID-1: swap-1 type: partition size: 4 GiB used: 3.35 GiB (83.7%)
priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:8
System Temperatures: cpu: 35.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 31.14 GiB used: 10.1 GiB (32.4%)
Processes: 402 Power: uptime: 47m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1829 libs: 422 tools: pamac,yay
pm: appimage pkgs: 0 pm: flatpak pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: yakuake inxi: 3.3.34
From active time I can assume, Bluetooth service was reset by something, because my computer is working longer than from 10:23.
systemctl status bluetooth.service
systemctl status bluetooth.service ✔
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Tue 2024-05-28 10:23:28 CEST; 1min 11s ago
Docs: man:bluetoothd(8)
Main PID: 7258 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 38227)
Memory: 1.0M (peak: 1.5M)
CPU: 24ms
CGroup: /system.slice/bluetooth.service
└─7258 /usr/lib/bluetooth/bluetoothd
maj 28 10:23:28 DesktopLinux bluetoothd[7258]: Endpoint registered: sender=:1.55 path=/MediaEndpoint/A2DPSource/aptx_ll_1
maj 28 10:23:28 DesktopLinux bluetoothd[7258]: Endpoint registered: sender=:1.55 path=/MediaEndpoint/A2DPSource/aptx_ll_0
maj 28 10:23:28 DesktopLinux bluetoothd[7258]: Endpoint registered: sender=:1.55 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
maj 28 10:23:28 DesktopLinux bluetoothd[7258]: Endpoint registered: sender=:1.55 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
maj 28 10:23:28 DesktopLinux bluetoothd[7258]: Endpoint registered: sender=:1.55 path=/MediaEndpoint/A2DPSource/faststream
maj 28 10:23:28 DesktopLinux bluetoothd[7258]: Endpoint registered: sender=:1.55 path=/MediaEndpoint/A2DPSource/faststream_duplex
maj 28 10:23:28 DesktopLinux bluetoothd[7258]: Endpoint registered: sender=:1.55 path=/MediaEndpoint/A2DPSink/opus_05
maj 28 10:23:28 DesktopLinux bluetoothd[7258]: Endpoint registered: sender=:1.55 path=/MediaEndpoint/A2DPSource/opus_05
maj 28 10:23:28 DesktopLinux bluetoothd[7258]: Endpoint registered: sender=:1.55 path=/MediaEndpoint/A2DPSink/opus_05_duplex
maj 28 10:23:28 DesktopLinux bluetoothd[7258]: Endpoint registered: sender=:1.55 path=/MediaEndpoint/A2DPSource/opus_05_duplex
