I had used Bluetooth several times before, but suddenly, when I wanted to use it, I found that Bluetooth did not work. I tried it with my headset, and it did not connect. I also tried it with my phone, and it did not connect. Can anybody help me?
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxi
in a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already for your problem in the forum ? (Wisdom lies in asking → listening → reading
Here is the output of the command
Kernel: 6.5.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=9ea51232-108a-4b99-b6a5-802b76550e5a rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 info: latte-dock
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81W0 v: IdeaPad 3 14ADA05
serial: <filter> Chassis: type: 10 v: IdeaPad 3 14ADA05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
v: E8CN34WW date: 04/28/2022
ID-1: BAT0 charge: 7.3 Wh (25.4%) condition: 28.7/35.3 Wh (81.2%)
power: 15.7 W volts: 8.1 min: 7.6 model: CPT-COS L16C2PB1 type: Li-poly
serial: <filter> status: charging cycles: 566
System RAM: total: 8 GiB available: 5.67 GiB used: 3.97 GiB (70.0%)
Array-1: capacity: 12 GiB slots: 2 modules: 2 EC: None
max-module-size: 6 GiB note: est.
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 4 GiB speed: 2400 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A5244CB0-CWE
serial: <filter>
Device-2: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
data: 64 total: 64 manufacturer: Samsung part-no: M471A5244CB0-CTD
serial: N/A
Info: model: AMD Athlon Gold 3150U with Radeon Graphics socket: FP5 bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2400 boost: enabled
base/boost: 2400/3300 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
bogomips: 19169
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 37.0 C
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.1:4 chip-ID: 04f2:b6ce
Display: server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x723c built: 2017 res: 1366x768
dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: max: 1366x768 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 3 Graphics (raven2
LLVM 16.0.6 DRM 3.54 6.5.11-1-MANJARO) device-ID: 1002:15d8
memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.269 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Vega 3 Graphics (RADV RAVEN2) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:15d8 surfaces: xcb,xlib
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.84 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
tools: pacat,pactl
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 39.0 C
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
chip-ID: 0cf3:e300 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 1.14 TiB used: 23.53 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLW256HEHP-000L7
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 5L7QCXB7 temp: 22.9 C
scheme: GPT
SMART: yes health: PASSED on: 15d 6h cycles: 1,127
read-units: 27,372,506 [14.0 TB] written-units: 9,674,135 [4.95 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
family: Mobile HDD size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: LFM3 temp: 22 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 129d 22h cycles: 1936 Old-Age:
g-sense error rate: 153 Pre-Fail: attribute: Spin_Retry_Count value: 100
worst: 100 threshold: 97
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 23.53 GiB (10.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 9ea51232-108a-4b99-b6a5-802b76550e5a
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: A932-00DA
ID-1: /dev/sda1 maj-min: 8:1 size: 146.48 GiB fs: ntfs label: N/A
uuid: 01D97A77E84D7EB0
ID-2: /dev/sda2 maj-min: 8:2 size: 390.62 GiB fs: ntfs label: N/A
uuid: 36D6B169D6B12A4F
ID-3: /dev/sda3 maj-min: 8:3 size: 394.4 GiB fs: ntfs label: N/A
uuid: 3036ABFE36ABC2E8
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5.1:4 info: Chicony Integrated Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b6ce class-ID: 0e02 serial: <filter>
Device-2: 1-6:3 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 38.6 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (rpm): N/A
Processes: 250 Uptime: 8m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1500
pm: pacman pkgs: 1489 libs: 364 tools: pamac pm: flatpak pkgs: 0 pm: snap
pkgs: 11 Shell: Sudo (sudo) v: 1.9.15p2 default: Bash v: 5.2.15
running-in: konsole inxi: 3.3.31
Kernel 6.5 is EOL. You should replace it with another kernel and also you need to update your system.
Have you checked already all settings in the graphical system setting manager of KDE for Bluetooth settings?
Yeah I was thinking about change it to Kernel 5.15.
No I didn’t checked anything, I am new linux user, so there is alot of things I didn’t know BTH
Since you’re a new Linux user, please work through this:
5.15 might be good, 6.1 also, since they are both LTS, and 6.1 will be maintained for 10 years!
And with Manjaro you should not “consider” updating older software, as it seems you have. You should update whenever an update becomes available…
now I just updated my system. So, how to change kernel I’m already installed 5.15 LTS, how to change to it
The wiki should have been your first stop:
