Hi
I setup and paired bluetooth with Sony MDR-XB650BT : “Bluetooth connected” but no sound !
Volume OK, several sites and sources… battery level OK…: no sound at all.
By the way : the sound output via 2.5 jack and loudspeaker is OK. Just bluetooth without sound !
Thanks for Your great help.
Did you set the bt-device as the output source for the sound source?
If you use pulseaudio you can use pavucontrol check that.
OK, vefified and seams to be OK, connected, input output levels OK… but no sound !!!
I got the same issue and solved it by going to Pulse Audio Volume control -> Output devices -> Built in analog sterio port -> Headphones (unplugged)
Howdy!
Could you follow these steps, please! ![]()
This worked for me, Thank You so much
yep, worked for me! Thank you. <3
Nice bro
