I recently installed a manjaro with KDE on my laptop with a built-in bluetooth adapter and the bluetooth doesn’t appear to work properly. The bluetooth icon appears grayed out and when clicking on it and selecting “Add New Device” it cannot see any devices at all, even when I put my headset into pairing mode. Opening Bluetooth in KDE settings it appears as disabled. Trying to enable it has no effect whatsoever. However, the bluetooth does work if I boot into windows.
And another curious detail: I can connect my Android phone to this laptop by using KDE Connect and it appears to work – at least they detect each other and don’t report any errors. And this connection is happening through Bluetooth, so it must be working on some level. But why can’t I use it?
Output from
$ systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2021-01-08 17:21:01 CET; 2h 31min ago
Docs: man:bluetoothd(8)
Main PID: 677 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 9374)
Memory: 2.0M
CGroup: /system.slice/bluetooth.service
└─677 /usr/lib/bluetooth/bluetoothd
Jan 08 17:21:01 ManjaroLP bluetoothd[677]: src/main.c:parse_controller_config() Key file does not have key “LEScanI>
Jan 08 17:21:01 ManjaroLP bluetoothd[677]: src/main.c:parse_controller_config() Key file does not have key “LEScanW>
Jan 08 17:21:01 ManjaroLP bluetoothd[677]: src/main.c:parse_controller_config() Key file does not have key “LEMinCo>
Jan 08 17:21:01 ManjaroLP bluetoothd[677]: src/main.c:parse_controller_config() Key file does not have key “LEMaxCo>
Jan 08 17:21:01 ManjaroLP bluetoothd[677]: src/main.c:parse_controller_config() Key file does not have key “LEConne>
Jan 08 17:21:01 ManjaroLP bluetoothd[677]: src/main.c:parse_controller_config() Key file does not have key “LEAutoc>
Jan 08 17:21:01 ManjaroLP systemd[1]: Started Bluetooth service.
Jan 08 17:21:01 ManjaroLP bluetoothd[677]: Starting SDP server
Jan 08 17:21:01 ManjaroLP bluetoothd[677]: Bluetooth management interface 1.18 initialized
...skipping...
Status: "Running"
Memory: 2.0M
But running bluetoothctl show
results in
No default controller available
And
[user@host ~]$ lsmod | grep blu
bluetooth 741376 13 btrtl,btintel,btbcm,bnep,ath3k,btusb
ecdh_generic 16384 1 bluetooth
rfkill 28672 12 asus_wmi,bluetooth,cfg80211
crc16 16384 2 bluetooth,ext4
And rfkill list
gives:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Finally
$ inxi -Fazy
gives:
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64 root=/dev/mapper/vg0-root ro
cryptdevice=UUID=c273662c-17fe-4fed-a414-c4da2ce6fbf3:cryptlvm rw quiet
udev.log_priority=3
resume=/dev/disk/by-uuid/616b7481-c262-4d11-b277-da306deb5c10
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X550LN v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X550LN v: 1.0 serial: <filter>
UEFI: American Megatrends v: X550LN.306 date: 06/26/2014
ID-1: BAT0 charge: 3.7 Wh condition: 3.9/38.5 Wh (10%) volts: 14.8/14.8
model: ASUSTeK X550A26 type: Li-ion serial: N/A status: Not charging
cycles: 164
Info: Dual Core model: Intel Core i5-4200U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26
L2 cache: 3 MiB
bogomips: 18366
Speed: 840 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 840 2: 814 3: 850
4: 837
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
Device-2: NVIDIA GM108M [GeForce 840M] vendor: ASUSTeK driver: nouveau
v: kernel bus ID: 04:00.0 chip ID: 10de:1341
Device-3: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 2-5:2 chip ID: 04f2:b40a serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 99 size: 350x190mm (13.8x7.5")
diag: 398mm (15.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.3.1 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Sound Server: ALSA v: k5.10.2-2-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.1
chip ID: 10ec:8168
IF: enp2s0f1 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: e000 bus ID: 03:00.0
chip ID: 168c:0036
Local Storage: total: 465.76 GiB used: 26.46 GiB (5.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1J
ID-1: / raw size: 32 GiB size: 31.25 GiB (97.65%) used: 14.68 GiB (47.0%)
fs: ext4 dev: /dev/dm-1 maj-min: 254:1 mapped: vg0-root
ID-2: /boot raw size: 388 MiB size: 367.7 MiB (94.77%) used: 161 MiB (43.8%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-3: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%)
used: 43.4 MiB (45.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-4: /home raw size: 277.64 GiB size: 272.28 GiB (98.07%)
used: 11.58 GiB (4.3%) fs: ext4 dev: /dev/dm-3 maj-min: 254:3
mapped: vg0-home
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-2 maj-min: 254:2 mapped: vg0-swap
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2100
Processes: 188 Uptime: 2h 40m wakeups: 1 Memory: 7.66 GiB
used: 1.65 GiB (21.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: pacman: 1677 lib: 428 flatpak: 0 Shell: Bash
v: 5.1.0 running in: konsole inxi: 3.2.01
What can be done to address this issue? As I mentioned, the adapter does work in Windows, but not in Linux.
