Bluetooth can't enable in KDE Plasma
Bluetooth was working more than a week ago. Every time I turn on, it is like this:
systemctl status bluetooth                                                               ✔
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Mon 2026-02-09 19:08:30 PST; 19min ago
 Invocation: c88e57b26db84689a62928a6737f10a8
       Docs: man:bluetoothd(8)
   Main PID: 807 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 38084)
     Memory: 2.1M (peak: 3M)
        CPU: 37ms
     CGroup: /system.slice/bluetooth.service
             └─807 /usr/lib/bluetooth/bluetoothd
Feb 09 19:08:30 beehive systemd[1]: Starting Bluetooth service...
Feb 09 19:08:30 beehive bluetoothd[807]: Bluetooth daemon 5.85
Feb 09 19:08:30 beehive bluetoothd[807]: Starting SDP server
Feb 09 19:08:30 beehive systemd[1]: Started Bluetooth service.
Feb 09 19:08:30 beehive bluetoothd[807]: Bluetooth management interface 1.23 initialized
rfkill list         ✔
1: hci0: Bluetooth
        Soft blocked: yes
        Hard blocked: no
Although I use # rfkill unblock bluetooth, it actually unblocks, but still cannot enable in Plasma:
I tried with different kernels, so far 6.19, 6.18, 6.17, 6.12 and none of them seems to work. I also plugged the bluetooth dongle in my Laptop with the same Manjaro kernels and working smooth.
Is there some app that can be blocking it? I had another issue with the AMD GPU that already solved, I am not really sure if the last update broke many things or something else.
The command to unblock is
The command is a user space command - root is not necessary.
Personally I cannot reproduce it, I use a bluetooth dongle on my workstation to connect a bluetooth headset (Apple), and it work without any issues
Bus 003 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Plasma Info (Manjaro Unstable Branch)
 $ kinfo
KDE Plasma Version: 6.5.5
KDE Frameworks Version: 6.22.0
Qt Version: 6.10.2
Kernel Version: 6.18.9-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 24 × AMD Ryzen Threadripper PRO 5945WX 12-Cores
Memory: 128 GiB of RAM (125.6 GiB usable)
Graphics Processor: AMD Radeon AI PRO R9700
I should have said that first have the issue with an ASUS BT500 dongle, after unblocking the internal (Intel AX200) it worked for a couple of days, but stopped working and same issue. I dig into a lot of forums (I usually look in Arch) and couldn’t find anything. I also commit blasphemy asking AI and nothing. I just had to dig somewhere in a supposedly missing file, but I belive the last major update came into conflict with drivers for bluetooth in general. Anyway, I just look in the aur and found someone posted an old driver (rtl8761b-firmware) because of conflicts with new updates or something. I don’t think any regular user could find this, but just installing and overriding the driver, works as expected.
I usually wait until manjaro team fixes these issues, I’ve become so lazy. But this time was driving me nutz. Hope it works for those with the same issue
