After the recent Manjaro 4/10 update, Bluetooth is stuck on disabled. In Manjaro settings, it shows “enable” but the button doesn’t do anything. It’s embedded in my motherboard so I can’t physically reconnect it. I can toggle it via bluetooth on/off commands, but it makes no difference.
I’ve had this same issue happen very rarely on my Dell laptop. For some reason rebooting doesn’t help, but shutting down completely and powering back on on does. Hopefully that helps.
Those messages are only informational. Certain plugins can’t be initialized unless the experimental D-Bus experimental interfaces are enabled. See Bluetooth - ArchWiki
