Hey To you all !
I have these days a big problem trying to play sound on my PHILIPS Bluetooth speaker.
Ive installed Manjaro before, i installed all necessary packages, plugged my Speaker and i was good to go. Because i had no enough space on my SSD i bought one, and reinstalled Manjaro in it.
So did the same thing as before, got through BLuetoothctl, connected my BLuetooth Speaker, got to Volume Control, checked set as fellback and nothing happens, got no sound !
Ive tried everything with the Help of ChatGPT , but nothing seems to work. I have Hope in Humanity ![]()
Here is a snapshot from inxi -Fazy :
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
API: ALSA v: k6.1.21-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.67 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
Device-1: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:5 chip-ID: 0a5c:217f class-ID: fe01 serial: <filter>
Outpt from pacmd list-sources :
index: 2
driver: <module-bluez5-device.c>
flags: DECIBEL_VOLUME LATENCY
state: RUNNING
suspend cause: (none)
priority: 1050
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max rewind: 0 KiB
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 1
linked by: 1
fixed latency: 51.12 ms
monitor_of: 2
card: 1 <bluez_card.94_9F_3F_FB_AC_20>
module: 25
properties:
device.description = "Monitor of Philips BT7900"
device.class = "monitor"
device.string = "94:9F:3F:FB:AC:20"
device.api = "bluez"
device.bus = "bluetooth"
bluez.path = "/org/bluez/hci0/dev_94_9F_3F_FB_AC_20"
bluez.class = "0x24040c"
bluez.alias = "Philips BT7900"
device.icon_name = "audio-card-bluetooth"
Output pacmd list-sinks :
index: 4
flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9050
volume: front-left: 20125 / 31% / -30.76 dB, front-right: 20125 / 31% / -30.76 dB
balance 0.00
volume steps: 128
muted: no
max request: 4 KiB
max rewind: 0 KiB
monitor source: 5
Stereo
used by: 0
linked by: 0
card: 3 <bluez_card.94_9F_3F_FB_AC_20>
module: 28
properties:
bluetooth.protocol = "a2dp_sink"
bluetooth.codec = "sbc"
device.description = "Philips BT7900"
device.class = "sound"
ports:
unknown-output: Bluetooth Output (priority 0, latency offset 0 usec, available: unknown)
properties:
active port: <unknown-output>
Through my Research i discovered that the problem might have to do with output port to set to a2dp_sink, but YOu guys know better then Me !
Thanks !
