Bluetooth audio issues
Anyone having BT audio issues? My Bluetooth Headphones (AirPods) are cutting in and out like crazy on YouTube after this update. Not sure what logs or debug info I can send, so please let me know, and I can attach it.
Using Gnome DE on Wayland. Just updated via the Testing Update Branch to Linux 6.16.6-1-MANJARO Kernel.
Hi @A4orce84 ,
Please, provied the outpud of the following terminal command:
inxi -v7azy
and also
pactl list sources
Also you could find help from Apple itself.
If the sound from your wireless headphones cuts out or is distorted - Apple Support
May be I could help you afterwards,
Regards
Your post has been moved to a dedicated topic.
Please provide any detail that might be relevant, along with system information as described (below). Outputs from the following might be useful to those wishing to help;
cat /etc/*-release
pacman -Q sof-firmware alsa-utils alsa-tools pipewire pipewire-{alsa,jack,media-session,pulse}
pactl list cards
pactl list sinks
pactl list sources
amixer scontents
sudo dmesg | egrep -E '(snd|sound|sof|hda|alsa)'
Please use appropriate pre-formatted text boxes (</>) for all code or command output. I’m sure someone will help when they are able.
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Here is the output you requested @j8a :
inxi -v7azy:
  Kernel: 6.16.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.16-x86_64
    root=UUID=b0bee983-91c6-4ae4-86ec-1d53ce5f5f8c rw apparmor=1
    security=apparmor resume=UUID=535cc135-beca-480b-8eb7-4497f3c62063
    udev.log_priority=3 i915.enable_dc=0
  Desktop: GNOME v: 48.4 tk: GTK v: 3.24.50 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 48.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 20KH002JUS v: ThinkPad X1 Carbon
  Mobo: LENOVO model: 20KH002JUS v: SDK0K17763 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20KH_BU_Think_FM_ThinkPad X1
    Carbon uuid: <superuser required> UEFI: LENOVO v: N23ET92W (1.67 )
    date: 07/02/2025
  ID-1: BAT0 charge: 37.9 Wh (79%) condition: 48/57 Wh (84.1%) power: 9 W
    volts: 11.97 min: 11.52 model: SMP 01AV430 type: Li-poly serial: <filter>
    charging: status: discharging control: start: 75% end: 80% cycles: 241
  System RAM: total: 16 GiB available: 15.49 GiB used: 3.19 GiB (20.6%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: LPDDR3 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Micron part-no: MT52L1G32D4PG-093
    serial: N/A
  Device-2: ChannelB-DIMM0 type: LPDDR3 detail: synchronous unbuffered
    serial: N/A
  Info: model: Intel Core i7-8650U bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
    model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 900 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
    8: 900 bogomips: 33599
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
    class-ID: 0300
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 13d3:56b2
    class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x233d built: 2017 res: 1920x1080
    dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
    device-ID: 8086:5917 memory: 15.13 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo gpu: gputop, intel_gpu_top, lsgpu
    x11: xprop,xrandr
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.16.6-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 8087:0032
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 3 state: up address: N/A
  Local Storage: total: 1.38 TiB used: 229.82 GiB (16.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 4B2QEXM7 temp: 28.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
    SDAPMUW-512G-1101 size: 476.94 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 20210001 temp: 44.9 C scheme: GPT
  ID-1: / raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 40.13 GiB (20.5%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:8 label: N/A
    uuid: b0bee983-91c6-4ae4-86ec-1d53ce5f5f8c
    used: 31.1 MiB (32.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3 label: N/A
    uuid: E8AD-6ECC
  ID-3: /home raw-size: 606.32 GiB size: 595.73 GiB (98.25%)
    used: 72.47 GiB (12.2%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:9
    label: N/A uuid: b1597333-7f3d-4fd5-868e-342acdd761dd
  ID-4: /mnt/Quattro raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
    used: 117.19 GiB (24.6%) fs: ntfs dev: /dev/nvme1n1p1 maj-min: 259:1
    label: Quattro uuid: 4326F0386F9348F1
  Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
    zswap: yes compressor: zstd max-pool: 20%
  ID-1: swap-1 type: partition size: 25 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p5 maj-min: 259:7 label: N/A
    uuid: 535cc135-beca-480b-8eb7-4497f3c62063
  ID-1: /dev/nvme0n1p2 maj-min: 259:4 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:5 size: 99.25 GiB fs: ntfs label: DRIVE
    uuid: A0E0AE32E0AE0F1A
  ID-3: /dev/nvme0n1p4 maj-min: 259:6 size: 847 MiB fs: ntfs label: N/A
    uuid: A252B6D152B6AA05
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-7:5 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Device-2: 1-8:3 info: IMC Networks Integrated Camera type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:56b2 class-ID: 0e02
  Device-3: 1-10:4 info: Raydium Touch System type: HID
    driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 96mA
    chip-ID: 2386:4328 class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 33.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0
  Processes: 345 Power: uptime: 1h 28m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.18 GiB services: gsd-power,
    tool: systemctl
  Packages: pm: pacman pkgs: 1748 libs: 421 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.39
Source #56
	State: SUSPENDED
	Description: Monitor of Built-in Audio Analog Stereo
	Driver: PipeWire
	Sample Specification: s32le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 4294967295
	Mute: no
	Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor of Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "0"
		alsa.class = "generic"
		alsa.components = "HDA:10ec0285,17aa225c,00100002 HDA:8086280b,80860101,00100000"
		alsa.device = "0"
		alsa.id = "ALC285 Analog"
		alsa.long_card_name = "HDA Intel PCH at 0x2ffb018000 irq 162"
		alsa.mixer_name = "Realtek ALC285"
		alsa.name = "ALC285 Analog"
		alsa.resolution_bits = "16"
		alsa.subclass = "generic-mix"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.sync.id = "00000000:00000000:00000000:00000000"
		api.alsa.card.longname = "HDA Intel PCH at 0x2ffb018000 irq 162"
		api.alsa.card.name = "HDA Intel PCH"
		api.alsa.path = "front:0"
		api.alsa.pcm.card = "0"
		api.alsa.pcm.stream = "playback"
		audio.channels = "2"
		audio.position = "FL,FR"
		card.profile.device = "6"
		device.api = "alsa"
		device.class = "monitor"
		device.icon_name = "audio-card-analog"
		device.id = "49"
		device.profile.description = "Analog Stereo"
		device.profile.name = "analog-stereo"
		device.routes = "2"
		factory.name = "api.alsa.pcm.sink"
		media.class = "Audio/Sink"
		device.description = "Built-in Audio"
		node.name = "alsa_output.pci-0000_00_1f.3.analog-stereo"
		node.nick = "ALC285 Analog"
		node.pause-on-idle = "false"
		object.path = "alsa:acp:PCH:6:playback"
		port.group = "playback"
		priority.driver = "1009"
		priority.session = "1009"
		factory.id = "19"
		clock.quantum-limit = "8192"
		client.id = "47"
		node.driver = "true"
		node.loop.name = "data-loop.0"
		library.name = "audioconvert/libspa-audioconvert"
		object.id = "56"
		object.serial = "56"
		api.acp.auto-port = "false"
		api.alsa.card = "0"
		api.alsa.split-enable = "true"
		api.alsa.use-acp = "true"
		api.dbus.ReserveDevice1.Priority = "-20"
		device.bus = "pci"
		device.enum.api = "udev"
		device.name = "alsa_card.pci-0000_00_1f.3"
		device.nick = "HDA Intel PCH"
		device.plugged.usec = "6737253"
		device.product.id = "0x9d71"
		device.product.name = "Sunrise Point-LP HD Audio"
		device.subsystem = "sound"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.vendor.id = "0x8086"
		spa.object.id = "2"
		device.string = "0"
	Ports:
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability group: Legacy 3, availability unknown)
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, availability group: Legacy 4, not available)
	Active Port: analog-output-speaker
	Formats:
		pcm
Source #57
	State: SUSPENDED
	Description: Built-in Audio Analog Stereo
	Driver: PipeWire
	Mute: yes
	Volume: front-left: 25186 /  38% / -24.92 dB,   front-right: 25186 /  38% / -24.92 dB
	        balance 0.00
	Base Volume: 6554 /  10% / -60.00 dB
	Monitor of Sink: n/a
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "0"
		alsa.device = "0"
		api.alsa.pcm.stream = "capture"
		card.profile.device = "0"
		device.api = "alsa"
		device.class = "sound"
		device.id = "49"
		device.routes = "2"
		factory.name = "api.alsa.pcm.source"
		media.class = "Audio/Source"
		node.name = "alsa_input.pci-0000_00_1f.3.analog-stereo"
		object.path = "alsa:acp:PCH:0:capture"
		port.group = "capture"
		priority.driver = "2009"
		priority.session = "2009"
		factory.id = "19"
		client.id = "47"
		object.id = "57"
		object.serial = "57"
		api.alsa.card = "0"
		device.bus = "pci"
		spa.object.id = "2"
		device.string = "0"
	Ports:
		analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, availability group: Legacy 1, availability unknown)
		analog-input-mic: Microphone (type: Mic, priority: 8700, availability group: Legacy 2, not available)
	Active Port: analog-input-internal-mic
	Formats:
		pcm
Please let me know if you need any additional information. Thank you!
Please see my post (above).
PipeWire · Wiki · Troubleshooting - Bluetooth - Debugging
  1. systemctl --user stop wireplumber.service if using systemctl, otherwise something like pkill -f wireplumber. Disconnect Bluetooth device.
  2. Run from command line with:
WIREPLUMBER_DEBUG="spa.bluez5*:4,pw.context:3,s-monitors:4,m-lua-scripting:4,s-device:4" wireplumber > pipewire-bluez.log 2>&1
  1. Connect Bluetooth device, and cause the problem behavior.
  2. Stop Wireplumber with ctrl-C and attach the produced pipewire-bluez.log to the issue. It contains information of what PipeWire tried to do during the connection.
Also check if dmesg contains messages about missing Bluetooth firmware. There have been issues where the proper firmware was not getting installed for devices
check linux-firmware-intel is installed for Intel AX210 Bluetooth device
ArchWiki - Bluetooth headset - Disable WirePlumber auto-switching
WirePlumber has profile auto-switching enabled by default. It can automatically switch between HSP/HFP and A2DP profiles whenever an input stream is detected. You can disable it with the following command:
wpctl settings --save bluetooth.autoswitch-to-headset-profile false
Output is attached below for each command:
cat /etc/*-release
Manjaro Linux
DISTRIB_ID="ManjaroLinux"
DISTRIB_RELEASE="25.0.9"
DISTRIB_CODENAME="Zetar"
DISTRIB_DESCRIPTION="Manjaro Linux"
Manjaro Linux
NAME="Manjaro Linux"
PRETTY_NAME="Manjaro Linux"
ID=manjaro
ID_LIKE=arch
BUILD_ID=rolling
ANSI_COLOR="32;1;24;144;200"
HOME_URL="https://manjaro.org/"
DOCUMENTATION_URL="https://wiki.manjaro.org/"
SUPPORT_URL="https://forum.manjaro.org/"
BUG_REPORT_URL="https://manjaro.org/help/"
PRIVACY_POLICY_URL="https://manjaro.org/privacy-policy/"
LOGO=manjarolinux
sof-firmware 2025.05.1-1
alsa-utils 1.2.14-1
error: package 'alsa-tools' was not found
pipewire 1:1.4.7-1
pipewire-alsa 1:1.4.7-1
error: package 'pipewire-jack' was not found
error: package 'pipewire-media-session' was not found
pipewire-pulse 1:1.4.7-1
pactl list cards
No Output
pactl list sinks
Sink #383
	State: SUSPENDED
	Description: Dummy Output
	Driver: PipeWire
	Sample Specification: float32le 2ch 48000Hz
	Mute: no
	        balance 0.00
	Monitor Source: auto_null.monitor
	Flags: DECIBEL_VOLUME LATENCY
	Properties:
		node.name = "auto_null"
		device.description = "Dummy Output"
		audio.rate = "48000"
		factory.name = "support.null-audio-sink"
		node.virtual = "true"
		monitor.channel-volumes = "true"
		factory.id = "19"
		client.id = "34"
		port.group = "stream.0"
		object.id = "53"
		object.serial = "383"
	Formats:
		pcm
pactl list sources
Source #383
	State: SUSPENDED
	Description: Monitor of Dummy Output
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Monitor of Sink: auto_null
	Properties:
		factory.id = "19"
		client.id = "34"
		object.id = "53"
	Formats:
		pcm
amixer scontents
No Output
sudo dmesg | egrep -E ‘(snd|sound|sof|hda|alsa)’
egrep: warning: egrep is obsolescent; using grep -E
[    0.074429] software IO TLB: area num 8.
[    1.522846] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.522849] software IO TLB: mapped [mem 0x0000000055131000-0x0000000059131000] (64MB)
[    5.742374] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops intel_audio_component_bind_ops [i915])
[    6.039830] snd_hda_codec_realtek hdaudioC0D0: ALC285: picked fixup  (pin match)
[    6.040160] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC285: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    6.040163] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    6.040165] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    6.040167] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    6.040168] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    6.040169] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    6.040170] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[    6.744885] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[    6.744945] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[    6.745003] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[    6.745055] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[    6.746133] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
Attaching the pipewire-bluez.log output below:
https://sharetext.io/7681f56e
If you need any additional information, please let me know. Thank you!
