Thanks for your guide.
The broken sound happens whenever I play music through Bluetooth. Both my 1000XM4 headset and Edifier speaker.
Below are the pactl outputs, I post the output under 6.1 and 6.3 kernel for your information.
6.1:
Sink #0
State: SUSPENDED
Description: Rembrandt Radeon High Definition Audio Controller HDMI / DisplayPort 2 Output
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 44100Hz
Channel Map: front-left,front-right
Owner Module: 6
Mute: yes
Volume: front-left: 0 / 0% / -inf dB, front-right: 0 / 0% / -inf dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_35_00.1.HiFi__hw_Generic_7__sink.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "U2790B"
alsa.id = "HDMI 1"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "7"
alsa.card = "0"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0x987c8000 irq 135"
device.bus_path = "pci-0000:35:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:35:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "1640"
device.product.name = "Rembrandt Radeon High Definition Audio Controller"
device.string = "_ucm0001.hw:Generic,7"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "HiFi: hw:Generic,7: sink"
device.profile.description = "HDMI / DisplayPort 2 Output"
alsa.mixer_device = "_ucm0001.hw:Generic"
device.description = "Rembrandt Radeon High Definition Audio Controller HDMI / DisplayPort 2 Output"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
[Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 1200, available)
Active Port: [Out] HDMI2
Formats:
pcm
Sink #1
State: SUSPENDED
Description: Rembrandt Radeon High Definition Audio Controller HDMI / DisplayPort 1 Output
Owner Module: 6
Mute: yes
balance 0.00
Monitor Source: alsa_output.pci-0000_35_00.1.HiFi__hw_Generic_3__sink.monitor
Properties:
device.api = "alsa"
alsa.name = "HDMI 0"
alsa.id = "HDMI 0"
alsa.device = "3"
alsa.card = "0"
device.bus = "pci"
device.string = "_ucm0001.hw:Generic,3"
device.profile.name = "HiFi: hw:Generic,3: sink"
device.profile.description = "HDMI / DisplayPort 1 Output"
device.description = "Rembrandt Radeon High Definition Audio Controller HDMI / DisplayPort 1 Output"
Ports:
[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 1100, available)
Active Port: [Out] HDMI1
Formats:
pcm
Sink #2
State: SUSPENDED
Description: Family 17h/19h HD Audio Controller Speaker + Headphones
Owner Module: 8
Mute: yes
balance 0.00
Monitor Source: alsa_output.pci-0000_35_00.6.HiFi__hw_Generic_1__sink.monitor
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
device.api = "alsa"
alsa.name = "ALC257 Analog"
alsa.id = "ALC257 Analog"
alsa.device = "0"
alsa.card = "1"
alsa.long_card_name = "HD-Audio Generic at 0x987c0000 irq 136"
device.bus_path = "pci-0000:35:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:35:00.6/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h/19h HD Audio Controller"
device.string = "_ucm0003.hw:Generic_1"
device.profile.name = "HiFi: hw:Generic_1: sink"
device.profile.description = "Speaker + Headphones"
alsa.mixer_device = "_ucm0003.hw:Generic_1"
device.description = "Family 17h/19h HD Audio Controller Speaker + Headphones"
Ports:
[Out] Speaker: Speaker (type: Speaker, priority: 100, availability unknown)
[Out] Headphones: Headphones (type: Headphones, priority: 200, not available)
Active Port: [Out] Speaker
Formats:
pcm
Sink #3
State: SUSPENDED
Description: WH-1000XM4
Driver: module-bluez5-device.c
Owner Module: 26
Mute: no
Volume: front-left: 45875 / 70% / -9.29 dB, front-right: 45875 / 70% / -9.29 dB
balance 0.00
Monitor Source: bluez_sink.14_3F_A6_60_09_2B.a2dp_sink.monitor
Properties:
bluetooth.protocol = "a2dp_sink"
bluetooth.codec = "sbc"
device.description = "WH-1000XM4"
device.string = "14:3F:A6:60:09:2B"
device.api = "bluez"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_14_3F_A6_60_09_2B"
bluez.class = "0x240404"
bluez.alias = "WH-1000XM4"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
Ports:
headset-output: Headset (type: Headset, priority: 0, availability unknown)
Active Port: headset-output
Formats:
pcm
6.3
Sink #0
State: SUSPENDED
Owner Module: 6
Mute: yes
balance 0.00
Properties:
device.api = "alsa"
alsa.id = "HDMI 1"
alsa.device = "7"
alsa.card = "0"
device.bus = "pci"
Ports:
Formats:
pcm
Sink #1
State: SUSPENDED
Owner Module: 6
Mute: yes
balance 0.00
Properties:
device.api = "alsa"
alsa.id = "HDMI 0"
alsa.device = "3"
alsa.card = "0"
device.bus = "pci"
Ports:
Formats:
pcm
Sink #2
State: SUSPENDED
Owner Module: 8
Mute: yes
balance 0.00
Properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
Ports:
Formats:
pcm
Sink #3
State: SUSPENDED
Owner Module: 26
Mute: no
balance 0.00
Properties:
bluetooth.battery = "80%"
Ports:
Formats:
pcm
