Bluetooth audio connection problems
I have a pair of Bluetooth earphones that used to connect and work fine but now the option to pair is greyed out in the blueman-manager. I noticed that the packages manjaro meta bluetooth is not installed and neither is pulseaudio bluetooth. If I try to install the later I get an error as such :-
could not satisfy dependencies:
  • removing pipewire-pulse breaks dependency ‘pipewire-pulse’ required by manjaro-pipewire
I don’t know why it wants to remove these and if I even need those bluetooth packages installing.
The bluetooth dongle sees my headphones :-
84:AC:60:19:4F:DC
public
QCY Melobuds ANC
QCY Melobuds ANC
0x248404
0x0000
audio-headset
paired yes
trusted yes
blocked no
legacy no
connected no
Confused ?
Restart your Device and then…
Try to connect in this order:
Trust>Pair>Connect.
It’s already trusted and paired. If I try to remove the device by right click, remove it does not remove them. Also the option to search for new devices is greyed out. I can turn the Bluetooth adaptor on and off ok.
It doesn’t matter if it trusted and paired already… remove both and restart your device.
Update. I installed the 6.15 kernel and now the connect option appears and they work. I did get these errors on boot now…
Selecting the REMOVE option on kernel 6.12 previously did nothing. It would not remove the device.
Jul 17 22:26:17 Asus kernel: Bluetooth: hci0: command 0x0c24 tx timeout
Jul 17 22:26:17 Asus kernel: Bluetooth: hci0: Opcode 0x0c24 failed: -110
Jul 17 22:26:17 Asus kernel: Bluetooth: hci0: Resetting usb device.
Jul 17 22:26:17 Asus kernel: Bluetooth: hci0: urb 00000000e5bef85a failed to resubmit (2)
Jul 17 22:26:19 Asus bluetoothd[674]: Failed to add UUID: Authentication Failed (0x05)
Jul 17 22:26:19 Asus kernel: Bluetooth: hci0: Opcode 0x0c24 failed: -110
Jul 17 22:26:19 Asus kernel: Bluetooth: hci0: command 0x0c24 tx timeout
Jul 17 22:26:19 Asus kernel: Bluetooth: hci0: Resetting usb device.
Jul 17 22:26:19 Asus kernel: Bluetooth: hci1: urb 0000000007f751d3 failed to resubmit (2)
Jul 17 22:26:21 Asus kernel: Bluetooth: hci1: command 0xfc61 tx timeout
Jul 17 22:26:21 Asus kernel: Bluetooth: hci1: RTL: Failed to generate devcoredump
Jul 17 22:26:21 Asus kernel: Bluetooth: hci1: Resetting usb device.
Jul 17 22:26:21 Asus kernel: Bluetooth: hci1: RTL: RTL: Read reg16 failed (-110)
Jul 17 22:26:21 Asus kernel: Bluetooth: hci1: unexpected event for opcode 0xfc61
Jul 17 22:26:21 Asus kernel: Bluetooth: hci1: urb 000000004eda327a failed to resubmit (2)
Jul 17 22:26:32 Asus kernel: Bluetooth: hci1: RTL: RTL: Read reg16 failed (-110)
Mod edit:- Please remember to format code or command output as preformatted text.
See How to Post Command Output as Preformatted Text.
Corrected for you this one time. No charge.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
