Hi,
I use the pinephone pro with manjaro phosh edition
[-94%]manjaro@manjaro-arm ~$ uname -a
Linux manjaro-arm 5.17.3-2-MANJARO-ARM #1 SMP PREEMPT Sat Apr 16 04:43:52 UTC 2022 aarch64 GNU/Linux
[-92%]manjaro@manjaro-arm ~$ cat /etc/lsb-release
DISTRIB_ID=Manjaro-ARM
DISTRIB_RELEASE=22.04
DISTRIB_CODENAME=
DISTRIB_DESCRIPTION="Manjaro ARM Linux"
But, I’ve some troubles with the bluetooth and all devices.
[ 16.374952] rfkill: input handler disabled
[ 44.627154] rk818-bat: changed: dsoc=99, rsoc=99, v=4012, ov=4201 c=-1111, cap=2694, f=2708, st=charge off, hotdie=0
[ 44.627206] rk818-bat: dl=100, rl=100, v=4189, halt=0, halt_n=0, max=0, init=0, sw=0, calib=0, below0=0, force=0
[ 66.021102] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 66.021164] Bluetooth: HIDP socket layer initialized
[ 66.025675] hid-generic 0005:04E8:7021.0001: unknown main item tag 0x0
[ 66.028477] input: Bluetooth Keyboard as /devices/platform/ff180000.serial/serial0/serial0-0/bluetooth/hci0/hci0:11/0005:04E8:7021.0001/input/input6
[ 66.032262] input: Bluetooth Keyboard Mouse as /devices/platform/ff180000.serial/serial0/serial0-0/bluetooth/hci0/hci0:11/0005:04E8:7021.0001/input/input7
[ 66.033386] hid-generic 0005:04E8:7021.0001: input,hidraw0: BLUETOOTH HID v1.1b Keyboard [Bluetooth Keyboard] on 14:13:33:0f:2c:e4
[ 128.011337] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 128.017530] Bridge firewalling registered
[ 162.389101] rk818-bat: changed: dsoc=98, rsoc=98, v=4056, ov=4201 c=-626, cap=2666, f=2708, st=charge off, hotdie=0
[ 162.389152] rk818-bat: dl=100, rl=100, v=4189, halt=0, halt_n=0, max=0, init=0, sw=0, calib=0, below0=0, force=0
[ 269.907726] rk818-bat: changed: dsoc=97, rsoc=97, v=3985, ov=4201 c=-939, cap=2640, f=2708, st=charge off, hotdie=0
[ 269.907769] rk818-bat: dl=100, rl=100, v=4189, halt=0, halt_n=0, max=0, init=0, sw=0, calib=0, below0=0, force=0
[ 392.800893] rk818-bat: changed: dsoc=96, rsoc=96, v=4037, ov=4201 c=-650, cap=2612, f=2708, st=charge off, hotdie=0
[ 392.800930] rk818-bat: dl=100, rl=100, v=4189, halt=0, halt_n=0, max=0, init=0, sw=0, calib=0, below0=0, force=0
[ 450.898900] Bluetooth: hci0: Opcode 0x200d failed: -110
[ 450.955041] Bluetooth: hci0: request failed to create LE connection: err -110
[ 450.963248] Unable to handle kernel paging request at virtual address dead000000000122
[ 450.972160] Mem abort info:
[ 450.975359] ESR = 0x96000044
[ 450.978818] EC = 0x25: DABT (current EL), IL = 32 bits
[ 450.984811] SET = 0, FnV = 0
[ 450.988269] EA = 0, S1PTW = 0
[ 450.991806] FSC = 0x04: level 0 translation fault
[ 450.997284] Data abort info:
[ 451.000532] ISV = 0, ISS = 0x00000044
[ 451.004844] CM = 0, WnR = 1
[ 451.008180] [dead000000000122] address between user and kernel address ranges
[ 451.016185] Internal error: Oops: 96000044 [#1] PREEMPT SMP
[ 451.022430] Modules linked in: xt_MASQUERADE nfnetlink iptable_nat br_netfilter bridge stp llc overlay hidp option usb_wwan usbserial qmi_wwan rfcomm bnep zram zsmalloc snd_soc_simple_card crct10dif_ce snd_soc_simple_card_utils leds_sgm3140 nls_iso8859_1 rockchip_isp1 snd_soc_rockchip_i2s phy_rockchip_dphy_rx0 hci_uart hantro_vpu(C) btrtl rockchip_vdec(C) rockchip_rga v4l2_vp9 videobuf2_vmalloc btbcm videobuf2_dma_sg v4l2_h264 bluetooth snd_soc_rt5640 brcmfmac ecdh_generic snd_soc_hdmi_codec snd_soc_rl6231 snd_soc_simple_amplifier inv_mpu6050_i2c inv_mpu6050 ecc stk3310 brcmutil snd_soc_core snd_pcm_dmaengine snd_pcm cfg80211 snd_timer af8133j snd rockchip_thermal rfkill soundcore
[ 451.090088] CPU: 3 PID: 3543 Comm: kworker/u13:3 Tainted: G C 5.17.3-2-MANJARO-ARM #1
[ 451.100320] Hardware name: Pine64 PinePhonePro (DT)
[ 451.105770] Workqueue: hci0 hci_cmd_sync_work [bluetooth]
[ 451.111879] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 451.119663] pc : hci_conn_cleanup+0x3c/0x170 [bluetooth]
[ 451.125647] lr : hci_conn_cleanup+0x2c/0x170 [bluetooth]
[ 451.131621] sp : ffff80000a05bca0
[ 451.135320] x29: ffff80000a05bca0 x28: 0000000000000000 x27: 0000000000000000
[ 451.143303] x26: dead000000000100 x25: dead000000000122 x24: ffff000004ba4000
[ 451.151285] x23: ffff800000ed7000 x22: ffff800000ed7020 x21: 0000000000000092
[ 451.159266] x20: ffff000004ba4000 x19: ffff0000b644b000 x18: ffffffffffffffff
[ 451.167248] x17: 31312d2072726520 x16: 3a6e6f697463656e x15: 0000003d18764be8
[ 451.175230] x14: 0003098a887e6f48 x13: 0000000000000000 x12: 000000000000000f
[ 451.183212] x11: 0000000000000000 x10: 000000000000026c x9 : 0000000000000000
[ 451.191192] x8 : ffff0000f7763340 x7 : ffff800009ca3bf0 x6 : ffff000006ad7430
[ 451.199176] x5 : 0000000000000000 x4 : 0000000000000000 x3 : ffff0000b644b0e4
[ 451.207180] x2 : dead000000000122 x1 : ffff000023abc000 x0 : dead000000000122
[ 451.215179] Call trace:
[ 451.217914] hci_conn_cleanup+0x3c/0x170 [bluetooth]
[ 451.223596] hci_conn_del+0xd4/0x190 [bluetooth]
[ 451.228886] hci_le_conn_failed+0x15c/0x1e4 [bluetooth]
[ 451.234856] create_le_conn_complete+0x64/0xa4 [bluetooth]
[ 451.241117] hci_cmd_sync_work+0x90/0xdc [bluetooth]
[ 451.246792] process_one_work+0x1d0/0x350
[ 451.251295] worker_thread+0x13c/0x460
[ 451.255496] kthread+0x10c/0x110
[ 451.259120] ret_from_fork+0x10/0x20
[ 451.263143] Code: a9400261 f9000420 d2802442 f2fbd5a2 (f9000001)
[ 451.269968] ---[ end trace 0000000000000000 ]---
[ 497.004705] rk818-bat: caltimer: ioffset=0x81f, coffset=0x830, poffset=17
[ 546.396222] rk818-bat: changed: dsoc=95, rsoc=95, v=4033, ov=4201 c=-602, cap=2586, f=2708, st=charge off, hotdie=0
[ 546.408081] rk818-bat: dl=100, rl=100, v=4189, halt=0, halt_n=0, max=0, init=0, sw=0, calib=0, below0=0, force=0
When the bluetooth crash I should restart the pinephone pro for already use some bluetooth devices
Someone have this problem ?
