Ever since I installed Manjaro I’ve been able to use bluetooth without any problems- until last night, when for no reason my keyboard disconnected. I checked gnome’s settings manager and found that gnome said there was no bluetooth adapter found- what do I do?
I’m not 100% what I was doing at the time that may have caused this to happen. I remember installing lib32-pipewire around the time it happened- but it could be unrelated?
… just by itself or along with a full system update?
(partial updates can and soon will cause problems)
/var/log/pacman.log
will hold everything you ever did
tac /var/log/pacman.log | less
to list it in reverse order - most recent change first
inxi -Fazy
for system information … the bluetooth adapter should show up there
Full system update, always make sure of it. That’s why I think it could be related, maybe some bluetooth package updated when I installed lib32-pipewire
[2024-08-15T00:37:31-0700] [ALPM] running ‘30-systemd-update.hook’…
[2024-08-15T00:37:31-0700] [ALPM] transaction completed
[2024-08-15T00:37:31-0700] [ALPM] installed lib32-pipewire (1:1.2.2-1)
[2024-08-15T00:37:31-0700] [ALPM] installed lib32-libpipewire (1:1.2.2-1)
[2024-08-15T00:37:31-0700] [ALPM] transaction started
[2024-08-15T00:37:24-0700] [PAMAC] synchronizing package lists
[2024-08-14T23:32:31-0700] [ALPM] running ‘30-systemd-update.hook’…
[2024-08-14T23:32:31-0700] [ALPM] transaction completed
[2024-08-14T23:32:31-0700] [ALPM] installed lib32-gnutls (3.8.6-1)
[2024-08-14T23:32:31-0700] [ALPM] installed lib32-nettle (3.10-1)
[2024-08-14T23:32:31-0700] [ALPM] installed lib32-gmp (6.3.0-1)
[2024-08-14T23:32:31-0700] [ALPM] transaction started
[2024-08-14T23:32:27-0700] [PAMAC] synchronizing package lists
[2024-08-14T23:31:11-0700] [ALPM] running ‘30-systemd-update.hook’…
(From /var/log/pacman.log
I don’t really see anything else from around that time…? I did install lib32-gnutls (forgot about that) but I don’t see how that could be related
Inxi:
Kernel: 6.6.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=f1bdbe7b-a24b-4667-ada2-684a1e4ac3eb rw quiet splash apparmor=1
security=apparmor resume=UUID=b3978c01-24b7-4ac7-ad50-cdca01f12a46
udev.log_priority=3
Desktop: GNOME v: 46.3.1 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy, xscreensaver, xscreensaver-systemd dm: GDM
v: 46.2 Distro: Manjaro base: Arch Linux
Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 4702 date: 10/20/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3493 high: 4001 min/max: 2200/5980 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3998 2: 4001
3: 3996 4: 2200 5: 4000 6: 4000 7: 4000 8: 2200 9: 4000 10: 2200 11: 3998
12: 3999 13: 4000 14: 4000 15: 4000 16: 2200 17: 4000 18: 2200 19: 2200
20: 3997 21: 2200 22: 3999 23: 3999 24: 3997 25: 4000 26: 3998 27: 4000
28: 3995 29: 2200 30: 4000 31: 2200 32: 4000 bogomips: 256098
affected
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: eVga.com. driver: nvidia
v: 550.107.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.0
chip-ID: 10de:1b06 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:7
chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 5120x1440 s-size: <missing: xdpyinfo>
Monitor-1: DP-0 pos: right res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 2560x1440 dpi: 109
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.107.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
memory: 10.74 GiB
Device-1: NVIDIA GP102 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.1
chip-ID: 10de:10ef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: FiiO BTR5 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.3:5 chip-ID: 2972:0047
class-ID: fe01
Device-4: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
Device-5: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:2
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-6: AKAI MPKmini2 driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:3 chip-ID: 2011:0715
class-ID: 0103 serial: <filter>
API: ALSA v: k6.6.44-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Local Storage: total: 5.46 TiB used: 1.24 TiB (22.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 45.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 428.46 GiB (23.8%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 39.0 C mobo: 36.0 C gpu: nvidia temp: 35 C
Fan Speeds (rpm): cpu: 0 gpu: nvidia fan: 0%
Memory: total: 32 GiB available: 31.25 GiB used: 8.87 GiB (28.4%)
Processes: 567 Power: uptime: 50m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1634 pm: pacman pkgs: 1622 libs: 406
tools: gnome-software,pamac,yay pm: flatpak pkgs: 12 Compilers: clang: 18.1.8
gcc: 14.1.1 alt: 13 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.35
there is no section about Bluetooth in that inxi output
(it should appear in between “Network” and “Drives”)
→ the system does not see the adapter at all
does a reboot / power cycle change that?
If not:
the hardware may be broken or just disconnected
I have no other ideas.
There was quite a big update (yesterday, for me).
you can scroll up/down in that list
(you probably know that - but not everyone does …)
But I don’t think the reason is there - the hardware might simply have given up the ghost …
No, tried that several times
I thought it might be related to dual booting windows (because for whatever reason that knocks out my wifi and I have to juggle booting into windows and linux until it works)
Seems like it, as much as I was hoping that wasn’t the case, because I’m pretty sure it’s on my motherboard? Guess I have to find a dongle then…
dmt
16 August 2024 00:35
7
To be accurate, you can install things on their own as long as you don’t update the local database.
ie
sudo pacman -S package
can’t possibly cause a partial update, unless you’ve previously run some variation of
sudo pacman -Sy
# or
sudo pacman -Syuw
Last time I checked (which was quite some time ago) the pamac
GUI forced updates anyway, because it likes to update the local database when it’s opened. Not sure about the CLI version.
