Hello, I am new to this forum, so please forgive me if my formatting is incorrect. I recently installed Manjaro and am unable to pair bluetooth due to an unknown issue. This is not a hardware issue as the bluetooth works just fine in windows 10 (dual-boot).
Currently I am running a fully up to date Manjaro KDE Plasma with kernel 5.14.10-1 and 5.10.70-1 (LTS) installed.
When I run sudo systemctl status bluetooth this is what is output:
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2021-11-16 21:06:23 EST; 15min ago
Docs: man:bluetoothd(8)
Main PID: 6106 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 7044)
Memory: 920.0K
CPU: 29ms
CGroup: /system.slice/bluetooth.service
└─6106 /usr/lib/bluetooth/bluetoothd
Nov 16 21:06:23 asus-vivobook bluetoothd[6106]: Bluetooth management interface 1.21 initialized
Nov 16 21:06:23 asus-vivobook bluetoothd[6106]: Endpoint registered: sender=:1.40 path=/MediaEndpoint/A2DPSink/sbc
Nov 16 21:06:23 asus-vivobook bluetoothd[6106]: Endpoint registered: sender=:1.40 path=/MediaEndpoint/A2DPSource/s>
Nov 16 21:06:23 asus-vivobook bluetoothd[6106]: Endpoint registered: sender=:1.40 path=/MediaEndpoint/A2DPSink/sbc>
Nov 16 21:07:00 asus-vivobook bluetoothd[6106]: Failed to set mode: Failed (0x03)
So from this I can tell bluetooth is activated, but there is an error. I have tried various commands and installed multiple packages including:
* sudo systemctl restart bluetooth
* sudo systemctl start bluetooth
* rfkill list (bluetooth not hard or soft blocked)
Installed these packages:
* bluez
* bluez-utils
And yet I am still greeted with the same message above. In the Bluetooth Wizard, it says 'Your Bluetooth adapter is not pairable.' Any help would be greatly appreciated.
