Hello,
I originally posted this under “Languages > French” (my native language) but got no answer, so I’m posting it again here and translating it as best as I can.
After waking up from suspend, sometimes, my PC’s integrated Bluetooth adapter isn’t detected anymore. When opening GNOME settings, under “Bluetooth” it says : “No Bluetooth found”.
Apart from this, Bluetooth is working perfectly on my computer, even after suspending. But it seems that the adapter disappears from my system after certain randomly selected wake-up times. I have to reboot my PC to get Bluetooth back.
Here is what rfkill gives me when Bluetooth is working :
ID TYPE DEVICE SOFT HARD
0 wlan phy0 unblocked unblocked
1 bluetooth hci0 unblocked unblocked
And here is what it gives me after waking up from suspend when the Bluetooth adapter isn’t detected anymore :
Here are lspci, lsusb and inxi outputs, in that order (these are the same when the adapter is detected as when the adapter stops being detected) :
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 07)
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31)
00:14.2 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Thermal Subsystem (rev 31)
00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (rev 31)
00:17.0 SATA controller: Intel Corporation Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] (rev 31)
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation H110 Chipset LPC/eSPI Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
00:1f.3 Audio device: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller (rev 31)
00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
01:00.0 VGA compatible controller: NVIDIA Corporation GK208B [GeForce GT 730] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GK208 HDMI/DP Audio Controller (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 006: ID 0cf3:e005 Qualcomm Atheros Communications
Bus 001 Device 003: ID 04b3:3025 IBM Corp. NetVista Full Width Keyboard
Bus 001 Device 002: ID 413c:301a Dell Computer Corp. Dell MS116 Optical Mouse
CPU: quad core Intel Core i5-6400 (-MCP-) speed/min/max: 3208/800/3300 MHz
Kernel: 6.2.12-1-MANJARO x86_64 Up: 2h 0m Mem: 4285.6/7889.9 MiB (54.3%)
Storage: 1.36 TiB (45.9% used) Procs: 290 Shell: Zsh inxi: 3.3.26
My PC is a 2016 Dell Inspiron 3650 desktop.
I also had this problem when running Ubuntu 18.04, 20.04 and Manjaro KDE, so it doesn’t seem to be distro specific.
I copied the outputs above when running Linux 6.2, but the problem persists with Linux 5.15.
Thanks in advance !
