Hi, I’ve just reinstalled Manjaro and installed the blueman package, but when I try to start it, it I get a error message: “Bluez daemon is not running, blueman-manager cannot continue. This probably means that there were no Bluetooth adapters detected or Bluetooth daemon was not started.”. I’ve search the on the Arch and Manjaro wikis aswell as the forums but couldn’t find any solutions. Bluetooth with blueman was always worked on this computer(including on Manjaro) and I don’t really know what’s wrong now. Any help is greatly appreciated(also sorry if this is the wrong category)
EDIT:
Here’s my system information
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=25258bac-8d59-462b-9fe6-005ba58b5dba rw quiet
resume=UUID=f56d790a-366e-4b17-a51d-44a2995a669d udev.log_priority=3
Desktop: Cinnamon 4.6.7 tk: GTK 3.24.23 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Desktop System: Dell product: G5 5090 v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Dell model: 0DXJD9 v: A00 serial: <filter> UEFI: Dell v: 1.2.1
date: 03/20/2020
Topology: 6-Core model: Intel Core i5-9400 bits: 64 type: MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: D (13) microcode: D6
L2 cache: 9216 KiB
bogomips: 34814
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800
Type: srbds mitigation: TSX disabled
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Dell driver: nvidia
v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f82
Display: x11 server: X.Org 1.20.9 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3")
diag: 584mm (23")
OpenGL: renderer: GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10fa
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Realtek vendor: Dell driver: r8169 v: kernel port: 3000
bus ID: 03:00.0 chip ID: 10ec:2502
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel port: 3000 bus ID: 04:00.0
chip ID: 168c:0042
IF: wlp4s0 state: up mac: <filter>
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-14:4
chip ID: 0cf3:e009
Local Storage: total: 1.37 TiB used: 79.01 GiB (5.6%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNS256G NVMe 256GB
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 10410104 scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC45 scheme: GPT
ID-3: /dev/sdb type: USB vendor: HP model: x900w size: 231.60 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: PMAP
scheme: MBR
ID-1: / raw size: 229.68 GiB size: 225.08 GiB (97.99%) used: 9.34 GiB (4.2%)
fs: ext4 dev: /dev/nvme0n1p1
ID-2: /home raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 3.00 GiB (0.3%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Processes: 282 Uptime: 32m Memory: 15.50 GiB used: 2.72 GiB (17.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1143 lib: 391
flatpak: 0 Shell: Bash v: 5.0.18 running in: gnome-terminal inxi: 3.1.05
