Blueman-manager cant connect bluetooth headset
blueman-manager and bluetooctl can list the device, can start a connection, but will fail with Failed to connect: org.bluez.Error.Failed br-connection-canceled
all sugestions in the internet mentions install pulse-bluetooth ( will install full pulseaudio as requirement ), but I am using pipewire,
bluetoothctl output:
[bluetooth]# devices
Device 0C:AE:BD:BA:88:95 EDIFIER W800BT Plus
[bluetoo0C:AE:BD:BA:88:95E:BD:BA:88:95
Attempting to connect to 0C:AE:BD:BA:88:95
[CHG] Device 0C:AE:BD:BA:88:95 Connected: yes
[EDIFIER W800BT Plus]# Failed to connect: org.bluez.Error.Failed br-connection-canceled
[CHG] Device 0C:AE:BD:BA:88:95 Connected: no
inxi output:
inxi --bluetooth -z
  Device-1: Actions general adapter driver: btusb type: USB
  Report: btmgmt ID: hci0 state: up address: <filter> bt-v: 5.3
Hi @hellupline ,
I wonder whether you could run the following terminal command:
pulseaudio --daemonize
The source is the following:
[SOLVED] Bluetooth connect failed: br-connection-profile-unavailable. (Page 3) / Newbie Corner / Arch Linux Forums
and try again.
You can also have support at:
Support for W800BT Plus -【Edifier】
Hope it help, regards
