I am having the same issue as the post “Wrong version libImath for Blender” which was closed 14 hours ago.
Unfortunately the tagged solution (rebooting) doesn’t make any change for my system.
~ >>> uptime
15:48:04 up 0 min, 1 user, load average: 1.20, 0.28, 0.09
~ >>> blender
blender: error while loading shared libraries: libImath-3_0.so.28: cannot open shared object file: No such file or directory
Here is the requested output from the marked solution.
~ >>> pacman -Qi blender
Version : 17:2.93.1-4
Description : A fully integrated 3D graphics creation suite
Architecture : x86_64
URL : https://www.blender.org
Licenses : GPL
Groups : None
Provides : None
Depends On : libpng libtiff openexr python desktop-file-utils
python-requests potrace shared-mime-info
hicolor-icon-theme xdg-utils glew openjpeg2 python-numpy
freetype2 openal ffmpeg fftw boost-libs opencollada
alembic openxr openimageio libsndfile jack opencolorio
openshadinglanguage openimagedenoise jemalloc libspnav
ptex opensubdiv openvdb log4cplus sdl2 embree
Optional Deps : cuda: cycles renderer cuda support [installed]
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 323.23 MiB
Packager : Sven-Hendrik Haase <svenstaro@gmail.com>
Build Date : Tue 20 Jul 2021 09:55:49 AM PDT
Install Date : Sat 24 Jul 2021 03:41:10 PM PDT
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
~ >>> pacman -Qi imath
Version : 3.1.1-1
Description : A C++ and python library of 2D and 3D vector, matrix, and math
operations for computer graphics
URL : https://www.openexr.com/
Licenses : BSD
Groups : None
Provides : None
Depends On : gcc-libs
Optional Deps : python: python bindings [installed]
boost-libs: python bindings [installed]
Required By : opencolorio opencolorio-qfix openexr openshadinglanguage
openshadinglanguage-qfix openvdb
Optional For : None
Replaces : None
Installed Size : 38.91 MiB
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Tue 20 Jul 2021 11:18:32 PM PDT
Install Date : Fri 23 Jul 2021 09:45:45 AM PDT
Install Reason : Installed as a dependency for another package
Install Script : No
~ >>> pacman -F /usr/lib/libImath*
usr/lib/libImath-3_1.so is owned by extra/imath 3.1.1-1
usr/lib/libImath-3_1.so.29 is owned by extra/imath 3.1.1-1
usr/lib/libImath-3_1.so.29.1.0 is owned by extra/imath 3.1.1-1
usr/lib/libImath.so is owned by extra/imath 3.1.1-1
I am not quite sure what next steps to take.
I would comment on the previous issue but it is closed due to poor manners.
