Regarding Hibernation: thanks for your comment with your experience. These warnings (reduced SSD lifespan) are still popping up on all sort of websites and YouTube videos so it’s great to hear “real person” experiences.
The use of this information is, that I have a second PC with the same Manjaro stand (both are updated regularly) and that both have experienced this issue (the old one is a RTX3080 and the new one an RTX4090). On the old one it was solved so there was a solution and it was some years ago so it is not related to new kernel or new Manjaro version issues. The little use of this information is that I forgot it how it was solved. (Always make notes…)
Here is the output of the inxi command:
Kernel: 6.11.2-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=3b6502af-d0df-4fb3-ac8f-b6e521c546da rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING WIFI II v: Rev X.0x
UEFI: American Megatrends v: 3607 date: 03/22/2024
Device-1: hidpp_battery_2 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 64 GiB available: 62.71 GiB used: 8.87 GiB (14.1%)
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 3666 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: G Skill Intl
part-no: F4-4000C18-16GVK serial: N/A
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1727 min/max: 550/4951 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1727 2: 1727 3: 1727
4: 1727 5: 1727 6: 1727 7: 1727 8: 1727 9: 1727 10: 1727 11: 1727 12: 1727
13: 1727 14: 1727 15: 1727 16: 1727 17: 1727 18: 1727 19: 1727 20: 1727
21: 1727 22: 1727 23: 1727 24: 1727 bogomips: 177653
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI
driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 07:00.0
chip-ID: 10de:2684 class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x400mm (27.64x15.75")
s-diag: 808mm (31.81")
Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 140
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 550.120 device-ID: 10de:2684
surfaces: xcb,xlib
Device-1: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 07:00.1 chip-ID: 10de:22ba class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.11.2-4-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:0608
class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.27 TiB used: 318.08 GiB (13.7%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 53.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Intenso model: SSD Sata III
tech: SSD serial: <filter> fw-rev: 4A0 scheme: GPT
ID-1: / raw-size: 588.62 GiB size: 578.31 GiB (98.25%) used: 32.09 GiB (5.5%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 3b6502af-d0df-4fb3-ac8f-b6e521c546da
ID-2: /_DATA raw-size: 1.24 TiB size: 1.24 TiB (100.00%)
used: 286 GiB (22.4%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 060246b8-07a8-4549-97fd-e20db268e964
ID-3: /_Linux_PhotoBackup raw-size: N/A size: 5.41 TiB
used: 1.04 TiB (19.3%) fs: nfs4
remote: 192.168.10.30:/volume1/Linux_Photobackup
ID-4: /_SERVER_Lilly raw-size: N/A size: 5.23 TiB used: 695.39 GiB (13.0%)
fs: nfs4 remote: 192.168.10.19:/volume1/Lilly
ID-5: /_SERVER_PhotoBackup raw-size: N/A size: 5.23 TiB
used: 695.39 GiB (13.0%) fs: nfs4 remote: 192.168.10.19:/volume1/Photo_Backup
ID-6: /_SYN_Backup_1 raw-size: N/A size: 5.41 TiB used: 1.04 TiB (19.3%)
fs: nfs4 remote: 192.168.10.30:/volume1/Syn_Backup_1
ID-7: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4C23-AC80
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: B4DD-75AF
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 465.15 GiB fs: ntfs label: N/A
uuid: BEFAE759FAE70C89
ID-4: /dev/sda4 maj-min: 8:4 size: 508 MiB fs: ntfs label: N/A
uuid: 78C6BA38C6B9F68A
Device-1: 1-6:6 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
serial: <filter>
Hub-2: 1-7:7 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-3: 1-9:14 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-9.2:15 info: Evoluent VerticalMouse 4 type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 1a7c:0191 class-ID: 0301
Device-2: 1-9.4:16 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Logitech Optical Wheel Mouse type: mouse
lanes: 1 mode: 1.0 power: 100mA chip-ID: 046d:c016 class-ID: 0301
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 45.1 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: pm: pacman pkgs: 1321 libs: 339 tools: pamac pm: flatpak pkgs: 0
1: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
3: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
4: http://manjaro.grena.ge/stable/$repo/$arch
5: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
6: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
7: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
8: http://mirror.fcix.net/manjaro/stable/$repo/$arch
9: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
10: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
11: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
12: https://mirror.init7.net/manjaro/stable/$repo/$arch
13: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
14: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
15: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
16: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
17: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
18: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
19: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
20: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
22: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
23: https://mirror.koddos.net/manjaro/stable/$repo/$arch
24: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
25: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
26: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
27: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
28: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
29: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
30: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
31: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
32: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
33: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
35: https://mirror.23m.com/manjaro/stable/$repo/$arch
36: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
37: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
38: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
39: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
40: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
41: https://mirrors.manjaro.org/repo/stable/$repo/$arch
42: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
43: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
44: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
45: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
46: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
47: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
48: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
49: https://mirror.zetup.net/manjaro/stable/$repo/$arch
50: https://muug.ca/mirror/manjaro/stable/$repo/$arch
51: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
52: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
53: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
54: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
55: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
56: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
57: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
58: https://mirror.funami.tech/manjaro/stable/$repo/$arch
59: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
60: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
61: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
62: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
63: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
64: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
65: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
66: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
67: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
68: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
69: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
70: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
71: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
72: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
73: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
74: https://mirror.dc.uz/manjaro/stable/$repo/$arch
75: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
76: https://manjaro.kurdy.org/stable/$repo/$arch
77: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
78: https://linorg.usp.br/manjaro/stable/$repo/$arch
79: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
80: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
81: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
82: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
83: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
84: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
85: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
86: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
87: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
88: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
89: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
90: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
91: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
92: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
93: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
94: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
95: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
96: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
97: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
98: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
99: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
100: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
101: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
102: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
103: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
104: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
105: https://mirror.easyname.at/manjaro/stable/$repo/$arch
106: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
107: https://mirrors2.manjaro.org/stable/$repo/$arch
108: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
109: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
110: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
111: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
112: https://manjaro.ynh.ovh/stable/$repo/$arch
Processes:
CPU top: 5 of 450
1: cpu: 138% command: blender pid: 2605 mem: 2471.8 MiB (3.8%)
2: cpu: 12.5% command: gimp-2.10 pid: 2754 mem: 1456.7 MiB (2.2%)
3: cpu: 5.7% command: ./blender pid: 2985 mem: 1766.5 MiB (2.7%)
4: cpu: 2.1% command: zsh pid: 14511 mem: 9.93 MiB (0.0%)
5: cpu: 0.8% command: luminance-hdr pid: 3178 mem: 637.5 MiB (0.9%)
Memory top: 5 of 450
1: mem: 2471.8 MiB (3.8%) command: blender pid: 2605 cpu: 138%
2: mem: 1766.5 MiB (2.7%) command: ./blender pid: 2985 cpu: 5.7%
3: mem: 1456.7 MiB (2.2%) command: gimp-2.10 pid: 2754 cpu: 12.5%
4: mem: 637.5 MiB (0.9%) command: luminance-hdr pid: 3178 cpu: 0.8%
5: mem: 582.9 MiB (0.9%) command: plasmashell pid: 1092 cpu: 0.1%
Processes: 450 Power: uptime: 3h 47m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.06 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
Just checked my other system and it shows some differences in the NVidia infos:
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia gpu: nvidia
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
On the old PC the display GPU is listed as: nvidia on the new PC it is: nvidia, nvidia-nvswitch
Also under API there are some differences. So, maybe there is more differences than I thought…
