Hi, I recently updated (add/remove software) and when I switch my KVM switch from my Windows laptop to my Linux computer I get a blank screen.
This use to happen after a long period of time (a few days) but now it happens every time I switch from the windows machine to linux on the KVM.
I also tried updating my kernel from 5.10 to 6.13.
I’m able to bring up the login-in screen after pressing CTRL+ALT+DEL, but after I login the screen is black (no signal)
I’m also able to bring up a new TTY. The only thing I can do is at the login screen is to restart the computer.
lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Iris Plus Graphics 650 (rev 06)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1c.7 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #8 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (4) I219-V (rev 21)
3a:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
3b:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
inxi
  Kernel: 6.13.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64
    root=UUID=70b3bf7d-7a3b-4709-919f-88b40fdbf004 rw quiet splash apparmor=1
    security=apparmor resume=UUID=93ade087-844c-450a-9645-ebd0daae78a9
    udev.log_priority=3 i915.enable_psr=0
    snd_hda_codec_hdmi.enable_silent_stream=0
  Desktop: Xfce v: 4.20.0 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: light-locker dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: Intel product: NUC7i7BNH v: J31153-307 serial: <filter>
    Chassis: type: 3 v: 2 serial: N/A
  Mobo: Intel model: NUC7i7BNB v: J31145-306 serial: <filter>
    uuid: 85ed6131-34b2-a661-25c7-94c69116d163 UEFI: Intel
    v: BNKBL357.86A.0093.2023.1030.1032 date: 10/30/2023
  System RAM: total: 32 GiB available: 31.23 GiB used: 3.73 GiB (11.9%)
    igpu: 64 MiB
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 2400 MT/s actual: 2133 MT/s volts:
    curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64 total: 64
    manufacturer: Crucial part-no: BLS16G4S240FSD.16FBD serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
  Slot: 1 type: PCIe gen: 1 status: available length: long volts: 3.3
    bus-ID: 00:1d.1
  Slot: 2 type: PCIe gen: 2 status: available length: long volts: 3.3
    bus-ID: 00:1c.4
  Slot: 3 type: PCIe gen: 3 status: available length: long volts: 3.3
    bus-ID: 00:1c.3
  Info: model: Intel Core i7-7567U socket: BGA1356 (U3E1) note: check bits: 64
    type: MT MCP arch: Amber/Kaby Lake note: check gen: core 7 level: v3
    note: check built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 9 microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 400 min/max: 400/4000 base/boost: 2200/2400 scaling:
    driver: intel_pstate governor: powersave volts: 0.9 V ext-clock: 100 MHz
    cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 28009
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel Iris Plus Graphics 650 driver: i915 v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20 ports: active: DP-1 empty: DP-2,HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:5927 class-ID: 0300
  Device-2: Logitech BRIO Ultra HD Webcam
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.3:3 chip-ID: 046d:085e
    class-ID: 0300 serial: <filter>
  Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4
    compositor: xfwm4 v: 4.20.0 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1017x572mm (40.04x22.52")
    s-diag: 1167mm (45.94")
  Monitor-1: DP-1 model: 324K built: 2016 res: mode: 3840x2160 hz: 60
    scale: 100% (1) dpi: 111 gamma: 1.2 chroma: red: x: 0.682 y: 0.310 green:
    x: 0.204 y: 0.694 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 880x510mm (34.65x20.08") diag: 707mm (27.8") ratio: 16:9
    modes: 3840x2160, 4096x2160, 2560x1440, 2560x1080, 1920x1200, 1920x1080,
    1920x1080i, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864,
    1280x720, 1440x576, 1024x768, 1440x480, 800x600, 720x576, 720x480,
    640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 102 4: parse_edid:
    unhandled CEA mode 101 5: parse_edid: unhandled CEA mode 93 6: parse_edid:
    unhandled CEA mode 94 7: parse_edid: unhandled CEA mode 95 8: parse_edid:
    unhandled CEA mode 90
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Info: Tools: de: xfce4-display-settings x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  Device-2: Roland UA-1EX driver: snd-usb-audio type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.4:8 chip-ID: 0582:0097
    class-ID: 0102
  Device-3: Logitech BRIO Ultra HD Webcam
  API: ALSA v: k6.13.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: n/a (root, process) tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process) with:
    tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 3a:00.0 chip-ID: 8086:24fd class-ID: 0280
  IF: wlp58s0 state: up mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 8087:0a2b
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 577.55 GiB used: 81.43 GiB (14.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDA120G
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 30RL scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD4
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
  ID-1: / raw-size: 448.39 GiB size: 440.28 GiB (98.19%)
    used: 81.43 GiB (18.5%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
    maj-min: 8:18 label: N/A uuid: 70b3bf7d-7a3b-4709-919f-88b40fdbf004
    used: 300 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
    label: NO_LABEL uuid: 4CE2-BDE0
  ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: N/A
    uuid: 93ade087-844c-450a-9645-ebd0daae78a9
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: 22B7-A0AF
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 110.94 GiB fs: ntfs label: N/A
    uuid: 700ABC890ABC4E3A
  ID-4: /dev/sda4 maj-min: 8:4 size: 756 MiB fs: ntfs label: Windows RE Tools
    uuid: 067CA9EC7CA9D6A9
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-3:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
  Device-1: 1-3.1:4 info: Corsair Gaming K70 RAPIDFIRE Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 1b1c:1b3a class-ID: 0300 serial: <filter>
  Device-2: 1-3.2:6 info: Logitech M-U0007 [Corded Mouse M500] type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 98mA chip-ID: 046d:c069 class-ID: 0301
  Hub-3: 1-4:7 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0801 class-ID: 0900
  Device-1: 1-4.4:8 info: Roland UA-1EX type: audio driver: snd-usb-audio
    interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 200mA chip-ID: 0582:0097 class-ID: 0102
  Device-2: 1-8:5 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Hub-4: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  Hub-5: 2-3:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
  Device-1: 2-3.3:3 info: Logitech BRIO Ultra HD Webcam type: video,audio,HID
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 046d:085e class-ID: 0300 serial: <filter>
  System Temperatures: cpu: 46.0 C pch: 46.5 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1624 pm: pacman pkgs: 1617 libs: 451 tools: pamac pm: flatpak
    pkgs: 0 pm: snap pkgs: 7
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    3: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.23m.com/manjaro/stable/$repo/$arch
    6: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    7: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    8: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 219
  1: cpu: 100% command: ps pid: 10482 mem: 3.86 MiB (0.0%)
  2: cpu: 22.9% command: chromium pid: 1799 mem: 257.2 MiB (0.8%)
  3: cpu: 14.9% command: chromium pid: 7103 mem: 283.4 MiB (0.8%)
  4: cpu: 13.9% command: chromium pid: 1759 mem: 471.1 MiB (1.4%)
  5: cpu: 11.5% command: chromium pid: 10428 mem: 263.3 MiB (0.8%)
  Memory top: 5 of 219
  1: mem: 471.1 MiB (1.4%) command: chromium pid: 1759 cpu: 13.9%
  2: mem: 339.0 MiB (1.0%) command: chromium pid: 10104 cpu: 1.3%
  3: mem: 310.2 MiB (0.9%) command: chromium pid: 1936 cpu: 1.4%
  4: mem: 303.7 MiB (0.9%) command: chromium pid: 10334 cpu: 10.0%
  5: mem: 296.2 MiB (0.9%) command: chromium pid: 1913 cpu: 0.7%
  Processes: 219 Power: uptime: 2h 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: upowerd,xfce4-power-manager
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.37
