I have partitined Macbook2012 for dual boot with manjaro linux 6.1, installed ReFInd after linux installation, but when trying to reboot i can see only white screen without any functionality. Any recommendations for the troubleshooting the issue are welcome.
[ataras@mpmacbook ~]$ inxi -v7azy
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ccb3bd81-487b-4e33-a499-542688a7355e rw quiet apparmor=1
security=apparmor resume=UUID=8f6b7b2d-7473-44c3-bda4-cb3d194f562b
udev.log_priority=3
Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Apple product: MacBookPro9,2 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-6F01561E16C75D06
Mobo: Apple model: Mac-6F01561E16C75D06 v: MacBookPro9,2
serial: <superuser required> UEFI: Apple v: 429.0.0.0.0 date: 03/18/2022
ID-1: BAT0 charge: 4.2 Wh (8.3%) condition: 50.9/62.9 Wh (80.9%) volts: 10.7
min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A status: discharging
cycles: 578
RAM: total: 7.67 GiB used: 1.83 GiB (23.8%)
Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1197 min/max: 1200/3100 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1197 2: 1197 3: 1197 4: 1197 bogomips: 19962
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Apple FaceTime HD Camera type: USB driver: uvcvideo
bus-ID: 1-1.1:3 chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: Picom v: git-b700a driver:
X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
s-diag: 398mm (15.69")
Monitor-1: LVDS-1 model: Apple Color LCD built: 2009 res: 1280x800 hz: 60
dpi: 114 gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
ratio: 16:10 modes: 1280x800
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0
chip-ID: 14e4:16b4 class-ID: 0200
IF: enp1s0f0 state: down mac: <filter>
Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14e4:4331 class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 2-1.8.1.3:9 chip-ID: 05ac:821d class-ID: fe01
Local Storage: total: 465.76 GiB used: 11.41 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: HDD HTS545050A7E362
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: B990 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRW GS41N rev: UA04
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 11.01 GiB (28.9%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: ccb3bd81-487b-4e33-a499-542688a7355e
ID-2: /boot/efi raw-size: 512.3 MiB size: 511.2 MiB (99.80%)
used: 2.6 MiB (0.5%) fs: vfat dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: BF6A-44D0
ID-3: /home raw-size: 245.46 GiB size: 240.55 GiB (98.00%)
used: 398.4 MiB (0.2%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: cd07d23a-5a3e-4485-8356-5cdd44a33be5
ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 8f6b7b2d-7473-44c3-bda4-cb3d194f562b
ID-1: /dev/sda2 maj-min: 8:2 size: 148.92 GiB fs: apfs label: N/A
uuid: 99ee17c7-f619-4a63-b0da-255bfc8eb117
ID-2: /dev/sda4 maj-min: 8:4 size: 15.03 GiB fs: apfs label: N/A
uuid: 5699fe92-de0c-4eb8-bfc2-030860330d1f
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: Apple FaceTime HD Camera type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 2-1.8:3 info: Microchip (formerly SMSC) 2.0 Hub ports: 3 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2513 class-ID: 0900
Hub-6: 2-1.8.1:4 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500
Device-1: 2-1.8.1.3:9 info: Apple Bluetooth USB Host Controller
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
Device-2: 2-1.8.2:5 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
chip-ID: 05ac:8242 class-ID: 0300
Device-3: 2-1.8.3:6 info: Apple Internal Keyboard/Trackpad (ISO)
type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 40mA chip-ID: 05ac:0253 class-ID: 0301
Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 62.0 C mobo: N/A
Processes: 192 Uptime: 54m wakeups: 3 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1070 libs: 305 tools: pamac,yay Shell: Bash v: 5.1.16
running-in: urxvtd inxi: 3.3.25
journalctl --boot=-1 --priority=3 --catalog --no-pager
Mar 08 22:05:07 mpmacbook kernel: DMAR-IR: [Firmware Bug]: ioapic 2 has no mapping iommu, interrupt remapping will be disabled
Mar 08 22:05:07 mpmacbook kernel: ACPI Error: Needed type [Reference], found [Integer] (____ptrval____) (20220331/exresop-66)
Mar 08 22:05:07 mpmacbook kernel: ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Store] (20220331/dswexec-431)
Mar 08 22:05:07 mpmacbook kernel: ACPI Error: Aborting method \_PR.CPU0._PDC due to previous error (AE_AML_OPERAND_TYPE) (20220331/psparse-529)
Mar 08 22:05:18 mpmacbook bluetoothd[486]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mar 08 22:05:18 mpmacbook bluetoothd[486]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mar 08 22:05:18 mpmacbook bluetoothd[486]: src/plugin.c:plugin_init() Failed to init bap plugin
Mar 08 22:05:32 mpmacbook lightdm[598]: gkr-pam: couldn't unlock the login keyring.
Mar 08 22:30:55 mpmacbook wpa_supplicant[590]: bgscan simple: Failed to enable signal strength monitoring
Mar 08 22:43:27 mpmacbook wpa_supplicant[590]: bgscan simple: Failed to enable signal strength monitoring
Mar 08 22:50:25 mpmacbook kernel: ERROR @wl_cfg80211_scan :
Mar 08 22:50:44 mpmacbook kernel: ERROR @wl_cfg80211_scan :
Mar 08 22:50:48 mpmacbook wpa_supplicant[590]: bgscan simple: Failed to enable signal strength monitoring
Mar 08 23:45:31 mpmacbook systemd-coredump[8672]: Failed to connect to coredump service: Connection refused
mhwd -l
> 0000:00:02.0 (0300:8086:0166) Display controller Intel Corporation:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
mhwd -l
[ataras@mpmacbook ~]$ lsblk -fa
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
sda
├─sda1 swap 1 8f6b7b2d-7473-44c3-bda4-cb3d194f562b [SWAP]
├─sda2 apfs 99ee17c7-f619-4a63-b0da-255bfc8eb117
├─sda3 ext4 1.0 cd07d23a-5a3e-4485-8356-5cdd44a33be5 227.9G 0% /home
├─sda4 apfs 5699fe92-de0c-4eb8-bfc2-030860330d1f
├─sda5 ext4 1.0 ccb3bd81-487b-4e33-a499-542688a7355e 25.2G 29% /
└─sda6 vfat FAT32 BF6A-44D0 508.6M 1% /boot/efi
sr0
refind-install
Not running as root; attempting to elevate privileges via sudo....
ShimSource is none
Installing rEFInd on Linux....
ESP was found at /boot/efi using vfat
Found rEFInd installation in /boot/efi/EFI/refind; upgrading it.
Installing driver for ext4 (ext4_x64.efi)
Copied rEFInd binary files
Notice: Backed up existing icons directory as icons-backup.
Existing refind.conf file found; copying sample file as refind.conf-sample
to avoid overwriting your customizations.
Keeping existing NVRAM entry
rEFInd is set as the default boot manager.
Existing //boot/refind_linux.conf found; not overwriting.
Installation has completed successfully.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
