After I had this issue, i also saw this 2 new errors in journal that showed up:
Mai 11 02:25:15 koboldx-z170 kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
Mai 11 02:26:26 koboldx-z170 kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
When i had this issue the first time, i was total shocked because i though my GPU breaked.
But after moving my mouse, the Monitor comes back life, like it was in a sleeping state, but i had deactivated all kind of Energy Savings in KDE.
The Nvidia-DRM issue that showed up in Journal makes me think, that it was linked 1 month old Nvidia Flickering Issue that i fixed with the workaround “nvidia_drm.modeset=1” in Grub Boot that i had to add in Grub in April after we had to reinstall nvidia-settings. The1 month old Topic (that was solved at this time because of the workaround) but still not fixed from nvidia and today i see this drawbacks from this workaround.
Yesterday, i had the second time this black screen issue (signal was total lost) and pressing keyboard or moving mouse wont do anything.
I saw no other way then pressing “quick” the power button… for a normal shutdown.
And 1-2sec just befor the shutdown, i saw the screen again befor the PC finally shutdown.
That makes me thinking that maybe i can restore the Monitor signal and get a picture with crtl+alt+f2 (TTY) and back to desktop with crtl+alt+f1, but i still very confused why this all happends and if switching to TTY really helps here or not ![]()
Also what makes it even more harder that this new stable update comes out, 1 day after i refreshed my Thermal Paste at my GPU, because of a heat issue that is fixed now, in this situations a rolling release can we a big problem ![]()
Im actually updated today my LTSC Kernel from 5.15 to 6.01 but i dont have high expectation and just waiting for the next blackscreen, that maybe happening 1 time in around 30hours in my limited experience with that issue… so its a really rare situation.
inxi --admin --verbosity=7 --filter --no-host --width:
Summary
Kernel: 5.15.109-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=eb235aa7-d461-413d-800e-ea57385703fb rw quiet apparmor=1
sysrq_always_enabled=1 retbleed=off security=apparmor nvidia_drm.modeset=1
resume=UUID=717b267e-7322-4bf9-a840-f1210d422d1a udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: F23d date: 12/01/2017
System RAM: available: 15.58 GiB used: 2.6 GiB (16.7%)
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4501 high: 4505 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4502 2: 4505 3: 4502
4: 4500 5: 4504 6: 4500 7: 4501 8: 4499 bogomips: 64026
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: retbleed status: Vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-3 empty: DP-1,
DP-2, HDMI-A-1, Unknown-1 bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 532x302mm (20.94x11.89")
s-diag: 612mm (24.08")
Monitor-1: DP-3 mapped: DP-4 note: disabled model: Dell S2417DG
serial: <filter> built: 2018 res: 2560x1440 dpi: 123 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 2080
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 0b:00.0 chip-ID: 1102:0012 class-ID: 0403
API: ALSA v: k5.15.109-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:5
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 4.57 TiB used: 198.35 GiB (4.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B7QCXE7 temp: 23.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HDN724030ALE640
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A5E0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: Portable SSD T5
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
scheme: MBR
ID-1: / raw-size: 88.61 GiB size: 86.66 GiB (97.80%) used: 32.57 GiB (37.6%)
fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: eb235aa7-d461-413d-800e-ea57385703fb
ID-2: /boot raw-size: 200 MiB size: 188.2 MiB (94.09%)
used: 70.5 MiB (37.5%) fs: ext3 dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: 26eda82e-b403-49b8-abca-202167417020
ID-3: /home raw-size: 332.03 GiB size: 325.75 GiB (98.11%)
used: 27.13 GiB (8.3%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: N/A
uuid: ada4a6a2-bd0a-4652-b386-7c637bba7ee9
ID-4: /media/linux-games raw-size: 196.58 GiB size: 192.43 GiB (97.89%)
used: 133.63 GiB (69.4%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
label: Linux-games uuid: dd5af583-9d00-4017-adf7-e1d8876486e7
ID-5: /media/temp raw-size: 63.48 GiB size: 62.18 GiB (97.96%)
used: 4.94 GiB (7.9%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: temp
uuid: 1e81b7c2-3438-438a-b572-ff8a966a78e1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 7.81 GiB used: 2.8 MiB (0.0%)
priority: -2 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 717b267e-7322-4bf9-a840-f1210d422d1a
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 442.47 GiB fs: ntfs label: ssm
uuid: AE7EDC0696B158FD
ID-2: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System-reserviert
uuid: B2286A122869D5BF
ID-3: /dev/sda2 maj-min: 8:2 size: 97.09 GiB fs: ntfs label: win10
uuid: 5E60C09860C077F3
ID-4: /dev/sda4 maj-min: 8:4 size: 585.94 GiB fs: ntfs label: games
uuid: 165692E31D7ADAF2
ID-5: /dev/sdb2 maj-min: 8:18 size: 1.57 TiB fs: <superuser required>
label: N/A uuid: N/A
ID-6: /dev/sdb3 maj-min: 8:19 size: 1.09 TiB fs: <superuser required>
Device-1: 1-3:5 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
class-ID: e001
Device-2: 1-9:2 info: Endor AG ClubSportPedal type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0eb7:183b class-ID: 0300
Device-3: 1-13:3 info: A4Tech XL-730K / XL-750BK XL-755BK Mice
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 09da:9090 class-ID: 0301
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
Device-1: 2-5:2 info: Samsung Portable SSD T5 type: mass storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 896mA chip-ID: 04e8:61f5 class-ID: 0806
serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 243 Uptime: 11h 53m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1494 pm: pacman pkgs: 1488 libs: 425 tools: pamac pm: flatpak
pkgs: 6 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
