hi i think i lost mi manjaro installation (latest LTS kernel) due to me being dumb…
it happened that i had manjaro running for several days (enjoying every second of it) and then yesterday i thought i´d look if MHWD is giving my slow 2.5gbit ethernet a driver boost. i installed every driver even those for my gpu (because why not) and then in the night i went to go to bed. i clicked the shutdown but nothing moved. i clicked the shutdown again and again nothing moved. this repeated 4 times until my pc finally shutdown. today i booted into a black screen with nothing but a blinking white “_”
i searched google for aid and came to the ctrl, alt, F2 thing to open the terminal and fix things BUT here is where things get REALLY bad. i cant log in since i never set any password. since my machine is always at home and only used by me (and i cant remember stuff) i went for the no password auto-login route. so when i opened the Mate terminal in GUI and it asked for a password i could just hit enter and go my way. now in this situation i cant seem to get anywhere since everything is set up to hate me.
Possibly ctrl alt F3
Set root-Password:
passwd
(passwd › Wiki › ubuntuusers.de)
((and write Password down on a pice of paper, place this under your keyboard for emergency ))
oh okay thank you i´m gonna try that in a second. first i need to shutdown this “emergency” windows leftover and boot in that wonderful manjaro. i am gonna come back and tell you how it went
Edit: soo i tried it and it is greeting me with login:
But i cant do anything because i dont have a login.
God bless you i managed to set a massword with your link behind “or simpler:” now for that driver error🤔
So the tipp i read online said to go with “StartX”
My output is like :
Xauth : file /root/.xauthority does not exist
And way further down the screen:
Vesa: refusing to run on uefi (EE) fatal server error: (EE) no screens found
My pleasure:
grapic driver (in german:)
* Falscher Grafikkartentreiber, beheben: *
Währen des Startvorgang, wenn Grub angezeigt wird, die E taste drücken
und dem Kernel folgende Bootoption: 3 nomodeset hinzufügen.
Mit F10 weiter.
So gelangst du zu einen Eingabe prompt in dem du dich einloggst
This means your grub is broken…
It can be repaired easily.
But you better call: @stephane by message - he is some where expert - My time today expires shortly, sorry.
Thanks for everything i managed to fix it all in one swift move. The grub really was done for but i googled a fix and found commands to chroot into it (skipped that) and to reinstall it (skipped that too) then there was a simple one to update it and that fixed it. Sadly i dont find it anymore. BUT i still had the driver error to be fixed. So i went into TTy2 and did a quick uninstall (mhwd command thing) and after that i swiftly put a sudo mhwd -a pci free 0300 in to install the RIGHT driver. Thank you i am back in my most loved OS
