I’ve got a dual boot Manjaro and Windows system a bit of background:
Almost all of this was done via chroot and a live usb
- botched
pacman -Syu
due to power outage - got a black screen with a message that vmlimuz(or something like that is not found) on next boot
- Followed advice on recovering from interrupted update, but that wasn’t enough as my whole kernel was gone and it wasn’t only a grub issue.
- Installed
linux66
and reinstalledlinux515
ran system updates after each one - reinstalled
video-linux
driver - still getting black screen, but no error message about vmlinuz
startx output ← having the feeling this is the issue, but the people with similar problems were always running nvidia cards
/etc/X11/xinit/xserverrc: line 2: /usr/bin/X: Success
Invalid MIT-MAGIC-COOKIE-1 key
xinit: giving up
xinit: unable to connect to X server: Resource temporarily unavailable
xinit: server error
12System:
12Kernel 6.6.8-2-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 13.2.1
12clocksource tsc 12available hpet,acpi_pm
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2311 quiet systemd.show_status=1
splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
12Console N/A 12Distro Manjaro Linux 12base Arch Linux
12Machine:
12Type Laptop 12System Micro-Star 12product Bravo 15 B5DD 12v REV:1.0 12serial <filter>
12Chassis 12type 10 12serial <filter>
12Mobo Micro-Star 12model MS-158K 12v REV:1.0 12serial <filter> 12UEFI American
Megatrends LLC. 12v E158KAMS.105 12date 05/20/2021
12Battery:
12ID-1 BAT1 12charge 46.4 Wh (98.3%) 12condition 47.2/52.0 Wh (90.7%) 12volts 13.0
12min 11.4 12model MSI Corp. MS-158K 12type Li-ion 12serial N/A 12status charging
12Memory:
12System RAM 12total 32 GiB 12available 30.74 GiB 12used 2.88 GiB (9.4%)
12Array-1 12capacity 32 GiB 12slots 2 12modules 2 12EC None 12max-module-size 16 GiB
12note est.
12Device-1 DIMM 0 12type DDR4 12detail synchronous unbuffered (unregistered)
12size 16 GiB 12speed 3200 MT/s 12volts 12curr 1.2 12min 1.2 12max 1.2 12width (bits)
12data 64 12total 64 12manufacturer Crucial 12part-no CT16G4SFRA32A.C8FE
12serial <filter>
12Device-2 DIMM 0 12type DDR4 12detail synchronous unbuffered (unregistered)
12data 64 12total 64 12manufacturer Crucial 12part-no CT16G4SFRA32A.M16FR
12serial <filter>
12CPU:
12Info 12model AMD Ryzen 5 5600H with Radeon Graphics 12socket FP6 12bits 64
12type MT MCP 12arch Zen 3 12gen 4 12level v3 12note check 12built 2021-22
12process TSMC n7 (7nm) 12family 0x19 (25) 12model-id 0x50 (80) 12stepping 0
12microcode 0xA50000C
12Topology 12cpus 1x 12cores 6 12tpc 2 12threads 12 12smt enabled 12cache 12L1 384 KiB
12desc d-6x32 KiB; i-6x32 KiB 12L2 3 MiB 12desc 6x512 KiB 12L3 16 MiB 12desc 1x16 MiB
12Speed (MHz) 12avg 400 12min/max 400/4280 12base/boost 3300/4250 12scaling
12driver amd-pstate-epp 12governor powersave 12volts 1.2 V 12ext-clock 100 MHz 12cores
121 400 122 400 123 400 124 400 125 400 126 400 127 400 128 400 129 400 1210 400 1211 400 1212 400
12bogomips 79090
12Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
12Vulnerabilities
12Type gather_data_sampling 12status Not affected
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type mmio_stale_data 12status Not affected
12Type retbleed 12status Not affected
12Type spec_rstack_overflow 12status Vulnerable: Safe RET, no microcode
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
12Type spectre_v2 12mitigation Retpolines, IBPB: conditional, IBRS_FW, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] 12vendor Micro-Star MSI
12driver amdgpu 12v kernel 12arch RDNA-1 12code Navi-1x 12process TSMC n7 (7nm)
12built 2019-20 12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12ports 12active none
12empty HDMI-A-1 12bus-ID 03:00.0 12chip-ID 1002:7340 12class-ID 0380
12Device-2 AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
12vendor Micro-Star MSI 12driver amdgpu 12v kernel 12arch GCN-5 12code Vega
12process GF 14nm 12built 2017-20 12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12link-max
12gen 4 12speed 16 GT/s 12ports 12active eDP-1 12empty none 12bus-ID 07:00.0
12chip-ID 1002:1638 12class-ID 0300 12temp 45.0 C
12Display 12server X.org 12compositor kwin_x11 12driver 12X 12loaded amdgpu
12unloaded modesetting,radeon 12alternate fbdev,vesa 12dri radeonsi 12gpu amdgpu
12tty 80x40
12Monitor-1 eDP-1 12model ChiMei InnoLux 0x1521 12built 2020 12res 1920x1080
12dpi 142 12gamma 1.2 12size 344x193mm (13.54x7.6") 12diag 394mm (15.5") 12ratio 16:9
12modes 12max 1920x1080 12min 640x480
12API EGL 12v 1.5 12hw 12drv amd radeonsi 12platforms 12device 0 12drv radeonsi 12device 1
12drv radeonsi 12device 2 12drv swrast 12surfaceless 12drv radeonsi
12inactive gbm,wayland,x11
12API OpenGL 12v 4.6 12compat-v 4.5 12vendor mesa 12v 23.1.9-manjaro1.1
12note console (EGL sourced) 12renderer AMD Radeon RX 5500M (navi14 LLVM 16.0.6
DRM 3.54 6.6.8-2-MANJARO), AMD Radeon Graphics (renoir LLVM 16.0.6 DRM
3.54 6.6.8-2-MANJARO), llvmpipe (LLVM 16.0.6 256 bits)
12API Vulkan 12v 1.3.274 12layers N/A 12device 0 12type discrete-gpu 12name AMD Radeon
RX 5500M (RADV NAVI14) 12driver mesa radv 12v 23.1.9-manjaro1.1
12device-ID 1002:7340 12surfaces N/A 12device 1 12type integrated-gpu 12name AMD
Radeon Graphics (RADV RENOIR) 12driver mesa radv 12v 23.1.9-manjaro1.1
12device-ID 1002:1638 12surfaces N/A
12Audio:
12Device-1 AMD Navi 10 HDMI Audio 12vendor Micro-Star MSI 12driver snd_hda_intel
12v kernel 12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12bus-ID 03:00.1 12chip-ID 1002:ab38
12class-ID 0403
12Device-2 AMD Renoir Radeon High Definition Audio 12vendor Micro-Star MSI
12driver snd_hda_intel 12v kernel 12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12link-max 12gen 4
12speed 16 GT/s 12bus-ID 07:00.1 12chip-ID 1002:1637 12class-ID 0403
12Device-3 AMD ACP/ACP3X/ACP6x Audio Coprocessor 12vendor Micro-Star MSI
12driver snd_rn_pci_acp3x 12v kernel 12alternate snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh 12pcie 12gen 3
12speed 8 GT/s 12lanes 16 12link-max 12gen 4 12speed 16 GT/s 12bus-ID 07:00.5
12chip-ID 1022:15e2 12class-ID 0480
12Device-4 AMD Family 17h/19h HD Audio 12vendor Micro-Star MSI
12speed 16 GT/s 12bus-ID 07:00.6 12chip-ID 1022:15e3 12class-ID 0403
12API ALSA 12v k6.6.8-2-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
12tools alsactl,alsamixer,amixer
12Server-1 JACK 12v 1.9.22 12status off 12tools cadence,jack_control,qjackctl
12Server-2 PipeWire 12v 1.0.0 12status n/a (root, process) 12with 121 pipewire-pulse
12status active 122 wireplumber 12status active 123 pipewire-alsa 12type plugin
12tools pactl,pw-cat,pw-cli,wpctl
12Network:
12Device-1 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
12vendor Micro-Star MSI 12driver r8169 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1
12port f000 12bus-ID 04:00.0 12chip-ID 10ec:8168 12class-ID 0200
12IF enp4s0 12state down 12mac <filter>
12Device-2 Intel Wi-Fi 6 AX200 12driver iwlwifi 12v kernel 12pcie 12gen 2
12speed 5 GT/s 12lanes 1 12bus-ID 05:00.0 12chip-ID 8086:2723 12class-ID 0280
12IF wlp5s0 12state up 12mac <filter>
12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
12IP v6 <filter> 12type noprefixroute 12scope link
12WAN IP <filter>
12Bluetooth:
12Device-1 Intel AX200 Bluetooth 12driver btusb 12v 0.8 12type USB 12rev 2.0
12speed 12 Mb/s 12lanes 1 12mode 1.1 12bus-ID 3-3:3 12chip-ID 8087:0029 12class-ID e001
12Report rfkill 12ID hci0 12rfk-id 0 12state up 12address see --recommends
12Logical:
12Message No logical block device data found.
12RAID:
12Message No RAID data found.
12Drives:
12Local Storage 12total 1011.68 GiB 12used 205.53 GiB (20.3%)
12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Lexar 12model 1TB SSD 12size 953.87 GiB
12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12tech SSD
12serial <filter> 12fw-rev V1.3 12temp 41.9 C
12SMART yes 12health PASSED 12on 224d 12h 12cycles 20,796
12read-units 20,520,925 [10.5 TB] 12written-units 20,489,656 [10.4 TB]
12ID-2 /dev/sda 12maj-min 8:0 12vendor A-Data 12model USB Flash Drive
12size 57.81 GiB 12block-size 12physical 512 B 12logical 512 B 12type USB 12rev 2.1
12spd 480 Mb/s 12lanes 1 12mode 2.0 12tech SSD 12serial <filter> 12fw-rev 1100
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Message No optical or floppy data found.
12Partition:
12ID-1 / 12raw-size 418.25 GiB 12size 410.61 GiB (98.17%) 12used 205.5 GiB (50.0%)
12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p5 12maj-min 259:5 12label N/A
12uuid 11b50f05-261f-4819-a8bd-b6410dd68dd8
12ID-2 /boot/efi 12raw-size 100 MiB 12size 96 MiB (96.00%) 12used 25.4 MiB (26.4%)
12fs vfat 12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1 12label N/A
12uuid F8CB-51EF
12Swap:
12Alert No swap data was found.
12Unmounted:
12ID-1 /dev/nvme0n1p2 12maj-min 259:2 12size 16 MiB 12fs N/A 12label N/A 12uuid N/A
12ID-2 /dev/nvme0n1p3 12maj-min 259:3 12size 244.03 GiB 12fs ntfs 12label N/A
12uuid E41CAAFF1CAACC3C
12ID-3 /dev/nvme0n1p4 12maj-min 259:4 12size 290.98 GiB 12fs ntfs 12label D
12uuid B842B4FE42B4C284
12ID-4 /dev/sda1 12maj-min 8:1 12size 3.64 GiB 12fs N/A 12label MANJARO_KDE_2311
12uuid 2023-12-23-02-18-39-00
12ID-5 /dev/sda2 12maj-min 8:2 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid FA8D-326E
12USB:
12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 4 12rev 2.0
12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
12Hub-2 2-0:1 12info super-speed hub 12ports 2 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
12lanes 1 12mode 3.2 gen-2x1 12chip-ID 1d6b:0003 12class-ID 0900
12Hub-3 3-0:1 12info hi-speed hub with single TT 12ports 4 12rev 2.0
12Device-1 3-2:2 12info A-DATA ADATA USB Flash Drive 12type mass storage
12driver usb-storage 12interfaces 1 12rev 2.1 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
12mode 2.0 12power 500mA 12chip-ID 125f:db8a 12class-ID 0806 12serial <filter>
12Device-2 3-3:3 12info Intel AX200 Bluetooth 12type bluetooth 12driver btusb
12interfaces 2 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA
12Hub-4 4-0:1 12info super-speed hub 12ports 2 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
12Sensors:
12System Temperatures 12cpu 54.4 C 12mobo N/A
12Fan Speeds (rpm) N/A
12GPU 12device amdgpu 12temp 45.0 C 12device amdgpu 12temp 46.0 C 12mem 0.0 C 12fan 65535
12watts 4.00
12Info:
12Processes 372 12Uptime 5m 12wakeups 0 12Init systemd 12v 254 12default graphical
12tool systemctl 12Compilers 12gcc 13.2.1 12clang 16.0.6 12Packages 1923 12pm pacman
12pkgs 1917 12libs 424 12tools pamac,yay 12pm flatpak 12pkgs 6
12Client Unknown Client: systemd 12inxi 3.3.31
