Hi there,
I have a small issue. After losing my home partition, I created a new partition, copied the files from my timeshift snapshot to the new partition and changed the UUID in /etc/fstab. Of course I also reinstalled grub, but it somehow still pointed to the wrong partition, that’s why a un-commented this:
GRUB_DISABLE_LINUX_UUID="true"
in /etc/default/grub.
Currently I’m able to boot manjaro and the login screen pops up, though after logging in nothing happens. I can still move the mouse and also open tty. When using startx following message appears:
X.Org X Server 1.21.1.8
Current Operating System: Linux Manji-home 6.1.31-1-MANJARO #1 SMP PREEMPT_DYNAMIC Tue May 30 23:14:35 UTC 2023 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=/dev/sdd3 rw quiet nowatchdog apparmor=1 security=apparmor resume=UUID=6697a587-6eda-4f18-88a9-1ba83fc20b33 udev.log_priority=3
Current version of pixman: 0.42.2
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.1.log", Time: Sun Jun 4 16:33:25 2023
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Failed to connect to bus: Operation not permitted
dbus-update-activation-environment: error: unable to connect to D-Bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
/etc/X11/xinit/xinitrc: line 52: xclock: command not found
/etc/X11/xinit/xinitrc: line 53: xterm: command not found
/etc/X11/xinit/xinitrc: line 55: exec: xterm: not found
/etc/X11/xinit/xinitrc: line 54: xterm: command not found
xinit: connection to X server lost
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
You can find the output of journalctl -p 3 -xb here and the log file /var/log/Xorg.1.log here
If you need further information, please let me know.
EDIT: Two more things:
- I tried to add a new user to make sure that it’s not my user account that is bugged or something. Unfortunately it still results in a black screen
- I noticed when reinstalling grub that they released a big update for the stable branch today, maybe that broke something in my system ?
