file:/var/log/Xorg.0.log
[ 9.482] (--) Log file renamed from "/var/log/Xorg.pid-1047.log" to "/var/log/Xorg.0.log"
[ 9.483]
X.Org X Server 1.21.1.13
[ 9.483] Current Operating System: Linux ling-20ym 6.1.90-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri May 3 05:13:01 UTC 2024 x86_64
[ 9.483] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=c88f5257-3476-44bc-8d68-fde2b5aceff8 rw processor.max_cstate=5 idle=nomwait quiet splash udev.log_priority=3
[ 9.483]
[ 9.483] Current version of pixman: 0.43.4
[ 9.483] Before reporting problems, check http://wiki.x.org
[ 9.483] Markers: (--) probed, (**) from config file, (==) default setting,
[ 9.483] (==) Log file: "/var/log/Xorg.0.log", Time: Sat May 18 13:07:30 2024
[ 9.485] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 9.485] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 9.486] (==) ServerLayout "layout"
[ 9.486] (**) |-->Screen "integrated" (0)
[ 9.486] (**) | |-->Monitor "<default monitor>"
[ 9.486] (**) | |-->Device "integrated"
[ 9.487] (**) | |-->GPUDevice "nvidia"
[ 9.487] (==) No monitor specified for screen "integrated".
[ 9.487] (**) Allowing byte-swapped clients
[ 9.487] (==) Automatically adding devices
[ 9.487] (==) Automatically enabling devices
[ 9.487] (==) Automatically adding GPU devices
[ 9.487] (==) Automatically binding GPU devices
[ 9.487] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 9.487] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 9.487] Entry deleted from font path.
[ 9.487] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 9.487] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 9.487] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 9.487] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 9.487] (**) ModulePath set to "/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 9.487] (II) The server relies on udev to provide the list of input devices.
[ 9.487] (II) Module ABI versions:
[ 9.487] X.Org ANSI C Emulation: 0.4
[ 9.487] X.Org Video Driver: 25.2
[ 9.487] X.Org XInput driver : 24.4
[ 9.487] X.Org Server Extension : 10.0
[ 9.488] (++) using VT number 2
[ 9.488] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 9.489] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 9.489] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card1
[ 9.549] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 9.549] (II) Platform probe for /sys/devices/pci0000:00/0000:00:08.1/0000:06:00.0/drm/card0
[ 9.571] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 9.571] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 9.573] (--) PCI: (1@0:0:0) 10de:2520:17aa:3801 rev 161, Mem @ 0xfc000000/16777216, 0x800000000/8589934592, 0xa00000000/33554432, I/O @ 0x00002000/128, BIOS @ 0x????????/524288
[ 9.573] (--) PCI:*(6@0:0:0) 1002:1638:17aa:3804 rev 197, Mem @ 0xa10000000/268435456, 0xa20000000/2097152, 0xfd400000/524288, I/O @ 0x00001000/256
[ 9.573] (II) Open ACPI successful (/var/run/acpid.socket)
[ 9.573] (II) LoadModule: "glx"
[ 9.574] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 9.579] (II) Module glx: vendor="X.Org Foundation"
[ 9.579] compiled for 1.21.1.13, module version = 1.0.0
[ 9.579] ABI class: X.Org Server Extension, version 10.0
[ 9.579] (II) LoadModule: "modesetting"
[ 9.579] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 9.581] (II) Module modesetting: vendor="X.Org Foundation"
[ 9.581] compiled for 1.21.1.13, module version = 1.21.1
[ 9.581] Module class: X.Org Video Driver
[ 9.581] ABI class: X.Org Video Driver, version 25.2
[ 9.581] (II) LoadModule: "nvidia"
[ 9.581] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 9.584] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 9.584] compiled for 1.6.99.901, module version = 1.0.0
[ 9.584] Module class: X.Org Video Driver
[ 9.584] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 9.584] (II) NVIDIA dlloader X Driver 470.239.06 Sat Feb 3 06:10:11 UTC 2024
[ 9.584] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 9.636] (II) modeset(0): using drv /dev/dri/card0
[ 9.637] (II) Loading sub module "fb"
[ 9.637] (II) LoadModule: "fb"
[ 9.637] (II) Module "fb" already built-in
[ 9.637] (II) Loading sub module "wfb"
[ 9.637] (II) LoadModule: "wfb"
[ 9.637] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 9.638] (II) Module wfb: vendor="X.Org Foundation"
[ 9.638] compiled for 1.21.1.13, module version = 1.0.0
[ 9.638] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.638] (II) Loading sub module "ramdac"
[ 9.638] (II) LoadModule: "ramdac"
[ 9.638] (II) Module "ramdac" already built-in
[ 9.639] (II) modeset(0): Creating default Display subsection in Screen section
"integrated" for depth/fbbpp 24/32
[ 9.639] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 9.639] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card0
[ 9.639] (==) modeset(0): RGB weight 888
[ 9.639] (==) modeset(0): Default visual is TrueColor
[ 9.639] (II) Loading sub module "glamoregl"
[ 9.639] (II) LoadModule: "glamoregl"
[ 9.639] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 9.644] (II) Module glamoregl: vendor="X.Org Foundation"
[ 9.644] compiled for 1.21.1.13, module version = 1.0.1
[ 9.644] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.796] (II) modeset(0): glamor X acceleration enabled on AMD Radeon Graphics (radeonsi, renoir, LLVM 17.0.6, DRM 3.49, 6.1.90-1-MANJARO)
[ 9.796] (II) modeset(0): glamor initialized
[ 9.796] (==) modeset(0): VariableRefresh: disabled
[ 9.796] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 9.799] (II) modeset(0): Output eDP-1 has no monitor section
[ 9.799] (II) modeset(0): Output DP-1 has no monitor section
[ 9.799] (II) modeset(0): Output DP-2 has no monitor section
[ 9.801] (II) modeset(0): EDID for output eDP-1
[ 9.801] (II) modeset(0): Manufacturer: CSO Model: 1603 Serial#: 0
[ 9.801] (II) modeset(0): Year: 2020 Week: 0
[ 9.801] (II) modeset(0): EDID Version: 1.4
[ 9.801] (II) modeset(0): Digital Display Input
[ 9.801] (II) modeset(0): 8 bits per channel
[ 9.801] (II) modeset(0): Digital interface is DisplayPort
[ 9.801] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 22
[ 9.801] (II) modeset(0): Gamma: 2.20
[ 9.801] (II) modeset(0): No DPMS capabilities specified
[ 9.801] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 9.801] (II) modeset(0): First detailed timing is preferred mode
[ 9.801] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 9.801] (II) modeset(0): Display is continuous-frequency
[ 9.801] (II) modeset(0): redX: 0.646 redY: 0.327 greenX: 0.293 greenY: 0.595
[ 9.801] (II) modeset(0): blueX: 0.137 blueY: 0.063 whiteX: 0.316 whiteY: 0.329
[ 9.801] (II) modeset(0): Manufacturer's mask: 0
[ 9.801] (II) modeset(0): Supported detailed timing:
[ 9.801] (II) modeset(0): clock: 268.6 MHz Image Size: 344 x 215 mm
[ 9.801] (II) modeset(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 9.801] (II) modeset(0): v_active: 1600 v_sync: 1603 v_sync_end 1609 v_blanking: 1646 v_border: 0
[ 9.802] (II) modeset(0): Ranges: V min: 40 V max: 60 Hz, H min: 99 H max: 99 kHz, PixClock max 275 MHz
[ 9.802] (II) modeset(0): CSOT T3
[ 9.802] (II) modeset(0): MNG007DA1-4
[ 9.802] (II) modeset(0): EDID (in hex):
[ 9.802] (II) modeset(0): 00ffffffffffff000e6f031600000000
[ 9.802] (II) modeset(0): 001e0104a522167803b111a5534b9823
[ 9.802] (II) modeset(0): 10515400000001010101010101010101
[ 9.802] (II) modeset(0): 010101010101ef6800a0a0402e603020
[ 9.802] (II) modeset(0): 360058d710000018000000fd00283c63
[ 9.802] (II) modeset(0): 631b010a202020202020000000fe0043
[ 9.802] (II) modeset(0): 534f542054330a2020202020000000fe
[ 9.802] (II) modeset(0): 004d4e473030374441312d340a2000e1
[ 9.802] (II) modeset(0): Not using default mode "2560x1440" (bad mode clock/interlace/doublescan)
[ 9.802] (II) modeset(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[ 9.802] (II) modeset(0): Not using default mode "2048x1152" (bad mode clock/interlace/doublescan)
[ 9.802] (II) modeset(0): Not using default mode "2560x1600" (bad mode clock/interlace/doublescan)
[ 9.802] (II) modeset(0): Printing probed modes for output eDP-1
[ 9.802] (II) modeset(0): Modeline "2560x1600"x60.0 268.63 2560 2608 2640 2720 1600 1603 1609 1646 -hsync -vsync (98.8 kHz eP)
[ 9.802] (II) modeset(0): Modeline "2560x1600"x50.0 268.63 2560 2608 2640 2720 1600 1932 1938 1975 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "2560x1600"x48.0 268.63 2560 2608 2640 2720 1600 2014 2020 2057 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "2560x1600"x60.0 268.50 2560 2608 2640 2720 1600 1603 1609 1646 +hsync -vsync (98.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz d)
[ 9.802] (II) modeset(0): Modeline "2048x1536"x60.0 266.95 2048 2200 2424 2800 1536 1537 1540 1589 -hsync +vsync (95.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "1920x1440"x60.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "1856x1392"x60.0 218.30 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.4 kHz d)
[ 9.802] (II) modeset(0): Modeline "1792x1344"x60.0 204.80 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "2048x1152"x59.9 197.00 2048 2184 2400 2752 1152 1155 1160 1195 -hsync +vsync (71.6 kHz d)
[ 9.802] (II) modeset(0): Modeline "2048x1152"x59.9 156.75 2048 2096 2128 2208 1152 1155 1160 1185 +hsync -vsync (71.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "1920x1200"x60.0 268.63 1920 2608 2640 2720 1200 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz d)
[ 9.802] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "1920x1080"x60.0 268.63 1920 2608 2640 2720 1080 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "1920x1080"x60.0 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 9.802] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 9.802] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 9.802] (II) modeset(0): Modeline "1600x1200"x60.0 268.63 1600 2608 2640 2720 1200 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "1680x1050"x60.0 268.63 1680 2608 2640 2720 1050 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 9.802] (II) modeset(0): Modeline "1600x900"x60.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 9.802] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 9.802] (II) modeset(0): Modeline "1280x1024"x60.0 268.63 1280 2608 2640 2720 1024 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "1440x900"x60.0 268.63 1440 2608 2640 2720 900 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 9.802] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 9.802] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 9.802] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "1280x800"x60.0 268.63 1280 2608 2640 2720 800 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 9.802] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "1280x720"x60.0 268.63 1280 2608 2640 2720 720 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 9.802] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 9.802] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 9.802] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "1024x768"x60.0 268.63 1024 2608 2640 2720 768 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 9.802] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 9.802] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 9.802] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 9.802] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 9.802] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 9.802] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 9.802] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 9.802] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 9.802] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "800x600"x60.0 268.63 800 2608 2640 2720 600 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 9.802] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 9.802] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 9.802] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 9.802] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 9.802] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 9.802] (II) modeset(0): Modeline "640x480"x60.0 268.63 640 2608 2640 2720 480 1603 1609 1646 -hsync -vsync (98.8 kHz e)
[ 9.802] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 9.802] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 9.802] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 9.802] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 9.802] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 9.802] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 9.802] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 9.802] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 9.802] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 9.802] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 9.802] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 9.802] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 9.802] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 9.802] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 9.802] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 9.802] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 9.802] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 9.802] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 9.802] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 9.802] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 9.802] (II) modeset(0): EDID for output DP-1
[ 9.802] (II) modeset(0): EDID for output DP-2
[ 9.802] (II) modeset(0): Output eDP-1 connected
[ 9.802] (II) modeset(0): Output DP-1 disconnected
[ 9.802] (II) modeset(0): Output DP-2 disconnected
[ 9.802] (II) modeset(0): Using exact sizes for initial modes
[ 9.802] (II) modeset(0): Output eDP-1 using initial mode 2560x1600 +0+0
[ 9.803] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 9.803] (==) modeset(0): DPI set to (96, 96)
[ 9.803] (II) Loading sub module "fb"
[ 9.803] (II) LoadModule: "fb"
[ 9.803] (II) Module "fb" already built-in
[ 9.803] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[ 9.803] (==) NVIDIA(G0): RGB weight 888
[ 9.803] (==) NVIDIA(G0): Default visual is TrueColor
[ 9.803] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 9.803] (**) Option "AllowNVIDIAGpuScreens"
[ 9.803] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 9.803] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[ 9.803] (**) NVIDIA(G0): Option "Coolbits" "28"
[ 9.803] (**) NVIDIA(G0): Enabling 2D acceleration
[ 9.803] (II) Loading sub module "glxserver_nvidia"
[ 9.803] (II) LoadModule: "glxserver_nvidia"
[ 9.803] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 9.828] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 9.828] compiled for 1.6.99.901, module version = 1.0.0
[ 9.828] Module class: X.Org Server Extension
[ 9.828] (II) NVIDIA GLX Module 470.239.06 Sat Feb 3 06:08:41 UTC 2024
[ 9.829] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 9.830] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 9.830] (--) NVIDIA(0): DFP-0 (boot)
[ 9.830] (--) NVIDIA(0): DFP-1
[ 9.830] (--) NVIDIA(0): DFP-2
[ 9.830] (--) NVIDIA(0): DFP-3
[ 9.830] (--) NVIDIA(0): DFP-4
[ 9.831] (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce RTX 3060 Laptop GPU (GA106-A) at
[ 9.831] (II) NVIDIA(G0): PCI:1:0:0 (GPU-0)
[ 9.831] (--) NVIDIA(G0): Memory: 6291456 kBytes
[ 9.831] (--) NVIDIA(G0): VideoBIOS: 94.06.19.00.3e
[ 9.831] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[ 9.831] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): connected
[ 9.831] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): Internal DisplayPort
[ 9.831] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): 2670.0 MHz maximum pixel clock
[ 9.835] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 9.835] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 9.835] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 9.835] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.835] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.835] (--) NVIDIA(GPU-0): DFP-2: 2670.0 MHz maximum pixel clock
[ 9.835] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.835] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.835] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.835] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 9.835] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 9.835] (--) NVIDIA(GPU-0): DFP-4: 2670.0 MHz maximum pixel clock
[ 9.860] (II) NVIDIA(G0): Validated MetaModes:
[ 9.860] (II) NVIDIA(G0): "NULL"
[ 9.860] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[ 9.919] (WW) NVIDIA(G0): Cannot find size of first mode for XMI P27QBB-RA (DFP-0);
[ 9.919] (WW) NVIDIA(G0): cannot compute DPI from XMI P27QBB-RA (DFP-0)'s EDID.
[ 9.919] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[ 9.975] (==) modeset(0): Backing store enabled
[ 9.975] (==) modeset(0): Silken mouse enabled
[ 9.976] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 9.976] (==) modeset(0): DPMS enabled
[ 9.976] (WW) modeset(0): Option "HotplugDriver" is not used
[ 9.976] (WW) modeset(0): Option "DRI" is not used
[ 9.976] (II) modeset(0): [DRI2] Setup complete
[ 9.976] (II) modeset(0): [DRI2] DRI driver: radeonsi
[ 9.976] (II) modeset(0): [DRI2] VDPAU driver: radeonsi
[ 9.976] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 9.976] (II) NVIDIA: access.
[ 10.003] (II) NVIDIA(G0): Setting mode "NULL"
[ 10.013] (==) NVIDIA(G0): Disabling shared memory pixmaps
[ 10.013] (==) NVIDIA(G0): Backing store enabled
[ 10.013] (==) NVIDIA(G0): Silken mouse enabled
[ 10.013] (==) NVIDIA(G0): DPMS enabled
[ 10.013] (II) Loading sub module "dri2"
[ 10.013] (II) LoadModule: "dri2"
[ 10.013] (II) Module "dri2" already built-in
[ 10.013] (II) NVIDIA(G0): [DRI2] Setup complete
[ 10.013] (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
[ 10.013] (II) Initializing extension Generic Event Extension
[ 10.013] (II) Initializing extension SHAPE
[ 10.013] (II) Initializing extension MIT-SHM
[ 10.014] (II) Initializing extension XInputExtension
[ 10.014] (II) Initializing extension XTEST
[ 10.014] (II) Initializing extension BIG-REQUESTS
[ 10.014] (II) Initializing extension SYNC
[ 10.014] (II) Initializing extension XKEYBOARD
[ 10.014] (II) Initializing extension XC-MISC
[ 10.014] (II) Initializing extension SECURITY
[ 10.014] (II) Initializing extension XFIXES
[ 10.014] (II) Initializing extension RENDER
[ 10.014] (II) Initializing extension RANDR
[ 10.014] (II) Initializing extension COMPOSITE
[ 10.014] (II) Initializing extension DAMAGE
[ 10.014] (II) Initializing extension MIT-SCREEN-SAVER
[ 10.015] (II) Initializing extension DOUBLE-BUFFER
[ 10.015] (II) Initializing extension RECORD
[ 10.015] (II) Initializing extension DPMS
[ 10.015] (II) Initializing extension Present
[ 10.015] (II) Initializing extension DRI3
[ 10.015] (II) Initializing extension X-Resource
[ 10.015] (II) Initializing extension XVideo
[ 10.015] (II) Initializing extension XVideo-MotionCompensation
[ 10.015] (II) Initializing extension GLX
[ 10.015] (II) Indirect GLX disabled.
[ 10.019] (II) AIGLX: Loaded and initialized radeonsi
[ 10.019] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 10.019] (II) Initializing extension XFree86-VidModeExtension
[ 10.019] (II) Initializing extension XFree86-DGA
[ 10.019] (II) Initializing extension XFree86-DRI
[ 10.019] (II) Initializing extension DRI2
[ 10.019] (II) Initializing extension NV-GLX
[ 10.019] (II) Initializing extension NV-CONTROL
[ 10.020] (II) modeset(0): Damage tracking initialized
[ 10.020] (II) modeset(0): Setting screen physical size to 677 x 423
[ 10.084] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[ 10.084] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 10.084] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 10.084] (**) Video Bus: Applying InputClass "system-keyboard"
[ 10.084] (II) LoadModule: "libinput"
[ 10.084] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 10.086] (II) Module libinput: vendor="X.Org Foundation"
[ 10.087] compiled for 1.21.1.8, module version = 1.4.0
[ 10.087] Module class: X.Org XInput Driver
[ 10.087] ABI class: X.Org XInput driver, version 24.4
[ 10.087] (II) Using input driver 'libinput' for 'Video Bus'
[ 10.087] (**) Video Bus: always reports core events
[ 10.087] (**) Option "Device" "/dev/input/event3"
[ 10.093] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 10.093] (II) event3 - Video Bus: device is a keyboard
[ 10.093] (II) event3 - Video Bus: device removed
[ 10.130] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input3/event3"
[ 10.130] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 10.130] (**) Option "xkb_layout" "cn"
[ 10.145] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 10.145] (II) event3 - Video Bus: device is a keyboard
[ 10.146] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[ 10.146] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 10.146] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 10.146] (**) Video Bus: Applying InputClass "system-keyboard"
[ 10.146] (II) Using input driver 'libinput' for 'Video Bus'
[ 10.146] (**) Video Bus: always reports core events
[ 10.146] (**) Option "Device" "/dev/input/event4"
[ 10.147] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 10.147] (II) event4 - Video Bus: device is a keyboard
[ 10.147] (II) event4 - Video Bus: device removed
[ 10.183] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:10/LNXVIDEO:01/input/input4/event4"
[ 10.183] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 10.183] (**) Option "xkb_layout" "cn"
[ 10.184] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 10.184] (II) event4 - Video Bus: device is a keyboard
[ 10.185] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 10.185] (II) No input driver specified, ignoring this device.
[ 10.185] (II) This device may have been added with another device file.
[ 10.185] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 10.185] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 10.185] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 10.185] (**) Power Button: Applying InputClass "system-keyboard"
[ 10.185] (II) Using input driver 'libinput' for 'Power Button'
[ 10.185] (**) Power Button: always reports core events
[ 10.185] (**) Option "Device" "/dev/input/event0"
[ 10.186] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 10.186] (II) event0 - Power Button: device is a keyboard
[ 10.186] (II) event0 - Power Button: device removed
[ 10.216] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 10.216] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 10.216] (**) Option "xkb_layout" "cn"
[ 10.217] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 10.217] (II) event0 - Power Button: device is a keyboard
[ 10.218] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[ 10.218] (II) No input driver specified, ignoring this device.
[ 10.218] (II) This device may have been added with another device file.
[ 10.218] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[ 10.219] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[ 10.219] (II) No input driver specified, ignoring this device.
[ 10.219] (II) This device may have been added with another device file.
[ 10.219] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[ 10.220] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event15)
[ 10.220] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 10.220] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
[ 10.220] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 10.220] (**) Logitech USB Receiver: always reports core events
[ 10.220] (**) Option "Device" "/dev/input/event15"
[ 10.281] (II) event15 - Logitech USB Receiver: is tagged by udev as: Mouse
[ 10.281] (II) event15 - Logitech USB Receiver: device is a pointer
[ 10.281] (II) event15 - Logitech USB Receiver: device removed
[ 10.333] (II) libinput: Logitech USB Receiver: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 10.333] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb1/1-2/1-2.4/1-2.4:1.0/0003:046D:C547.0003/input/input21/event15"
[ 10.333] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 9)
[ 10.333] (**) Option "AccelerationScheme" "none"
[ 10.333] (**) Logitech USB Receiver: (accel) selected scheme none/0
[ 10.333] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 10.333] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 10.391] (II) event15 - Logitech USB Receiver: is tagged by udev as: Mouse
[ 10.391] (II) event15 - Logitech USB Receiver: device is a pointer
[ 10.392] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse2)
[ 10.392] (II) No input driver specified, ignoring this device.
[ 10.392] (II) This device may have been added with another device file.
[ 10.393] (II) config/udev: Adding input device Logitech USB Receiver Keyboard (/dev/input/event16)
[ 10.393] (**) Logitech USB Receiver Keyboard: Applying InputClass "evdev keyboard catchall"
[ 10.393] (**) Logitech USB Receiver Keyboard: Applying InputClass "libinput keyboard catchall"
[ 10.393] (**) Logitech USB Receiver Keyboard: Applying InputClass "system-keyboard"
[ 10.393] (II) Using input driver 'libinput' for 'Logitech USB Receiver Keyboard'
[ 10.393] (**) Logitech USB Receiver Keyboard: always reports core events
[ 10.393] (**) Option "Device" "/dev/input/event16"
[ 10.395] (II) event16 - Logitech USB Receiver Keyboard: is tagged by udev as: Keyboard
[ 10.395] (II) event16 - Logitech USB Receiver Keyboard: device is a keyboard
[ 10.395] (II) event16 - Logitech USB Receiver Keyboard: device removed
[ 10.413] (II) libinput: Logitech USB Receiver Keyboard: needs a virtual subdevice
[ 10.413] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb1/1-2/1-2.4/1-2.4:1.1/0003:046D:C547.0004/input/input22/event16"
[ 10.413] (II) XINPUT: Adding extended input device "Logitech USB Receiver Keyboard" (type: MOUSE, id 10)
[ 10.413] (**) Option "AccelerationScheme" "none"
[ 10.413] (**) Logitech USB Receiver Keyboard: (accel) selected scheme none/0
[ 10.413] (**) Logitech USB Receiver Keyboard: (accel) acceleration factor: 2.000
[ 10.413] (**) Logitech USB Receiver Keyboard: (accel) acceleration threshold: 4
[ 10.415] (II) event16 - Logitech USB Receiver Keyboard: is tagged by udev as: Keyboard
[ 10.415] (II) event16 - Logitech USB Receiver Keyboard: device is a keyboard
[ 10.416] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event19)
[ 10.416] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[ 10.416] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[ 10.416] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[ 10.416] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[ 10.416] (**) Integrated Camera: Integrated C: always reports core events
[ 10.416] (**) Option "Device" "/dev/input/event19"
[ 10.417] (II) event19 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 10.417] (II) event19 - Integrated Camera: Integrated C: device is a keyboard
[ 10.417] (II) event19 - Integrated Camera: Integrated C: device removed
[ 10.470] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb3/3-3/3-3:1.0/input/input23/event19"
[ 10.470] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 11)
[ 10.470] (**) Option "xkb_layout" "cn"
[ 10.471] (II) event19 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 10.471] (II) event19 - Integrated Camera: Integrated C: device is a keyboard
[ 10.472] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8296) Keyboard (/dev/input/event13)
[ 10.472] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: Applying InputClass "evdev keyboard catchall"
[ 10.472] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: Applying InputClass "libinput keyboard catchall"
[ 10.472] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: Applying InputClass "system-keyboard"
[ 10.472] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8296) Keyboard'
[ 10.472] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: always reports core events
[ 10.472] (**) Option "Device" "/dev/input/event13"
[ 10.473] (II) event13 - ITE Tech. Inc. ITE Device(8296) Keyboard: is tagged by udev as: Keyboard
[ 10.473] (II) event13 - ITE Tech. Inc. ITE Device(8296) Keyboard: device is a keyboard
[ 10.473] (II) event13 - ITE Tech. Inc. ITE Device(8296) Keyboard: device removed
[ 10.533] (II) libinput: ITE Tech. Inc. ITE Device(8296) Keyboard: needs a virtual subdevice
[ 10.533] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb3/3-4/3-4:1.0/0003:048D:C916.0002/input/input17/event13"
[ 10.533] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8296) Keyboard" (type: MOUSE, id 12)
[ 10.533] (**) Option "AccelerationScheme" "none"
[ 10.533] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: (accel) selected scheme none/0
[ 10.533] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: (accel) acceleration factor: 2.000
[ 10.533] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: (accel) acceleration threshold: 4
[ 10.534] (II) event13 - ITE Tech. Inc. ITE Device(8296) Keyboard: is tagged by udev as: Keyboard
[ 10.534] (II) event13 - ITE Tech. Inc. ITE Device(8296) Keyboard: device is a keyboard
[ 10.535] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8296) Wireless Radio Control (/dev/input/event14)
[ 10.535] (**) ITE Tech. Inc. ITE Device(8296) Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[ 10.535] (**) ITE Tech. Inc. ITE Device(8296) Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[ 10.535] (**) ITE Tech. Inc. ITE Device(8296) Wireless Radio Control: Applying InputClass "system-keyboard"
[ 10.535] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8296) Wireless Radio Control'
[ 10.535] (**) ITE Tech. Inc. ITE Device(8296) Wireless Radio Control: always reports core events
[ 10.535] (**) Option "Device" "/dev/input/event14"
[ 10.537] (II) event14 - ITE Tech. Inc. ITE Device(8296) Wireless Radio Control: is tagged by udev as: Keyboard
[ 10.537] (II) event14 - ITE Tech. Inc. ITE Device(8296) Wireless Radio Control: device is a keyboard
[ 10.537] (II) event14 - ITE Tech. Inc. ITE Device(8296) Wireless Radio Control: device removed
[ 10.596] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb3/3-4/3-4:1.0/0003:048D:C916.0002/input/input18/event14"
[ 10.596] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8296) Wireless Radio Control" (type: KEYBOARD, id 13)
[ 10.596] (**) Option "xkb_layout" "cn"
[ 10.599] (II) event14 - ITE Tech. Inc. ITE Device(8296) Wireless Radio Control: is tagged by udev as: Keyboard
[ 10.599] (II) event14 - ITE Tech. Inc. ITE Device(8296) Wireless Radio Control: device is a keyboard
[ 10.600] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event17)
[ 10.600] (II) No input driver specified, ignoring this device.
[ 10.600] (II) This device may have been added with another device file.
[ 10.600] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event18)
[ 10.601] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event6)
[ 10.601] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[ 10.601] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[ 10.601] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[ 10.601] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[ 10.601] (**) Ideapad extra buttons: always reports core events
[ 10.601] (**) Option "Device" "/dev/input/event6"
[ 10.602] (II) event6 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 10.602] (II) event6 - Ideapad extra buttons: device is a keyboard
[ 10.602] (II) event6 - Ideapad extra buttons: device removed
[ 10.643] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input9/event6"
[ 10.643] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 14)
[ 10.643] (**) Option "xkb_layout" "cn"
[ 10.644] (II) event6 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 10.644] (II) event6 - Ideapad extra buttons: device is a keyboard
[ 10.645] (II) config/udev: Adding input device SYNA2BA6:00 06CB:CE44 Mouse (/dev/input/event7)
[ 10.645] (**) SYNA2BA6:00 06CB:CE44 Mouse: Applying InputClass "evdev pointer catchall"
[ 10.645] (**) SYNA2BA6:00 06CB:CE44 Mouse: Applying InputClass "libinput pointer catchall"
[ 10.645] (II) Using input driver 'libinput' for 'SYNA2BA6:00 06CB:CE44 Mouse'
[ 10.645] (**) SYNA2BA6:00 06CB:CE44 Mouse: always reports core events
[ 10.645] (**) Option "Device" "/dev/input/event7"
[ 10.646] (II) event7 - SYNA2BA6:00 06CB:CE44 Mouse: is tagged by udev as: Mouse Pointingstick
[ 10.646] (II) event7 - SYNA2BA6:00 06CB:CE44 Mouse: device is a pointer
[ 10.647] (II) event7 - SYNA2BA6:00 06CB:CE44 Mouse: device removed
[ 10.693] (II) libinput: SYNA2BA6:00 06CB:CE44 Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 10.693] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-SYNA2BA6:00/0018:06CB:CE44.0001/input/input10/event7"
[ 10.693] (II) XINPUT: Adding extended input device "SYNA2BA6:00 06CB:CE44 Mouse" (type: MOUSE, id 15)
[ 10.693] (**) Option "AccelerationScheme" "none"
[ 10.693] (**) SYNA2BA6:00 06CB:CE44 Mouse: (accel) selected scheme none/0
[ 10.693] (**) SYNA2BA6:00 06CB:CE44 Mouse: (accel) acceleration factor: 2.000
[ 10.693] (**) SYNA2BA6:00 06CB:CE44 Mouse: (accel) acceleration threshold: 4
[ 10.694] (II) event7 - SYNA2BA6:00 06CB:CE44 Mouse: is tagged by udev as: Mouse Pointingstick
[ 10.694] (II) event7 - SYNA2BA6:00 06CB:CE44 Mouse: device is a pointer
[ 10.696] (II) config/udev: Adding input device SYNA2BA6:00 06CB:CE44 Mouse (/dev/input/mouse0)
[ 10.696] (II) No input driver specified, ignoring this device.
[ 10.696] (II) This device may have been added with another device file.
[ 10.696] (II) config/udev: Adding input device SYNA2BA6:00 06CB:CE44 Touchpad (/dev/input/event8)
[ 10.696] (**) SYNA2BA6:00 06CB:CE44 Touchpad: Applying InputClass "evdev touchpad catchall"
[ 10.696] (**) SYNA2BA6:00 06CB:CE44 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 10.696] (**) SYNA2BA6:00 06CB:CE44 Touchpad: Applying InputClass "touchpad"
[ 10.696] (II) Using input driver 'libinput' for 'SYNA2BA6:00 06CB:CE44 Touchpad'
[ 10.696] (**) SYNA2BA6:00 06CB:CE44 Touchpad: always reports core events
[ 10.696] (**) Option "Device" "/dev/input/event8"
[ 10.697] (II) event8 - SYNA2BA6:00 06CB:CE44 Touchpad: is tagged by udev as: Touchpad
[ 10.699] (II) event8 - SYNA2BA6:00 06CB:CE44 Touchpad: device is a touchpad
[ 10.699] (II) event8 - SYNA2BA6:00 06CB:CE44 Touchpad: device removed
[ 10.776] (**) Option "Tapping" "on"
[ 10.776] (II) libinput: SYNA2BA6:00 06CB:CE44 Touchpad: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 10.777] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-SYNA2BA6:00/0018:06CB:CE44.0001/input/input11/event8"
[ 10.777] (II) XINPUT: Adding extended input device "SYNA2BA6:00 06CB:CE44 Touchpad" (type: TOUCHPAD, id 16)
[ 10.778] (**) Option "AccelerationScheme" "none"
[ 10.778] (**) SYNA2BA6:00 06CB:CE44 Touchpad: (accel) selected scheme none/0
[ 10.778] (**) SYNA2BA6:00 06CB:CE44 Touchpad: (accel) acceleration factor: 2.000
[ 10.778] (**) SYNA2BA6:00 06CB:CE44 Touchpad: (accel) acceleration threshold: 4
[ 10.779] (II) event8 - SYNA2BA6:00 06CB:CE44 Touchpad: is tagged by udev as: Touchpad
[ 10.781] (II) event8 - SYNA2BA6:00 06CB:CE44 Touchpad: device is a touchpad
[ 10.781] (II) config/udev: Adding input device SYNA2BA6:00 06CB:CE44 Touchpad (/dev/input/mouse1)
[ 10.781] (**) SYNA2BA6:00 06CB:CE44 Touchpad: Applying InputClass "touchpad"
[ 10.781] (II) Using input driver 'libinput' for 'SYNA2BA6:00 06CB:CE44 Touchpad'
[ 10.781] (**) SYNA2BA6:00 06CB:CE44 Touchpad: always reports core events
[ 10.781] (**) Option "Device" "/dev/input/mouse1"
[ 10.840] (II) mouse1 - not using input device '/dev/input/mouse1'.
[ 10.840] (EE) libinput: SYNA2BA6:00 06CB:CE44 Touchpad: Failed to create a device for /dev/input/mouse1
[ 10.840] (EE) PreInit returned 2 for "SYNA2BA6:00 06CB:CE44 Touchpad"
[ 10.840] (II) UnloadModule: "libinput"
[ 10.840] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 10.840] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 10.840] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 10.840] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 10.840] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 10.840] (**) AT Translated Set 2 keyboard: always reports core events
[ 10.840] (**) Option "Device" "/dev/input/event2"
[ 10.841] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 10.841] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 10.842] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 10.860] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 10.860] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 17)
[ 10.860] (**) Option "xkb_layout" "cn"
[ 10.861] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 10.861] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 10.862] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 10.862] (II) No input driver specified, ignoring this device.
[ 10.862] (II) This device may have been added with another device file.
[ 10.890] (**) Logitech USB Receiver Keyboard: Applying InputClass "evdev keyboard catchall"
[ 10.890] (**) Logitech USB Receiver Keyboard: Applying InputClass "libinput keyboard catchall"
[ 10.890] (**) Logitech USB Receiver Keyboard: Applying InputClass "system-keyboard"
[ 10.890] (II) Using input driver 'libinput' for 'Logitech USB Receiver Keyboard'
[ 10.890] (**) Logitech USB Receiver Keyboard: always reports core events
[ 10.890] (**) Option "Device" "/dev/input/event16"
[ 10.890] (II) libinput: Logitech USB Receiver Keyboard: is a virtual subdevice
[ 10.890] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb1/1-2/1-2.4/1-2.4:1.1/0003:046D:C547.0004/input/input22/event16"
[ 10.890] (II) XINPUT: Adding extended input device "Logitech USB Receiver Keyboard" (type: KEYBOARD, id 18)
[ 10.890] (**) Option "xkb_layout" "cn"
[ 10.891] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: Applying InputClass "evdev keyboard catchall"
[ 10.891] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: Applying InputClass "libinput keyboard catchall"
[ 10.891] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: Applying InputClass "system-keyboard"
[ 10.891] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8296) Keyboard'
[ 10.891] (**) ITE Tech. Inc. ITE Device(8296) Keyboard: always reports core events
[ 10.891] (**) Option "Device" "/dev/input/event13"
[ 10.891] (II) libinput: ITE Tech. Inc. ITE Device(8296) Keyboard: is a virtual subdevice
[ 10.891] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb3/3-4/3-4:1.0/0003:048D:C916.0002/input/input17/event13"
[ 10.891] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8296) Keyboard" (type: KEYBOARD, id 19)
[ 10.891] (**) Option "xkb_layout" "cn"
[ 11.252] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 11.252] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 11.252] (--) NVIDIA(GPU-0): DFP-0: 2670.0 MHz maximum pixel clock
[ 11.257] (II) modeset(0): EDID vendor "CSO", prod id 5635
[ 11.257] (II) modeset(0): Using EDID range info for horizontal sync
[ 11.257] (II) modeset(0): Using EDID range info for vertical refresh
[ 11.257] (II) modeset(0): Printing DDC gathered Modelines:
[ 11.257] (II) modeset(0): Modeline "2560x1600"x0.0 268.63 2560 2608 2640 2720 1600 1603 1609 1646 -hsync -vsync (98.8 kHz eP)
[ 11.261] (II) modeset(0): EDID vendor "CSO", prod id 5635
[ 11.261] (II) modeset(0): Using hsync ranges from config file
[ 11.261] (II) modeset(0): Using vrefresh ranges from config file
[ 11.261] (II) modeset(0): Printing DDC gathered Modelines:
[ 11.261] (II) modeset(0): Modeline "2560x1600"x0.0 268.63 2560 2608 2640 2720 1600 1603 1609 1646 -hsync -vsync (98.8 kHz eP)
[ 12.251] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): connected
[ 12.252] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): Internal DisplayPort
[ 12.252] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): 2670.0 MHz maximum pixel clock
[ 12.256] (II) modeset(0): EDID vendor "CSO", prod id 5635
[ 12.256] (II) modeset(0): Using hsync ranges from config file
[ 12.256] (II) modeset(0): Using vrefresh ranges from config file
[ 12.256] (II) modeset(0): Printing DDC gathered Modelines:
[ 12.256] (II) modeset(0): Modeline "2560x1600"x0.0 268.63 2560 2608 2640 2720 1600 1603 1609 1646 -hsync -vsync (98.8 kHz eP)
[ 22.690] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 24.375] (II) modeset(0): EDID vendor "CSO", prod id 5635
[ 24.375] (II) modeset(0): Using hsync ranges from config file
[ 24.375] (II) modeset(0): Using vrefresh ranges from config file
[ 24.375] (II) modeset(0): Printing DDC gathered Modelines:
[ 24.375] (II) modeset(0): Modeline "2560x1600"x0.0 268.63 2560 2608 2640 2720 1600 1603 1609 1646 -hsync -vsync (98.8 kHz eP)
[ 24.378] (II) modeset(0): EDID vendor "CSO", prod id 5635
[ 24.378] (II) modeset(0): Using hsync ranges from config file
[ 24.378] (II) modeset(0): Using vrefresh ranges from config file
[ 24.378] (II) modeset(0): Printing DDC gathered Modelines:
[ 24.378] (II) modeset(0): Modeline "2560x1600"x0.0 268.63 2560 2608 2640 2720 1600 1603 1609 1646 -hsync -vsync (98.8 kHz eP)
[ 24.378] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): connected
[ 24.378] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): Internal DisplayPort
[ 24.378] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): 2670.0 MHz maximum pixel clock
[ 24.382] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 24.382] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 24.382] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 24.382] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 24.382] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 24.382] (--) NVIDIA(GPU-0): DFP-2: 2670.0 MHz maximum pixel clock
[ 24.383] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 24.383] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 24.383] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 24.383] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 24.383] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 24.383] (--) NVIDIA(GPU-0): DFP-4: 2670.0 MHz maximum pixel clock
[ 24.400] (II) modeset(0): EDID vendor "CSO", prod id 5635
[ 24.400] (II) modeset(0): Using hsync ranges from config file
[ 24.400] (II) modeset(0): Using vrefresh ranges from config file
[ 24.400] (II) modeset(0): Printing DDC gathered Modelines:
[ 24.400] (II) modeset(0): Modeline "2560x1600"x0.0 268.63 2560 2608 2640 2720 1600 1603 1609 1646 -hsync -vsync (98.8 kHz eP)
[ 24.403] (II) modeset(0): EDID vendor "CSO", prod id 5635
[ 24.403] (II) modeset(0): Using hsync ranges from config file
[ 24.403] (II) modeset(0): Using vrefresh ranges from config file
[ 24.403] (II) modeset(0): Printing DDC gathered Modelines:
[ 24.403] (II) modeset(0): Modeline "2560x1600"x0.0 268.63 2560 2608 2640 2720 1600 1603 1609 1646 -hsync -vsync (98.8 kHz eP)
[ 24.403] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): connected
[ 24.403] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): Internal DisplayPort
[ 24.403] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): 2670.0 MHz maximum pixel clock
[ 24.408] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 24.408] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 24.408] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 24.408] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 24.408] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 24.408] (--) NVIDIA(GPU-0): DFP-2: 2670.0 MHz maximum pixel clock
[ 24.408] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 24.408] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 24.408] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 24.408] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 24.408] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 24.408] (--) NVIDIA(GPU-0): DFP-4: 2670.0 MHz maximum pixel clock
[ 25.019] (II) modeset(0): EDID vendor "CSO", prod id 5635
[ 25.019] (II) modeset(0): Using hsync ranges from config file
[ 25.019] (II) modeset(0): Using vrefresh ranges from config file
[ 25.019] (II) modeset(0): Printing DDC gathered Modelines:
[ 25.019] (II) modeset(0): Modeline "2560x1600"x0.0 268.63 2560 2608 2640 2720 1600 1603 1609 1646 -hsync -vsync (98.8 kHz eP)
[ 25.021] (II) modeset(0): EDID vendor "CSO", prod id 5635
[ 25.021] (II) modeset(0): Using hsync ranges from config file
[ 25.021] (II) modeset(0): Using vrefresh ranges from config file
[ 25.021] (II) modeset(0): Printing DDC gathered Modelines:
[ 25.021] (II) modeset(0): Modeline "2560x1600"x0.0 268.63 2560 2608 2640 2720 1600 1603 1609 1646 -hsync -vsync (98.8 kHz eP)
[ 25.022] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): connected
[ 25.022] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): Internal DisplayPort
[ 25.022] (--) NVIDIA(GPU-0): XMI P27QBB-RA (DFP-0): 2670.0 MHz maximum pixel clock
[ 25.026] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 25.026] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 25.026] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 25.026] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 25.026] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 25.026] (--) NVIDIA(GPU-0): DFP-2: 2670.0 MHz maximum pixel clock
[ 25.026] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 25.026] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 25.026] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 25.026] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 25.026] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 25.026] (--) NVIDIA(GPU-0): DFP-4: 2670.0 MHz maximum pixel clock
[ 26.306] (II) modeset(0): Allocate new frame buffer 2560x1440 stride
[ 28.853] (II) event3 - Video Bus: device removed
[ 28.880] (II) event4 - Video Bus: device removed
[ 28.903] (II) event0 - Power Button: device removed
[ 28.933] (II) event15 - Logitech USB Receiver: device removed
[ 29.010] (II) event19 - Integrated Camera: Integrated C: device removed
[ 29.090] (II) event14 - ITE Tech. Inc. ITE Device(8296) Wireless Radio Control: device removed
[ 29.150] (II) event6 - Ideapad extra buttons: device removed
[ 29.193] (II) event7 - SYNA2BA6:00 06CB:CE44 Mouse: device removed
[ 29.250] (II) event8 - SYNA2BA6:00 06CB:CE44 Touchpad: device removed
[ 29.313] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 29.360] (II) event16 - Logitech USB Receiver Keyboard: device removed
[ 29.393] (II) event13 - ITE Tech. Inc. ITE Device(8296) Keyboard: device removed
[ 29.423] (II) AIGLX: Suspending AIGLX clients for VT switch
