For a couple of months I have not been able to wake my system from sleep. Everytime I will end on a blank screen with a white cursor in the top right. No mouse visible, can’t switch to alternate terminal sessions, can REISUB. After rebooting there are no entries in any logs that indicate the problem.
Any assitance would be greatly appreciated as this is driving me nuts.
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: initrd=\amd-ucode.img initrd=\intel-ucode.img
initrd=\initramfs-5.15-x86_64.img
root=UUID=cb023762-f991-4832-93fc-c4cff17d353f rw
cryptdevice=UUID=7cebcd26-2ac0-437e-999a-b8945c83b5b0:cryptroot
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: Gigabyte product: B450 AORUS M v: N/A serial: N/A
Mobo: Gigabyte model: B450 AORUS M serial: N/A
UEFI: American Megatrends LLC. v: F62d date: 10/13/2021
RAM: total: 15.61 GiB used: 3.73 GiB (23.9%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 size: No Module Installed
Device-2: DIMM 1 size: 8 GiB speed: 2400 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Kingston part-no: KHX2400C15/8G
serial: <filter>
Device-3: DIMM 0 size: No Module Installed
Device-4: DIMM 1 size: 8 GiB speed: 2400 MT/s type: DDR4
serial: <filter>
Info: model: AMD Ryzen 5 2600 socket: AM4 bits: 64 type: MT MCP arch: Zen+
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1758 high: 2800 min/max: 1550/3400 boost: enabled
base/boost: 3400/3900 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 1550 2: 1550 3: 1550 4: 1550
5: 1550 6: 2800 7: 2800 8: 1550 9: 1550 10: 1550 11: 1550 12: 1550
bogomips: 81475
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: ASUSTeK driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 07:00.0
chip-ID: 10de:1f02 class-ID: 0300
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5")
s-diag: 692mm (27.3")
Monitor-1: DP-2 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54
direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
bus-ID: 07:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: no
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0
chip-ID: 168c:0030 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-1: cryptroot maj-min: 254:0 type: LUKS dm: dm-0 size: 931.01 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 931.01 GiB
Local Storage: total: 3.18 TiB used: 1.03 TiB (32.5%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 46.9 C scheme: GPT
SMART: yes health: PASSED on: 27d 3h cycles: 891
read-units: 8,299,374 [4.24 TB] written-units: 11,290,302 [5.78 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
family: based SSDs size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 2B6Q temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 20d 14h cycles: 2989
written: 3.15 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 250GB
rev: DB6Q temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 204d 7h cycles: 5037
written: 3.83 TiB
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD20EZRZ-00Z5HB0 family: Blue size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: 0A80 temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 309d 11h cycles: 2241
ID-1: / raw-size: 931.01 GiB size: 915.4 GiB (98.32%)
used: 446.55 GiB (48.8%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: cryptroot label: N/A uuid: N/A
ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
used: 166.6 MiB (32.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: A8D3-4ECC
ID-3: /mnt/media raw-size: 1.82 TiB size: 1.79 TiB (98.38%)
used: 458.64 GiB (25.0%) fs: ext4 block-size: 4096 B dev: /dev/sdc1
maj-min: 8:33 label: Media uuid: de3c6b51-1183-4785-95ae-cb0e30dfd52c
ID-4: /mnt/steam raw-size: 232.88 GiB size: 228.23 GiB (98.00%)
used: 152.67 GiB (66.9%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: Steam uuid: 31b3c794-cac7-44fc-ab93-e9eaa73f1b8f
ID-1: swap-1 type: file size: 15.65 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 232.88 GiB fs: ext4 label: Vbox
uuid: 6db97dbb-3970-467e-b3c8-6114f0a5c971
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: Logitech G PRO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08c class-ID: 0300 serial: <filter>
Device-2: 1-6:3 info: Holtek USB-HID Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:0192 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 41 C
Processes: 309 Uptime: 34m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1933 lib: 450
flatpak: 0 Shell: Zsh (sudo) v: 5.8.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.13
journalctl --system --boot=-1 | tail --lines=50
Mar 13 10:41:39 gc-home dbus-daemon[986]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.140' (uid=0 pid=4374 comm="sudo sysctl --system ")
Mar 13 10:41:39 gc-home dbus-daemon[986]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 13 10:41:39 gc-home audit[4374]: USER_ACCT pid=4374 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mar 13 10:41:39 gc-home audit[4374]: CRED_REFR pid=4374 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mar 13 10:41:39 gc-home kernel: audit: type=1101 audit(1647128499.138:125): pid=4374 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mar 13 10:41:39 gc-home kernel: audit: type=1110 audit(1647128499.138:126): pid=4374 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mar 13 10:41:39 gc-home audit[4374]: USER_START pid=4374 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mar 13 10:41:39 gc-home kernel: audit: type=1105 audit(1647128499.142:127): pid=4374 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mar 13 10:41:39 gc-home audit[4374]: USER_END pid=4374 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mar 13 10:41:39 gc-home audit[4374]: CRED_DISP pid=4374 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mar 13 10:41:39 gc-home kernel: audit: type=1106 audit(1647128499.145:128): pid=4374 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mar 13 10:41:39 gc-home kernel: audit: type=1104 audit(1647128499.145:129): pid=4374 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mar 13 10:41:39 gc-home kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Mar 13 10:41:39 gc-home kernel: ata1.00: supports DRM functions and may not be fully accessible
Mar 13 10:41:39 gc-home kernel: ata1.00: disabling queued TRIM support
Mar 13 10:41:39 gc-home kernel: ata1.00: configured for UDMA/133
Mar 13 10:41:39 gc-home kernel: ahci 0000:02:00.1: port does not support device sleep
Mar 13 10:41:39 gc-home kernel: sd 0:0:0:0: [sda] Starting disk
Mar 13 10:41:57 gc-home kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Mar 13 10:41:57 gc-home kernel: sd 0:0:0:0: [sda] Stopping disk
Mar 13 10:42:30 gc-home ModemManager[1061]: <info> [sleep-monitor] system is about to suspend
Mar 13 10:42:30 gc-home NetworkManager[987]: <info> [1647128550.9008] manager: sleep: sleep requested (sleeping: no enabled: yes)
Mar 13 10:42:30 gc-home NetworkManager[987]: <info> [1647128550.9009] device (wlp6s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 10:42:30 gc-home NetworkManager[987]: <info> [1647128550.9012] device (wlp6s0): set-hw-addr: reset MAC address to D4:6E:0E:1C:95:3F (unmanage)
Mar 13 10:42:30 gc-home NetworkManager[987]: <info> [1647128550.9017] manager: NetworkManager state is now ASLEEP
Mar 13 10:42:30 gc-home NetworkManager[987]: <info> [1647128550.9019] device (eno1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 10:42:30 gc-home dbus-daemon[986]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=987 comm="/usr/bin/NetworkManager --no-daemon ")
Mar 13 10:42:30 gc-home systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 13 10:42:30 gc-home dbus-daemon[986]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 13 10:42:30 gc-home systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 13 10:42:30 gc-home audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 10:42:30 gc-home kernel: audit: type=1130 audit(1647128550.912:130): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 10:42:30 gc-home NetworkManager[987]: <info> [1647128550.9191] device (eno1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 10:42:30 gc-home avahi-daemon[984]: Withdrawing address record for fe80::d0f7:d0a4:eb45:cc76 on eno1.
Mar 13 10:42:30 gc-home avahi-daemon[984]: Leaving mDNS multicast group on interface eno1.IPv6 with address fe80::d0f7:d0a4:eb45:cc76.
Mar 13 10:42:30 gc-home avahi-daemon[984]: Interface eno1.IPv6 no longer relevant for mDNS.
Mar 13 10:42:30 gc-home NetworkManager[987]: <info> [1647128550.9728] dhcp4 (eno1): canceled DHCP transaction
Mar 13 10:42:30 gc-home NetworkManager[987]: <info> [1647128550.9728] dhcp4 (eno1): state changed bound -> terminated
Mar 13 10:42:30 gc-home avahi-daemon[984]: Withdrawing address record for 192.168.1.21 on eno1.
Mar 13 10:42:30 gc-home avahi-daemon[984]: Leaving mDNS multicast group on interface eno1.IPv4 with address 192.168.1.21.
Mar 13 10:42:30 gc-home avahi-daemon[984]: Interface eno1.IPv4 no longer relevant for mDNS.
Mar 13 10:42:30 gc-home NetworkManager[987]: <info> [1647128550.9833] device (eno1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 10:42:30 gc-home kernel: r8169 0000:04:00.0 eno1: Link is Down
Mar 13 10:42:31 gc-home systemd[1]: Reached target Sleep.
Mar 13 10:42:31 gc-home systemd[1]: Starting System Suspend...
Mar 13 10:42:31 gc-home systemd-sleep[4448]: Entering sleep state 'suspend'...
Mar 13 10:42:31 gc-home kernel: PM: suspend entry (deep)
Mar 13 10:42:31 gc-home kernel: Filesystems sync: 0.009 seconds
