I can’t log in after setting my laptop to sleep mode, no login shown, just a black screen with no cursor.
I use tty to start the login by running systemctl restart sddm.service
How can I solve this problem
provide formatted system info:
inxi -Fazv7
and logs (put the pc in sleep, restart sddm) - and post output:
journalctl -b0 -p4 --no-pager
- I noticed that the laptop works properly when I switch to sleep mode, the problem is when I leave the laptop for 10 minutes the laptop switches to seeping mode automatically, and the black screen Shown
inxi -Fazv7
/home/juba inxi -Fazv7 ✔ root@Manjaro
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=ffc6fd49-9656-4809-b229-f0fefff2b1a8 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Precision M4800 v: 00 serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0T3YTY v: A00 serial: <filter> UEFI: Dell v: A26
date: 06/13/2019
ID-1: BAT0 charge: 38.8 Wh (66.9%) condition: 58.0/99.9 Wh (58.1%)
volts: 11.2 min: 11.1 model: SMP DELL 4HJXXD1 type: Li-ion serial: <filter>
status: discharging
RAM: total: 15.53 GiB used: 2.77 GiB (17.8%)
Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB
note: est.
Device-1: DIMM B type: no module installed
Device-2: DIMM C type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471B1G73QH0-YK0 serial: <filter>
Device-3: DIMM A type: no module installed
Device-4: DIMM D type: DDR3 detail: synchronous size: 8 GiB
manufacturer: Kingston part-no: 9905428-087.A00LF serial: <filter>
Info: model: Intel Core i7-4810MQ socket: rPGA988B bits: 64 type: MT MCP
arch: Haswell gen: core 4 level: v3 note: check built: 2013-15
process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
microcode: 0x28
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1008 high: 1093 min/max: 800/3800 base/boost: 2800/2800
scaling: driver: intel_cpufreq governor: ondemand volts: 1.2 V
ext-clock: 100 MHz cores: 1: 1093 2: 940 3: 1084 4: 998 5: 998 6: 997
7: 999 8: 959 bogomips: 44719
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Dell
driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK107GLM [Quadro K1100M] vendor: Dell driver: N/A
alternate: nouveau, nvidia_drm, nvidia non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:0ff6 class-ID: 0300
Device-3: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.5:3 chip-ID: 0c45:64d0 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: intel,nvidia dri: i965 gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x21ed built: 2011
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-3: NVIDIA GK107 HDMI Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
IF-ID-1: outline-tun0 state: down mac: N/A
IP v4: <filter> scope: global
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 417.33 GiB used: 336.37 GiB (80.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD3200BPVT-24ZEST0 family: Scorpio Blue Serial ATA (AF)
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B sata: 2.6
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1A02 temp: 27 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 15d 11h cycles: 4963
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: THNSNJ128GMCU
family: HG6 Series SSD size: 119.24 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 0101 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 240d 11h cycles: 2573
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GS40N rev: A100
dev-links: cdrom
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
used: 88.37 GiB (75.8%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: ffc6fd49-9656-4809-b229-f0fefff2b1a8
used: 568 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: NO_LABEL uuid: B099-CA5E
ID-3: /media/juba/JubaHDD raw-size: 298.09 GiB size: 292.35 GiB (98.07%)
used: 248.01 GiB (84.8%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: MahmoudHDD uuid: b38b075f-1896-4041-a911-81e03e0cab50
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Device-1: 1-1.5:3 info: Microdia Integrated Webcam type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Device-1: 2-1.8:4 info: Broadcom BCM5880 Secure Applications Processor
type: Smart Card driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a5c:5800 class-ID: 0b00 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 15 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 54.0 C mobo: 44.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 283 Uptime: 36m wakeups: 2 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1720 pm: pacman pkgs: 1695 libs: 385 tools: octopi,pamac,yay
pm: flatpak pkgs: 18 pm: snap pkgs: 7 Shell: Zsh (su) v: 5.9
running-in: konsole inxi: 3.3.24
- journalctl -b0 -p4 --no-pager
journalctl -b0 -p4 --no-pager ✔ root@Manjaro
Jan 03 08:41:11 Manjaro kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Jan 03 08:41:11 Manjaro kernel: #5 #6 #7
Jan 03 08:41:11 Manjaro kernel: pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
Jan 03 08:41:11 Manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jan 03 08:41:11 Manjaro kernel: ata1.00: ATA Identify Device Log not supported
Jan 03 08:41:11 Manjaro kernel: usb 2-1.8: config 0 descriptor??
Jan 03 08:41:11 Manjaro kernel: i8042: Warning: Keylock active
Jan 03 08:41:11 Manjaro kernel: vboxdrv: loading out-of-tree module taints kernel.
Jan 03 08:41:11 Manjaro kernel: VBoxNetAdp: Successfully started.
Jan 03 08:41:11 Manjaro kernel: VBoxNetFlt: Successfully started.
Jan 03 08:41:12 Manjaro kernel: wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
Jan 03 08:41:12 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000183F (\_SB.PCI0.EHC2.E1PM) (20210730/utaddress-204)
Jan 03 08:41:12 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000183F (\_SB.PCI0.EHC1.E1PM) (20210730/utaddress-204)
Jan 03 08:41:12 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20210730/utaddress-204)
Jan 03 08:41:12 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20210730/utaddress-204)
Jan 03 08:41:12 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\_SB.PCI0.PEG0.PEGP.GPSP) (20210730/utaddress-204)
Jan 03 08:41:12 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20210730/utaddress-204)
Jan 03 08:41:12 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20210730/utaddress-204)
Jan 03 08:41:12 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\_SB.PCI0.PEG0.PEGP.GPSP) (20210730/utaddress-204)
Jan 03 08:41:12 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20210730/utaddress-204)
Jan 03 08:41:12 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20210730/utaddress-204)
Jan 03 08:41:12 Manjaro kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Jan 03 08:41:12 Manjaro kernel: i801_smbus 0000:00:1f.3: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
Jan 03 08:41:12 Manjaro kernel: EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck is recommended
Jan 03 08:41:12 Manjaro kernel: at24 0-0051: supply vcc not found, using dummy regulator
Jan 03 08:41:12 Manjaro kernel: at24 0-0053: supply vcc not found, using dummy regulator
Jan 03 08:41:12 Manjaro kernel: mtd: partition "BIOS" extends beyond the end of device "intel-spi" -- size truncated to 0x800000
Jan 03 08:41:13 Manjaro kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Jan 03 08:41:13 Manjaro thermald[1397]: NO RAPL sysfs present
Jan 03 08:41:13 Manjaro kernel: iwlwifi 0000:03:00.0: RF_KILL bit toggled to disable radio.
Jan 03 08:41:13 Manjaro kernel: iwlwifi 0000:03:00.0: reporting RF_KILL (radio disabled)
Jan 03 08:41:13 Manjaro kernel: kauditd_printk_skb: 223 callbacks suppressed
Jan 03 08:41:15 Manjaro systemd[4307]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Jan 03 08:41:15 Manjaro systemd[4307]: Failed to start Update XDG user dir configuration.
Jan 03 08:41:16 Manjaro sddm-greeter[4535]: QFont::fromString: Invalid description '(empty)'
Jan 03 08:41:16 Manjaro sddm-greeter[4535]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fffab328880), parent's thread is QThread(0x55ea276eb680), current thread is QThread(0x55ea2780ee60)
Jan 03 08:41:16 Manjaro sddm-greeter[4535]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jan 03 08:41:17 Manjaro sddm-greeter[4535]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jan 03 08:41:17 Manjaro sddm-greeter[4535]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jan 03 08:41:17 Manjaro sddm-greeter[4535]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jan 03 08:41:17 Manjaro sddm-greeter[4535]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Jan 03 08:41:17 Manjaro sddm-greeter[4535]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.23'
Jan 03 08:41:18 Manjaro kernel: kauditd_printk_skb: 43 callbacks suppressed
Jan 03 08:41:19 Manjaro systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
Jan 03 08:41:19 Manjaro systemd[1]: Failed to start pkgfile database update.
Jan 03 08:41:21 Manjaro ksplashqml[5221]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Jan 03 08:41:21 Manjaro ksplashqml[5221]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Jan 03 08:41:21 Manjaro ksmserver[5276]: Qt: Session management error: networkIdsList argument is NULL
Jan 03 08:41:21 Manjaro ksmserver[5276]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
Jan 03 08:41:21 Manjaro kwin_x11[5279]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jan 03 08:41:21 Manjaro kwin_x11[5279]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jan 03 08:41:22 Manjaro org_kde_powerdevil[5339]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jan 03 08:41:22 Manjaro plasmashell[5314]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jan 03 08:41:22 Manjaro plasmashell[5314]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jan 03 08:41:22 Manjaro pipewire-media-session[5401]: mod.rt: Can't find xdg-portal: (null)
Jan 03 08:41:22 Manjaro pipewire-media-session[5401]: mod.rt: found session bus but no portal
Jan 03 08:41:22 Manjaro pipewire[5399]: mod.rt: Can't find xdg-portal: (null)
Jan 03 08:41:22 Manjaro pipewire[5399]: mod.rt: found session bus but no portal
Jan 03 08:41:22 Manjaro org_kde_powerdevil[5339]: org.kde.powerdevil: Empty command?
Jan 03 08:41:22 Manjaro org_kde_powerdevil[5339]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jan 03 08:41:22 Manjaro kded5[5278]: kf.bluezqt: PendingCall Error: "Unit dbus-org.bluez.service not found."
Jan 03 08:41:22 Manjaro ksystemstats[5492]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Voltage %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 03 08:41:22 Manjaro ksystemstats[5492]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Temperature %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 03 08:41:22 Manjaro akonadi_control[5551]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 03 08:41:23 Manjaro akonadiserver[5561]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 03 08:41:23 Manjaro kernel: kauditd_printk_skb: 52 callbacks suppressed
Jan 03 08:41:23 Manjaro plasmashell[5314]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/main.qml:70:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 03 08:41:23 Manjaro plasmashell[5314]: Both point size and pixel size set. Using pixel size.
Jan 03 08:41:23 Manjaro plasmashell[5314]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:82:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 03 08:41:23 Manjaro plasmashell[5314]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:76:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 03 08:41:24 Manjaro plasmashell[5314]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jan 03 08:41:24 Manjaro plasmashell[5314]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Jan 03 08:41:24 Manjaro akonadi_google_resource[5611]: org.kde.pim.google: Got error: KGAPI2::TaskListFetchJob(0x55a49a1cfe50) "Invalid response content type"
Jan 03 08:41:24 Manjaro akonadi_google_resource[5611]: org.kde.pim.google: Got error: KGAPI2::CalendarFetchJob(0x55a49a186d70) "Invalid response content type"
Jan 03 08:41:24 Manjaro plasmashell[5314]: Both point size and pixel size set. Using pixel size.
Jan 03 08:41:24 Manjaro kernel: snd_hda_codec_hdmi hdaudioC2D0: Unable to sync register 0x5f0800. -5
Jan 03 08:41:24 Manjaro plasmashell[5314]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:115:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 03 08:41:24 Manjaro plasmashell[5314]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:101:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 03 08:41:24 Manjaro plasmashell[5314]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:86:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 03 08:41:24 Manjaro plasmashell[5314]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 03 08:41:24 Manjaro plasmashell[5314]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 03 08:41:24 Manjaro plasmashell[5314]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 03 08:41:24 Manjaro pulseaudio[5696]: The decibel volume range for element 'PCM' (-2837 dB - -6 dB) has negative maximum. Disabling the decibel range.
Jan 03 08:41:25 Manjaro plasmashell[5314]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 03 08:41:25 Manjaro pulseaudio[5696]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jan 03 08:41:25 Manjaro pulseaudio[5696]: GetManagedObjects() failed: org.freedesktop.systemd1.NoSuchUnit: Unit dbus-org.bluez.service not found.
Jan 03 08:41:25 Manjaro plasmashell[5314]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 03 08:41:25 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.diskquota/contents/ui/main.qml:75: ReferenceError: model is not defined
Jan 03 08:41:26 Manjaro plasmashell[5314]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 03 08:41:27 Manjaro plasmashell[5314]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 03 08:41:27 Manjaro plasmashell[5314]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 03 08:41:28 Manjaro krunner[5727]: QCommandLineParser: argument list cannot be empty, it should contain at least the executable name
Jan 03 08:41:28 Manjaro plasmashell[5314]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 03 08:41:28 Manjaro krunner[5727]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Jan 03 08:41:28 Manjaro krunner[5727]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 03 08:41:30 Manjaro krunner[5727]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Jan 03 08:41:31 Manjaro kioslave5[5811]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
Jan 03 08:41:34 Manjaro kioslave5[5811]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
Jan 03 08:41:37 Manjaro kioslave5[5855]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
Jan 03 08:41:37 Manjaro kioslave5[5855]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
Jan 03 08:41:38 Manjaro kioslave5[5874]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
Jan 03 08:41:39 Manjaro kioslave5[5890]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
Jan 03 08:41:39 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 08:41:39 Manjaro plasmashell[5314]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 03 08:41:40 Manjaro ModemManager[1495]: <warn> [plugin/generic] could not grab port ttyS4: Cannot add port 'tty/ttyS4', unhandled port type
Jan 03 08:41:40 Manjaro ModemManager[1495]: <warn> [base-manager] couldn't create modem for device '/sys/devices/pci0000:00/0000:00:16.3': Failed to find primary AT port
Jan 03 08:41:52 Manjaro kalarm[5962]: org.kde.pim.kalarm: MigrateKde4Files::migrate: Can't find KDE4 data directory
Jan 03 08:41:52 Manjaro plasmashell[5314]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 03 08:45:15 Manjaro pulseaudio[5696]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Jan 03 08:45:15 Manjaro pulseaudio[5696]: Most likely this is a bug in the ALSA driver 'snd_usb_audio'. Please report this issue to the ALSA developers.
Jan 03 08:45:15 Manjaro pulseaudio[5696]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Jan 03 08:46:27 Manjaro kwin_x11[5279]: kwin_core: XCB error: 152 (BadDamage), sequence: 4783, resource id: 16777901, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jan 03 08:46:28 Manjaro kioslave5[6310]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
Jan 03 08:46:30 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:162: TypeError: Cannot read property 'text' of null
Jan 03 08:46:30 Manjaro plasmashell[5314]: trying to show an empty dialog
Jan 03 08:46:30 Manjaro plasmashell[5314]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Jan 03 08:46:31 Manjaro kernel: iwlwifi 0000:03:00.0: RF_KILL bit toggled to enable radio.
Jan 03 08:46:31 Manjaro kernel: iwlwifi 0000:03:00.0: reporting RF_KILL (radio enabled)
Jan 03 08:46:32 Manjaro NetworkManager[1465]: <warn> [1672728392.2963] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Jan 03 08:46:32 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Jan 03 08:46:32 Manjaro plasmashell[5314]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 03 08:46:33 Manjaro krunner[5727]: QCommandLineParser: argument list cannot be empty, it should contain at least the executable name
Jan 03 08:46:33 Manjaro krunner[5727]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Jan 03 08:46:38 Manjaro plasmashell[5314]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x555eb0037a60) QQmlContext(0x555eae5e78d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jan 03 08:46:38 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jan 03 08:46:38 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jan 03 08:46:41 Manjaro krunner[5727]: QCommandLineParser: argument list cannot be empty, it should contain at least the executable name
Jan 03 08:46:41 Manjaro krunner[5727]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Jan 03 08:46:43 Manjaro krunner[5727]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Jan 03 08:48:00 Manjaro konsole[7756]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 03 08:48:00 Manjaro konsole[7756]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 03 08:48:03 Manjaro xdg-desktop-por[5242]: A backend call failed: No such method 'CreateMonitor' in interface 'org.freedesktop.impl.portal.Inhibit' at object path '/org/freedesktop/portal/desktop' (signature 'ooss')
Jan 03 08:48:03 Manjaro xdg-desktop-por[5242]: Failed to close session implementation: GDBus.Error:org.freedesktop.DBus.Error.UnknownObject: No such object path '/org/freedesktop/portal/desktop/session/1_90/gtk1385468520'
Jan 03 08:48:43 Manjaro plasmashell[5314]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-C-Media_Electronics_Inc._USB_PnP_Sound_Device-00.analog-stereo"
Jan 03 08:48:43 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:119: TypeError: Value is undefined and could not be converted to an object
Jan 03 08:48:43 Manjaro plasmashell[5314]: org.kde.plasma.pulseaudio: No object for name "alsa_input.usb-C-Media_Electronics_Inc._USB_PnP_Sound_Device-00.mono-fallback"
Jan 03 08:49:57 Manjaro kwin_x11[5279]: kwin_core: XCB error: 152 (BadDamage), sequence: 56083, resource id: 16791650, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jan 03 08:58:01 Manjaro crond[1355]: (root) CAN'T OPEN (/etc/crontab): No such file or directory
Jan 03 09:02:23 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:03:32 Manjaro kstart5[10367]: Omitting both --window and --windowclass arguments is not recommended
Jan 03 09:03:37 Manjaro plasmashell[5314]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x555eafdca7b0) QQmlContext(0x555eae5e78d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jan 03 09:03:37 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jan 03 09:03:37 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jan 03 09:03:37 Manjaro plasmashell[5314]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x555ead9ae670) QQmlContext(0x555eae5e78d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jan 03 09:03:37 Manjaro kioslave5[10396]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
Jan 03 09:04:54 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:10:35 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:10:49 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:10:51 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:11:01 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:11:07 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:11:11 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:11:18 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:11:19 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:11:29 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:11:40 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:11:41 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:14:28 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:14:32 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:14:36 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:14:37 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:14:38 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:14:39 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:14:41 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:14:56 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:15:36 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Jan 03 09:15:45 Manjaro plasmashell[5314]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x555eb049bd80) QQmlContext(0x555eae5e78d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jan 03 09:15:45 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jan 03 09:15:45 Manjaro plasmashell[5314]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jan 03 09:17:44 Manjaro xdg-desktop-por[5242]: A backend call failed: No such method 'CreateMonitor' in interface 'org.freedesktop.impl.portal.Inhibit' at object path '/org/freedesktop/portal/desktop' (signature 'ooss')
Jan 03 09:17:44 Manjaro xdg-desktop-por[5242]: Failed to close session implementation: GDBus.Error:org.freedesktop.DBus.Error.UnknownObject: No such object path '/org/freedesktop/portal/desktop/session/1_116/gtk221651738'
Jan 03 09:18:40 Manjaro kwin_x11[5279]: kwin_core: XCB error: 152 (BadDamage), sequence: 8435, resource id: 16839569, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jan 03 09:18:40 Manjaro konsole[7756]: kf.notifications: Playing audio notification failed: Destroyed
Jan 03 09:18:51 Manjaro kscreenlocker_greet[12480]: Qt: Session management error: networkIdsList argument is NULL
Jan 03 09:18:51 Manjaro kded5[5278]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
Jan 03 09:18:51 Manjaro kernel: ACPI: button: The lid device is not compliant to SW_LID.
Jan 03 09:18:51 Manjaro kscreenlocker_greet[12480]: kf.kirigami: Failed to find a Kirigami platform plugin
Jan 03 09:18:51 Manjaro NetworkManager[1465]: <warn> [1672730331.9768] dns-mgr: could not commit DNS changes: Failed to rename file “/etc/resolv.conf.M5MJY1” to “/etc/resolv.conf”: g_rename() failed: Operation not permitted
Jan 03 09:18:52 Manjaro kscreenlocker_greet[12480]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Jan 03 09:19:06 Manjaro kernel: snd_hda_intel 0000:01:00.1: can't change power state from D0 to D3hot (config space inaccessible)
Jan 03 09:19:06 Manjaro kernel: xhci_hcd 0000:00:14.0: xHC error in resume, USBSTS 0x401, Reinit
Jan 03 09:19:06 Manjaro kernel: ata1.00: ATA Identify Device Log not supported
Jan 03 09:19:06 Manjaro rtkit-daemon[5266]: The canary thread is apparently starving. Taking action.
Jan 03 09:19:06 Manjaro kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
Jan 03 09:19:06 Manjaro kernel: acpi PNP0401:00: Already enumerated
Jan 03 09:19:06 Manjaro kernel: acpi PNP0501:00: Still not present
Jan 03 09:19:06 Manjaro kernel: snd_hda_codec_hdmi hdaudioC2D0: Unable to sync register 0x5f0800. -5
Jan 03 09:19:10 Manjaro plasmashell[5314]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
Jan 03 09:19:12 Manjaro NetworkManager[1465]: <warn> [1672730352.0694] dns-mgr: could not commit DNS changes: Failed to rename file “/etc/resolv.conf.YIA5X1” to “/etc/resolv.conf”: g_rename() failed: Operation not permitted
Jan 03 09:19:12 Manjaro NetworkManager[1465]: <warn> [1672730352.6447] dns-mgr: could not commit DNS changes: Failed to rename file “/etc/resolv.conf.N6FFY1” to “/etc/resolv.conf”: g_rename() failed: Operation not permitted
Jan 03 09:19:12 Manjaro konsole[12949]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 03 09:19:12 Manjaro konsole[12949]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 03 09:19:22 Manjaro kernel: kauditd_printk_skb: 2 callbacks suppressed
you dont have a nvidia driver installed, so post output from:
mhwd -l -li
and you are also on RAID:
so you can switch from raid to AHCI in bios, but if you are dual booting with windows, and you switch, you will not be able to boot into windows
- I’m using bumblebee drivers
- Do you recommend installing Nvidia proprietary drivers instead of bumblebee?
mhwd -l -li ✔ root@Manjaro
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-390xx-bumblebee 2021.11.26 false PCI
> 0000:01:00.0 (0300:10de:0ff6) Display controller nVidia Corporation:
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation:
- I switched to AHCI, I’m not using dual boot.
no you dont use any nvidia drivers:
and the bumblebee is the reason… its a mess, and not supported…
although, there is this:
indicating that you should be able to use the 470 series instead of the bumblebee mess…
do you still have issues with AHCI enabled and black screen after waking up?
- I tested the laptop one time and it works properly, I’ll test it again to make sure.
- I switched to Nvidia proprietary drivers (390 like recommended in hardware configuration)
I have some questions if you can help me
- I’m using optimus-manager with
bbswitchswitching method, when I’m using the intel GPU the nvidia driver shown with No drivers (N/A):
when I’m using nvidia the output:
Device-2: NVIDIA GK107GLM [Quadro K1100M] vendor: Dell driver: nvidia
v: 390.157 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
process: TSMC 28nm built: 2012-18 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-2,DP-3,DP-4 bus-ID: 01:00.0
- Should I reinstall my system to avoid redundancy caused by RAID (If I’m understanding correctly)
- why RAID is the problem when waking up after sleep
Thank you for your help, I’m so grateful to you
i see, so you use optimus/bbswitch, thats why the nvidia was not detected…
so stay on nvidia, and see if you still have the black screen issues…
in some cases switching to AHCI will be enough, but in others, reinstalling the system while on AHCI is needed … but test so more suspending/resuming…
The problem happened again, but this time I forgot the laptop in sleep mode for about 8 hours
This is the output of journalctl after the black screen shown (using tty)
Jan 05 09:07:43 Manjaro kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Jan 05 09:07:43 Manjaro kernel: #5 #6 #7
Jan 05 09:07:43 Manjaro kernel: pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
Jan 05 09:07:43 Manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jan 05 09:07:43 Manjaro kernel: ata1.00: ATA Identify Device Log not supported
Jan 05 09:07:43 Manjaro kernel: usb 2-1.8: config 0 descriptor??
Jan 05 09:07:43 Manjaro kernel: i8042: Warning: Keylock active
Jan 05 09:07:43 Manjaro kernel: vboxdrv: loading out-of-tree module taints kernel.
Jan 05 09:07:43 Manjaro kernel: VBoxNetAdp: Successfully started.
Jan 05 09:07:43 Manjaro kernel: VBoxNetFlt: Successfully started.
Jan 05 09:07:44 Manjaro kernel: wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
Jan 05 09:07:44 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000183F (\_SB.PCI0.EHC2.E1PM) (20210730/utaddress-204)
Jan 05 09:07:44 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000183F (\_SB.PCI0.EHC1.E1PM) (20210730/utaddress-204)
Jan 05 09:07:44 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20210730/utaddress-204)
Jan 05 09:07:44 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20210730/utaddress-204)
Jan 05 09:07:44 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\_SB.PCI0.PEG0.PEGP.GPSP) (20210730/utaddress-204)
Jan 05 09:07:44 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20210730/utaddress-204)
Jan 05 09:07:44 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20210730/utaddress-204)
Jan 05 09:07:44 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\_SB.PCI0.PEG0.PEGP.GPSP) (20210730/utaddress-204)
Jan 05 09:07:44 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20210730/utaddress-204)
Jan 05 09:07:44 Manjaro kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20210730/utaddress-204)
Jan 05 09:07:44 Manjaro kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Jan 05 09:07:44 Manjaro kernel: i801_smbus 0000:00:1f.3: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
Jan 05 09:07:44 Manjaro kernel: EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck is recommended
Jan 05 09:07:44 Manjaro kernel: mtd: partition "BIOS" extends beyond the end of device "intel-spi" -- size truncated to 0x800000
Jan 05 09:07:45 Manjaro kernel: at24 0-0051: supply vcc not found, using dummy regulator
Jan 05 09:07:45 Manjaro kernel: at24 0-0053: supply vcc not found, using dummy regulator
Jan 05 09:07:45 Manjaro kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Jan 05 09:07:45 Manjaro kernel: iwlwifi 0000:03:00.0: RF_KILL bit toggled to disable radio.
Jan 05 09:07:45 Manjaro kernel: iwlwifi 0000:03:00.0: reporting RF_KILL (radio disabled)
Jan 05 09:07:45 Manjaro kernel: kauditd_printk_skb: 185 callbacks suppressed
Jan 05 09:07:45 Manjaro kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Jan 05 09:07:48 Manjaro systemd[3793]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Jan 05 09:07:48 Manjaro systemd[3793]: Failed to start Update XDG user dir configuration.
Jan 05 09:07:48 Manjaro sddm-greeter[3802]: QFont::fromString: Invalid description '(empty)'
Jan 05 09:07:48 Manjaro sddm-greeter[3802]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffe8885fd50), parent's thread is QThread(0x559ecbb6a6a0), current thread is QThread(0x559ecbc8a950)
Jan 05 09:07:48 Manjaro sddm-greeter[3802]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jan 05 09:07:49 Manjaro sddm-greeter[3802]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jan 05 09:07:49 Manjaro sddm-greeter[3802]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jan 05 09:07:49 Manjaro sddm-greeter[3802]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jan 05 09:07:50 Manjaro sddm-greeter[3802]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Jan 05 09:07:50 Manjaro sddm-greeter[3802]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.23'
Jan 05 09:07:50 Manjaro kernel: kauditd_printk_skb: 61 callbacks suppressed
Jan 05 09:07:51 Manjaro systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
Jan 05 09:07:51 Manjaro systemd[1]: Failed to start pkgfile database update.
Jan 05 09:08:12 Manjaro ModemManager[1652]: <warn> [plugin/generic] could not grab port ttyS4: Cannot add port 'tty/ttyS4', unhandled port type
Jan 05 09:08:12 Manjaro ModemManager[1652]: <warn> [base-manager] couldn't create modem for device '/sys/devices/pci0000:00/0000:00:16.3': Failed to find primary AT port
Jan 05 09:08:39 Manjaro kernel: kauditd_printk_skb: 2 callbacks suppressed
Jan 05 09:08:39 Manjaro systemd-xdg-autostart-generator[4315]: /home/juba/.config/autostart/org.kde.latte-dock.desktop:114: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Jan 05 09:08:39 Manjaro systemd-xdg-autostart-generator[4350]: /home/juba/.config/autostart/org.kde.latte-dock.desktop:114: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Jan 05 09:08:40 Manjaro ksplashqml[4337]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Jan 05 09:08:40 Manjaro ksplashqml[4337]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Jan 05 09:08:40 Manjaro ksmserver[4392]: Qt: Session management error: networkIdsList argument is NULL
Jan 05 09:08:40 Manjaro ksmserver[4392]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
Jan 05 09:08:40 Manjaro kwin_x11[4395]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jan 05 09:08:40 Manjaro kwin_x11[4395]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jan 05 09:08:40 Manjaro pipewire[4509]: mod.rt: Can't find xdg-portal: (null)
Jan 05 09:08:40 Manjaro pipewire[4509]: mod.rt: found session bus but no portal
Jan 05 09:08:40 Manjaro pipewire-media-session[4510]: mod.rt: Can't find xdg-portal: (null)
Jan 05 09:08:40 Manjaro pipewire-media-session[4510]: mod.rt: found session bus but no portal
Jan 05 09:08:41 Manjaro org_kde_powerdevil[4456]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jan 05 09:08:41 Manjaro plasmashell[4427]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jan 05 09:08:41 Manjaro plasmashell[4427]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jan 05 09:08:41 Manjaro kded5[4394]: kf.bluezqt: PendingCall Error: "Unit dbus-org.bluez.service not found."
Jan 05 09:08:41 Manjaro org_kde_powerdevil[4456]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jan 05 09:08:41 Manjaro ksystemstats[4619]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Voltage %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 05 09:08:41 Manjaro ksystemstats[4619]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Temperature %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 05 09:08:42 Manjaro akonadi_control[4689]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:08:42 Manjaro akonadiserver[4695]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:08:42 Manjaro plasmashell[4427]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/main.qml:70:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:08:42 Manjaro plasmashell[4427]: Both point size and pixel size set. Using pixel size.
Jan 05 09:08:42 Manjaro plasmashell[4427]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:82:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:08:42 Manjaro plasmashell[4427]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:76:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:08:42 Manjaro plasmashell[4427]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Jan 05 09:08:42 Manjaro plasmashell[4427]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jan 05 09:08:43 Manjaro akonadi_google_resource[4758]: org.kde.pim.google: Got error: KGAPI2::TaskListFetchJob(0x55b2cc198680) "Invalid response content type"
Jan 05 09:08:43 Manjaro akonadi_google_resource[4758]: org.kde.pim.google: Got error: KGAPI2::CalendarFetchJob(0x55b2cc194800) "Invalid response content type"
Jan 05 09:08:43 Manjaro plasmashell[4427]: Both point size and pixel size set. Using pixel size.
Jan 05 09:08:43 Manjaro kernel: snd_hda_codec_hdmi hdaudioC2D0: Unable to sync register 0x5f0800. -5
Jan 05 09:08:43 Manjaro plasmashell[4427]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:115:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:08:43 Manjaro plasmashell[4427]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:101:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:08:43 Manjaro plasmashell[4427]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:86:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:08:43 Manjaro plasmashell[4427]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 05 09:08:43 Manjaro plasmashell[4427]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:08:43 Manjaro plasmashell[4427]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:08:44 Manjaro pulseaudio[4840]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jan 05 09:08:44 Manjaro pulseaudio[4840]: GetManagedObjects() failed: org.freedesktop.systemd1.NoSuchUnit: Unit dbus-org.bluez.service not found.
Jan 05 09:08:45 Manjaro kstart5[4897]: Omitting both --window and --windowclass arguments is not recommended
Jan 05 09:08:45 Manjaro plasmashell[4427]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:08:45 Manjaro konsole[4902]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 05 09:08:45 Manjaro konsole[4902]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 05 09:08:46 Manjaro plasmashell[4427]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:08:46 Manjaro plasmashell[4427]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:08:46 Manjaro plasmashell[4427]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 05 09:08:46 Manjaro plasmashell[4427]: file:///usr/share/plasma/plasmoids/org.kde.plasma.diskquota/contents/ui/main.qml:75: ReferenceError: model is not defined
Jan 05 09:08:47 Manjaro kernel: kauditd_printk_skb: 51 callbacks suppressed
Jan 05 09:09:11 Manjaro kalarm[5369]: org.kde.pim.kalarm: MigrateKde4Files::migrate: Can't find KDE4 data directory
Jan 05 09:09:11 Manjaro plasmashell[4427]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:09:11 Manjaro kernel: kauditd_printk_skb: 4 callbacks suppressed
Jan 05 09:09:18 Manjaro plasmashell[4427]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:162: TypeError: Cannot read property 'text' of null
Jan 05 09:09:18 Manjaro plasmashell[4427]: trying to show an empty dialog
Jan 05 09:09:18 Manjaro plasmashell[4427]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Jan 05 09:09:21 Manjaro kernel: iwlwifi 0000:03:00.0: RF_KILL bit toggled to enable radio.
Jan 05 09:09:21 Manjaro kernel: iwlwifi 0000:03:00.0: reporting RF_KILL (radio enabled)
Jan 05 09:09:22 Manjaro NetworkManager[1621]: <warn> [1672902562.0466] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Jan 05 09:09:22 Manjaro plasmashell[4427]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Jan 05 09:09:27 Manjaro plasmashell[4427]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Jan 05 09:09:28 Manjaro plasmashell[4427]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5627b05ab490) QQmlContext(0x5627ae80bdc0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jan 05 09:09:28 Manjaro plasmashell[4427]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jan 05 09:09:28 Manjaro plasmashell[4427]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jan 05 09:09:29 Manjaro plasmashell[4427]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:09:33 Manjaro kdeconnectd[4569]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:09:33 Manjaro plasmashell[4427]: file:///usr/share/plasma/plasmoids/org.kde.kdeconnect/contents/ui/FullRepresentation.qml:37:23: QML DeviceDelegate: Binding loop detected for property "height"
Jan 05 09:09:34 Manjaro kdeconnectd[4569]: kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/juba/.local/share/kpeoplevcard/kdeconnect-5140bc793a3634c7/1123i756384398fbe2e9b.851r1003-2E524E504E324C543A2E32.851r1111-2E524E504E324C543A2E32.851r1124-2E524E504E324C543A2E32.851r1338-2E524E504E324C543A2E32.851r1687-2E524E504E324C543A2E32.851r1707-2E524E504E324C543A2E32.851r1720-2E524E504E324C543A2E32.851r1741-2E524E504E324C543A2E32.851r1758-2E524E504E324C543A2E32.851r1771-2E524E504E324C543A2E32.851r1789-2E524E504E324C543A2E32.851r1813-2E524E504E324C543A2E32.851r1830-2E524E504E324C543A2E32.851r1845-2E524E504E324C543A2E32.vcf"
Jan 05 09:09:34 Manjaro plasmashell[4427]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5627b0bed530) QQmlContext(0x5627ae80bdc0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jan 05 09:09:34 Manjaro plasmashell[4427]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jan 05 09:09:34 Manjaro plasmashell[4427]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jan 05 09:10:41 Manjaro akonadi_contacts_resource[4757]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:10:41 Manjaro kglobalaccel5[4414]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:10:41 Manjaro kwalletd5[4322]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:10:41 Manjaro ksmserver[4392]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:10:41 Manjaro kded5[4394]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:10:41 Manjaro kwin_x11[4395]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:10:41 Manjaro akonadi_control[4689]: org.kde.pim.akonadicontrol: ProcessControl: Application '/usr/bin/akonadi_contacts_resource' returned with exit code 1 (Unknown error)
Jan 05 09:10:41 Manjaro kglobalaccel5[4414]: The X11 connection broke: I/O error (code 1)
Jan 05 09:10:41 Manjaro org_kde_powerdevil[4456]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:10:41 Manjaro systemd[4309]: plasma-ksmserver.service: Failed with result 'exit-code'.
Jan 05 09:10:41 Manjaro systemd[4309]: plasma-kglobalaccel.service: Failed with result 'exit-code'.
Jan 05 09:10:41 Manjaro systemd[4309]: plasma-polkit-agent.service: Failed with result 'exit-code'.
Jan 05 09:10:41 Manjaro plasmashell[4427]: org.kde.pim.akonadicore: "QLocalSocket: Remote closed" "/run/user/1000/akonadi/akonadiserver-ntf.socket"
Jan 05 09:10:41 Manjaro plasmashell[4427]: org.kde.pim.akonadicore: "QLocalSocket: Remote closed" "/run/user/1000/akonadi/akonadiserver-cmd.socket"
Jan 05 09:10:41 Manjaro plasmashell[4427]: QXcbClipboard::setMimeData: Cannot set X11 selection owner
Jan 05 09:10:41 Manjaro systemd[4309]: plasma-kded.service: Failed with result 'exit-code'.
Jan 05 09:10:41 Manjaro systemd[4309]: app-org.moson.matray@autostart.service: Failed with result 'exit-code'.
Jan 05 09:10:41 Manjaro startplasma-x11[4323]: org.kde.startup: "kdeinit5_shutdown" () exited with code 255
Jan 05 09:10:41 Manjaro kactivitymanagerd[4447]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:10:41 Manjaro plasmashell[4427]: org.kde.pim.akonadicore: Socket error occurred: "QLocalSocket: Remote closed"
Jan 05 09:10:41 Manjaro systemd[4309]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Jan 05 09:10:41 Manjaro pulseaudio[4840]: Error opening PCM device front:1: No such file or directory
Jan 05 09:10:43 Manjaro systemd[5844]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Jan 05 09:10:43 Manjaro systemd[5844]: Failed to start Update XDG user dir configuration.
Jan 05 09:10:43 Manjaro sddm-greeter[5853]: QFont::fromString: Invalid description '(empty)'
Jan 05 09:10:43 Manjaro sddm-greeter[5853]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd1d39dd40), parent's thread is QThread(0x55dc71b106a0), current thread is QThread(0x55dc71c31660)
Jan 05 09:10:43 Manjaro sddm-greeter[5853]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jan 05 09:10:43 Manjaro sddm-greeter[5853]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jan 05 09:10:43 Manjaro sddm-greeter[5853]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jan 05 09:10:43 Manjaro sddm-greeter[5853]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jan 05 09:10:44 Manjaro sddm-greeter[5853]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Jan 05 09:10:49 Manjaro kernel: kauditd_printk_skb: 34 callbacks suppressed
Jan 05 09:10:50 Manjaro systemd-xdg-autostart-generator[5901]: /home/juba/.config/autostart/org.kde.latte-dock.desktop:114: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Jan 05 09:10:50 Manjaro ksplashqml[5888]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Jan 05 09:10:50 Manjaro ksplashqml[5888]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Jan 05 09:10:50 Manjaro ksmserver[5940]: Qt: Session management error: networkIdsList argument is NULL
Jan 05 09:10:50 Manjaro ksmserver[5940]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.94'
Jan 05 09:10:50 Manjaro kwin_x11[5943]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jan 05 09:10:50 Manjaro kwin_x11[5943]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jan 05 09:10:50 Manjaro plasmashell[5981]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jan 05 09:10:50 Manjaro plasmashell[5981]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jan 05 09:10:51 Manjaro plasmashell[5981]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jan 05 09:10:51 Manjaro plasmashell[5981]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jan 05 09:10:51 Manjaro org_kde_powerdevil[6001]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jan 05 09:10:51 Manjaro org_kde_powerdevil[6001]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jan 05 09:10:51 Manjaro optimus-manager-qt[6077]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Jan 05 09:10:51 Manjaro msm_kde_notifier[6081]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Jan 05 09:10:51 Manjaro pamac-tray-plasma[6116]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Jan 05 09:10:51 Manjaro akonadi_control[6200]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:10:52 Manjaro ksystemstats[6224]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Voltage %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 05 09:10:52 Manjaro ksystemstats[6224]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Temperature %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 05 09:10:52 Manjaro kded5[5942]: kf.bluezqt: PendingCall Error: "Unit dbus-org.bluez.service not found."
Jan 05 09:10:52 Manjaro akonadiserver[6219]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:10:52 Manjaro plasmashell[5981]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/main.qml:70:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:10:52 Manjaro plasmashell[5981]: Both point size and pixel size set. Using pixel size.
Jan 05 09:10:52 Manjaro plasmashell[5981]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:82:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:10:52 Manjaro plasmashell[5981]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:76:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:10:53 Manjaro akonadiserver[6219]: org.kde.pim.akonadiserver: Cannot connect to agent instance with identifier 'akonadi_maildir_resource_0', error message: ''
Jan 05 09:10:53 Manjaro akonadi_google_resource[6279]: org.kde.pim.google: Got error: KGAPI2::CalendarFetchJob(0x55b3d03e20e0) "Invalid response content type"
Jan 05 09:10:53 Manjaro akonadi_google_resource[6279]: org.kde.pim.google: Got error: KGAPI2::TaskListFetchJob(0x55b3d03b8c10) "Invalid response content type"
Jan 05 09:10:53 Manjaro plasmashell[5981]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jan 05 09:10:53 Manjaro plasmashell[5981]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Jan 05 09:10:53 Manjaro kernel: snd_hda_codec_hdmi hdaudioC2D0: Unable to sync register 0x5f0800. -5
Jan 05 09:10:53 Manjaro plasmashell[5981]: Both point size and pixel size set. Using pixel size.
Jan 05 09:10:53 Manjaro plasmashell[5981]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:115:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:10:53 Manjaro plasmashell[5981]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:101:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:10:53 Manjaro plasmashell[5981]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:86:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:10:53 Manjaro plasmashell[5981]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 05 09:10:53 Manjaro plasmashell[5981]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:10:53 Manjaro plasmashell[5981]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:10:54 Manjaro plasmashell[5981]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:10:54 Manjaro pulseaudio[6384]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jan 05 09:10:54 Manjaro pulseaudio[6384]: GetManagedObjects() failed: org.freedesktop.systemd1.NoSuchUnit: Unit dbus-org.bluez.service not found.
Jan 05 09:10:54 Manjaro plasmashell[5981]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:10:54 Manjaro kstart5[6428]: Omitting both --window and --windowclass arguments is not recommended
Jan 05 09:10:54 Manjaro plasmashell[5981]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 05 09:10:54 Manjaro plasmashell[5981]: file:///usr/share/plasma/plasmoids/org.kde.plasma.diskquota/contents/ui/main.qml:75: ReferenceError: model is not defined
Jan 05 09:10:54 Manjaro konsole[6433]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 05 09:10:54 Manjaro konsole[6433]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 05 09:10:54 Manjaro kernel: kauditd_printk_skb: 18 callbacks suppressed
Jan 05 09:10:55 Manjaro plasmashell[5981]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:10:56 Manjaro plasmashell[5981]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:10:56 Manjaro plasmashell[5981]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:11:03 Manjaro kernel: kauditd_printk_skb: 3 callbacks suppressed
Jan 05 09:11:14 Manjaro kglobalaccel5[5970]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:14 Manjaro kwalletd5[5874]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:14 Manjaro kded5[5942]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:15 Manjaro ksmserver[5940]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:15 Manjaro kwin_x11[5943]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:15 Manjaro kglobalaccel5[5970]: The X11 connection broke: I/O error (code 1)
Jan 05 09:11:15 Manjaro gmenudbusmenuproxy[5999]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:15 Manjaro kactivitymanagerd[5991]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:15 Manjaro xembedsniproxy[6003]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:15 Manjaro org_kde_powerdevil[6001]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:15 Manjaro xdg-desktop-portal-kde[6002]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:15 Manjaro systemd[4309]: plasma-gmenudbusmenuproxy.service: Failed with result 'exit-code'.
Jan 05 09:11:15 Manjaro systemd[4309]: plasma-ksmserver.service: Failed with result 'exit-code'.
Jan 05 09:11:15 Manjaro systemd[4309]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
Jan 05 09:11:15 Manjaro plasmashell[5981]: org.kde.pim.akonadicore: "QLocalSocket: Remote closed" "/run/user/1000/akonadi/akonadiserver-ntf.socket"
Jan 05 09:11:15 Manjaro plasmashell[5981]: org.kde.pim.akonadicore: "QLocalSocket: Remote closed" "/run/user/1000/akonadi/akonadiserver-cmd.socket"
Jan 05 09:11:15 Manjaro plasmashell[5981]: org.kde.pim.akonadicore: Socket error occurred: "QLocalSocket: Remote closed"
Jan 05 09:11:15 Manjaro startplasma-x11[5875]: org.kde.startup: "kdeinit5_shutdown" () exited with code 255
Jan 05 09:11:15 Manjaro systemd[4309]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Jan 05 09:11:15 Manjaro systemd[4309]: plasma-kded.service: Failed with result 'exit-code'.
Jan 05 09:11:15 Manjaro systemd[4309]: app-org.moson.matray@autostart.service: Failed with result 'exit-code'.
Jan 05 09:11:15 Manjaro pulseaudio[6384]: Error opening PCM device front:1: No such file or directory
Jan 05 09:11:16 Manjaro systemd[6631]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Jan 05 09:11:16 Manjaro systemd[6631]: Failed to start Update XDG user dir configuration.
Jan 05 09:11:16 Manjaro sddm-greeter[6640]: QFont::fromString: Invalid description '(empty)'
Jan 05 09:11:16 Manjaro sddm-greeter[6640]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffe07298100), parent's thread is QThread(0x556c41e276a0), current thread is QThread(0x556c41f47950)
Jan 05 09:11:16 Manjaro sddm-greeter[6640]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jan 05 09:11:17 Manjaro sddm-greeter[6640]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jan 05 09:11:17 Manjaro sddm-greeter[6640]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jan 05 09:11:17 Manjaro sddm-greeter[6640]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jan 05 09:11:17 Manjaro sddm-greeter[6640]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Jan 05 09:11:22 Manjaro kernel: kauditd_printk_skb: 34 callbacks suppressed
Jan 05 09:11:22 Manjaro NetworkManager[1621]: <warn> [1672902682.4484] device (wlp3s0): no secrets: No agents were available for this request.
Jan 05 09:11:22 Manjaro NetworkManager[1621]: <warn> [1672902682.4487] device (wlp3s0): Activation: failed for connection '802.11'
Jan 05 09:11:22 Manjaro NetworkManager[1621]: <warn> [1672902682.4554] device (wlp3s0): no secrets: No agents were available for this request.
Jan 05 09:11:22 Manjaro NetworkManager[1621]: <warn> [1672902682.4558] device (wlp3s0): Activation: failed for connection 'Completion'
Jan 05 09:11:22 Manjaro systemd-xdg-autostart-generator[6694]: /home/juba/.config/autostart/org.kde.latte-dock.desktop:114: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Jan 05 09:11:23 Manjaro ksplashqml[6681]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Jan 05 09:11:23 Manjaro ksplashqml[6681]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Jan 05 09:11:23 Manjaro ksmserver[6733]: Qt: Session management error: networkIdsList argument is NULL
Jan 05 09:11:23 Manjaro ksmserver[6733]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.160'
Jan 05 09:11:23 Manjaro kwin_x11[6736]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jan 05 09:11:23 Manjaro kwin_x11[6736]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jan 05 09:11:23 Manjaro plasmashell[6773]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jan 05 09:11:23 Manjaro plasmashell[6773]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jan 05 09:11:23 Manjaro org_kde_powerdevil[6793]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jan 05 09:11:24 Manjaro kded5[6735]: kf.bluezqt: PendingCall Error: "Unit dbus-org.bluez.service not found."
Jan 05 09:11:24 Manjaro org_kde_powerdevil[6793]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jan 05 09:11:24 Manjaro org_kde_powerdevil[6793]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jan 05 09:11:24 Manjaro ksystemstats[6930]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Voltage %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 05 09:11:24 Manjaro ksystemstats[6930]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Temperature %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 05 09:11:24 Manjaro akonadi_control[7014]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:11:25 Manjaro plasmashell[6773]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/main.qml:70:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:25 Manjaro plasmashell[6773]: Both point size and pixel size set. Using pixel size.
Jan 05 09:11:25 Manjaro plasmashell[6773]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:82:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:25 Manjaro plasmashell[6773]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:76:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:25 Manjaro akonadiserver[7020]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:11:25 Manjaro plasmashell[6773]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Jan 05 09:11:25 Manjaro plasmashell[6773]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jan 05 09:11:25 Manjaro kstart5[7088]: Omitting both --window and --windowclass arguments is not recommended
Jan 05 09:11:25 Manjaro kernel: snd_hda_codec_hdmi hdaudioC2D0: Unable to sync register 0x5f0800. -5
Jan 05 09:11:26 Manjaro plasmashell[6773]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:115:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:26 Manjaro plasmashell[6773]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:101:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:26 Manjaro plasmashell[6773]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:86:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:26 Manjaro konsole[7125]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 05 09:11:26 Manjaro konsole[7125]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 05 09:11:26 Manjaro akonadi_google_resource[7079]: org.kde.pim.google: Got error: KGAPI2::TaskListFetchJob(0x561ea181e330) "Invalid response content type"
Jan 05 09:11:26 Manjaro plasmashell[6773]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 05 09:11:26 Manjaro akonadi_google_resource[7079]: org.kde.pim.google: Got error: KGAPI2::CalendarFetchJob(0x561ea1832520) "Invalid response content type"
Jan 05 09:11:26 Manjaro plasmashell[6773]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:11:26 Manjaro plasmashell[6773]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:11:26 Manjaro pulseaudio[7112]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jan 05 09:11:26 Manjaro pulseaudio[7112]: GetManagedObjects() failed: org.freedesktop.systemd1.NoSuchUnit: Unit dbus-org.bluez.service not found.
Jan 05 09:11:27 Manjaro plasmashell[6773]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:11:27 Manjaro kernel: kauditd_printk_skb: 25 callbacks suppressed
Jan 05 09:11:29 Manjaro plasmashell[6773]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:11:29 Manjaro plasmashell[6773]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 05 09:11:29 Manjaro plasmashell[6773]: file:///usr/share/plasma/plasmoids/org.kde.plasma.diskquota/contents/ui/main.qml:75: ReferenceError: model is not defined
Jan 05 09:11:29 Manjaro plasmashell[6773]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:11:34 Manjaro kdeconnectd[6899]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:11:35 Manjaro plasmashell[6773]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x56059a758950) QQmlContext(0x560598d3c530) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jan 05 09:11:35 Manjaro plasmashell[6773]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jan 05 09:11:35 Manjaro plasmashell[6773]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jan 05 09:11:35 Manjaro kdeconnectd[6899]: kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/juba/.local/share/kpeoplevcard/kdeconnect-5140bc793a3634c7/1123i756384398fbe2e9b.851r1003-2E524E504E324C543A2E32.851r1111-2E524E504E324C543A2E32.851r1124-2E524E504E324C543A2E32.851r1338-2E524E504E324C543A2E32.851r1687-2E524E504E324C543A2E32.851r1707-2E524E504E324C543A2E32.851r1720-2E524E504E324C543A2E32.851r1741-2E524E504E324C543A2E32.851r1758-2E524E504E324C543A2E32.851r1771-2E524E504E324C543A2E32.851r1789-2E524E504E324C543A2E32.851r1813-2E524E504E324C543A2E32.851r1830-2E524E504E324C543A2E32.851r1845-2E524E504E324C543A2E32.vcf"
Jan 05 09:11:37 Manjaro kernel: kauditd_printk_skb: 4 callbacks suppressed
Jan 05 09:11:40 Manjaro akonadi_contacts_resource[7078]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro kglobalaccel5[6760]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro kded5[6735]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro kwalletd5[6667]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro ksmserver[6733]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro kwin_x11[6736]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro kglobalaccel5[6760]: The X11 connection broke: I/O error (code 1)
Jan 05 09:11:40 Manjaro plasmashell[6773]: QXcbClipboard::setMimeData: Cannot set X11 selection owner
Jan 05 09:11:40 Manjaro akonadi_control[7014]: org.kde.pim.akonadicontrol: ProcessControl: Application '/usr/bin/akonadi_contacts_resource' returned with exit code 1 (Unknown error)
Jan 05 09:11:40 Manjaro gmenudbusmenuproxy[6791]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro polkit-kde-authentication-agent-1[6792]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro xdg-desktop-portal-kde[6795]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro xembedsniproxy[6796]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro akonadi_control[7014]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro systemd[4309]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
Jan 05 09:11:40 Manjaro kdeconnectd[6899]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro optimus-manager-qt[6892]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro akonadi_maildir_resource[7082]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro akonadi_maildispatcher_agent[7083]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro akonadi_google_resource[7079]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro akonadi_ical_resource[7080]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro kdeconnectd[6899]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo"
Jan 05 09:11:40 Manjaro kdeconnectd[6899]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_00_1b.0.analog-stereo"
Jan 05 09:11:40 Manjaro systemd[4309]: plasma-kglobalaccel.service: Failed with result 'exit-code'.
Jan 05 09:11:40 Manjaro systemd[4309]: plasma-ksmserver.service: Failed with result 'exit-code'.
Jan 05 09:11:40 Manjaro systemd[4309]: plasma-kded.service: Failed with result 'exit-code'.
Jan 05 09:11:40 Manjaro systemd[4309]: plasma-gmenudbusmenuproxy.service: Failed with result 'exit-code'.
Jan 05 09:11:40 Manjaro systemd[4309]: plasma-polkit-agent.service: Failed with result 'exit-code'.
Jan 05 09:11:40 Manjaro systemd[4309]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
Jan 05 09:11:40 Manjaro systemd[4309]: app-org.moson.matray@autostart.service: Failed with result 'exit-code'.
Jan 05 09:11:40 Manjaro plasmashell[6773]: org.kde.pim.akonadicore: "QLocalSocket: Remote closed" "/run/user/1000/akonadi/akonadiserver-ntf.socket"
Jan 05 09:11:40 Manjaro plasmashell[6773]: org.kde.pim.akonadicore: "QLocalSocket: Remote closed" "/run/user/1000/akonadi/akonadiserver-cmd.socket"
Jan 05 09:11:40 Manjaro kactivitymanagerd[6788]: The X11 connection broke (error 1). Did the X11 server die?
Jan 05 09:11:40 Manjaro startplasma-x11[6668]: org.kde.startup: "kdeinit5_shutdown" () exited with code 255
Jan 05 09:11:40 Manjaro systemd[4309]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Jan 05 09:11:40 Manjaro pulseaudio[7112]: Error opening PCM device front:1: No such file or directory
Jan 05 09:11:41 Manjaro systemd[7408]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Jan 05 09:11:41 Manjaro systemd[7408]: Failed to start Update XDG user dir configuration.
Jan 05 09:11:42 Manjaro sddm-greeter[7417]: QFont::fromString: Invalid description '(empty)'
Jan 05 09:11:42 Manjaro sddm-greeter[7417]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffe414c41d0), parent's thread is QThread(0x558669eed6a0), current thread is QThread(0x55866a00d0a0)
Jan 05 09:11:42 Manjaro sddm-greeter[7417]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jan 05 09:11:42 Manjaro sddm-greeter[7417]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jan 05 09:11:42 Manjaro sddm-greeter[7417]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jan 05 09:11:42 Manjaro sddm-greeter[7417]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jan 05 09:11:42 Manjaro sddm-greeter[7417]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Jan 05 09:11:46 Manjaro kernel: kauditd_printk_skb: 35 callbacks suppressed
Jan 05 09:11:47 Manjaro systemd-xdg-autostart-generator[7469]: /home/juba/.config/autostart/org.kde.latte-dock.desktop:114: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Jan 05 09:11:47 Manjaro ksplashqml[7456]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Jan 05 09:11:47 Manjaro ksplashqml[7456]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Jan 05 09:11:47 Manjaro NetworkManager[1621]: <warn> [1672902707.6790] device (wlp3s0): no secrets: No agents were available for this request.
Jan 05 09:11:47 Manjaro NetworkManager[1621]: <warn> [1672902707.6794] device (wlp3s0): Activation: failed for connection '802.11'
Jan 05 09:11:47 Manjaro NetworkManager[1621]: <warn> [1672902707.6870] device (wlp3s0): no secrets: No agents were available for this request.
Jan 05 09:11:47 Manjaro NetworkManager[1621]: <warn> [1672902707.6875] device (wlp3s0): Activation: failed for connection 'Completion'
Jan 05 09:11:47 Manjaro ksmserver[7508]: Qt: Session management error: networkIdsList argument is NULL
Jan 05 09:11:47 Manjaro ksmserver[7508]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.226'
Jan 05 09:11:47 Manjaro kwin_x11[7511]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jan 05 09:11:47 Manjaro kwin_x11[7511]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jan 05 09:11:48 Manjaro plasmashell[7549]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jan 05 09:11:48 Manjaro plasmashell[7549]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jan 05 09:11:48 Manjaro org_kde_powerdevil[7579]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jan 05 09:11:48 Manjaro kded5[7510]: kf.bluezqt: PendingCall Error: "Unit dbus-org.bluez.service not found."
Jan 05 09:11:48 Manjaro kded5[7510]: kscreen.kded: PowerDevil SuspendSession action not available!
Jan 05 09:11:48 Manjaro org_kde_powerdevil[7579]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jan 05 09:11:48 Manjaro ksystemstats[7666]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Voltage %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 05 09:11:48 Manjaro ksystemstats[7666]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Temperature %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 05 09:11:49 Manjaro akonadi_control[7787]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:11:49 Manjaro akonadiserver[7799]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:11:49 Manjaro plasmashell[7549]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/main.qml:70:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:49 Manjaro plasmashell[7549]: Both point size and pixel size set. Using pixel size.
Jan 05 09:11:49 Manjaro plasmashell[7549]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:82:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:49 Manjaro plasmashell[7549]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:76:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:49 Manjaro plasmashell[7549]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jan 05 09:11:49 Manjaro plasmashell[7549]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Jan 05 09:11:50 Manjaro kstart5[7894]: Omitting both --window and --windowclass arguments is not recommended
Jan 05 09:11:50 Manjaro kernel: snd_hda_codec_hdmi hdaudioC2D0: Unable to sync register 0x5f0800. -5
Jan 05 09:11:50 Manjaro akonadi_google_resource[7851]: org.kde.pim.google: Got error: KGAPI2::CalendarFetchJob(0x563a7599b5f0) "Invalid response content type"
Jan 05 09:11:50 Manjaro akonadi_google_resource[7851]: org.kde.pim.google: Got error: KGAPI2::TaskListFetchJob(0x563a7599f1f0) "Invalid response content type"
Jan 05 09:11:50 Manjaro plasmashell[7549]: Both point size and pixel size set. Using pixel size.
Jan 05 09:11:50 Manjaro plasmashell[7549]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:115:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:50 Manjaro plasmashell[7549]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:101:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:50 Manjaro plasmashell[7549]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:86:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 05 09:11:50 Manjaro plasmashell[7549]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 05 09:11:50 Manjaro plasmashell[7549]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:11:50 Manjaro konsole[7954]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 05 09:11:50 Manjaro konsole[7954]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 05 09:11:50 Manjaro plasmashell[7549]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:11:50 Manjaro pulseaudio[7921]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jan 05 09:11:50 Manjaro pulseaudio[7921]: GetManagedObjects() failed: org.freedesktop.systemd1.NoSuchUnit: Unit dbus-org.bluez.service not found.
Jan 05 09:11:52 Manjaro plasmashell[7549]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:11:52 Manjaro kernel: kauditd_printk_skb: 9 callbacks suppressed
Jan 05 09:11:53 Manjaro plasmashell[7549]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:11:53 Manjaro plasmashell[7549]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 05 09:11:53 Manjaro plasmashell[7549]: file:///usr/share/plasma/plasmoids/org.kde.plasma.diskquota/contents/ui/main.qml:75: ReferenceError: model is not defined
Jan 05 09:11:54 Manjaro plasmashell[7549]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:11:55 Manjaro plasmashell[7549]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 05 09:11:59 Manjaro kdeconnectd[7679]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jan 05 09:11:59 Manjaro plasmashell[7549]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x559f868dddd0) QQmlContext(0x559f8544e270) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jan 05 09:11:59 Manjaro plasmashell[7549]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jan 05 09:11:59 Manjaro plasmashell[7549]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jan 05 09:11:59 Manjaro kdeconnectd[7679]: kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/juba/.local/share/kpeoplevcard/kdeconnect-5140bc793a3634c7/1123i756384398fbe2e9b.851r1003-2E524E504E324C543A2E32.851r1111-2E524E504E324C543A2E32.851r1124-2E524E504E324C543A2E32.851r1338-2E524E504E324C543A2E32.851r1687-2E524E504E324C543A2E32.851r1707-2E524E504E324C543A2E32.851r1720-2E524E504E324C543A2E32.851r1741-2E524E504E324C543A2E32.851r1758-2E524E504E324C543A2E32.851r1771-2E524E504E324C543A2E32.851r1789-2E524E504E324C543A2E32.851r1813-2E524E504E324C543A2E32.851r1830-2E524E504E324C543A2E32.851r1845-2E524E504E324C543A2E32.vcf"
Jan 05 09:12:01 Manjaro kernel: kauditd_printk_skb: 4 callbacks suppressed
Jan 05 09:12:05 Manjaro plasmashell[7549]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:162: TypeError: Cannot read property 'text' of null
Jan 05 09:12:05 Manjaro plasmashell[7549]: trying to show an empty dialog
Jan 05 09:12:05 Manjaro plasmashell[7549]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Jan 05 09:12:05 Manjaro plasmashell[7549]: file:///usr/share/plasma/plasmoids/org.kde.kdeconnect/contents/ui/FullRepresentation.qml:37:23: QML DeviceDelegate: Binding loop detected for property "height"
Jan 05 09:12:08 Manjaro plasmashell[7549]: trying to show an empty dialog
Jan 05 09:12:19 Manjaro kalarm[8145]: org.kde.pim.kalarm: MigrateKde4Files::migrate: Can't find KDE4 data directory
Jan 05 09:12:19 Manjaro plasmashell[7549]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 05 09:12:21 Manjaro plasmashell[7549]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Jan 05 09:12:22 Manjaro plasmashell[7549]: kf.coreaddons: "Could not find plugin org.kde.desktopcontainment"
Jan 05 09:12:22 Manjaro plasmashell[7549]: Error loading KCM: "Could not find plugin org.kde.desktopcontainment"
Jan 05 09:12:22 Manjaro plasmashell[7549]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationContainmentAppearance.qml:210: TypeError: Cannot read property 'objectName' of null
Jan 05 09:12:22 Manjaro plasmashell[7549]: kf.coreaddons: "Could not find plugin org.kde.image"
Jan 05 09:12:22 Manjaro plasmashell[7549]: Error loading KCM: "Could not find plugin org.kde.image"
Jan 05 09:12:22 Manjaro plasmashell[7549]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationContainmentAppearance.qml:138:9: QML StackView: Binding loop detected for property "implicitHeight"
Jan 05 09:12:22 Manjaro plasmashell[7549]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationAppletPage.qml:38:5: QML Loader: Binding loop detected for property "height"
Jan 05 09:12:22 Manjaro plasmashell[7549]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationContainmentAppearance.qml:51:5: QML ColumnLayout: Binding loop detected for property "height"
Jan 05 09:12:22 Manjaro plasmashell[7549]: file:///usr/lib/qt/qml/org/kde/kcm/SettingHighlighter.qml:0: ReferenceError: kcm is not defined
Jan 05 09:12:22 Manjaro plasmashell[7549]: file:///usr/share/plasma/plasmoids/org.kde.plasma.diskquota/contents/ui/main.qml:75: ReferenceError: model is not defined
Jan 05 09:12:22 Manjaro plasmashell[7549]: Both point size and pixel size set. Using pixel size.
Jan 05 09:12:22 Manjaro plasmashell[7549]: file:///home/juba/.local/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/Tooltip.qml:106:13: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jan 05 09:12:22 Manjaro plasmashell[7549]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Jan 05 09:12:22 Manjaro plasmashell[7549]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Jan 05 09:12:33 Manjaro kdeconnectd[7679]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo"
Jan 05 09:12:33 Manjaro kdeconnectd[7679]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_00_1b.0.analog-stereo"
Jan 05 09:12:36 Manjaro kernel: ACPI: button: The lid device is not compliant to SW_LID.
Jan 05 09:12:37 Manjaro kded5[7510]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Jan 05 17:58:56 Manjaro kernel: snd_hda_intel 0000:01:00.1: can't change power state from D0 to D3hot (config space inaccessible)
Jan 05 17:58:56 Manjaro kernel: xhci_hcd 0000:00:14.0: xHC error in resume, USBSTS 0x401, Reinit
Jan 05 17:58:56 Manjaro kernel: ata1.00: ATA Identify Device Log not supported
Jan 05 17:58:56 Manjaro kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
Jan 05 17:58:56 Manjaro kernel: acpi PNP0401:00: Already enumerated
Jan 05 17:58:56 Manjaro kernel: acpi PNP0501:00: Still not present
Jan 05 17:58:56 Manjaro kernel: snd_hda_codec_hdmi hdaudioC2D0: Unable to sync register 0x5f0800. -5
Jan 05 17:59:00 Manjaro NetworkManager[1621]: <warn> [1672934340.7268] device (wlp3s0): no secrets: No agents were available for this request.
Jan 05 17:59:00 Manjaro NetworkManager[1621]: <warn> [1672934340.7271] device (wlp3s0): Activation: failed for connection '802.11'
Jan 05 17:59:04 Manjaro NetworkManager[1621]: <warn> [1672934344.3815] device (wlp3s0): no secrets: No agents were available for this request.
Jan 05 17:59:04 Manjaro NetworkManager[1621]: <warn> [1672934344.3819] device (wlp3s0): Activation: failed for connection 'Completion'
Jan 05 17:59:14 Manjaro kernel: usb 1-1.5: device descriptor read/64, error -71
Jan 05 17:59:15 Manjaro kernel: usb 1-1.5: unable to read config index 0 descriptor/all
Jan 05 17:59:15 Manjaro kernel: usb 1-1.5: can't read configurations, error -71
Jan 05 17:59:15 Manjaro kernel: usb 1-1-port5: Cannot enable. Maybe the USB cable is bad?
Jan 05 17:59:16 Manjaro kernel: usb 1-1.5: unable to read config index 0 descriptor/all
Jan 05 17:59:16 Manjaro kernel: usb 1-1.5: can't read configurations, error -71
Jan 05 17:59:22 Manjaro ModemManager[1652]: <warn> [plugin/generic] could not grab port ttyS4: Cannot add port 'tty/ttyS4', unhandled port type
Jan 05 17:59:22 Manjaro ModemManager[1652]: <warn> [base-manager] couldn't create modem for device '/sys/devices/pci0000:00/0000:00:16.3': Failed to find primary AT port
Jan 05 17:59:55 Manjaro kernel: usb 1-1-port5: Cannot enable. Maybe the USB cable is bad?
Jan 05 17:59:57 Manjaro kernel: usb 1-1-port5: Cannot enable. Maybe the USB cable is bad?
Jan 05 17:59:58 Manjaro kernel: usb 1-1-port5: Cannot enable. Maybe the USB cable is bad?
Jan 05 17:59:59 Manjaro kernel: usb 1-1-port5: Cannot enable. Maybe the USB cable is bad?
Jan 05 18:00:00 Manjaro kernel: usb 1-1-port5: Cannot enable. Maybe the USB cable is bad?
Jan 05 18:00:00 Manjaro kernel: usb 1-1-port5: unable to enumerate USB device
Colorful output (before killing sddm):
colorful output (after killing sddm):
I think you will need PCI devices
lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 04)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
00:16.3 Serial controller: Intel Corporation 8 Series/C220 Series Chipset Family KT Controller (rev 04)
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-LM (rev 04)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d4)
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d4)
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d4)
00:1c.4 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #5 (rev d4)
00:1c.6 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #7 (rev d4)
00:1c.7 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #8 (rev d4)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation QM87 Express LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GK107GLM [Quadro K1100M] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GK107 HDMI Audio Controller (rev a1)
03:00.0 Network controller: Intel Corporation Wireless 7260 (rev bb)
11:00.0 SD Host controller: O2 Micro, Inc. SD/MMC Card Reader Controller (rev 01)
first you have this:
run fsck on that partition, if its your root partition, you need to boot into live usb and run it from there, dont ignore this error!
and for this:
in system settings disable any actions when lid closes - set it to ‘do nothing’
and for this:
disable power saving options for this:
kate /etc/modprobe.d/snd-hda-intel.conf
add there these options:
options snd_hda_intel power_save=0
options snd_hda_intel power_save_controller=N
save it
reboot and test
File system error
- ext4 error solved using
e2fsck, It was not the root partition it was the HDD.
e2fsck /dev/sda1 ✔ root@Manjaro
e2fsck 1.46.5 (30-Dec-2021)
MahmoudHDD contains a file system with errors, check forced.
Pass 1: Checking inodes, blocks, and sizes
Inode 54 extent tree (at level 2) could be narrower. Optimize<y>? yes
Inode 16515102 extent tree (at level 1) could be narrower. Optimize<y>? yes
Pass 1E: Optimizing extent trees
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
/lost+found not found. Create<y>? yes
Pass 4: Checking reference counts
Pass 5: Checking group summary information
MahmoudHDD: ***** FILE SYSTEM WAS MODIFIED *****
MahmoudHDD: 906986/19537920 files (0.6% non-contiguous), 51312115/78142464 blocks
snd_hda_intel error
- I created snd-dha-intel.conf with the suggested content but the error still appear after sleep
cat /etc/modprobe.d/snd-hda-intel.conf ✔ root@Manjaro
lid error
- It’s very annoying to disable sleeping when closing lid, So I will not do that
I’m having the same problem (as stated in this other post). I didn’t quite understand which command gave the output with the errors that were found. EDIT: Okay I got it it’s journalctl -b0 -p4 --no-pager . But when do you run it? After force-rebooting whenever you’re confronted to this black screen? In my case I can’t acces to tty, it’s just force-reboot or wait till the battery is over ![]()
And, more importantly, is the sleep problem still there for you, after those fixes?
check with this if its disabled, it should return 0:
cat /sys/module/snd_hda_intel/parameters/power_save
this is for testing purposes, to see if its related or not…
you use wayland, so try with xorg…
and the logs for the previous failed boot are these:
journalctl -b-1 -p4 --no-pager
0
- Ok I’ll disable lid functions
@brahma
Thank you very much, The problem has been solved.
I have one question please, what is the meaning of the configuration we added in this file snd-hda-intel.conf, does that mean disabling power saving mode?
by the way, I have laptop-mode-tools installed.
how was it solved? with xorg?
it disables power saving on your audio card… if the xorg was the solution, you can delete the config:
sudo rm /etc/modprobe.d/snd-hda-intel.conf
