Black Screen With Cursor (top left) Instead of Login Screen
Hello, I’m having a problem when I decrypt my hard drive, it runs through everything like normal, but then when I would be greeted with a log-in screen it is just a black screen with a flashing cursor in the top left of the screen. I can not type or do anything on this screen. I thought about updating my bios to see if that fixes it but want to see if there is another option first. What should I do?
Thank you for your time,
Jesse.
  Kernel: 5.9.16-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 10.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
    root=UUID=7b26bffd-8253-4fc8-b3bd-6ccb31b0123a rw quiet
    cryptdevice=UUID=c23a1bbe-b769-4379-a79d-73e29de8d9c5:luks-c23a1bbe-b769-4379-a79d-73e29de8d9c5
    root=/dev/mapper/luks-c23a1bbe-b769-4379-a79d-73e29de8d9c5
    udev.log_priority=3
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: B550 AORUS PRO AC v: x.x
    serial: <superuser required> UEFI: American Megatrends v: F11p
    date: 12/18/2020
  RAM: total: 31.37 GiB used: 1.91 GiB (6.1%)
  RAM Report:
    permissions: Unable to run dmidecode. Rinxi --admin --verbosity=7 --filter --width
    udev.log_priority=3
    date: 12/18/2020
  RAM Report:
  Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2316 high: 3592 min/max: 2200/3900 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3592 2: 2052
    3: 2052 4: 2053 5: 2196 6: 2197 7: 2195 8: 2197 9: 3592 10: 2052 11: 2053
    12: 2053 13: 2196 14: 2196 15: 2195 16: 2194 bogomips: 124615
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd
    wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    conditional, RSB filling
  Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: Gigabyte
    driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
    active: HDMI-A-1,HDMI-A-2 empty: DP-1, DP-2, DP-3, HDMI-A-3
    bus-ID: 0c:00.0 chip-ID: 1002:687f class-ID: 0300
  Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3000x1920 s-dpi: 96 s-size: 794x508mm (31.26x20.00")
    s-diag: 943mm (37.11")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-r model: ONA24HB19T01
    serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
    size: 517x323mm (20.35x12.72") diag: 610mm (24") ratio: 16:10 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary,top-left
    model: ONA18HO015 serial: <filter> built: 2017 res: 1080x1920 hz: 60 dpi: 70
    gamma: 1.2 size: 393x698mm (15.47x27.48") diag: 552mm (21.7")
    ratio: 16:10, 15:9 modes: max: 1920x1080 min: 720x400
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.1
    chip-ID: 1002:aaf8 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 09:00.0
    chip-ID: 8086:24fb class-ID: 0280
  IF: wlp9s0 state: up mac: <filter>
  Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-5:2 chip-ID: 8087:0aa7 class-ID: e001
  Device-1: luks-c23a1bbe-b769-4379-a79d-73e29de8d9c5 maj-min: 254:0
    type: LUKS dm: dm-0 size: 465.46 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 465.46 GiB
  Local Storage: total: 4.09 TiB used: 12.8 GiB (0.3%)
    model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
    rev: 111110WD temp: 40.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
    type: HDD rpm: 7200 serial: <filter> rev: 0001
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
  ID-1: / raw-size: 465.46 GiB size: 457.16 GiB (98.22%) used: 12.8 GiB (2.8%)
    fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-c23a1bbe-b769-4379-a79d-73e29de8d9c5 label: N/A
    uuid: 7b26bffd-8253-4fc8-b3bd-6ccb31b0123a
    used: 480 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 5397-7FFA
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-5:2 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
  Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-7:4 info: Integrated Express ITE Device type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-2: 1-8:5 info: Logitech G502 Proteus Spectrum Optical Mouse
    type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
    serial: <filter>
  Device-3: 1-9:6 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
    power: 100mA chip-ID: 258a:1006 class-ID: 0300
  Hub-3: 1-10:7 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 52.1 C mobo: N/A gpu: amdgpu temp: 50.0 C
    mem: 49.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1008
  Processes: 348 Uptime: 6m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1038 lib: 361
  Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.16
  Components:
    uuid: 5397-7FFA
    serial: <filter>
    mem: 49.0 C
General guidance is here:
But this kernel version doesn’t exist anymore…
I guess you have to update the kernel.
Ya, I tried to last time I booted but then this started happening after, and here we are. Thanks for the linked solution, I’ll let you know if it works.
