Black screen when powering on the system
i often get a black screen when powering on the system, and after i power it off from the power button and i power it on again it goes well.
how to know what is causing this problem? and how to fix it?
this is the log in a next successful log in after a non successful one:
    ~   journalctl -b-1 -p4 --no-pager                                                                ✔
مارس 31 01:55:21 Manaro kernel: x86/cpu: SGX disabled by BIOS.
مارس 31 01:55:21 Manaro kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
مارس 31 01:55:21 Manaro kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
مارس 31 01:55:21 Manaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
مارس 31 01:55:21 Manaro kernel: hpet_acpi_add: no address or irqs in _CRS
مارس 31 01:55:21 Manaro kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
مارس 31 01:55:21 Manaro kernel: i8042: Warning: Keylock active
مارس 31 01:55:21 Manaro kernel: usb 1-10: config 0 descriptor??
مارس 31 01:55:21 Manaro kernel: vboxdrv: loading out-of-tree module taints kernel.
مارس 31 01:55:21 Manaro kernel: VBoxNetAdp: Successfully started.
مارس 31 01:55:21 Manaro kernel: VBoxNetFlt: Successfully started.
مارس 31 01:55:20 Manaro systemd-vconsole-setup[198]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
مارس 31 01:55:20 Manaro systemd-vconsole-setup[198]: Fonts will not be copied to remaining consoles
مارس 31 01:55:21 Manaro systemd-udevd[220]: /etc/udev/rules.d/40-libsane.rules:26 GOTO="libsane_rules_end" has no matching label, ignoring.
مارس 31 01:55:21 Manaro systemd-udevd[220]: /etc/udev/rules.d/S99-2000S1.rules:26 GOTO="libsane_rules_end" has no matching label, ignoring.
مارس 31 01:55:21 Manaro kernel: wmi_bus wmi_bus-PNP0C14:01: WQBC data block query control method not found
مارس 31 01:55:21 Manaro kernel: ACPI Warning: SystemMemory range 0x00000000FE028000-0x00000000FE0281FF conflicts with OpRegion 0x00000000FE028000-0x00000000FE028207 (\_SB.PCI0.GEXP.BAR0) (20230628/utaddress-204)
مارس 31 01:55:21 Manaro kernel: intel-lpss: probe of INT3446:00 failed with error -16
مارس 31 01:55:22 Manaro systemd-vconsole-setup[372]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
مارس 31 01:55:22 Manaro systemd-vconsole-setup[372]: Fonts will not be copied to remaining consoles
مارس 31 01:55:23 Manaro kernel: Bluetooth: hci0: Failed to send firmware data (-19)
مارس 31 01:55:23 Manaro kernel: Bluetooth: hci0: sending frame failed (-19)
مارس 31 01:55:23 Manaro kernel: Bluetooth: hci0: FW download error recovery failed (-19)
مارس 31 01:55:23 Manaro kernel: Bluetooth: hci0: Supported features event size mismatch
مارس 31 01:55:23 Manaro kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
مارس 31 01:55:23 Manaro kernel: thermal thermal_zone7: failed to read out thermal zone (-61)
مارس 31 01:55:23 Manaro bluetoothd[403]: src/plugin.c:init_plugin() System does not support bap plugin
مارس 31 01:55:23 Manaro bluetoothd[403]: src/plugin.c:init_plugin() System does not support bass plugin
مارس 31 01:55:23 Manaro bluetoothd[403]: src/plugin.c:init_plugin() System does not support mcp plugin
مارس 31 01:55:23 Manaro bluetoothd[403]: src/plugin.c:init_plugin() System does not support vcp plugin
مارس 31 01:55:23 Manaro bluetoothd[403]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
مارس 31 01:55:23 Manaro bluetoothd[403]: src/plugin.c:init_plugin() System does not support micp plugin
مارس 31 01:55:23 Manaro bluetoothd[403]: src/plugin.c:init_plugin() System does not support ccp plugin
مارس 31 01:55:23 Manaro bluetoothd[403]: src/plugin.c:init_plugin() System does not support csip plugin
output of: sudo inxi --admin --verbosity=8 --filter --no-host --width --repos
 sudo inxi --admin --verbosity=8 --filter --no-host --width --repos         ✔
[sudo] password for pc:
  Kernel: 6.7.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
    root=UUID=94056c3c-7682-4647-ae52-62c2357c4be2 rw quiet splash
    resume=UUID=16903b87-9499-4dcb-907d-8ae397807ed4 udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Laptop System: Dell product: Latitude 7480 v: N/A serial: <filter>
    Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0CDXCF v: A00 serial: <filter> part-nu: 07A0
    uuid: 4c4c4544-004c-5910-8050-cac04f504c32 UEFI: Dell v: 1.36.0
    date: 01/29/2024
  ID-1: BAT0 charge: 11.5 Wh (54.8%) condition: 21.0/60.0 Wh (34.9%) volts: 7.7
    min: 7.6 model: SMP DELL DM3WC64 type: Li-poly serial: <filter>
    status: discharging
  System RAM: total: 12 GiB available: 11.56 GiB used: 6.81 GiB (58.9%)
    igpu: 32 MiB
  Device-1: DIMM A type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: spec: 2400 MT/s actual: 2133 MT/s volts: curr: 1.2
    min: 1.2 max: 1.2 width (bits): data: 64 total: 64
    manufacturer: 01980000802C part-no: KMKYF9-MIH serial: <filter>
  Device-2: DIMM B type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 4 GiB speed: spec: 2400 MT/s actual: 2133 MT/s volts: curr: 1.2
    manufacturer: 01980000802C part-no: ACR24D4S7S1MB-4 serial: <filter>
  Slot: 0 type: PCIe lanes: 16 status: in use length: long volts: 3.3
    bus-ID: 00:1c.0 children: 1: 01:00.0 class-ID: ff00 type: unassigned
  Slot: 1 type: PCIe lanes: 1 status: available length: short volts: 3.3
    bus-ID: 00:1c.1
  Slot: 2 type: PCIe lanes: 1 status: in use length: short volts: 3.3
    bus-ID: 00:1c.2 children: 1: 02:00.0 class-ID: 0280 type: network
  Slot: 3 type: PCIe lanes: 1 status: available length: short volts: 3.3
    bus-ID: 00:1c.3
  Slot: 4 type: PCIe lanes: 1 status: available length: short volts: 3.3
    bus-ID: 00:1c.4
  Slot: 5 type: PCIe lanes: 1 status: available length: short volts: 3.3
    bus-ID: 00:1c.5
  Slot: 6 type: PCIe lanes: 1 status: available length: short volts: 3.3
    bus-ID: 00:1c.6
  Slot: 7 type: PCI bits: 32 status: available length: short volts: 3.3
    bus-ID: 00:1c.7
  Info: model: Intel Core i5-6300U socket: U3E1 bits: 64 type: MT MCP
    arch: Skylake gen: core 6 level: v3 note: check built: 2015
    process: Intel 14nm family: 6 model-id: 0x4E (78) stepping: 3
    microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 890 high: 900 min/max: 400/3000 base/boost: 2300/3000
    scaling: driver: intel_pstate governor: powersave volts: 0.8 V
    ext-clock: 100 MHz cores: 1: 880 2: 900 3: 882 4: 900 bogomips: 20004
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
    class-ID: 0300
  Device-2: Microdia HP Integrated Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0c45:6321
    class-ID: 0e02
  Display: server: X.Org v: 23.2.4 with: Xwayland v: 23.2.4
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: eDP-1 model: AU Optronics 0x333d built: 2016 res: 1920x1080
    hz: 60 dpi: 157 gamma: 1.2 chroma: red: x: 0.631 y: 0.337 green: x: 0.322
    y: 0.616 blue: x: 0.157 y: 0.039 white: x: 0.314 y: 0.329
    size: 310x170mm (12.2x6.69") diag: 355mm (14") ratio: 16:9 modes: 1920x1080
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.3-manjaro1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    device-ID: 8086:1916 memory: 11.29 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 520 (SKL GT2) driver: mesa intel v: 24.0.3-manjaro1.2
    device-ID: 8086:1916 surfaces: xcb,xlib
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:9d70 class-ID: 0403
  API: ALSA v: k6.7.10-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.4 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
  Local Storage: total: 246.08 GiB used: 168.08 GiB (68.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ256HBJD-00BH1
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1NFAV temp: 29.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 4d 9h cycles: 1,222
    read-units: 8,857,846 [4.53 TB] written-units: 4,829,910 [2.47 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: USB Flash Drive
    size: 7.61 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 1100
    scheme: GPT
  ID-1: / raw-size: 59.8 GiB size: 58.56 GiB (97.93%) used: 26.41 GiB (45.1%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 94056c3c-7682-4647-ae52-62c2357c4be2
  ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
    used: 31.9 MiB (8.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 723E-0A93
  ID-3: /home raw-size: 170.46 GiB size: 166.72 GiB (97.81%)
    used: 141.63 GiB (84.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4
    maj-min: 259:4 label: N/A uuid: 06f345a5-0511-43fe-b7d8-9997a5430090
  ID-4: /run/media/pc/7FDC-E579 raw-size: 7.6 GiB size: 7.58 GiB (99.80%)
    used: 16 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: 7FDC-E579
  ID-1: swap-1 type: partition size: 7.81 GiB used: 13.8 MiB (0.2%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 16903b87-9499-4dcb-907d-8ae397807ed4
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:7 info: A-DATA C906 Flash Drive type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 125f:c96a class-ID: 0806
    serial: <filter>
  Device-2: 1-5:2 info: Microdia HP Integrated Webcam type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0c45:6321 class-ID: 0e02
  Device-3: 1-10:6 info: Broadcom 5880 type: smart card driver: N/A
    interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 0a5c:5834 class-ID: 0b00 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 47.0 C pch: 41.5 C mobo: 37.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1548 libs: 417 tools: octopi,pamac,yay pm: flatpak
    pkgs: 0
    1: https://coresite.mm.fcix.net/manjaro/testing/$repo/$arch
    2: https://mirror.nyist.edu.cn/manjaro/testing/$repo/$arch
    3: https://manjarolinux-mirror.cloud.mu/testing/$repo/$arch
    4: http://ossmirror.mycloud.services/os/linux/manjaro/testing/$repo/$arch
    5: https://mirrors.cicku.me/manjaro/testing/$repo/$arch
    6: https://repos.silknet.com/manjaro/testing/$repo/$arch
    7: https://manjaro.c3sl.ufpr.br/testing/$repo/$arch
    8: https://fastmirror.pp.ua/manjaro/testing/$repo/$arch
    9: http://ftp.belnet.be/mirrors/manjaro/repos/testing/$repo/$arch
    10: https://gsl-syd.mm.fcix.net/manjaro/testing/$repo/$arch
    11: http://mirror.fcix.net/manjaro/testing/$repo/$arch
    12: https://ftp.psnc.pl/linux/manjaro/testing/$repo/$arch
    13: https://mirrors.up.pt/pub/manjaro/testing/$repo/$arch
    14: https://mnvoip.mm.fcix.net/manjaro/testing/$repo/$arch
    15: https://mirror.bouwhuis.network/manjaro/testing/$repo/$arch
    16: https://mirror.ibakerserver.pt/manjaro/testing/$repo/$arch
    17: http://ftp.free.org/mirrors/repo.manjaro.org/repos/testing/$repo/$arch
    18: https://manjaro.mirror.wearetriple.com/testing/$repo/$arch
    19: https://mirrors.xtom.jp/manjaro/testing/$repo/$arch
    20: https://mirror.vinehost.net/manjaro/testing/$repo/$arch
    21: https://mirrors.xtom.ee/manjaro/testing/$repo/$arch
    22: https://codingflyboy.mm.fcix.net/manjaro/testing/$repo/$arch
    23: https://repo.ialab.dsu.edu/manjaro/testing/$repo/$arch
    24: https://manjaro.ynh.ovh/testing/$repo/$arch
    25: https://mirror.it4i.cz/manjaro/testing/$repo/$arch
    26: https://mirror.koddos.net/manjaro/testing/$repo/$arch
    27: https://mirror.init7.net/manjaro/testing/$repo/$arch
    28: https://mirrors.jlu.edu.cn/manjaro/testing/$repo/$arch
    29: https://mirror.23m.com/manjaro/testing/$repo/$arch
    30: https://ohioix.mm.fcix.net/manjaro/testing/$repo/$arch
    31: https://mirror.freedif.org/Manjaro/testing/$repo/$arch
    32: https://mirrors.ustc.edu.cn/manjaro/testing/$repo/$arch
    33: https://linorg.usp.br/manjaro/testing/$repo/$arch
    34: https://irltoolkit.mm.fcix.net/manjaro/testing/$repo/$arch
    35: https://mirror.alpix.eu/manjaro/testing/$repo/$arch
    36: https://mirror.seahost.de/manjaro/testing/$repo/$arch
    37: https://mirror.ufam.edu.br/manjaro/testing/$repo/$arch
    38: https://repo.iut.ac.ir/repo/manjaro/testing/$repo/$arch
    39: https://mirror.yandex.ru/mirrors/manjaro/testing/$repo/$arch
    40: https://mirrors.nic.cz/manjaro/testing/$repo/$arch
    41: https://mirror.bardia.tech/manjaro/testing/$repo/$arch
    42: https://ftp.caliu.cat/pub/distribucions/manjaro/testing/$repo/$arch
    43: http://ftp.snt.utwente.nl/pub/linux/manjaro/testing/$repo/$arch
    44: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
    45: http://mirror.terrahost.no/linux/manjaro/testing/$repo/$arch
    46: https://mirror.futureweb.be/manjaro/testing/$repo/$arch
    47: http://mirror.is.co.za/mirrors/manjaro.org/testing/$repo/$arch
    48: https://mirror.kku.ac.th/manjaro/testing/$repo/$arch
    49: http://manjaro.mirrors.theom.nz/manjaro/testing/$repo/$arch
    50: https://mirror.phoepsilonix.love/manjaro/testing/$repo/$arch
    51: http://ftp.dei.uc.pt/pub/linux/manjaro/testing/$repo/$arch
    52: https://mirror.zetup.net/manjaro/testing/$repo/$arch
    53: https://opencolo.mm.fcix.net/manjaro/testing/$repo/$arch
    54: https://mirror.funami.tech/manjaro/testing/$repo/$arch
    55: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/testing/$repo/$arch
    56: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/testing/$repo/$arch
    57: https://mirror.kamtv.ru/manjaro/testing/$repo/$arch
    58: http://mirror.xeonbd.com/manjaro/testing/$repo/$arch
    59: https://mirrors.sjtug.sjtu.edu.cn/manjaro/testing/$repo/$arch
    60: https://ba.mirror.garr.it/mirrors/manjaro/testing/$repo/$arch
    61: https://mirrors.ocf.berkeley.edu/manjaro/testing/$repo/$arch
    62: https://manjaro.mirror.garr.it/manjaro/testing/$repo/$arch
    63: http://free.nchc.org.tw/manjaro/testing/$repo/$arch
    64: https://mirrors.gigenet.com/manjaro/testing/$repo/$arch
    65: https://mirror1.sox.rs/manjaro/testing/$repo/$arch
    66: https://forksystems.mm.fcix.net/manjaro/testing/$repo/$arch
    67: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/testing/$repo/$arch
    68: https://mirrors.tuna.tsinghua.edu.cn/manjaro/testing/$repo/$arch
    69: https://mirror.dc.uz/manjaro/testing/$repo/$arch
    70: https://mirror.truenetwork.ru/manjaro/testing/$repo/$arch
    71: https://manjaro.mirrors.lavatech.top/testing/$repo/$arch
    72: https://mirrors.dotsrc.org/manjaro/testing/$repo/$arch
    73: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/testing/$repo/$arch
    74: https://mirror.xenyth.net/manjaro/testing/$repo/$arch
    75: https://mirror.archlinux.tw/Manjaro/testing/$repo/$arch
    76: https://manjaro.kyberorg.fi/testing/$repo/$arch
    77: https://ftpmirror1.infania.net/mirror/manjaro/testing/$repo/$arch
    78: https://manjaro.repo.cure.edu.uy/testing/$repo/$arch
    79: https://uvermont.mm.fcix.net/manjaro/testing/$repo/$arch
    80: http://ftp.riken.jp/Linux/manjaro/testing/$repo/$arch
    81: https://mirrors.netix.net/manjaro/testing/$repo/$arch
    82: https://quantum-mirror.hu/mirrors/pub/manjaro/testing/$repo/$arch
    83: https://mirror.math.princeton.edu/pub/manjaro/testing/$repo/$arch
    84: https://mirrors.pku.edu.cn/manjaro/testing/$repo/$arch
    85: https://mirrors.ucr.ac.cr/manjaro/testing/$repo/$arch
    86: https://edgeuno-bog2.mm.fcix.net/manjaro/testing/$repo/$arch
    87: https://fosszone.csd.auth.gr/manjaro/testing/$repo/$arch
    88: https://mirror.albony.xyz/manjaro/testing/$repo/$arch
    89: https://mirror.alwyzon.net/manjaro/testing/$repo/$arch
    90: https://manjaro.mirror.liquidtelecom.com/testing/$repo/$arch
    91: https://mirror.aarnet.edu.au/pub/manjaro/testing/$repo/$arch
    92: http://kartolo.sby.datautama.net.id/manjaro/testing/$repo/$arch
    93: https://ftp.gwdg.de/pub/linux/manjaro/testing/$repo/$arch
    94: https://ask4.mm.fcix.net/manjaro/testing/$repo/$arch
    95: https://mirror.netcologne.de/manjaro/testing/$repo/$arch
    96: http://mirror.datacenter.by/pub/mirrors/manjaro/testing/$repo/$arch
    97: https://ct.mirror.garr.it/mirrors/manjaro/testing/$repo/$arch
    98: https://manjaro.ipacct.com/manjaro/testing/$repo/$arch
    99: https://bd.mirror.vanehost.com/Manjaro/testing/$repo/$arch
    100: https://volico.mm.fcix.net/manjaro/testing/$repo/$arch
    101: https://ridgewireless.mm.fcix.net/manjaro/testing/$repo/$arch
    102: https://ftp.halifax.rwth-aachen.de/manjaro/testing/$repo/$arch
    103: https://manjaro.kurdy.org/testing/$repo/$arch
    104: https://mirrors.xtom.de/manjaro/testing/$repo/$arch
    105: https://mirror.2degrees.nz/manjaro/testing/$repo/$arch
    106: https://mirror.dkm.cz/manjaro/testing/$repo/$arch
    107: https://mirror.easyname.at/manjaro/testing/$repo/$arch
    108: https://southfront.mm.fcix.net/manjaro/testing/$repo/$arch
    109: https://mirror.telepoint.bg/manjaro/testing/$repo/$arch
    110: https://mirrors.sonic.net/manjaro/testing/$repo/$arch
    111: https://mirror.csclub.uwaterloo.ca/manjaro/testing/$repo/$arch
    112: https://mirror.erickochen.nl/manjaro/testing/$repo/$arch
    113: https://mirror.ufro.cl/manjaro/testing/$repo/$arch
    114: https://ftp.lysator.liu.se/pub/manjaro/testing/$repo/$arch
    115: http://manjaro.grena.ge/testing/$repo/$arch
    116: http://ftp.tu-chemnitz.de/pub/linux/manjaro/testing/$repo/$arch
    117: https://muug.ca/mirror/manjaro/testing/$repo/$arch
    118: https://mirrors2.manjaro.org/testing/$repo/$arch
    119: https://ftp.linux.org.tr/manjaro/testing/$repo/$arch
    120: https://nnenix.mm.fcix.net/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 263
  1: cpu: 33.7% command: java pid: 26002 mem: 465.2 MiB (3.9%)
  2: cpu: 29.6% command: firefox pid: 25290 mem: 474.7 MiB (4.0%)
  3: cpu: 16.1% command: konsole pid: 26798 mem: 193.8 MiB (1.6%)
  4: cpu: 12.7% command: zsh pid: 26824 mem: 8.46 MiB (0.0%)
  5: cpu: 4.0% command: dolphin pid: 23467 mem: 223.1 MiB (1.8%)
  Memory top: 5 of 263
  1: mem: 615.9 MiB (5.2%) command: firefox pid: 14682 cpu: 0.4%
  2: mem: 529.8 MiB (4.4%)
    command: Z:\home\pc\shamela_4\shamela4\app\win\64\bin\shamela.exe pid: 17964
    cpu: 0.1%
  3: mem: 515.5 MiB (4.3%) command: telegram-desktop pid: 2225 cpu: 0.2%
  4: mem: 479.4 MiB (4.0%) command: plasmashell pid: 791 cpu: 0.2%
  5: mem: 474.7 MiB (4.0%) command: firefox pid: 25290 cpu: 29.6%
  Processes: 263 Power: uptime: 12h 57m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 4.62 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Sudo (sudo) v: 1.9.15p5
    default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
You need to provide more info. Based on the tags you seem to run Plasma. Is it still Plasma 5 from stable branch or already Plasma 6. The later has some issues with Black Screens. Also is our system running in a virtual machine or is it a real hardware installation.
it is a real hardware installation
I’m in testing branch with plasma 6
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
thank you.
post edited
I’m taking a guess that the culprit is the Plymouth package; it often causes boot issues much as you describe.
Completely removing Plymouth might solve your issue; it’s generally considered to be unwelcome bloat and many people (myself included) tend to remove it whether (or not) it’s causing any issues; because, sooner or later, it will.
Plymouth isn’t a typical package to uninstall. Because it’s closely tied in with boot processes, there is a special procedure to follow to remove it completely, and safely:
See the Plymouth page in the Manjaro Wiki for the correct instructions to uninstall it.
I hope this helps. Cheers.
i have followed all that instructions and deleted it.
i will tell you if the problem occurs
" it’s generally considered to be unwelcome bloat "
so why manjaro team keep it?
Many packages can potentially come under the heading of bloat; yet, many people still want to have their pretty desktop things and often complain bitterly when they are taken away.
Plymouth is a virtual crap shoot as to whether it might cause boot issues, or not; it can depend on many variables and differences between computers. Laptops seem most affected, in my experience.
Enough people still use Plymouth without any issue to not warrant it being removed across the board; in my opinion; however, if it was indeed removed from the repos, you would certainly not catch me complaining.
So, there is no blame to be automatically assigned to the Manjaro team, or anyone else, simply because you’re among those inconvenienced by it. If it doesn’t cause any issues, keep it, and if it does, then dump it; or if you’re not sure either way, dump it. :wink:
Cheers.
it seems that the problem is gone
i tried to power off and then power on several times with no black screen problem.
thank you.
and i hope that manjaro team take care of this problem
