Hi. I tried to log in with wayland but the screen is black. I tried adding nvidia_drm.modeset=1
to the GRUB_CMDLINE_LINUX_DEFAULT but it didn’t work. Before it was GRUB_CMDLINE_LINUX_DEFAULT="quiet splash udev.log_priority=3"
info:
inxi -Fazy ✔
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=d90c52e9-87d9-4b34-b0b5-b319bf18266d rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: LENOVO product: 82JF v: Legion 5 Pro 16ITH6
serial: <superuser required> Chassis: type: 10 v: Legion 5 Pro 16ITH6
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> part-nu: LENOVO_MT_82JF_BU_idea_FM_Legion 5 Pro
16ITH6 uuid: <superuser required> UEFI: LENOVO v: H1CN56WW date: 09/19/2023
ID-1: BAT0 charge: 70.6 Wh (100.0%) condition: 70.6/80.0 Wh (88.2%)
volts: 17.2 min: 15.4 model: Sunwoda L20D4PC1 type: Li-poly serial: <filter>
status: full cycles: 399
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x50
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 830 high: 1293 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 1293 12: 800 13: 800 14: 800
15: 800 16: 800 bogomips: 73744
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: NVIDIA GA107BM [GeForce RTX 3050 Mobile] vendor: Lenovo
driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:25e2 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 191 s-size: 340x221mm (13.39x8.70")
s-diag: 406mm (15.97")
Monitor-1: DP-4 res: 2560x1600 dpi: 4064 size: 16x10mm (0.63x0.39")
diag: 19mm (0.74") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3050 Laptop
GPU/PCIe/SSE2 memory: 3.91 GiB
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3050 Laptop GPU driver: nvidia v: 550.90.07
device-ID: 10de:25e2 surfaces: xcb,xlib
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 58:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp88s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:9 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.38 TiB used: 230.46 GiB (16.4%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: SK Hynix model: HFS512GDE9X084N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41010C22 temp: 48.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 42.9 C
scheme: GPT
ID-1: / raw-size: 390.63 GiB size: 383.42 GiB (98.15%) used: 35.62 GiB (9.3%)
fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 72 MiB (28.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (rpm): N/A
Memory: total: 32 GiB available: 31.2 GiB used: 1.61 GiB (5.2%)
Processes: 341 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1324 libs: 365 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 17.0.6 gcc: 14.1.1 alt: 13 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.35
Is there a way I can make it work? I guess its an nvidia problem.
