Black screen using Hybrid graphics (sometimes)
Hello, first post here. Before I start, I have spent days searching the internet including this forum trying to figure out my problem. My computer is the Asus Zephyrus G16 2023 model with the 4060 maxq and 32GB of RAM.
I just installed Manjaro KDE and everything is working great when I have the computer in dedicated graphics via the UEFI (reboots normally and starts up normally every time). However, this is where it gets harder to figure out.
If I boot the system up in dedicated graphics mode then reboot and switch to Dynamic (hybrid graphics) in the UEFI it will boot up just fine the first time ONLY, and hybrid graphics works as expected. Then, when I reboot again (while in hybrid graphics), I just get a black screen with a cursor until I reboot, switch back to dedicated in the UEFI, login, reboot and switch to dynamic in the UEFI then I can use hybrid until I reboot again.
The only thing I have really tried was switching to lightdm as I saw that SDDM may be the culprit, but Lightdm does the same thing. In fact, Gnome and GDM also does this. I am not sure what you all need or what state you would like my computer in when pulling logs, but please let me know, I’ll provide whatever you need to help.
Thank you,
fetch below:
OS: Manjaro Linux x86_64
Host: ROG Zephyrus G16 GU603VV 1.0
Kernel: 6.12.4-1-MANJARO
Uptime: 12 mins
Packages: 1707 (pacman)
Shell: bash 5.2.37
Resolution: 1920x1200
DE: Plasma 6.2.4
WM: KWin
Theme: Breeze-Dark [GTK2], Breeze [GTK3]
Icons: breeze-dark [GTK2/3]
Terminal: konsole
CPU: 13th Gen Intel i7-13620H (16) @ 4.700GHz
GPU: Intel Raptor Lake-P [UHD Graphics]
GPU: NVIDIA GeForce RTX 4060 Max-Q / Mobile
Memory: 2036MiB / 31707MiB
Hello and welcome to the Manjaro Forum!
Could I ask you for the output of inxi -zv8 (paste it here in your reply, select it and click the </> button of the reply window).
Cheers! :slight_smile:
Also, as a new user it is recommended to see:
Thank you for your quick response! My computer is in dedicated graphics mode at the moment.
  Host: archtop Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 14.2.1 clocksource: tsc avail: acpi_pm
    root=UUID=4a7af4d7-44c1-4ce6-bd53-34f832a3d94b rw rootflags=subvol=@
    quiet acpi_backlight=native
    cryptdevice=UUID=8d119e22-5b55-46b4-a00f-19668e5e896a:luks-8d119e22-5b55-46b4-a00f-19668e5e896a
    root=/dev/mapper/luks-8d119e22-5b55-46b4-a00f-19668e5e896a splash
    resume=/dev/mapper/luks-5eb3a645-1889-4293-b4a2-14c47c7b3640
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
    wm: kwin_x11 vt: 2 dm: 1: LightDM v: 1.32.0 note: stopped 2: SDDM
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G16 GU603VV v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: GU603VV v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: GU603VV.314
    date: 09/07/2023
  ID-1: BAT0 charge: 77.7 Wh (100.0%) condition: 77.7/90.0 Wh (86.3%)
    power: 22.2 W volts: 16.4 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown
    serial: 5870 status: not charging
  System RAM: total: 32 GiB available: 30.96 GiB used: 6.24 GiB (20.1%)
  Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 16 GiB
    speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Micron Technology
    part-no: ATF2G64AZ-3G2F1 serial: 00000038
  Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Crucial Technology
    part-no: CT16G4SFRA32A.C8FE serial: 606E5D74
  Info: model: 13th Gen Intel Core i7-13620H bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
    microcode: 0x4123
  Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
    st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
    KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 24 MiB
    desc: 1x24 MiB
  Speed (MHz): avg: 400 min/max: 400/4700:4900:3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 bogomips: 93424
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb
    pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
    rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: ASUSTeK driver: i915
    v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm) built: 2022+
    ports: active: none empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:a7a8
    class-ID: 0380
  Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
    driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:28e0
    class-ID: 0300
  Device-3: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 0408:30c3
    class-ID: fe01 serial: 0x0001
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting failed: nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915,nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 143 s-size: 341x221mm (13.43x8.70")
    s-diag: 406mm (16")
  Monitor-1: Unknown-1 mapped: DP-2 res: 1920x1200 dpi: 3048
    size: 16x10mm (0.63x0.39") modes: 800x600
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Laptop
    GPU/PCIe/SSE2 memory: 7.81 GiB
  API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4060 Laptop GPU driver: N/A device-ID: 10de:28e0
    surfaces: xcb,xlib
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51ca class-ID: 0403
  Device-2: NVIDIA AD107 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  IF: wlo1 state: up mac: c8:5e:a9:2e:77:0a
  IP v4: 10.17.183.80/8 type: dynamic noprefixroute scope: global
    broadcast: 10.255.255.255
  IP v6: fe80::a80e:43e6:d72a:33fa/64 type: noprefixroute scope: link
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 3a:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp58s0 state: down mac: e8:9c:25:d0:19:2d
  WAN IP: 66.115.255.186
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
    class-ID: e001
  Device-1: luks-8d119e22-5b55-46b4-a00f-19668e5e896a maj-min: 254:0
    type: LUKS dm: dm-0 size: 442.58 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:7 size: 442.58 GiB
  Device-2: luks-5eb3a645-1889-4293-b4a2-14c47c7b3640 maj-min: 254:1
    type: LUKS dm: dm-1 size: 34.06 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:8 size: 34.06 GiB
  Local Storage: total: 1.38 TiB used: 36.22 GiB (2.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Micron model: 2400 MTFDKBA512QFM
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: 231840937A08 fw-rev: V3MA003 temp: 34.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
    model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: 232747800183
    fw-rev: 731100WD temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 442.58 GiB size: 442.58 GiB (100.00%)
    used: 36.22 GiB (8.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-8d119e22-5b55-46b4-a00f-19668e5e896a label: N/A
    uuid: 4a7af4d7-44c1-4ce6-bd53-34f832a3d94b
    used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: N/A
    uuid: 0A55-B944
  ID-3: /home raw-size: 442.58 GiB size: 442.58 GiB (100.00%)
  ID-4: /var/cache raw-size: 442.58 GiB size: 442.58 GiB (100.00%)
  ID-5: /var/log raw-size: 442.58 GiB size: 442.58 GiB (100.00%)
  ID-1: swap-1 type: partition size: 34.06 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-5eb3a645-1889-4293-b4a2-14c47c7b3640 label: swap
    uuid: bc574cdb-1ab2-4f96-9059-f024391cc265
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 0266-1E44
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 930.43 GiB fs: bitlocker
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 994 MiB fs: ntfs label: N/A
    uuid: 787258197257DB08
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: ASUSTek N-KEY Device type: keyboard
    driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:19b6 class-ID: 0301
  Device-2: 3-7:3 info: Quanta USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:30c3 class-ID: fe01
    serial: 0x0001
  Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 42 C
  Fan Speeds (rpm): cpu: 2800
  Packages: pm: pacman pkgs: 1707 libs: 502 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    3: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    4: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    5: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    6: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    7: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    8: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 383
  1: cpu: 4.7% command: thunderbird pid: 2519 mem: 815.8 MiB (2.5%)
  2: cpu: 4.6% command: qemu-system-x86_64 pid: 3547 mem: 2894.1 MiB (9.1%)
  3: cpu: 2.1% command: chrome pid: 3698 mem: 309.8 MiB (0.9%)
  4: cpu: 1.7% command: Xorg pid: 949 mem: 142.9 MiB (0.4%)
  5: cpu: 1.3% command: chrome pid: 1785 mem: 275.3 MiB (0.8%)
  Memory top: 5 of 383
  1: mem: 2894.1 MiB (9.1%) command: qemu-system-x86_64 pid: 3547 cpu: 4.6%
  2: mem: 815.8 MiB (2.5%) command: thunderbird pid: 2519 cpu: 4.7%
  3: mem: 508.2 MiB (1.6%) command: chrome pid: 1734 cpu: 0.6%
  4: mem: 499.5 MiB (1.5%) command: plasmashell pid: 1147 cpu: 0.2%
  5: mem: 309.8 MiB (0.9%) command: chrome pid: 3698 cpu: 2.1%
  Processes: 383 Power: uptime: 59m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.35 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
Thanks, wish everyone would do that! :ok_hand:
I’m not familiar with the current crop of Nvidia graphics (used to have one years ago), but hopefully this info will help someone who does.
I just wonder if a Wayland session is worth a try? Although I see mixed reports re. Nvidia + Wayland, it’s easy to switch back to x11.
Also I see you are using LightDM rather than SDDM; this might make a difference?
Another thought: can you switch to another TTY? e.g.CTRL + ALT + f3
Wayland has been pretty sketchy for me. It works sometimes, sometimes it doesn’t with a black screen regardless of GPU mode. I can’t wait for it to work properly, I like the multi touch in KDE.
Yeah, not sure why it says I am using LightDM, I have it installed but disabled. I just uninstalled it however.
Yes, if I boot into a black screen I can switch to a different TTY. I have also tried restarting SDDM from a different TTY with no success.
What I’d do is see if the LightDM removal helped; I don’t have it on this system.
Failing that, there is also a newer Kernel (linux613) which is currently still a release candidate, but may have better driver support already included for a machine this new.
I was having this issue prior to the install of LightDM, I just recently installed it to test. I will try the new kernel and provide an update.
Switching to the new Kernel had the same results. However, I was able to get a jouurnalctl for SDDM (as my research makes me believe this may still be the problem) and another inxi -zv8 output (in case that changed at all) for you from the TTY.
Journalctl
Dec 25 22:57:43 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 25 22:57:43 archtop sddm[867]: Initializing...
Dec 25 22:57:43 archtop sddm[867]: Starting...
Dec 25 22:57:43 archtop sddm[867]: Logind interface found
Dec 25 22:57:43 archtop sddm[867]: Adding new display...
Dec 25 22:57:43 archtop sddm[867]: Loaded empty theme configuration
Dec 25 22:57:43 archtop sddm[867]: Xauthority path: "/run/sddm/xauth_fQmOMm"
Dec 25 22:57:43 archtop sddm[867]: Using VT 2
Dec 25 22:57:43 archtop sddm[867]: Display server starting...
Dec 25 22:57:43 archtop sddm[867]: Writing cookie to "/run/sddm/xauth_fQmOMm"
Dec 25 22:57:43 archtop sddm[867]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_fQmOMm -noreset -displayfd 16
Dec 25 22:57:45 archtop sddm[867]: Setting default cursor
Dec 25 22:57:45 archtop sddm[867]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 25 22:57:45 archtop sddm[867]: Display server started.
Dec 25 22:57:45 archtop sddm[867]: Socket server starting...
Dec 25 22:57:45 archtop sddm[867]: Socket server started.
Dec 25 22:57:45 archtop sddm[867]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 25 22:57:45 archtop sddm[867]: Greeter starting...
Dec 25 22:57:45 archtop sddm-helper[897]: [PAM] Starting...
Dec 25 22:57:45 archtop sddm-helper[897]: [PAM] Authenticating...
Dec 25 22:57:45 archtop sddm-helper[897]: [PAM] returning.
Dec 25 22:57:45 archtop sddm-helper[897]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 25 22:57:46 archtop sddm-helper[897]: Writing cookie to "/tmp/xauth_MNNDPB"
Dec 25 22:57:46 archtop sddm-helper[897]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-lLuhRJ --theme /usr/share/sddm/themes/breath"
Dec 25 22:57:46 archtop sddm[867]: Greeter session started successfully
Dec 25 22:57:46 archtop sddm[867]: Message received from greeter: Connect
Dec 25 22:58:08 archtop sddm[867]: Message received from greeter: Login
Dec 25 22:58:08 archtop sddm[867]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 25 22:58:08 archtop sddm[867]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 25 22:58:08 archtop sddm-helper[956]: [PAM] Starting...
Dec 25 22:58:08 archtop sddm-helper[956]: [PAM] Authenticating...
Dec 25 22:58:08 archtop sddm-helper[956]: [PAM] Preparing to converse...
Dec 25 22:58:08 archtop sddm-helper[956]: [PAM] Conversation with 1 messages
Dec 25 22:58:08 archtop sddm-helper[956]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 25 22:58:08 archtop sddm-helper[956]: [PAM] returning.
Dec 25 22:58:08 archtop sddm[867]: Authentication for user  "zmoon"  successful
Dec 25 22:58:08 archtop sddm-helper[956]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 25 22:58:08 archtop sddm-helper[956]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 25 22:58:08 archtop sddm[867]: Auth: sddm-helper exited successfully
Dec 25 22:58:08 archtop sddm[867]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 25 22:58:08 archtop sddm-helper[956]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 25 22:58:08 archtop sddm-helper[956]: Writing cookie to "/tmp/xauth_EwTvRX"
Dec 25 22:58:08 archtop sddm-helper[956]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 25 22:58:08 archtop sddm[867]: Session started true
Dec 26 11:09:13 archtop sddm[867]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 11:09:13 archtop sddm[867]: Auth: sddm-helper (--socket /tmp/sddm-auth-7f1a563f-552d-4bec-a367-b6d4c1b37283 --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 11:09:13 archtop sddm[867]: Auth: sddm-helper exited with 1
Dec 26 11:09:13 archtop sddm[867]: Signal received: SIGTERM
Dec 26 11:09:13 archtop sddm[867]: Socket server stopping...
Dec 26 11:09:13 archtop sddm[867]: Socket server stopped.
Dec 26 11:09:13 archtop sddm[867]: Display server stopping...
Dec 26 11:09:13 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 11:09:15 archtop sddm[867]: Display server stopped.
Dec 26 11:09:15 archtop sddm[867]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 11:09:15 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 11:09:15 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 11:09:15 archtop systemd[1]: sddm.service: Consumed 7min 38.530s CPU time, 1.1G memory peak.
-- Boot 2db340661e1f402387306d62820235e3 --
Dec 26 11:10:08 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 11:10:08 archtop sddm[926]: Initializing...
Dec 26 11:10:08 archtop sddm[926]: Starting...
Dec 26 11:10:08 archtop sddm[926]: Logind interface found
Dec 26 11:10:08 archtop sddm[926]: Adding new display...
Dec 26 11:10:08 archtop sddm[926]: Loaded empty theme configuration
Dec 26 11:10:08 archtop sddm[926]: Xauthority path: "/run/sddm/xauth_pLVMLs"
Dec 26 11:10:08 archtop sddm[926]: Using VT 2
Dec 26 11:10:08 archtop sddm[926]: Display server starting...
Dec 26 11:10:08 archtop sddm[926]: Writing cookie to "/run/sddm/xauth_pLVMLs"
Dec 26 11:10:08 archtop sddm[926]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_pLVMLs -noreset -displayfd 16
Dec 26 11:10:09 archtop sddm[926]: Failed to read display number from pipe
Dec 26 11:10:09 archtop sddm[926]: Display server stopping...
Dec 26 11:10:09 archtop sddm[926]: Attempt 1 starting the Display server on vt 2 failed
Dec 26 11:10:11 archtop sddm[926]: Display server starting...
Dec 26 11:10:11 archtop sddm[926]: Writing cookie to "/run/sddm/xauth_pLVMLs"
Dec 26 11:10:11 archtop sddm[926]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_pLVMLs -noreset -displayfd 16
Dec 26 11:10:12 archtop sddm[926]: Failed to read display number from pipe
Dec 26 11:10:12 archtop sddm[926]: Display server stopping...
Dec 26 11:10:12 archtop sddm[926]: Attempt 2 starting the Display server on vt 2 failed
Dec 26 11:10:14 archtop sddm[926]: Display server starting...
Dec 26 11:10:14 archtop sddm[926]: Writing cookie to "/run/sddm/xauth_pLVMLs"
Dec 26 11:10:14 archtop sddm[926]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_pLVMLs -noreset -displayfd 16
Dec 26 11:10:15 archtop sddm[926]: Failed to read display number from pipe
Dec 26 11:10:15 archtop sddm[926]: Display server stopping...
Dec 26 11:10:15 archtop sddm[926]: Attempt 3 starting the Display server on vt 2 failed
Dec 26 11:10:15 archtop sddm[926]: Could not start Display server on vt 2
Dec 26 11:12:33 archtop sddm[926]: Signal received: SIGTERM
Dec 26 11:12:33 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 11:12:33 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 11:12:33 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 11:12:33 archtop systemd[1]: sddm.service: Consumed 1.046s CPU time, 336M memory peak.
-- Boot fd2767d35000429bbe633d1465e6f3c8 --
Dec 26 11:13:37 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 11:13:37 archtop sddm[908]: Initializing...
Dec 26 11:13:37 archtop sddm[908]: Starting...
Dec 26 11:13:37 archtop sddm[908]: Logind interface found
Dec 26 11:13:37 archtop sddm[908]: Adding new display...
Dec 26 11:13:37 archtop sddm[908]: Loaded empty theme configuration
Dec 26 11:13:37 archtop sddm[908]: Xauthority path: "/run/sddm/xauth_jwCLCQ"
Dec 26 11:13:37 archtop sddm[908]: Using VT 2
Dec 26 11:13:37 archtop sddm[908]: Display server starting...
Dec 26 11:13:37 archtop sddm[908]: Writing cookie to "/run/sddm/xauth_jwCLCQ"
Dec 26 11:13:37 archtop sddm[908]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_jwCLCQ -noreset -displayfd 16
Dec 26 11:13:38 archtop sddm[908]: Failed to read display number from pipe
Dec 26 11:13:38 archtop sddm[908]: Display server stopping...
Dec 26 11:13:38 archtop sddm[908]: Attempt 1 starting the Display server on vt 2 failed
Dec 26 11:13:40 archtop sddm[908]: Display server starting...
Dec 26 11:13:40 archtop sddm[908]: Writing cookie to "/run/sddm/xauth_jwCLCQ"
Dec 26 11:13:40 archtop sddm[908]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_jwCLCQ -noreset -displayfd 16
Dec 26 11:13:41 archtop sddm[908]: Failed to read display number from pipe
Dec 26 11:13:41 archtop sddm[908]: Display server stopping...
Dec 26 11:13:41 archtop sddm[908]: Attempt 2 starting the Display server on vt 2 failed
Dec 26 11:13:43 archtop sddm[908]: Display server starting...
Dec 26 11:13:43 archtop sddm[908]: Writing cookie to "/run/sddm/xauth_jwCLCQ"
Dec 26 11:13:43 archtop sddm[908]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_jwCLCQ -noreset -displayfd 16
Dec 26 11:13:44 archtop sddm[908]: Failed to read display number from pipe
Dec 26 11:13:44 archtop sddm[908]: Display server stopping...
Dec 26 11:13:44 archtop sddm[908]: Attempt 3 starting the Display server on vt 2 failed
Dec 26 11:13:44 archtop sddm[908]: Could not start Display server on vt 2
Dec 26 11:14:13 archtop sddm[908]: Signal received: SIGTERM
Dec 26 11:14:13 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 11:14:13 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 11:14:13 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 11:14:13 archtop systemd[1]: sddm.service: Consumed 1.031s CPU time, 336.6M memory peak.
-- Boot 46a39d577d1347f28796e9435bc93a63 --
Dec 26 11:17:09 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 11:17:09 archtop sddm[918]: Initializing...
Dec 26 11:17:09 archtop sddm[918]: Starting...
Dec 26 11:17:09 archtop sddm[918]: Logind interface found
Dec 26 11:17:09 archtop sddm[918]: Adding new display...
Dec 26 11:17:09 archtop sddm[918]: Loaded empty theme configuration
Dec 26 11:17:09 archtop sddm[918]: Xauthority path: "/run/sddm/xauth_QWqgrG"
Dec 26 11:17:09 archtop sddm[918]: Using VT 2
Dec 26 11:17:09 archtop sddm[918]: Display server starting...
Dec 26 11:17:09 archtop sddm[918]: Writing cookie to "/run/sddm/xauth_QWqgrG"
Dec 26 11:17:09 archtop sddm[918]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_QWqgrG -noreset -displayfd 16
Dec 26 11:17:10 archtop sddm[918]: Failed to read display number from pipe
Dec 26 11:17:10 archtop sddm[918]: Display server stopping...
Dec 26 11:17:10 archtop sddm[918]: Attempt 1 starting the Display server on vt 2 failed
Dec 26 11:17:12 archtop sddm[918]: Display server starting...
Dec 26 11:17:12 archtop sddm[918]: Writing cookie to "/run/sddm/xauth_QWqgrG"
Dec 26 11:17:12 archtop sddm[918]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_QWqgrG -noreset -displayfd 16
Dec 26 11:17:13 archtop sddm[918]: Failed to read display number from pipe
Dec 26 11:17:13 archtop sddm[918]: Display server stopping...
Dec 26 11:17:13 archtop sddm[918]: Attempt 2 starting the Display server on vt 2 failed
Dec 26 11:17:15 archtop sddm[918]: Display server starting...
Dec 26 11:17:15 archtop sddm[918]: Writing cookie to "/run/sddm/xauth_QWqgrG"
Dec 26 11:17:15 archtop sddm[918]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_QWqgrG -noreset -displayfd 16
Dec 26 11:17:16 archtop sddm[918]: Failed to read display number from pipe
Dec 26 11:17:16 archtop sddm[918]: Display server stopping...
Dec 26 11:17:16 archtop sddm[918]: Attempt 3 starting the Display server on vt 2 failed
Dec 26 11:17:16 archtop sddm[918]: Could not start Display server on vt 2
Dec 26 11:22:52 archtop sddm[918]: Signal received: SIGTERM
Dec 26 11:22:52 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 11:22:52 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 11:22:52 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 11:22:52 archtop systemd[1]: sddm.service: Consumed 1.062s CPU time, 336.6M memory peak.
-- Boot ec8f7fb22ee84f0bbf780467c86e0175 --
Dec 26 11:24:03 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 11:24:03 archtop sddm[912]: Initializing...
Dec 26 11:24:03 archtop sddm[912]: Starting...
Dec 26 11:24:03 archtop sddm[912]: Logind interface found
Dec 26 11:24:03 archtop sddm[912]: Adding new display...
Dec 26 11:24:03 archtop sddm[912]: Loaded empty theme configuration
Dec 26 11:24:03 archtop sddm[912]: Xauthority path: "/run/sddm/xauth_LtefhZ"
Dec 26 11:24:03 archtop sddm[912]: Using VT 2
Dec 26 11:24:03 archtop sddm[912]: Display server starting...
Dec 26 11:24:03 archtop sddm[912]: Writing cookie to "/run/sddm/xauth_LtefhZ"
Dec 26 11:24:03 archtop sddm[912]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_LtefhZ -noreset -displayfd 16
Dec 26 11:24:06 archtop sddm[912]: Setting default cursor
Dec 26 11:24:06 archtop sddm[912]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 11:24:06 archtop sddm[912]: Display server started.
Dec 26 11:24:06 archtop sddm[912]: Socket server starting...
Dec 26 11:24:06 archtop sddm[912]: Socket server started.
Dec 26 11:24:06 archtop sddm[912]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 11:24:06 archtop sddm[912]: Greeter starting...
Dec 26 11:24:06 archtop sddm-helper[924]: [PAM] Starting...
Dec 26 11:24:06 archtop sddm-helper[924]: [PAM] Authenticating...
Dec 26 11:24:06 archtop sddm-helper[924]: [PAM] returning.
Dec 26 11:24:06 archtop sddm-helper[924]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 11:24:07 archtop sddm-helper[924]: Writing cookie to "/tmp/xauth_dMJCYO"
Dec 26 11:24:07 archtop sddm-helper[924]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-GUFWWj --theme /usr/share/sddm/themes/breath"
Dec 26 11:24:07 archtop sddm[912]: Greeter session started successfully
Dec 26 11:24:07 archtop sddm[912]: Message received from greeter: Connect
Dec 26 11:24:21 archtop sddm[912]: Message received from greeter: Login
Dec 26 11:24:21 archtop sddm[912]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 11:24:21 archtop sddm[912]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 11:24:21 archtop sddm-helper[965]: [PAM] Starting...
Dec 26 11:24:21 archtop sddm-helper[965]: [PAM] Authenticating...
Dec 26 11:24:21 archtop sddm-helper[965]: [PAM] Preparing to converse...
Dec 26 11:24:21 archtop sddm-helper[965]: [PAM] Conversation with 1 messages
Dec 26 11:24:21 archtop sddm-helper[965]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 11:24:21 archtop sddm-helper[965]: [PAM] returning.
Dec 26 11:24:21 archtop sddm[912]: Authentication for user  "zmoon"  successful
Dec 26 11:24:21 archtop sddm-helper[965]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 11:24:21 archtop sddm-helper[965]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 11:24:21 archtop sddm[912]: Auth: sddm-helper exited successfully
Dec 26 11:24:21 archtop sddm[912]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 11:24:22 archtop sddm-helper[965]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 11:24:22 archtop sddm-helper[965]: Writing cookie to "/tmp/xauth_OPRoSN"
Dec 26 11:24:22 archtop sddm-helper[965]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 11:24:22 archtop sddm[912]: Session started true
Dec 26 11:38:21 archtop sddm[912]: Auth: sddm-helper exited successfully
Dec 26 11:38:21 archtop sddm[912]: Socket server stopping...
Dec 26 11:38:21 archtop sddm[912]: Socket server stopped.
Dec 26 11:38:21 archtop sddm[912]: Display server stopping...
Dec 26 11:38:23 archtop sddm[912]: Display server stopped.
Dec 26 11:38:23 archtop sddm[912]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 11:38:23 archtop sddm[912]: Removing display SDDM::Display(0x5bf3ba768c80) ...
Dec 26 11:38:23 archtop sddm[912]: Adding new display...
Dec 26 11:38:23 archtop sddm[912]: Loaded empty theme configuration
Dec 26 11:38:23 archtop sddm[912]: Xauthority path: "/run/sddm/xauth_BdicOc"
Dec 26 11:38:23 archtop sddm[912]: Using VT 2
Dec 26 11:38:23 archtop sddm[912]: Display server starting...
Dec 26 11:38:23 archtop sddm[912]: Writing cookie to "/run/sddm/xauth_BdicOc"
Dec 26 11:38:23 archtop sddm[912]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_BdicOc -noreset -displayfd 18
Dec 26 11:38:26 archtop sddm[912]: Setting default cursor
Dec 26 11:38:26 archtop sddm[912]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 11:38:26 archtop sddm[912]: Display server started.
Dec 26 11:38:26 archtop sddm[912]: Socket server starting...
Dec 26 11:38:26 archtop sddm[912]: Socket server started.
Dec 26 11:38:26 archtop sddm[912]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 11:38:26 archtop sddm[912]: Greeter starting...
Dec 26 11:38:26 archtop sddm-helper[3358]: [PAM] Starting...
Dec 26 11:38:26 archtop sddm-helper[3358]: [PAM] Authenticating...
Dec 26 11:38:26 archtop sddm-helper[3358]: [PAM] returning.
Dec 26 11:38:26 archtop sddm-helper[3358]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 11:38:26 archtop sddm-helper[3358]: Writing cookie to "/tmp/xauth_XcPacL"
Dec 26 11:38:26 archtop sddm-helper[3358]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-hkDJds --theme /usr/share/sddm/themes/breath"
Dec 26 11:38:26 archtop sddm[912]: Greeter session started successfully
Dec 26 11:38:26 archtop sddm[912]: Message received from greeter: Connect
Dec 26 11:38:34 archtop sddm[912]: Message received from greeter: Login
Dec 26 11:38:34 archtop sddm[912]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 11:38:34 archtop sddm[912]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 11:38:34 archtop sddm-helper[3416]: [PAM] Starting...
Dec 26 11:38:34 archtop sddm-helper[3416]: [PAM] Authenticating...
Dec 26 11:38:34 archtop sddm-helper[3416]: [PAM] Preparing to converse...
Dec 26 11:38:34 archtop sddm-helper[3416]: [PAM] Conversation with 1 messages
Dec 26 11:38:34 archtop sddm-helper[3416]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 11:38:34 archtop sddm-helper[3416]: [PAM] returning.
Dec 26 11:38:34 archtop sddm[912]: Authentication for user  "zmoon"  successful
Dec 26 11:38:34 archtop sddm-helper[3416]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 11:38:34 archtop sddm-helper[3416]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 11:38:35 archtop sddm[912]: Auth: sddm-helper exited successfully
Dec 26 11:38:35 archtop sddm[912]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 11:38:35 archtop sddm-helper[3416]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 11:38:35 archtop sddm-helper[3416]: Writing cookie to "/tmp/xauth_YPXnrr"
Dec 26 11:38:35 archtop sddm-helper[3416]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 11:38:35 archtop sddm[912]: Session started true
Dec 26 11:43:00 archtop sddm[912]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 11:43:00 archtop sddm[912]: Auth: sddm-helper (--socket /tmp/sddm-auth-a11cd2c4-b21c-4995-aff3-4baa751031b5 --id 3 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 11:43:00 archtop sddm[912]: Auth: sddm-helper exited with 1
Dec 26 11:43:00 archtop sddm[912]: Signal received: SIGTERM
Dec 26 11:43:00 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 11:43:00 archtop sddm[912]: Socket server stopping...
Dec 26 11:43:00 archtop sddm[912]: Socket server stopped.
Dec 26 11:43:00 archtop sddm[912]: Display server stopping...
Dec 26 11:43:01 archtop sddm[912]: Display server stopped.
Dec 26 11:43:01 archtop sddm[912]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 11:43:01 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 11:43:01 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 11:43:01 archtop systemd[1]: sddm.service: Consumed 55.154s CPU time, 404.3M memory peak.
-- Boot a1803510724142d79a6c9324a0da77bb --
Dec 26 11:44:44 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 11:44:44 archtop sddm[917]: Initializing...
Dec 26 11:44:44 archtop sddm[917]: Starting...
Dec 26 11:44:44 archtop sddm[917]: Logind interface found
Dec 26 11:44:44 archtop sddm[917]: Adding new display...
Dec 26 11:44:44 archtop sddm[917]: Loaded empty theme configuration
Dec 26 11:44:44 archtop sddm[917]: Xauthority path: "/run/sddm/xauth_YqCLLk"
Dec 26 11:44:44 archtop sddm[917]: Using VT 2
Dec 26 11:44:44 archtop sddm[917]: Display server starting...
Dec 26 11:44:44 archtop sddm[917]: Writing cookie to "/run/sddm/xauth_YqCLLk"
Dec 26 11:44:44 archtop sddm[917]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_YqCLLk -noreset -displayfd 16
Dec 26 11:44:45 archtop sddm[917]: Setting default cursor
Dec 26 11:44:45 archtop sddm[917]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 11:44:45 archtop sddm[917]: Display server started.
Dec 26 11:44:45 archtop sddm[917]: Socket server starting...
Dec 26 11:44:45 archtop sddm[917]: Socket server started.
Dec 26 11:44:45 archtop sddm[917]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 11:44:45 archtop sddm[917]: Greeter starting...
Dec 26 11:44:45 archtop sddm-helper[932]: [PAM] Starting...
Dec 26 11:44:45 archtop sddm-helper[932]: [PAM] Authenticating...
Dec 26 11:44:45 archtop sddm-helper[932]: [PAM] returning.
Dec 26 11:44:45 archtop sddm-helper[932]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 11:44:46 archtop sddm-helper[932]: Writing cookie to "/tmp/xauth_mTgNrm"
Dec 26 11:44:46 archtop sddm-helper[932]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-kkmdAI --theme /usr/share/sddm/themes/breath"
Dec 26 11:44:46 archtop sddm[917]: Greeter session started successfully
Dec 26 11:44:46 archtop sddm[917]: Message received from greeter: Connect
Dec 26 11:45:01 archtop sddm[917]: Message received from greeter: Login
Dec 26 11:45:01 archtop sddm[917]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 11:45:01 archtop sddm[917]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 11:45:01 archtop sddm-helper[981]: [PAM] Starting...
Dec 26 11:45:01 archtop sddm-helper[981]: [PAM] Authenticating...
Dec 26 11:45:01 archtop sddm-helper[981]: [PAM] Preparing to converse...
Dec 26 11:45:01 archtop sddm-helper[981]: [PAM] Conversation with 1 messages
Dec 26 11:45:01 archtop sddm-helper[981]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 11:45:01 archtop sddm-helper[981]: [PAM] returning.
Dec 26 11:45:01 archtop sddm[917]: Authentication for user  "zmoon"  successful
Dec 26 11:45:01 archtop sddm-helper[981]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 11:45:01 archtop sddm-helper[981]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 11:45:01 archtop sddm[917]: Auth: sddm-helper exited successfully
Dec 26 11:45:01 archtop sddm[917]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 11:45:01 archtop sddm-helper[981]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 11:45:01 archtop sddm-helper[981]: Writing cookie to "/tmp/xauth_KJsBYk"
Dec 26 11:45:01 archtop sddm-helper[981]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 11:45:01 archtop sddm[917]: Session started true
Dec 26 12:06:20 archtop sddm[917]: Auth: sddm-helper exited successfully
Dec 26 12:06:20 archtop sddm[917]: Socket server stopping...
Dec 26 12:06:20 archtop sddm[917]: Socket server stopped.
Dec 26 12:06:20 archtop sddm[917]: Display server stopping...
Dec 26 12:06:23 archtop sddm[917]: Display server stopped.
Dec 26 12:06:23 archtop sddm[917]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 12:06:23 archtop sddm[917]: Removing display SDDM::Display(0x5ae3d3f06c50) ...
Dec 26 12:06:23 archtop sddm[917]: Adding new display...
Dec 26 12:06:23 archtop sddm[917]: Loaded empty theme configuration
Dec 26 12:06:23 archtop sddm[917]: Xauthority path: "/run/sddm/xauth_vsUStJ"
Dec 26 12:06:23 archtop sddm[917]: Using VT 2
Dec 26 12:06:23 archtop sddm[917]: Display server starting...
Dec 26 12:06:23 archtop sddm[917]: Writing cookie to "/run/sddm/xauth_vsUStJ"
Dec 26 12:06:23 archtop sddm[917]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_vsUStJ -noreset -displayfd 18
Dec 26 12:06:25 archtop sddm[917]: Setting default cursor
Dec 26 12:06:25 archtop sddm[917]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 12:06:25 archtop sddm[917]: Display server started.
Dec 26 12:06:25 archtop sddm[917]: Socket server starting...
Dec 26 12:06:25 archtop sddm[917]: Socket server started.
Dec 26 12:06:25 archtop sddm[917]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 12:06:25 archtop sddm[917]: Greeter starting...
Dec 26 12:06:25 archtop sddm-helper[16683]: [PAM] Starting...
Dec 26 12:06:25 archtop sddm-helper[16683]: [PAM] Authenticating...
Dec 26 12:06:25 archtop sddm-helper[16683]: [PAM] returning.
Dec 26 12:06:25 archtop sddm-helper[16683]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 12:06:25 archtop sddm-helper[16683]: Writing cookie to "/tmp/xauth_nhMlTf"
Dec 26 12:06:25 archtop sddm-helper[16683]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-fChiBE --theme /usr/share/sddm/themes/breath"
Dec 26 12:06:25 archtop sddm[917]: Greeter session started successfully
Dec 26 12:06:25 archtop sddm[917]: Message received from greeter: Connect
Dec 26 12:07:04 archtop sddm[917]: Message received from greeter: Login
Dec 26 12:07:04 archtop sddm[917]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 12:07:04 archtop sddm[917]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 12:07:05 archtop sddm-helper[16751]: [PAM] Starting...
Dec 26 12:07:05 archtop sddm-helper[16751]: [PAM] Authenticating...
Dec 26 12:07:05 archtop sddm-helper[16751]: [PAM] Preparing to converse...
Dec 26 12:07:05 archtop sddm-helper[16751]: [PAM] Conversation with 1 messages
Dec 26 12:07:05 archtop sddm-helper[16751]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 12:07:05 archtop sddm-helper[16751]: [PAM] returning.
Dec 26 12:07:05 archtop sddm[917]: Authentication for user  "zmoon"  successful
Dec 26 12:07:05 archtop sddm-helper[16751]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 12:07:05 archtop sddm-helper[16751]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 12:07:05 archtop sddm[917]: Auth: sddm-helper exited successfully
Dec 26 12:07:05 archtop sddm[917]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 12:07:05 archtop sddm-helper[16751]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 12:07:05 archtop sddm-helper[16751]: Writing cookie to "/tmp/xauth_gZzsdB"
Dec 26 12:07:05 archtop sddm-helper[16751]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 12:07:05 archtop sddm[917]: Session started true
Dec 26 12:20:56 archtop sddm[917]: Auth: sddm-helper exited successfully
Dec 26 12:20:56 archtop sddm[917]: Socket server stopping...
Dec 26 12:20:56 archtop sddm[917]: Socket server stopped.
Dec 26 12:20:56 archtop sddm[917]: Display server stopping...
Dec 26 12:21:00 archtop sddm[917]: Display server stopped.
Dec 26 12:21:00 archtop sddm[917]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 12:21:00 archtop sddm[917]: Removing display SDDM::Display(0x5ae3d3f25900) ...
Dec 26 12:21:00 archtop sddm[917]: Adding new display...
Dec 26 12:21:00 archtop sddm[917]: Loaded empty theme configuration
Dec 26 12:21:00 archtop sddm[917]: Xauthority path: "/run/sddm/xauth_sQvnNF"
Dec 26 12:21:00 archtop sddm[917]: Using VT 2
Dec 26 12:21:00 archtop sddm[917]: Display server starting...
Dec 26 12:21:00 archtop sddm[917]: Writing cookie to "/run/sddm/xauth_sQvnNF"
Dec 26 12:21:00 archtop sddm[917]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_sQvnNF -noreset -displayfd 18
Dec 26 12:21:01 archtop sddm[917]: Setting default cursor
Dec 26 12:21:01 archtop sddm[917]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 12:21:01 archtop sddm[917]: Display server started.
Dec 26 12:21:01 archtop sddm[917]: Socket server starting...
Dec 26 12:21:01 archtop sddm[917]: Socket server started.
Dec 26 12:21:01 archtop sddm[917]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 12:21:01 archtop sddm[917]: Greeter starting...
Dec 26 12:21:01 archtop sddm-helper[19590]: [PAM] Starting...
Dec 26 12:21:01 archtop sddm-helper[19590]: [PAM] Authenticating...
Dec 26 12:21:01 archtop sddm-helper[19590]: [PAM] returning.
Dec 26 12:21:01 archtop sddm-helper[19590]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 12:21:01 archtop sddm-helper[19590]: Writing cookie to "/tmp/xauth_VjTNdz"
Dec 26 12:21:01 archtop sddm-helper[19590]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-jXOAnA --theme /usr/share/sddm/themes/breath"
Dec 26 12:21:01 archtop sddm[917]: Greeter session started successfully
Dec 26 12:21:01 archtop sddm[917]: Message received from greeter: Connect
Dec 26 12:21:08 archtop sddm[917]: Message received from greeter: Login
Dec 26 12:21:08 archtop sddm[917]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 12:21:08 archtop sddm[917]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 12:21:08 archtop sddm-helper[19653]: [PAM] Starting...
Dec 26 12:21:08 archtop sddm-helper[19653]: [PAM] Authenticating...
Dec 26 12:21:08 archtop sddm-helper[19653]: [PAM] Preparing to converse...
Dec 26 12:21:08 archtop sddm-helper[19653]: [PAM] Conversation with 1 messages
Dec 26 12:21:09 archtop sddm-helper[19653]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 12:21:09 archtop sddm-helper[19653]: [PAM] returning.
Dec 26 12:21:09 archtop sddm[917]: Authentication for user  "zmoon"  successful
Dec 26 12:21:09 archtop sddm-helper[19653]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 12:21:09 archtop sddm-helper[19653]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 12:21:09 archtop sddm[917]: Auth: sddm-helper exited successfully
Dec 26 12:21:09 archtop sddm[917]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 12:21:09 archtop sddm-helper[19653]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 12:21:09 archtop sddm-helper[19653]: Writing cookie to "/tmp/xauth_JTgNov"
Dec 26 12:21:09 archtop sddm-helper[19653]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 12:21:09 archtop sddm[917]: Session started true
Dec 26 12:28:51 archtop sddm[917]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 12:28:51 archtop sddm[917]: Auth: sddm-helper (--socket /tmp/sddm-auth-84fb55b3-ca5a-4e59-bd38-cde59ad605d1 --id 5 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 12:28:51 archtop sddm[917]: Auth: sddm-helper exited with 1
Dec 26 12:28:51 archtop sddm[917]: Signal received: SIGTERM
Dec 26 12:28:51 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 12:28:51 archtop sddm[917]: Socket server stopping...
Dec 26 12:28:51 archtop sddm[917]: Socket server stopped.
Dec 26 12:28:51 archtop sddm[917]: Display server stopping...
Dec 26 12:28:54 archtop sddm[917]: Display server stopped.
Dec 26 12:28:54 archtop sddm[917]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 12:28:54 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 12:28:54 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 12:28:54 archtop systemd[1]: sddm.service: Consumed 2min 17.356s CPU time, 1.5G memory peak.
-- Boot d914c89183b2471282664f5779a68b43 --
Dec 26 12:29:46 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 12:29:46 archtop sddm[943]: Initializing...
Dec 26 12:29:46 archtop sddm[943]: Starting...
Dec 26 12:29:46 archtop sddm[943]: Logind interface found
Dec 26 12:29:46 archtop sddm[943]: Adding new display...
Dec 26 12:29:46 archtop sddm[943]: Loaded empty theme configuration
Dec 26 12:29:46 archtop sddm[943]: Xauthority path: "/run/sddm/xauth_ISWMpN"
Dec 26 12:29:46 archtop sddm[943]: Using VT 2
Dec 26 12:29:46 archtop sddm[943]: Display server starting...
Dec 26 12:29:46 archtop sddm[943]: Writing cookie to "/run/sddm/xauth_ISWMpN"
Dec 26 12:29:46 archtop sddm[943]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_ISWMpN -noreset -displayfd 16
Dec 26 12:29:47 archtop sddm[943]: Failed to read display number from pipe
Dec 26 12:29:47 archtop sddm[943]: Display server stopping...
Dec 26 12:29:47 archtop sddm[943]: Attempt 1 starting the Display server on vt 2 failed
Dec 26 12:29:49 archtop sddm[943]: Display server starting...
Dec 26 12:29:49 archtop sddm[943]: Writing cookie to "/run/sddm/xauth_ISWMpN"
Dec 26 12:29:49 archtop sddm[943]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_ISWMpN -noreset -displayfd 16
Dec 26 12:29:50 archtop sddm[943]: Failed to read display number from pipe
Dec 26 12:29:50 archtop sddm[943]: Display server stopping...
Dec 26 12:29:50 archtop sddm[943]: Attempt 2 starting the Display server on vt 2 failed
Dec 26 12:29:52 archtop sddm[943]: Display server starting...
Dec 26 12:29:52 archtop sddm[943]: Writing cookie to "/run/sddm/xauth_ISWMpN"
Dec 26 12:29:52 archtop sddm[943]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_ISWMpN -noreset -displayfd 16
Dec 26 12:29:53 archtop sddm[943]: Failed to read display number from pipe
Dec 26 12:29:53 archtop sddm[943]: Display server stopping...
Dec 26 12:29:53 archtop sddm[943]: Attempt 3 starting the Display server on vt 2 failed
Dec 26 12:29:53 archtop sddm[943]: Could not start Display server on vt 2
Dec 26 12:34:10 archtop sddm[943]: Signal received: SIGTERM
Dec 26 12:34:10 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 12:34:10 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 12:34:10 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 12:34:10 archtop systemd[1]: sddm.service: Consumed 1.036s CPU time, 335.4M memory peak.
-- Boot c3d2b7ed47494643b9467906e1cfca42 --
Dec 26 12:36:35 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 12:36:36 archtop sddm[939]: Initializing...
Dec 26 12:36:36 archtop sddm[939]: Starting...
Dec 26 12:36:36 archtop sddm[939]: Logind interface found
Dec 26 12:36:36 archtop sddm[939]: Adding new display...
Dec 26 12:36:36 archtop sddm[939]: Loaded empty theme configuration
Dec 26 12:36:36 archtop sddm[939]: Xauthority path: "/run/sddm/xauth_PJvDox"
Dec 26 12:36:36 archtop sddm[939]: Using VT 2
Dec 26 12:36:36 archtop sddm[939]: Display server starting...
Dec 26 12:36:36 archtop sddm[939]: Writing cookie to "/run/sddm/xauth_PJvDox"
Dec 26 12:36:36 archtop sddm[939]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_PJvDox -noreset -displayfd 16
Dec 26 12:36:37 archtop sddm[939]: Failed to read display number from pipe
Dec 26 12:36:37 archtop sddm[939]: Display server stopping...
Dec 26 12:36:37 archtop sddm[939]: Attempt 1 starting the Display server on vt 2 failed
Dec 26 12:36:39 archtop sddm[939]: Display server starting...
Dec 26 12:36:39 archtop sddm[939]: Writing cookie to "/run/sddm/xauth_PJvDox"
Dec 26 12:36:39 archtop sddm[939]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_PJvDox -noreset -displayfd 16
Dec 26 12:36:40 archtop sddm[939]: Failed to read display number from pipe
Dec 26 12:36:40 archtop sddm[939]: Display server stopping...
Dec 26 12:36:40 archtop sddm[939]: Attempt 2 starting the Display server on vt 2 failed
Dec 26 12:36:42 archtop sddm[939]: Display server starting...
Dec 26 12:36:42 archtop sddm[939]: Writing cookie to "/run/sddm/xauth_PJvDox"
Dec 26 12:36:42 archtop sddm[939]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_PJvDox -noreset -displayfd 16
Dec 26 12:36:42 archtop sddm[939]: Failed to read display number from pipe
Dec 26 12:36:42 archtop sddm[939]: Display server stopping...
Dec 26 12:36:42 archtop sddm[939]: Attempt 3 starting the Display server on vt 2 failed
Dec 26 12:36:42 archtop sddm[939]: Could not start Display server on vt 2
Dec 26 12:43:20 archtop sddm[939]: Signal received: SIGTERM
Dec 26 12:43:20 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 12:43:20 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 12:43:20 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 12:43:20 archtop systemd[1]: sddm.service: Consumed 1.061s CPU time, 336.6M memory peak.
Dec 26 12:43:20 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 12:43:20 archtop sddm[1046]: Initializing...
Dec 26 12:43:20 archtop sddm[1046]: Starting...
Dec 26 12:43:20 archtop sddm[1046]: Logind interface found
Dec 26 12:43:20 archtop sddm[1046]: Adding new display...
Dec 26 12:43:20 archtop sddm[1046]: Loaded empty theme configuration
Dec 26 12:43:20 archtop sddm[1046]: Xauthority path: "/run/sddm/xauth_BVLTaQ"
Dec 26 12:43:20 archtop sddm[1046]: Using VT 1
Dec 26 12:43:20 archtop sddm[1046]: Display server starting...
Dec 26 12:43:20 archtop sddm[1046]: Writing cookie to "/run/sddm/xauth_BVLTaQ"
Dec 26 12:43:20 archtop sddm[1046]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /run/sddm/xauth_BVLTaQ -noreset -displayfd 16
Dec 26 12:43:22 archtop sddm[1046]: Failed to read display number from pipe
Dec 26 12:43:22 archtop sddm[1046]: Display server stopping...
Dec 26 12:43:22 archtop sddm[1046]: Attempt 1 starting the Display server on vt 1 failed
Dec 26 12:43:24 archtop sddm[1046]: Display server starting...
Dec 26 12:43:24 archtop sddm[1046]: Writing cookie to "/run/sddm/xauth_BVLTaQ"
Dec 26 12:43:24 archtop sddm[1046]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /run/sddm/xauth_BVLTaQ -noreset -displayfd 16
Dec 26 12:43:25 archtop sddm[1046]: Failed to read display number from pipe
Dec 26 12:43:25 archtop sddm[1046]: Display server stopping...
Dec 26 12:43:25 archtop sddm[1046]: Attempt 2 starting the Display server on vt 1 failed
Dec 26 12:43:27 archtop sddm[1046]: Display server starting...
Dec 26 12:43:27 archtop sddm[1046]: Writing cookie to "/run/sddm/xauth_BVLTaQ"
Dec 26 12:43:27 archtop sddm[1046]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /run/sddm/xauth_BVLTaQ -noreset -displayfd 16
Dec 26 12:43:28 archtop sddm[1046]: Failed to read display number from pipe
Dec 26 12:43:28 archtop sddm[1046]: Display server stopping...
Dec 26 12:43:28 archtop sddm[1046]: Attempt 3 starting the Display server on vt 1 failed
Dec 26 12:43:28 archtop sddm[1046]: Could not start Display server on vt 1
Dec 26 12:53:33 archtop sddm[1046]: Signal received: SIGTERM
Dec 26 12:53:33 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 12:53:33 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 12:53:33 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 12:53:33 archtop systemd[1]: sddm.service: Consumed 2.222s CPU time, 82M memory peak.
-- Boot ae7bc6be499c476a8fe89e6eb243ec3e --
Dec 26 12:55:03 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 12:55:03 archtop sddm[944]: Initializing...
Dec 26 12:55:03 archtop sddm[944]: Starting...
Dec 26 12:55:03 archtop sddm[944]: Logind interface found
Dec 26 12:55:03 archtop sddm[944]: Adding new display...
Dec 26 12:55:03 archtop sddm[944]: Loaded empty theme configuration
Dec 26 12:55:03 archtop sddm[944]: Xauthority path: "/run/sddm/xauth_rEasIN"
Dec 26 12:55:03 archtop sddm[944]: Using VT 2
Dec 26 12:55:03 archtop sddm[944]: Display server starting...
Dec 26 12:55:03 archtop sddm[944]: Writing cookie to "/run/sddm/xauth_rEasIN"
Dec 26 12:55:03 archtop sddm[944]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_rEasIN -noreset -displayfd 16
Dec 26 12:55:04 archtop sddm[944]: Failed to read display number from pipe
Dec 26 12:55:04 archtop sddm[944]: Display server stopping...
Dec 26 12:55:04 archtop sddm[944]: Attempt 1 starting the Display server on vt 2 failed
Dec 26 12:55:06 archtop sddm[944]: Display server starting...
Dec 26 12:55:06 archtop sddm[944]: Writing cookie to "/run/sddm/xauth_rEasIN"
Dec 26 12:55:06 archtop sddm[944]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_rEasIN -noreset -displayfd 16
Dec 26 12:55:07 archtop sddm[944]: Failed to read display number from pipe
Dec 26 12:55:07 archtop sddm[944]: Display server stopping...
Dec 26 12:55:07 archtop sddm[944]: Attempt 2 starting the Display server on vt 2 failed
Dec 26 12:55:09 archtop sddm[944]: Display server starting...
Dec 26 12:55:09 archtop sddm[944]: Writing cookie to "/run/sddm/xauth_rEasIN"
Dec 26 12:55:09 archtop sddm[944]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_rEasIN -noreset -displayfd 16
Dec 26 12:55:10 archtop sddm[944]: Failed to read display number from pipe
Dec 26 12:55:10 archtop sddm[944]: Display server stopping...
Dec 26 12:55:10 archtop sddm[944]: Attempt 3 starting the Display server on vt 2 failed
Dec 26 12:55:10 archtop sddm[944]: Could not start Display server on vt 2
Dec 26 12:57:56 archtop sddm[944]: Signal received: SIGTERM
Dec 26 12:57:56 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 12:57:56 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 12:57:56 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 12:57:56 archtop systemd[1]: sddm.service: Consumed 1.025s CPU time, 336.1M memory peak.
Dec 26 12:57:56 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 12:57:56 archtop sddm[1039]: Initializing...
Dec 26 12:57:56 archtop sddm[1039]: Starting...
Dec 26 12:57:56 archtop sddm[1039]: Logind interface found
Dec 26 12:57:56 archtop sddm[1039]: Adding new display...
Dec 26 12:57:56 archtop sddm[1039]: Loaded empty theme configuration
Dec 26 12:57:56 archtop sddm[1039]: Xauthority path: "/run/sddm/xauth_lJzYiI"
Dec 26 12:57:56 archtop sddm[1039]: Using VT 1
Dec 26 12:57:56 archtop sddm[1039]: Display server starting...
Dec 26 12:57:56 archtop sddm[1039]: Writing cookie to "/run/sddm/xauth_lJzYiI"
Dec 26 12:57:56 archtop sddm[1039]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /run/sddm/xauth_lJzYiI -noreset -displayfd 16
Dec 26 12:57:59 archtop sddm[1039]: Failed to read display number from pipe
Dec 26 12:57:59 archtop sddm[1039]: Display server stopping...
Dec 26 12:57:59 archtop sddm[1039]: Attempt 1 starting the Display server on vt 1 failed
Dec 26 12:58:00 archtop sddm[1039]: Display server starting...
Dec 26 12:58:00 archtop sddm[1039]: Writing cookie to "/run/sddm/xauth_lJzYiI"
Dec 26 12:58:00 archtop sddm[1039]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /run/sddm/xauth_lJzYiI -noreset -displayfd 16
Dec 26 12:58:01 archtop sddm[1039]: Failed to read display number from pipe
Dec 26 12:58:01 archtop sddm[1039]: Display server stopping...
Dec 26 12:58:01 archtop sddm[1039]: Attempt 2 starting the Display server on vt 1 failed
Dec 26 12:58:03 archtop sddm[1039]: Display server starting...
Dec 26 12:58:03 archtop sddm[1039]: Writing cookie to "/run/sddm/xauth_lJzYiI"
Dec 26 12:58:03 archtop sddm[1039]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /run/sddm/xauth_lJzYiI -noreset -displayfd 16
Dec 26 12:58:04 archtop sddm[1039]: Failed to read display number from pipe
Dec 26 12:58:04 archtop sddm[1039]: Display server stopping...
Dec 26 12:58:04 archtop sddm[1039]: Attempt 3 starting the Display server on vt 1 failed
Dec 26 12:58:04 archtop sddm[1039]: Could not start Display server on vt 1
Dec 26 13:17:02 archtop sddm[1039]: Signal received: SIGTERM
Dec 26 13:17:02 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 13:17:02 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 13:17:02 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 13:17:02 archtop systemd[1]: sddm.service: Consumed 2.191s CPU time, 81.6M memory peak.
-- Boot 72488fc44f9b44e4a1ffb870ee08548a --
Dec 26 13:18:34 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 13:18:34 archtop sddm[947]: Initializing...
Dec 26 13:18:34 archtop sddm[947]: Starting...
Dec 26 13:18:34 archtop sddm[947]: Logind interface found
Dec 26 13:18:34 archtop sddm[947]: Adding new display...
Dec 26 13:18:34 archtop sddm[947]: Loaded empty theme configuration
Dec 26 13:18:34 archtop sddm[947]: Xauthority path: "/run/sddm/xauth_sUCURH"
Dec 26 13:18:34 archtop sddm[947]: Using VT 2
Dec 26 13:18:34 archtop sddm[947]: Display server starting...
Dec 26 13:18:34 archtop sddm[947]: Writing cookie to "/run/sddm/xauth_sUCURH"
Dec 26 13:18:34 archtop sddm[947]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_sUCURH -noreset -displayfd 16
Dec 26 13:18:38 archtop sddm[947]: Setting default cursor
Dec 26 13:18:38 archtop sddm[947]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 13:18:38 archtop sddm[947]: Display server started.
Dec 26 13:18:38 archtop sddm[947]: Socket server starting...
Dec 26 13:18:38 archtop sddm[947]: Socket server started.
Dec 26 13:18:38 archtop sddm[947]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 13:18:38 archtop sddm[947]: Greeter starting...
Dec 26 13:18:38 archtop sddm-helper[959]: [PAM] Starting...
Dec 26 13:18:38 archtop sddm-helper[959]: [PAM] Authenticating...
Dec 26 13:18:38 archtop sddm-helper[959]: [PAM] returning.
Dec 26 13:18:38 archtop sddm-helper[959]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 13:18:38 archtop sddm-helper[959]: Writing cookie to "/tmp/xauth_pvYhoW"
Dec 26 13:18:38 archtop sddm-helper[959]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-WkVXoM --theme /usr/share/sddm/themes/breath"
Dec 26 13:18:38 archtop sddm[947]: Greeter session started successfully
Dec 26 13:18:38 archtop sddm[947]: Message received from greeter: Connect
Dec 26 13:18:47 archtop sddm[947]: Message received from greeter: Login
Dec 26 13:18:47 archtop sddm[947]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 13:18:47 archtop sddm[947]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 13:18:47 archtop sddm-helper[999]: [PAM] Starting...
Dec 26 13:18:47 archtop sddm-helper[999]: [PAM] Authenticating...
Dec 26 13:18:47 archtop sddm-helper[999]: [PAM] Preparing to converse...
Dec 26 13:18:47 archtop sddm-helper[999]: [PAM] Conversation with 1 messages
Dec 26 13:18:47 archtop sddm-helper[999]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 13:18:47 archtop sddm-helper[999]: [PAM] returning.
Dec 26 13:18:47 archtop sddm[947]: Authentication for user  "zmoon"  successful
Dec 26 13:18:47 archtop sddm-helper[999]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 13:18:47 archtop sddm-helper[999]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 13:18:47 archtop sddm[947]: Auth: sddm-helper exited successfully
Dec 26 13:18:47 archtop sddm[947]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 13:18:47 archtop sddm-helper[999]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 13:18:47 archtop sddm-helper[999]: Writing cookie to "/tmp/xauth_fHKKvr"
Dec 26 13:18:47 archtop sddm-helper[999]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 13:18:47 archtop sddm[947]: Session started true
Dec 26 13:23:21 archtop sddm[947]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 13:23:21 archtop sddm[947]: Auth: sddm-helper (--socket /tmp/sddm-auth-c14b3517-a0bb-49db-8750-34c28769b542 --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 13:23:21 archtop sddm[947]: Auth: sddm-helper exited with 1
Dec 26 13:23:21 archtop sddm[947]: Signal received: SIGTERM
Dec 26 13:23:21 archtop sddm[947]: Socket server stopping...
Dec 26 13:23:21 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 13:23:21 archtop sddm[947]: Socket server stopped.
Dec 26 13:23:21 archtop sddm[947]: Display server stopping...
Dec 26 13:23:22 archtop sddm[947]: Display server stopped.
Dec 26 13:23:22 archtop sddm[947]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 13:23:22 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 13:23:22 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 13:23:22 archtop systemd[1]: sddm.service: Consumed 16.697s CPU time, 374.2M memory peak.
-- Boot 9f1bc99f6de94c7db7b65dbfac02ed04 --
Dec 26 13:25:07 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 13:25:07 archtop sddm[928]: Initializing...
Dec 26 13:25:07 archtop sddm[928]: Starting...
Dec 26 13:25:07 archtop sddm[928]: Logind interface found
Dec 26 13:25:07 archtop sddm[928]: Adding new display...
Dec 26 13:25:07 archtop sddm[928]: Loaded empty theme configuration
Dec 26 13:25:07 archtop sddm[928]: Xauthority path: "/run/sddm/xauth_TeCmct"
Dec 26 13:25:07 archtop sddm[928]: Using VT 2
Dec 26 13:25:07 archtop sddm[928]: Display server starting...
Dec 26 13:25:07 archtop sddm[928]: Writing cookie to "/run/sddm/xauth_TeCmct"
Dec 26 13:25:07 archtop sddm[928]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_TeCmct -noreset -displayfd 16
Dec 26 13:25:08 archtop sddm[928]: Setting default cursor
Dec 26 13:25:08 archtop sddm[928]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 13:25:08 archtop sddm[928]: Display server started.
Dec 26 13:25:08 archtop sddm[928]: Socket server starting...
Dec 26 13:25:08 archtop sddm[928]: Socket server started.
Dec 26 13:25:08 archtop sddm[928]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 13:25:08 archtop sddm[928]: Greeter starting...
Dec 26 13:25:08 archtop sddm-helper[942]: [PAM] Starting...
Dec 26 13:25:08 archtop sddm-helper[942]: [PAM] Authenticating...
Dec 26 13:25:08 archtop sddm-helper[942]: [PAM] returning.
Dec 26 13:25:08 archtop sddm-helper[942]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 13:25:09 archtop sddm-helper[942]: Writing cookie to "/tmp/xauth_PwhpuB"
Dec 26 13:25:09 archtop sddm-helper[942]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-feALrH --theme /usr/share/sddm/themes/breath"
Dec 26 13:25:09 archtop sddm[928]: Greeter session started successfully
Dec 26 13:25:09 archtop sddm[928]: Message received from greeter: Connect
Dec 26 13:25:18 archtop sddm[928]: Message received from greeter: Login
Dec 26 13:25:18 archtop sddm[928]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 13:25:18 archtop sddm[928]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 13:25:18 archtop sddm-helper[990]: [PAM] Starting...
Dec 26 13:25:18 archtop sddm-helper[990]: [PAM] Authenticating...
Dec 26 13:25:18 archtop sddm-helper[990]: [PAM] Preparing to converse...
Dec 26 13:25:18 archtop sddm-helper[990]: [PAM] Conversation with 1 messages
Dec 26 13:25:18 archtop sddm-helper[990]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 13:25:18 archtop sddm-helper[990]: [PAM] returning.
Dec 26 13:25:18 archtop sddm[928]: Authentication for user  "zmoon"  successful
Dec 26 13:25:18 archtop sddm-helper[990]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 13:25:18 archtop sddm-helper[990]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 13:25:18 archtop sddm[928]: Auth: sddm-helper exited successfully
Dec 26 13:25:18 archtop sddm[928]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 13:25:18 archtop sddm-helper[990]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 13:25:19 archtop sddm-helper[990]: Writing cookie to "/tmp/xauth_NnRXUl"
Dec 26 13:25:19 archtop sddm-helper[990]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 13:25:19 archtop sddm[928]: Session started true
Dec 26 13:26:04 archtop sddm[928]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 13:26:04 archtop sddm[928]: Auth: sddm-helper (--socket /tmp/sddm-auth-7fe18261-3d98-495e-b05f-ded190530ce5 --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 13:26:04 archtop sddm[928]: Auth: sddm-helper exited with 1
Dec 26 13:26:04 archtop sddm[928]: Signal received: SIGTERM
Dec 26 13:26:04 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 13:26:04 archtop sddm[928]: Socket server stopping...
Dec 26 13:26:04 archtop sddm[928]: Socket server stopped.
Dec 26 13:26:04 archtop sddm[928]: Display server stopping...
Dec 26 13:26:08 archtop sddm[928]: Display server stopped.
Dec 26 13:26:08 archtop sddm[928]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 13:26:08 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 13:26:08 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 13:26:08 archtop systemd[1]: sddm.service: Consumed 2.787s CPU time, 381.1M memory peak.
-- Boot e456ae34626d407794aa52401fdf5fa7 --
Dec 26 13:26:55 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 13:26:55 archtop sddm[947]: Initializing...
Dec 26 13:26:55 archtop sddm[947]: Starting...
Dec 26 13:26:55 archtop sddm[947]: Logind interface found
Dec 26 13:26:55 archtop sddm[947]: Adding new display...
Dec 26 13:26:55 archtop sddm[947]: Loaded empty theme configuration
Dec 26 13:26:55 archtop sddm[947]: Xauthority path: "/run/sddm/xauth_ZsnCEV"
Dec 26 13:26:55 archtop sddm[947]: Using VT 2
Dec 26 13:26:55 archtop sddm[947]: Display server starting...
Dec 26 13:26:55 archtop sddm[947]: Writing cookie to "/run/sddm/xauth_ZsnCEV"
Dec 26 13:26:55 archtop sddm[947]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_ZsnCEV -noreset -displayfd 16
Dec 26 13:26:56 archtop sddm[947]: Failed to read display number from pipe
Dec 26 13:26:56 archtop sddm[947]: Display server stopping...
Dec 26 13:26:56 archtop sddm[947]: Attempt 1 starting the Display server on vt 2 failed
Dec 26 13:26:58 archtop sddm[947]: Display server starting...
Dec 26 13:26:58 archtop sddm[947]: Writing cookie to "/run/sddm/xauth_ZsnCEV"
Dec 26 13:26:58 archtop sddm[947]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_ZsnCEV -noreset -displayfd 16
Dec 26 13:26:59 archtop sddm[947]: Failed to read display number from pipe
Dec 26 13:26:59 archtop sddm[947]: Display server stopping...
Dec 26 13:26:59 archtop sddm[947]: Attempt 2 starting the Display server on vt 2 failed
Dec 26 13:27:01 archtop sddm[947]: Display server starting...
Dec 26 13:27:01 archtop sddm[947]: Writing cookie to "/run/sddm/xauth_ZsnCEV"
Dec 26 13:27:01 archtop sddm[947]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_ZsnCEV -noreset -displayfd 16
Dec 26 13:27:02 archtop sddm[947]: Failed to read display number from pipe
Dec 26 13:27:02 archtop sddm[947]: Display server stopping...
Dec 26 13:27:02 archtop sddm[947]: Attempt 3 starting the Display server on vt 2 failed
Dec 26 13:27:02 archtop sddm[947]: Could not start Display server on vt 2
Dec 26 13:35:45 archtop sddm[947]: Signal received: SIGTERM
Dec 26 13:35:45 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 13:35:45 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 13:35:45 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 13:35:45 archtop systemd[1]: sddm.service: Consumed 1.060s CPU time, 337.1M memory peak.
-- Boot f54b74bc44c04368b9ad63e94fe3024e --
Dec 26 13:37:17 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 13:37:18 archtop sddm[948]: Initializing...
Dec 26 13:37:18 archtop sddm[948]: Starting...
Dec 26 13:37:18 archtop sddm[948]: Logind interface found
Dec 26 13:37:18 archtop sddm[948]: Adding new display...
Dec 26 13:37:18 archtop sddm[948]: Loaded empty theme configuration
Dec 26 13:37:18 archtop sddm[948]: Xauthority path: "/run/sddm/xauth_AZzhJe"
Dec 26 13:37:18 archtop sddm[948]: Using VT 2
Dec 26 13:37:18 archtop sddm[948]: Display server starting...
Dec 26 13:37:18 archtop sddm[948]: Writing cookie to "/run/sddm/xauth_AZzhJe"
Dec 26 13:37:18 archtop sddm[948]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_AZzhJe -noreset -displayfd 16
Dec 26 13:37:21 archtop sddm[948]: Setting default cursor
Dec 26 13:37:21 archtop sddm[948]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 13:37:21 archtop sddm[948]: Display server started.
Dec 26 13:37:21 archtop sddm[948]: Socket server starting...
Dec 26 13:37:21 archtop sddm[948]: Socket server started.
Dec 26 13:37:21 archtop sddm[948]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 13:37:21 archtop sddm[948]: Greeter starting...
Dec 26 13:37:21 archtop sddm-helper[960]: [PAM] Starting...
Dec 26 13:37:21 archtop sddm-helper[960]: [PAM] Authenticating...
Dec 26 13:37:21 archtop sddm-helper[960]: [PAM] returning.
Dec 26 13:37:21 archtop sddm-helper[960]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 13:37:21 archtop sddm-helper[960]: Writing cookie to "/tmp/xauth_DNSJkO"
Dec 26 13:37:21 archtop sddm-helper[960]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-Uvkena --theme /usr/share/sddm/themes/breath"
Dec 26 13:37:21 archtop sddm[948]: Greeter session started successfully
Dec 26 13:37:22 archtop sddm[948]: Message received from greeter: Connect
Dec 26 13:37:30 archtop sddm[948]: Message received from greeter: Login
Dec 26 13:37:30 archtop sddm[948]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 13:37:30 archtop sddm[948]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 13:37:30 archtop sddm-helper[1001]: [PAM] Starting...
Dec 26 13:37:30 archtop sddm-helper[1001]: [PAM] Authenticating...
Dec 26 13:37:30 archtop sddm-helper[1001]: [PAM] Preparing to converse...
Dec 26 13:37:30 archtop sddm-helper[1001]: [PAM] Conversation with 1 messages
Dec 26 13:37:30 archtop sddm-helper[1001]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 13:37:30 archtop sddm-helper[1001]: [PAM] returning.
Dec 26 13:37:30 archtop sddm[948]: Authentication for user  "zmoon"  successful
Dec 26 13:37:30 archtop sddm-helper[1001]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 13:37:30 archtop sddm-helper[1001]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 13:37:30 archtop sddm[948]: Auth: sddm-helper exited successfully
Dec 26 13:37:30 archtop sddm[948]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 13:37:31 archtop sddm-helper[1001]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 13:37:31 archtop sddm-helper[1001]: Writing cookie to "/tmp/xauth_MgVzSF"
Dec 26 13:37:31 archtop sddm-helper[1001]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 13:37:31 archtop sddm[948]: Session started true
Dec 26 13:39:53 archtop sddm[948]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 13:39:53 archtop sddm[948]: Auth: sddm-helper (--socket /tmp/sddm-auth-81707af8-30b7-43aa-a906-987731fa17d8 --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 13:39:53 archtop sddm[948]: Auth: sddm-helper exited with 1
Dec 26 13:39:53 archtop sddm[948]: Signal received: SIGTERM
Dec 26 13:39:53 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 13:39:53 archtop sddm[948]: Socket server stopping...
Dec 26 13:39:53 archtop sddm[948]: Socket server stopped.
Dec 26 13:39:53 archtop sddm[948]: Display server stopping...
Dec 26 13:39:55 archtop sddm[948]: Display server stopped.
Dec 26 13:39:55 archtop sddm[948]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 13:39:55 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 13:39:55 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 13:39:55 archtop systemd[1]: sddm.service: Consumed 6.014s CPU time, 365.8M memory peak.
-- Boot 2a3c90e30b8647f6947084c5e52ac4c7 --
Dec 26 13:40:49 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 13:40:49 archtop sddm[927]: Initializing...
Dec 26 13:40:49 archtop sddm[927]: Starting...
Dec 26 13:40:49 archtop sddm[927]: Logind interface found
Dec 26 13:40:49 archtop sddm[927]: Adding new display...
Dec 26 13:40:49 archtop sddm[927]: Loaded empty theme configuration
Dec 26 13:40:49 archtop sddm[927]: Xauthority path: "/run/sddm/xauth_tnmiwR"
Dec 26 13:40:49 archtop sddm[927]: Using VT 2
Dec 26 13:40:49 archtop sddm[927]: Display server starting...
Dec 26 13:40:49 archtop sddm[927]: Writing cookie to "/run/sddm/xauth_tnmiwR"
Dec 26 13:40:49 archtop sddm[927]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_tnmiwR -noreset -displayfd 16
Dec 26 13:40:53 archtop sddm[927]: Setting default cursor
Dec 26 13:40:53 archtop sddm[927]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 13:40:53 archtop sddm[927]: Display server started.
Dec 26 13:40:53 archtop sddm[927]: Socket server starting...
Dec 26 13:40:53 archtop sddm[927]: Socket server started.
Dec 26 13:40:53 archtop sddm[927]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 13:40:53 archtop sddm[927]: Greeter starting...
Dec 26 13:40:53 archtop sddm-helper[941]: [PAM] Starting...
Dec 26 13:40:53 archtop sddm-helper[941]: [PAM] Authenticating...
Dec 26 13:40:53 archtop sddm-helper[941]: [PAM] returning.
Dec 26 13:40:53 archtop sddm-helper[941]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 13:40:53 archtop sddm-helper[941]: Writing cookie to "/tmp/xauth_YzMoWL"
Dec 26 13:40:53 archtop sddm-helper[941]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-MzSmuD --theme /usr/share/sddm/themes/breath"
Dec 26 13:40:53 archtop sddm[927]: Greeter session started successfully
Dec 26 13:40:53 archtop sddm[927]: Message received from greeter: Connect
Dec 26 13:41:06 archtop sddm[927]: Message received from greeter: Login
Dec 26 13:41:06 archtop sddm[927]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 13:41:06 archtop sddm[927]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 13:41:06 archtop sddm-helper[978]: [PAM] Starting...
Dec 26 13:41:06 archtop sddm-helper[978]: [PAM] Authenticating...
Dec 26 13:41:06 archtop sddm-helper[978]: [PAM] Preparing to converse...
Dec 26 13:41:06 archtop sddm-helper[978]: [PAM] Conversation with 1 messages
Dec 26 13:41:06 archtop sddm-helper[978]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 13:41:06 archtop sddm-helper[978]: [PAM] returning.
Dec 26 13:41:06 archtop sddm[927]: Authentication for user  "zmoon"  successful
Dec 26 13:41:06 archtop sddm-helper[978]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 13:41:06 archtop sddm-helper[978]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 13:41:06 archtop sddm[927]: Auth: sddm-helper exited successfully
Dec 26 13:41:06 archtop sddm[927]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 13:41:06 archtop sddm-helper[978]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 13:41:06 archtop sddm-helper[978]: Writing cookie to "/tmp/xauth_bOqzif"
Dec 26 13:41:06 archtop sddm-helper[978]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 13:41:06 archtop sddm[927]: Session started true
Dec 26 19:06:11 archtop sddm[927]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 19:06:11 archtop sddm[927]: Auth: sddm-helper (--socket /tmp/sddm-auth-27975398-dbef-4053-83e7-c8f27b959f16 --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 19:06:11 archtop sddm[927]: Auth: sddm-helper exited with 1
Dec 26 19:06:11 archtop sddm[927]: Signal received: SIGTERM
Dec 26 19:06:11 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 19:06:11 archtop sddm[927]: Socket server stopping...
Dec 26 19:06:11 archtop sddm[927]: Socket server stopped.
Dec 26 19:06:11 archtop sddm[927]: Display server stopping...
Dec 26 19:06:13 archtop sddm[927]: Display server stopped.
Dec 26 19:06:13 archtop sddm[927]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 19:06:13 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 19:06:13 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 19:06:13 archtop systemd[1]: sddm.service: Consumed 2min 21.164s CPU time, 396.5M memory peak.
-- Boot 856727b2b3d0404fab86505fcead38a4 --
Dec 26 19:07:20 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 19:07:20 archtop sddm[936]: Initializing...
Dec 26 19:07:20 archtop sddm[936]: Starting...
Dec 26 19:07:20 archtop sddm[936]: Logind interface found
Dec 26 19:07:20 archtop sddm[936]: Adding new display...
Dec 26 19:07:20 archtop sddm[936]: Loaded empty theme configuration
Dec 26 19:07:20 archtop sddm[936]: Xauthority path: "/run/sddm/xauth_tQmtIC"
Dec 26 19:07:20 archtop sddm[936]: Using VT 2
Dec 26 19:07:20 archtop sddm[936]: Display server starting...
Dec 26 19:07:20 archtop sddm[936]: Writing cookie to "/run/sddm/xauth_tQmtIC"
Dec 26 19:07:20 archtop sddm[936]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_tQmtIC -noreset -displayfd 16
Dec 26 19:07:21 archtop sddm[936]: Setting default cursor
Dec 26 19:07:21 archtop sddm[936]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 19:07:21 archtop sddm[936]: Display server started.
Dec 26 19:07:21 archtop sddm[936]: Socket server starting...
Dec 26 19:07:21 archtop sddm[936]: Socket server started.
Dec 26 19:07:21 archtop sddm[936]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 19:07:21 archtop sddm[936]: Greeter starting...
Dec 26 19:07:21 archtop sddm-helper[976]: [PAM] Starting...
Dec 26 19:07:21 archtop sddm-helper[976]: [PAM] Authenticating...
Dec 26 19:07:21 archtop sddm-helper[976]: [PAM] returning.
Dec 26 19:07:21 archtop sddm-helper[976]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 19:07:22 archtop sddm-helper[976]: Writing cookie to "/tmp/xauth_cQccVK"
Dec 26 19:07:22 archtop sddm-helper[976]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-DNbmXz --theme /usr/share/sddm/themes/breath"
Dec 26 19:07:22 archtop sddm[936]: Greeter session started successfully
Dec 26 19:07:22 archtop sddm[936]: Message received from greeter: Connect
Dec 26 19:07:31 archtop sddm[936]: Message received from greeter: Login
Dec 26 19:07:31 archtop sddm[936]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 19:07:31 archtop sddm[936]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 19:07:31 archtop sddm-helper[1030]: [PAM] Starting...
Dec 26 19:07:31 archtop sddm-helper[1030]: [PAM] Authenticating...
Dec 26 19:07:31 archtop sddm-helper[1030]: [PAM] Preparing to converse...
Dec 26 19:07:31 archtop sddm-helper[1030]: [PAM] Conversation with 1 messages
Dec 26 19:07:31 archtop sddm-helper[1030]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 19:07:31 archtop sddm-helper[1030]: [PAM] returning.
Dec 26 19:07:31 archtop sddm[936]: Authentication for user  "zmoon"  successful
Dec 26 19:07:31 archtop sddm-helper[1030]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 19:07:31 archtop sddm-helper[1030]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 19:07:31 archtop sddm[936]: Auth: sddm-helper exited successfully
Dec 26 19:07:31 archtop sddm[936]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 19:07:32 archtop sddm-helper[1030]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 19:07:32 archtop sddm-helper[1030]: Writing cookie to "/tmp/xauth_holLsJ"
Dec 26 19:07:32 archtop sddm-helper[1030]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 19:07:32 archtop sddm[936]: Session started true
Dec 26 19:09:55 archtop sddm[936]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 19:09:55 archtop sddm[936]: Auth: sddm-helper (--socket /tmp/sddm-auth-88aa2729-5e78-497e-8595-97b9bb529dab --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 19:09:55 archtop sddm[936]: Auth: sddm-helper exited with 1
Dec 26 19:09:55 archtop sddm[936]: Signal received: SIGTERM
Dec 26 19:09:55 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 19:09:55 archtop sddm[936]: Socket server stopping...
Dec 26 19:09:55 archtop sddm[936]: Socket server stopped.
Dec 26 19:09:55 archtop sddm[936]: Display server stopping...
Dec 26 19:09:57 archtop sddm[936]: Display server stopped.
Dec 26 19:09:57 archtop sddm[936]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 19:09:57 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 19:09:57 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 19:09:57 archtop systemd[1]: sddm.service: Consumed 9.059s CPU time, 430.7M memory peak.
-- Boot a0dfa277fe3b45c189384b25b32a3cd4 --
Dec 26 19:10:43 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 19:10:43 archtop sddm[950]: Initializing...
Dec 26 19:10:43 archtop sddm[950]: Starting...
Dec 26 19:10:43 archtop sddm[950]: Logind interface found
Dec 26 19:10:43 archtop sddm[950]: Adding new display...
Dec 26 19:10:43 archtop sddm[950]: Loaded empty theme configuration
Dec 26 19:10:43 archtop sddm[950]: Xauthority path: "/run/sddm/xauth_vPaLeJ"
Dec 26 19:10:43 archtop sddm[950]: Using VT 2
Dec 26 19:10:43 archtop sddm[950]: Display server starting...
Dec 26 19:10:43 archtop sddm[950]: Writing cookie to "/run/sddm/xauth_vPaLeJ"
Dec 26 19:10:43 archtop sddm[950]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_vPaLeJ -noreset -displayfd 16
Dec 26 19:10:44 archtop sddm[950]: Failed to read display number from pipe
Dec 26 19:10:44 archtop sddm[950]: Display server stopping...
Dec 26 19:10:44 archtop sddm[950]: Attempt 1 starting the Display server on vt 2 failed
Dec 26 19:10:46 archtop sddm[950]: Display server starting...
Dec 26 19:10:46 archtop sddm[950]: Writing cookie to "/run/sddm/xauth_vPaLeJ"
Dec 26 19:10:46 archtop sddm[950]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_vPaLeJ -noreset -displayfd 16
Dec 26 19:10:47 archtop sddm[950]: Failed to read display number from pipe
Dec 26 19:10:47 archtop sddm[950]: Display server stopping...
Dec 26 19:10:47 archtop sddm[950]: Attempt 2 starting the Display server on vt 2 failed
Dec 26 19:10:49 archtop sddm[950]: Display server starting...
Dec 26 19:10:49 archtop sddm[950]: Writing cookie to "/run/sddm/xauth_vPaLeJ"
Dec 26 19:10:49 archtop sddm[950]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_vPaLeJ -noreset -displayfd 16
Dec 26 19:10:50 archtop sddm[950]: Failed to read display number from pipe
Dec 26 19:10:50 archtop sddm[950]: Display server stopping...
Dec 26 19:10:50 archtop sddm[950]: Attempt 3 starting the Display server on vt 2 failed
Dec 26 19:10:50 archtop sddm[950]: Could not start Display server on vt 2
Dec 26 20:27:02 archtop sddm[950]: Signal received: SIGTERM
Dec 26 20:27:02 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 20:27:02 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 20:27:02 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 20:27:02 archtop systemd[1]: sddm.service: Consumed 1.037s CPU time, 336.5M memory peak.
-- Boot 3309fd827f274faaa4e1f3daefe393c7 --
Dec 26 20:28:55 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 20:28:55 archtop sddm[939]: Initializing...
Dec 26 20:28:55 archtop sddm[939]: Starting...
Dec 26 20:28:55 archtop sddm[939]: Logind interface found
Dec 26 20:28:55 archtop sddm[939]: Adding new display...
Dec 26 20:28:55 archtop sddm[939]: Loaded empty theme configuration
Dec 26 20:28:55 archtop sddm[939]: Xauthority path: "/run/sddm/xauth_rNeLFa"
Dec 26 20:28:55 archtop sddm[939]: Using VT 2
Dec 26 20:28:55 archtop sddm[939]: Display server starting...
Dec 26 20:28:55 archtop sddm[939]: Writing cookie to "/run/sddm/xauth_rNeLFa"
Dec 26 20:28:55 archtop sddm[939]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_rNeLFa -noreset -displayfd 16
Dec 26 20:28:59 archtop sddm[939]: Setting default cursor
Dec 26 20:28:59 archtop sddm[939]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 20:28:59 archtop sddm[939]: Display server started.
Dec 26 20:28:59 archtop sddm[939]: Socket server starting...
Dec 26 20:28:59 archtop sddm[939]: Socket server started.
Dec 26 20:28:59 archtop sddm[939]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 20:28:59 archtop sddm[939]: Greeter starting...
Dec 26 20:28:59 archtop sddm-helper[965]: [PAM] Starting...
Dec 26 20:28:59 archtop sddm-helper[965]: [PAM] Authenticating...
Dec 26 20:28:59 archtop sddm-helper[965]: [PAM] returning.
Dec 26 20:28:59 archtop sddm-helper[965]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 20:28:59 archtop sddm-helper[965]: Writing cookie to "/tmp/xauth_RldhSX"
Dec 26 20:28:59 archtop sddm-helper[965]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-OAdSFp --theme /usr/share/sddm/themes/breath"
Dec 26 20:28:59 archtop sddm[939]: Greeter session started successfully
Dec 26 20:28:59 archtop sddm[939]: Message received from greeter: Connect
Dec 26 20:29:08 archtop sddm[939]: Message received from greeter: Login
Dec 26 20:29:08 archtop sddm[939]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 20:29:08 archtop sddm[939]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 20:29:08 archtop sddm-helper[1012]: [PAM] Starting...
Dec 26 20:29:08 archtop sddm-helper[1012]: [PAM] Authenticating...
Dec 26 20:29:08 archtop sddm-helper[1012]: [PAM] Preparing to converse...
Dec 26 20:29:08 archtop sddm-helper[1012]: [PAM] Conversation with 1 messages
Dec 26 20:29:08 archtop sddm-helper[1012]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 20:29:08 archtop sddm-helper[1012]: [PAM] returning.
Dec 26 20:29:08 archtop sddm[939]: Authentication for user  "zmoon"  successful
Dec 26 20:29:08 archtop sddm-helper[1012]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 20:29:08 archtop sddm-helper[1012]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 20:29:08 archtop sddm[939]: Auth: sddm-helper exited successfully
Dec 26 20:29:08 archtop sddm[939]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 20:29:08 archtop sddm-helper[1012]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 20:29:08 archtop sddm-helper[1012]: Writing cookie to "/tmp/xauth_dxYbzn"
Dec 26 20:29:08 archtop sddm-helper[1012]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 20:29:08 archtop sddm[939]: Session started true
Dec 26 20:40:09 archtop sddm[939]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 20:40:09 archtop sddm[939]: Auth: sddm-helper (--socket /tmp/sddm-auth-30a2e8d6-2dc0-40eb-8cff-7dde61094e04 --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 20:40:09 archtop sddm[939]: Auth: sddm-helper exited with 1
Dec 26 20:40:09 archtop sddm[939]: Signal received: SIGTERM
Dec 26 20:40:09 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 20:40:09 archtop sddm[939]: Socket server stopping...
Dec 26 20:40:09 archtop sddm[939]: Socket server stopped.
Dec 26 20:40:09 archtop sddm[939]: Display server stopping...
Dec 26 20:40:11 archtop sddm[939]: Display server stopped.
Dec 26 20:40:11 archtop sddm[939]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 20:40:11 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 20:40:11 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 20:40:11 archtop systemd[1]: sddm.service: Consumed 13.832s CPU time, 363.4M memory peak.
-- Boot 0c9d7d4253654e1fbe1bbc516dffd4d9 --
Dec 26 20:41:02 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 20:41:02 archtop sddm[953]: Initializing...
Dec 26 20:41:02 archtop sddm[953]: Starting...
Dec 26 20:41:02 archtop sddm[953]: Logind interface found
Dec 26 20:41:02 archtop sddm[953]: Adding new display...
Dec 26 20:41:02 archtop sddm[953]: Loaded empty theme configuration
Dec 26 20:41:02 archtop sddm[953]: Xauthority path: "/run/sddm/xauth_hbDfmU"
Dec 26 20:41:02 archtop sddm[953]: Using VT 2
Dec 26 20:41:02 archtop sddm[953]: Display server starting...
Dec 26 20:41:02 archtop sddm[953]: Writing cookie to "/run/sddm/xauth_hbDfmU"
Dec 26 20:41:02 archtop sddm[953]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_hbDfmU -noreset -displayfd 16
Dec 26 20:41:06 archtop sddm[953]: Setting default cursor
Dec 26 20:41:06 archtop sddm[953]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 20:41:06 archtop sddm[953]: Display server started.
Dec 26 20:41:06 archtop sddm[953]: Socket server starting...
Dec 26 20:41:06 archtop sddm[953]: Socket server started.
Dec 26 20:41:06 archtop sddm[953]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 20:41:06 archtop sddm[953]: Greeter starting...
Dec 26 20:41:06 archtop sddm-helper[982]: [PAM] Starting...
Dec 26 20:41:06 archtop sddm-helper[982]: [PAM] Authenticating...
Dec 26 20:41:06 archtop sddm-helper[982]: [PAM] returning.
Dec 26 20:41:06 archtop sddm-helper[982]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 20:41:06 archtop sddm-helper[982]: Writing cookie to "/tmp/xauth_wuzUFw"
Dec 26 20:41:06 archtop sddm-helper[982]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-UsHAoD --theme /usr/share/sddm/themes/breath"
Dec 26 20:41:06 archtop sddm[953]: Greeter session started successfully
Dec 26 20:41:06 archtop sddm[953]: Message received from greeter: Connect
Dec 26 20:41:16 archtop sddm[953]: Message received from greeter: Login
Dec 26 20:41:16 archtop sddm[953]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 20:41:16 archtop sddm[953]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 20:41:16 archtop sddm-helper[1026]: [PAM] Starting...
Dec 26 20:41:16 archtop sddm-helper[1026]: [PAM] Authenticating...
Dec 26 20:41:16 archtop sddm-helper[1026]: [PAM] Preparing to converse...
Dec 26 20:41:16 archtop sddm-helper[1026]: [PAM] Conversation with 1 messages
Dec 26 20:41:16 archtop sddm-helper[1026]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 20:41:16 archtop sddm-helper[1026]: [PAM] returning.
Dec 26 20:41:16 archtop sddm[953]: Authentication for user  "zmoon"  successful
Dec 26 20:41:16 archtop sddm-helper[1026]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 20:41:16 archtop sddm-helper[1026]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 20:41:16 archtop sddm[953]: Auth: sddm-helper exited successfully
Dec 26 20:41:16 archtop sddm[953]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 20:41:17 archtop sddm-helper[1026]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 20:41:17 archtop sddm-helper[1026]: Writing cookie to "/tmp/xauth_PJtfiO"
Dec 26 20:41:17 archtop sddm-helper[1026]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 20:41:17 archtop sddm[953]: Session started true
Dec 26 21:27:23 archtop sddm[953]: Auth: sddm-helper exited successfully
Dec 26 21:27:23 archtop sddm[953]: Socket server stopping...
Dec 26 21:27:23 archtop sddm[953]: Socket server stopped.
Dec 26 21:27:23 archtop sddm[953]: Display server stopping...
Dec 26 21:27:24 archtop sddm[953]: Display server stopped.
Dec 26 21:27:24 archtop sddm[953]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 21:27:24 archtop sddm[953]: Removing display SDDM::Display(0x5e2735fc7c80) ...
Dec 26 21:27:24 archtop sddm[953]: Adding new display...
Dec 26 21:27:24 archtop sddm[953]: Loaded empty theme configuration
Dec 26 21:27:24 archtop sddm[953]: Xauthority path: "/run/sddm/xauth_ntSsTM"
Dec 26 21:27:24 archtop sddm[953]: Using VT 2
Dec 26 21:27:24 archtop sddm[953]: Display server starting...
Dec 26 21:27:24 archtop sddm[953]: Writing cookie to "/run/sddm/xauth_ntSsTM"
Dec 26 21:27:24 archtop sddm[953]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_ntSsTM -noreset -displayfd 18
Dec 26 21:27:28 archtop sddm[953]: Setting default cursor
Dec 26 21:27:28 archtop sddm[953]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 21:27:28 archtop sddm[953]: Display server started.
Dec 26 21:27:28 archtop sddm[953]: Socket server starting...
Dec 26 21:27:28 archtop sddm[953]: Socket server started.
Dec 26 21:27:28 archtop sddm[953]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 21:27:28 archtop sddm[953]: Greeter starting...
Dec 26 21:27:28 archtop sddm-helper[3462]: [PAM] Starting...
Dec 26 21:27:28 archtop sddm-helper[3462]: [PAM] Authenticating...
Dec 26 21:27:28 archtop sddm-helper[3462]: [PAM] returning.
Dec 26 21:27:28 archtop sddm-helper[3462]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 21:27:28 archtop sddm-helper[3462]: Writing cookie to "/tmp/xauth_AVyryG"
Dec 26 21:27:28 archtop sddm-helper[3462]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-WfMXzQ --theme /usr/share/sddm/themes/breath"
Dec 26 21:27:28 archtop sddm[953]: Greeter session started successfully
Dec 26 21:27:28 archtop sddm[953]: Message received from greeter: Connect
Dec 26 21:27:44 archtop sddm[953]: Message received from greeter: Login
Dec 26 21:27:44 archtop sddm[953]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
Dec 26 21:27:44 archtop sddm[953]: Session "/usr/share/wayland-sessions/plasmawayland.desktop" selected, command: "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland" for VT 1
Dec 26 21:27:44 archtop sddm-helper[3510]: [PAM] Starting...
Dec 26 21:27:44 archtop sddm-helper[3510]: [PAM] Authenticating...
Dec 26 21:27:44 archtop sddm-helper[3510]: [PAM] Preparing to converse...
Dec 26 21:27:44 archtop sddm-helper[3510]: [PAM] Conversation with 1 messages
Dec 26 21:27:44 archtop sddm-helper[3510]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 21:27:44 archtop sddm-helper[3510]: [PAM] returning.
Dec 26 21:27:44 archtop sddm[953]: Authentication for user  "zmoon"  successful
Dec 26 21:27:44 archtop sddm-helper[3510]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 21:27:44 archtop sddm-helper[3510]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 21:27:44 archtop sddm[953]: Auth: sddm-helper exited successfully
Dec 26 21:27:44 archtop sddm[953]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 21:27:44 archtop sddm-helper[3510]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 21:27:44 archtop sddm-helper[3510]: Starting Wayland user session: "/usr/share/sddm/scripts/wayland-session" "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland"
Dec 26 21:27:46 archtop sddm[953]: Session started true
Dec 26 21:28:59 archtop sddm[953]: Auth: sddm-helper exited successfully
Dec 26 21:28:59 archtop sddm[953]: Socket server stopping...
Dec 26 21:28:59 archtop sddm[953]: Socket server stopped.
Dec 26 21:28:59 archtop sddm[953]: Display server stopping...
Dec 26 21:28:59 archtop sddm[953]: Display server stopped.
Dec 26 21:28:59 archtop sddm[953]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 21:28:59 archtop sddm[953]: Removing display SDDM::Display(0x5e2735fd5c80) ...
Dec 26 21:28:59 archtop sddm[953]: Adding new display...
Dec 26 21:28:59 archtop sddm[953]: Loaded empty theme configuration
Dec 26 21:28:59 archtop sddm[953]: Xauthority path: "/run/sddm/xauth_pZrwDp"
Dec 26 21:28:59 archtop sddm[953]: Using VT 2
Dec 26 21:28:59 archtop sddm[953]: Display server starting...
Dec 26 21:28:59 archtop sddm[953]: Writing cookie to "/run/sddm/xauth_pZrwDp"
Dec 26 21:28:59 archtop sddm[953]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_pZrwDp -noreset -displayfd 18
Dec 26 21:29:03 archtop sddm[953]: Setting default cursor
Dec 26 21:29:03 archtop sddm[953]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 21:29:03 archtop sddm[953]: Display server started.
Dec 26 21:29:03 archtop sddm[953]: Socket server starting...
Dec 26 21:29:03 archtop sddm[953]: Socket server started.
Dec 26 21:29:03 archtop sddm[953]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 21:29:03 archtop sddm[953]: Greeter starting...
Dec 26 21:29:03 archtop sddm-helper[4850]: [PAM] Starting...
Dec 26 21:29:03 archtop sddm-helper[4850]: [PAM] Authenticating...
Dec 26 21:29:03 archtop sddm-helper[4850]: [PAM] returning.
Dec 26 21:29:03 archtop sddm-helper[4850]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 21:29:03 archtop sddm-helper[4850]: Writing cookie to "/tmp/xauth_NDwaho"
Dec 26 21:29:03 archtop sddm-helper[4850]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-DdTOvg --theme /usr/share/sddm/themes/breath"
Dec 26 21:29:03 archtop sddm[953]: Greeter session started successfully
Dec 26 21:29:03 archtop sddm[953]: Message received from greeter: Connect
Dec 26 21:29:17 archtop sddm[953]: Message received from greeter: Login
Dec 26 21:29:17 archtop sddm[953]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 21:29:17 archtop sddm[953]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 21:29:17 archtop sddm-helper[4897]: [PAM] Starting...
Dec 26 21:29:17 archtop sddm-helper[4897]: [PAM] Authenticating...
Dec 26 21:29:17 archtop sddm-helper[4897]: [PAM] Preparing to converse...
Dec 26 21:29:17 archtop sddm-helper[4897]: [PAM] Conversation with 1 messages
Dec 26 21:29:17 archtop sddm-helper[4897]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 21:29:17 archtop sddm-helper[4897]: [PAM] returning.
Dec 26 21:29:17 archtop sddm[953]: Authentication for user  "zmoon"  successful
Dec 26 21:29:17 archtop sddm-helper[4897]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 21:29:17 archtop sddm-helper[4897]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 21:29:17 archtop sddm[953]: Auth: sddm-helper exited successfully
Dec 26 21:29:17 archtop sddm[953]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 21:29:18 archtop sddm-helper[4897]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 21:29:18 archtop sddm-helper[4897]: Writing cookie to "/tmp/xauth_EHFOIU"
Dec 26 21:29:18 archtop sddm-helper[4897]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 21:29:18 archtop sddm[953]: Session started true
Dec 26 21:46:54 archtop sddm[953]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 21:46:54 archtop sddm[953]: Auth: sddm-helper (--socket /tmp/sddm-auth-7f754c70-4ccf-4461-b21d-c08d0bf21e0f --id 5 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 21:46:54 archtop sddm[953]: Auth: sddm-helper exited with 1
Dec 26 21:46:54 archtop sddm[953]: Signal received: SIGTERM
Dec 26 21:46:54 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 21:46:54 archtop sddm[953]: Socket server stopping...
Dec 26 21:46:54 archtop sddm[953]: Socket server stopped.
Dec 26 21:46:54 archtop sddm[953]: Display server stopping...
Dec 26 21:46:56 archtop sddm[953]: Display server stopped.
Dec 26 21:46:56 archtop sddm[953]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 21:46:56 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 21:46:56 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 21:46:56 archtop systemd[1]: sddm.service: Consumed 53.475s CPU time, 356.7M memory peak.
-- Boot be6f33f1dfe64f3d95b6e98c1261b72b --
Dec 26 21:47:41 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 21:47:41 archtop sddm[951]: Initializing...
Dec 26 21:47:41 archtop sddm[951]: Starting...
Dec 26 21:47:41 archtop sddm[951]: Logind interface found
Dec 26 21:47:41 archtop sddm[951]: Adding new display...
Dec 26 21:47:41 archtop sddm[951]: Loaded empty theme configuration
Dec 26 21:47:41 archtop sddm[951]: Xauthority path: "/run/sddm/xauth_CqYNfw"
Dec 26 21:47:41 archtop sddm[951]: Using VT 2
Dec 26 21:47:41 archtop sddm[951]: Display server starting...
Dec 26 21:47:41 archtop sddm[951]: Writing cookie to "/run/sddm/xauth_CqYNfw"
Dec 26 21:47:41 archtop sddm[951]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_CqYNfw -noreset -displayfd 16
Dec 26 21:47:45 archtop sddm[951]: Setting default cursor
Dec 26 21:47:45 archtop sddm[951]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 21:47:45 archtop sddm[951]: Display server started.
Dec 26 21:47:45 archtop sddm[951]: Socket server starting...
Dec 26 21:47:45 archtop sddm[951]: Socket server started.
Dec 26 21:47:45 archtop sddm[951]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 21:47:45 archtop sddm[951]: Greeter starting...
Dec 26 21:47:45 archtop sddm-helper[979]: [PAM] Starting...
Dec 26 21:47:45 archtop sddm-helper[979]: [PAM] Authenticating...
Dec 26 21:47:45 archtop sddm-helper[979]: [PAM] returning.
Dec 26 21:47:45 archtop sddm-helper[979]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 21:47:45 archtop sddm-helper[979]: Writing cookie to "/tmp/xauth_uykyVH"
Dec 26 21:47:45 archtop sddm-helper[979]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-nwPVWg --theme /usr/share/sddm/themes/breath"
Dec 26 21:47:45 archtop sddm[951]: Greeter session started successfully
Dec 26 21:47:45 archtop sddm[951]: Message received from greeter: Connect
Dec 26 21:48:07 archtop sddm[951]: Message received from greeter: Login
Dec 26 21:48:07 archtop sddm[951]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
Dec 26 21:48:07 archtop sddm[951]: Session "/usr/share/wayland-sessions/plasmawayland.desktop" selected, command: "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland" for VT 1
Dec 26 21:48:07 archtop sddm-helper[1028]: [PAM] Starting...
Dec 26 21:48:07 archtop sddm-helper[1028]: [PAM] Authenticating...
Dec 26 21:48:07 archtop sddm-helper[1028]: [PAM] Preparing to converse...
Dec 26 21:48:07 archtop sddm-helper[1028]: [PAM] Conversation with 1 messages
Dec 26 21:48:07 archtop sddm-helper[1028]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 21:48:07 archtop sddm-helper[1028]: [PAM] returning.
Dec 26 21:48:07 archtop sddm[951]: Authentication for user  "zmoon"  successful
Dec 26 21:48:07 archtop sddm-helper[1028]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 21:48:07 archtop sddm-helper[1028]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 21:48:08 archtop sddm[951]: Auth: sddm-helper exited successfully
Dec 26 21:48:08 archtop sddm[951]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 21:48:08 archtop sddm-helper[1028]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 21:48:08 archtop sddm-helper[1028]: Starting Wayland user session: "/usr/share/sddm/scripts/wayland-session" "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland"
Dec 26 21:48:09 archtop sddm[951]: Session started true
Dec 26 21:48:27 archtop sddm[951]: Auth: sddm-helper exited successfully
Dec 26 21:48:27 archtop sddm[951]: Socket server stopping...
Dec 26 21:48:27 archtop sddm[951]: Socket server stopped.
Dec 26 21:48:27 archtop sddm[951]: Display server stopping...
Dec 26 21:48:27 archtop sddm[951]: Display server stopped.
Dec 26 21:48:27 archtop sddm[951]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 21:48:27 archtop sddm[951]: Removing display SDDM::Display(0x6193ffc17c50) ...
Dec 26 21:48:27 archtop sddm[951]: Adding new display...
Dec 26 21:48:27 archtop sddm[951]: Loaded empty theme configuration
Dec 26 21:48:27 archtop sddm[951]: Xauthority path: "/run/sddm/xauth_YUWAmO"
Dec 26 21:48:27 archtop sddm[951]: Using VT 2
Dec 26 21:48:27 archtop sddm[951]: Display server starting...
Dec 26 21:48:27 archtop sddm[951]: Writing cookie to "/run/sddm/xauth_YUWAmO"
Dec 26 21:48:27 archtop sddm[951]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_YUWAmO -noreset -displayfd 18
Dec 26 21:48:31 archtop sddm[951]: Setting default cursor
Dec 26 21:48:31 archtop sddm[951]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 21:48:31 archtop sddm[951]: Display server started.
Dec 26 21:48:31 archtop sddm[951]: Socket server starting...
Dec 26 21:48:31 archtop sddm[951]: Socket server started.
Dec 26 21:48:31 archtop sddm[951]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 21:48:31 archtop sddm[951]: Greeter starting...
Dec 26 21:48:31 archtop sddm-helper[2323]: [PAM] Starting...
Dec 26 21:48:31 archtop sddm-helper[2323]: [PAM] Authenticating...
Dec 26 21:48:31 archtop sddm-helper[2323]: [PAM] returning.
Dec 26 21:48:31 archtop sddm-helper[2323]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 21:48:31 archtop sddm-helper[2323]: Writing cookie to "/tmp/xauth_TPTRFi"
Dec 26 21:48:31 archtop sddm-helper[2323]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-mECRIm --theme /usr/share/sddm/themes/breath"
Dec 26 21:48:31 archtop sddm[951]: Greeter session started successfully
Dec 26 21:48:31 archtop sddm[951]: Message received from greeter: Connect
Dec 26 21:48:46 archtop sddm[951]: Message received from greeter: Login
Dec 26 21:48:46 archtop sddm[951]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 21:48:46 archtop sddm[951]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 21:48:46 archtop sddm-helper[2374]: [PAM] Starting...
Dec 26 21:48:46 archtop sddm-helper[2374]: [PAM] Authenticating...
Dec 26 21:48:46 archtop sddm-helper[2374]: [PAM] Preparing to converse...
Dec 26 21:48:46 archtop sddm-helper[2374]: [PAM] Conversation with 1 messages
Dec 26 21:48:46 archtop sddm-helper[2374]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 21:48:46 archtop sddm-helper[2374]: [PAM] returning.
Dec 26 21:48:46 archtop sddm[951]: Authentication for user  "zmoon"  successful
Dec 26 21:48:46 archtop sddm-helper[2374]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 21:48:46 archtop sddm-helper[2374]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 21:48:46 archtop sddm[951]: Auth: sddm-helper exited successfully
Dec 26 21:48:46 archtop sddm[951]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 21:48:46 archtop sddm-helper[2374]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 21:48:46 archtop sddm-helper[2374]: Writing cookie to "/tmp/xauth_fqUPGO"
Dec 26 21:48:46 archtop sddm-helper[2374]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 21:48:46 archtop sddm[951]: Session started true
Dec 26 21:56:54 archtop sddm[951]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 21:56:54 archtop sddm[951]: Auth: sddm-helper (--socket /tmp/sddm-auth-2e4aa1fc-abab-460e-9f5e-b9cd570af771 --id 3 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 26 21:56:54 archtop sddm[951]: Auth: sddm-helper exited with 1
Dec 26 21:56:54 archtop sddm[951]: Signal received: SIGTERM
Dec 26 21:56:54 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 21:56:54 archtop sddm[951]: Socket server stopping...
Dec 26 21:56:54 archtop sddm[951]: Socket server stopped.
Dec 26 21:56:54 archtop sddm[951]: Display server stopping...
Dec 26 21:56:55 archtop sddm[951]: Display server stopped.
Dec 26 21:56:55 archtop sddm[951]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 26 21:56:55 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 21:56:55 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 21:56:55 archtop systemd[1]: sddm.service: Consumed 13.089s CPU time, 394.8M memory peak.
-- Boot fbe1f04333364db3beac3851601e96be --
Dec 26 21:58:12 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 21:58:12 archtop sddm[948]: Initializing...
Dec 26 21:58:12 archtop sddm[948]: Starting...
Dec 26 21:58:12 archtop sddm[948]: Logind interface found
Dec 26 21:58:12 archtop sddm[948]: Adding new display...
Dec 26 21:58:12 archtop sddm[948]: Loaded empty theme configuration
Dec 26 21:58:12 archtop sddm[948]: Xauthority path: "/run/sddm/xauth_LFjYHm"
Dec 26 21:58:12 archtop sddm[948]: Using VT 2
Dec 26 21:58:12 archtop sddm[948]: Display server starting...
Dec 26 21:58:12 archtop sddm[948]: Writing cookie to "/run/sddm/xauth_LFjYHm"
Dec 26 21:58:12 archtop sddm[948]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_LFjYHm -noreset -displayfd 16
Dec 26 21:58:13 archtop sddm[948]: Setting default cursor
Dec 26 21:58:13 archtop sddm[948]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 21:58:13 archtop sddm[948]: Display server started.
Dec 26 21:58:13 archtop sddm[948]: Socket server starting...
Dec 26 21:58:13 archtop sddm[948]: Socket server started.
Dec 26 21:58:13 archtop sddm[948]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 21:58:13 archtop sddm[948]: Greeter starting...
Dec 26 21:58:13 archtop sddm-helper[986]: [PAM] Starting...
Dec 26 21:58:13 archtop sddm-helper[986]: [PAM] Authenticating...
Dec 26 21:58:13 archtop sddm-helper[986]: [PAM] returning.
Dec 26 21:58:13 archtop sddm-helper[986]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 21:58:14 archtop sddm-helper[986]: Writing cookie to "/tmp/xauth_PHcuaV"
Dec 26 21:58:14 archtop sddm-helper[986]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-eSQAyO --theme /usr/share/sddm/themes/breath"
Dec 26 21:58:14 archtop sddm[948]: Greeter session started successfully
Dec 26 21:58:14 archtop sddm[948]: Message received from greeter: Connect
Dec 26 21:58:28 archtop sddm[948]: Message received from greeter: Login
Dec 26 21:58:28 archtop sddm[948]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
Dec 26 21:58:28 archtop sddm[948]: Session "/usr/share/wayland-sessions/plasmawayland.desktop" selected, command: "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland" for VT 1
Dec 26 21:58:28 archtop sddm-helper[1044]: [PAM] Starting...
Dec 26 21:58:28 archtop sddm-helper[1044]: [PAM] Authenticating...
Dec 26 21:58:28 archtop sddm-helper[1044]: [PAM] Preparing to converse...
Dec 26 21:58:28 archtop sddm-helper[1044]: [PAM] Conversation with 1 messages
Dec 26 21:58:28 archtop sddm-helper[1044]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 21:58:28 archtop sddm-helper[1044]: [PAM] returning.
Dec 26 21:58:28 archtop sddm[948]: Authentication for user  "zmoon"  successful
Dec 26 21:58:28 archtop sddm-helper[1044]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 21:58:28 archtop sddm-helper[1044]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 21:58:28 archtop sddm[948]: Auth: sddm-helper exited successfully
Dec 26 21:58:28 archtop sddm[948]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 21:58:28 archtop sddm-helper[1044]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 21:58:28 archtop sddm-helper[1044]: Starting Wayland user session: "/usr/share/sddm/scripts/wayland-session" "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland"
Dec 26 21:58:29 archtop sddm[948]: Session started true
Dec 26 22:45:51 archtop sddm[948]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 26 22:45:51 archtop sddm[948]: Auth: sddm-helper (--socket /tmp/sddm-auth-f09f0d9a-1357-4916-9535-3d16345b0b95 --id 1 --start /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user zmoon) crashed (exit code 1)
Dec 26 22:45:51 archtop sddm[948]: Auth: sddm-helper exited with 1
Dec 26 22:45:51 archtop sddm[948]: Signal received: SIGTERM
Dec 26 22:45:51 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 22:45:51 archtop sddm[948]: Socket server stopping...
Dec 26 22:45:51 archtop sddm[948]: Socket server stopped.
Dec 26 22:45:51 archtop sddm[948]: Display server stopping...
Dec 26 22:46:21 archtop sddm[948]: Display server stopping...
Dec 26 22:46:51 archtop sddm[948]: QProcess: Destroyed while process ("/usr/bin/X") is still running.
Dec 26 22:47:21 archtop systemd[1]: sddm.service: Killing process 966 (Xorg:traceq0) with signal SIGKILL.
-- Boot 9fa9a30f82d6416fb0a2b3b003cabd75 --
Dec 26 22:49:28 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 22:49:28 archtop sddm[964]: Initializing...
Dec 26 22:49:28 archtop sddm[964]: Starting...
Dec 26 22:49:28 archtop sddm[964]: Logind interface found
Dec 26 22:49:28 archtop sddm[964]: Adding new display...
Dec 26 22:49:28 archtop sddm[964]: Loaded empty theme configuration
Dec 26 22:49:28 archtop sddm[964]: Xauthority path: "/run/sddm/xauth_pnzhPf"
Dec 26 22:49:28 archtop sddm[964]: Using VT 2
Dec 26 22:49:28 archtop sddm[964]: Display server starting...
Dec 26 22:49:28 archtop sddm[964]: Writing cookie to "/run/sddm/xauth_pnzhPf"
Dec 26 22:49:28 archtop sddm[964]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_pnzhPf -noreset -displayfd 16
Dec 26 22:49:29 archtop sddm[964]: Failed to read display number from pipe
Dec 26 22:49:29 archtop sddm[964]: Display server stopping...
Dec 26 22:49:29 archtop sddm[964]: Attempt 1 starting the Display server on vt 2 failed
Dec 26 22:49:31 archtop sddm[964]: Display server starting...
Dec 26 22:49:31 archtop sddm[964]: Writing cookie to "/run/sddm/xauth_pnzhPf"
Dec 26 22:49:31 archtop sddm[964]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_pnzhPf -noreset -displayfd 16
Dec 26 22:49:32 archtop sddm[964]: Failed to read display number from pipe
Dec 26 22:49:32 archtop sddm[964]: Display server stopping...
Dec 26 22:49:32 archtop sddm[964]: Attempt 2 starting the Display server on vt 2 failed
Dec 26 22:49:34 archtop sddm[964]: Display server starting...
Dec 26 22:49:34 archtop sddm[964]: Writing cookie to "/run/sddm/xauth_pnzhPf"
Dec 26 22:49:34 archtop sddm[964]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_pnzhPf -noreset -displayfd 16
Dec 26 22:49:35 archtop sddm[964]: Failed to read display number from pipe
Dec 26 22:49:35 archtop sddm[964]: Display server stopping...
Dec 26 22:49:35 archtop sddm[964]: Attempt 3 starting the Display server on vt 2 failed
Dec 26 22:49:35 archtop sddm[964]: Could not start Display server on vt 2
Dec 26 22:53:18 archtop sddm[964]: Signal received: SIGTERM
Dec 26 22:53:18 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 26 22:53:18 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 26 22:53:18 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 26 22:53:18 archtop systemd[1]: sddm.service: Consumed 1.053s CPU time, 335.4M memory peak.
-- Boot d37c8b5375ec4ab7b7406fabe6097497 --
Dec 26 22:54:30 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 22:54:30 archtop sddm[942]: Initializing...
Dec 26 22:54:30 archtop sddm[942]: Starting...
Dec 26 22:54:30 archtop sddm[942]: Logind interface found
Dec 26 22:54:30 archtop sddm[942]: Adding new display...
Dec 26 22:54:30 archtop sddm[942]: Loaded empty theme configuration
Dec 26 22:54:30 archtop sddm[942]: Xauthority path: "/run/sddm/xauth_OisloF"
Dec 26 22:54:30 archtop sddm[942]: Using VT 2
Dec 26 22:54:30 archtop sddm[942]: Display server starting...
Dec 26 22:54:30 archtop sddm[942]: Writing cookie to "/run/sddm/xauth_OisloF"
Dec 26 22:54:30 archtop sddm[942]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_OisloF -noreset -displayfd 16
Dec 26 22:54:34 archtop sddm[942]: Setting default cursor
Dec 26 22:54:34 archtop sddm[942]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 22:54:34 archtop sddm[942]: Display server started.
Dec 26 22:54:34 archtop sddm[942]: Socket server starting...
Dec 26 22:54:34 archtop sddm[942]: Socket server started.
Dec 26 22:54:34 archtop sddm[942]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 22:54:34 archtop sddm[942]: Greeter starting...
Dec 26 22:54:34 archtop sddm-helper[968]: [PAM] Starting...
Dec 26 22:54:34 archtop sddm-helper[968]: [PAM] Authenticating...
Dec 26 22:54:34 archtop sddm-helper[968]: [PAM] returning.
Dec 26 22:54:34 archtop sddm-helper[968]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 22:54:34 archtop sddm-helper[968]: Writing cookie to "/tmp/xauth_UpSUlJ"
Dec 26 22:54:34 archtop sddm-helper[968]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-uwZAKR --theme /usr/share/sddm/themes/breath"
Dec 26 22:54:34 archtop sddm[942]: Greeter session started successfully
Dec 26 22:54:34 archtop sddm[942]: Message received from greeter: Connect
Dec 26 22:54:42 archtop sddm[942]: Message received from greeter: Login
-- Boot 9226d9c7035e4478aa803ae816babe22 --
Dec 26 22:56:15 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 26 22:56:15 archtop sddm[949]: Initializing...
Dec 26 22:56:15 archtop sddm[949]: Starting...
Dec 26 22:56:15 archtop sddm[949]: Logind interface found
Dec 26 22:56:15 archtop sddm[949]: Adding new display...
Dec 26 22:56:15 archtop sddm[949]: Loaded empty theme configuration
Dec 26 22:56:15 archtop sddm[949]: Xauthority path: "/run/sddm/xauth_hUMdwO"
Dec 26 22:56:15 archtop sddm[949]: Using VT 2
Dec 26 22:56:15 archtop sddm[949]: Display server starting...
Dec 26 22:56:15 archtop sddm[949]: Writing cookie to "/run/sddm/xauth_hUMdwO"
Dec 26 22:56:15 archtop sddm[949]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_hUMdwO -noreset -displayfd 16
Dec 26 22:56:18 archtop sddm[949]: Setting default cursor
Dec 26 22:56:18 archtop sddm[949]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 26 22:56:18 archtop sddm[949]: Display server started.
Dec 26 22:56:18 archtop sddm[949]: Socket server starting...
Dec 26 22:56:18 archtop sddm[949]: Socket server started.
Dec 26 22:56:18 archtop sddm[949]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 26 22:56:18 archtop sddm[949]: Greeter starting...
Dec 26 22:56:18 archtop sddm-helper[963]: [PAM] Starting...
Dec 26 22:56:18 archtop sddm-helper[963]: [PAM] Authenticating...
Dec 26 22:56:18 archtop sddm-helper[963]: [PAM] returning.
Dec 26 22:56:18 archtop sddm-helper[963]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 26 22:56:19 archtop sddm-helper[963]: Writing cookie to "/tmp/xauth_VhPOJj"
Dec 26 22:56:19 archtop sddm-helper[963]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-jrBIwr --theme /usr/share/sddm/themes/breath"
Dec 26 22:56:19 archtop sddm[949]: Greeter session started successfully
Dec 26 22:56:19 archtop sddm[949]: Message received from greeter: Connect
Dec 26 22:56:32 archtop sddm[949]: Message received from greeter: Login
Dec 26 22:56:32 archtop sddm[949]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 26 22:56:32 archtop sddm[949]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 26 22:56:32 archtop sddm-helper[1024]: [PAM] Starting...
Dec 26 22:56:32 archtop sddm-helper[1024]: [PAM] Authenticating...
Dec 26 22:56:32 archtop sddm-helper[1024]: [PAM] Preparing to converse...
Dec 26 22:56:32 archtop sddm-helper[1024]: [PAM] Conversation with 1 messages
Dec 26 22:56:32 archtop sddm-helper[1024]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 26 22:56:32 archtop sddm-helper[1024]: [PAM] returning.
Dec 26 22:56:32 archtop sddm[949]: Authentication for user  "zmoon"  successful
Dec 26 22:56:32 archtop sddm-helper[1024]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 26 22:56:32 archtop sddm-helper[1024]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 26 22:56:32 archtop sddm[949]: Auth: sddm-helper exited successfully
Dec 26 22:56:32 archtop sddm[949]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 26 22:56:32 archtop sddm-helper[1024]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 26 22:56:32 archtop sddm-helper[1024]: Writing cookie to "/tmp/xauth_cBpNCF"
Dec 26 22:56:32 archtop sddm-helper[1024]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 26 22:56:32 archtop sddm[949]: Session started true
-- Boot 193a8df657174724b58ad3d0b9244b87 --
Dec 27 09:15:44 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 27 09:15:44 archtop sddm[944]: Initializing...
Dec 27 09:15:44 archtop sddm[944]: Starting...
Dec 27 09:15:44 archtop sddm[944]: Logind interface found
Dec 27 09:15:44 archtop sddm[944]: Adding new display...
Dec 27 09:15:44 archtop sddm[944]: Loaded empty theme configuration
Dec 27 09:15:44 archtop sddm[944]: Xauthority path: "/run/sddm/xauth_DbxiRQ"
Dec 27 09:15:44 archtop sddm[944]: Using VT 2
Dec 27 09:15:44 archtop sddm[944]: Display server starting...
Dec 27 09:15:44 archtop sddm[944]: Writing cookie to "/run/sddm/xauth_DbxiRQ"
Dec 27 09:15:44 archtop sddm[944]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_DbxiRQ -noreset -displayfd 16
Dec 27 09:15:47 archtop sddm[944]: Setting default cursor
Dec 27 09:15:47 archtop sddm[944]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 27 09:15:47 archtop sddm[944]: Display server started.
Dec 27 09:15:47 archtop sddm[944]: Socket server starting...
Dec 27 09:15:47 archtop sddm[944]: Socket server started.
Dec 27 09:15:47 archtop sddm[944]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 27 09:15:47 archtop sddm[944]: Greeter starting...
Dec 27 09:15:47 archtop sddm-helper[958]: [PAM] Starting...
Dec 27 09:15:47 archtop sddm-helper[958]: [PAM] Authenticating...
Dec 27 09:15:47 archtop sddm-helper[958]: [PAM] returning.
Dec 27 09:15:47 archtop sddm-helper[958]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 27 09:15:48 archtop sddm-helper[958]: Writing cookie to "/tmp/xauth_uobBfZ"
Dec 27 09:15:48 archtop sddm-helper[958]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-ZPXVRl --theme /usr/share/sddm/themes/breath"
Dec 27 09:15:48 archtop sddm[944]: Greeter session started successfully
Dec 27 09:15:48 archtop sddm[944]: Message received from greeter: Connect
Dec 27 09:15:56 archtop sddm[944]: Message received from greeter: Login
Dec 27 09:15:56 archtop sddm[944]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 27 09:15:56 archtop sddm[944]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 27 09:15:56 archtop sddm-helper[995]: [PAM] Starting...
Dec 27 09:15:56 archtop sddm-helper[995]: [PAM] Authenticating...
Dec 27 09:15:56 archtop sddm-helper[995]: [PAM] Preparing to converse...
Dec 27 09:15:56 archtop sddm-helper[995]: [PAM] Conversation with 1 messages
Dec 27 09:15:56 archtop unix_chkpwd[997]: password check failed for user (zmoon)
Dec 27 09:15:56 archtop sddm-helper[995]: pam_unix(sddm:auth): authentication failure; logname= uid=0 euid=0 tty= ruser= rhost=  user=zmoon
Dec 27 09:15:58 archtop sddm-helper[995]: [PAM] authenticate: Authentication failure
Dec 27 09:15:58 archtop sddm-helper[995]: [PAM] returning.
Dec 27 09:15:58 archtop sddm[944]: Authentication error: SDDM::Auth::ERROR_AUTHENTICATION "Authentication failure"
Dec 27 09:15:58 archtop sddm-helper[995]: [PAM] Asked to close the session but it wasn't previously open
Dec 27 09:15:58 archtop sddm[944]: Authentication for user  ""  failed
Dec 27 09:15:58 archtop sddm-helper[995]: [PAM] Ended.
Dec 27 09:15:58 archtop sddm[944]: Auth: sddm-helper exited with 1
Dec 27 09:16:04 archtop sddm[944]: Message received from greeter: Login
Dec 27 09:16:04 archtop sddm[944]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 27 09:16:04 archtop sddm[944]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 27 09:16:04 archtop sddm-helper[999]: [PAM] Starting...
Dec 27 09:16:04 archtop sddm-helper[999]: [PAM] Authenticating...
Dec 27 09:16:04 archtop sddm-helper[999]: [PAM] Preparing to converse...
Dec 27 09:16:04 archtop sddm-helper[999]: [PAM] Conversation with 1 messages
Dec 27 09:16:04 archtop sddm-helper[999]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 27 09:16:04 archtop sddm-helper[999]: [PAM] returning.
Dec 27 09:16:04 archtop sddm[944]: Authentication for user  "zmoon"  successful
Dec 27 09:16:04 archtop sddm-helper[999]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 27 09:16:04 archtop sddm-helper[999]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 27 09:16:04 archtop sddm[944]: Auth: sddm-helper exited successfully
Dec 27 09:16:04 archtop sddm[944]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 27 09:16:05 archtop sddm-helper[999]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 27 09:16:05 archtop sddm-helper[999]: Writing cookie to "/tmp/xauth_scaVyF"
Dec 27 09:16:05 archtop sddm-helper[999]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 27 09:16:05 archtop sddm[944]: Session started true
Dec 27 09:28:32 archtop sddm[944]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 27 09:28:32 archtop sddm[944]: Auth: sddm-helper (--socket /tmp/sddm-auth-eb196ff6-7003-4f96-a8cc-247eb80c5e56 --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 27 09:28:32 archtop sddm[944]: Auth: sddm-helper exited with 1
Dec 27 09:28:32 archtop sddm[944]: Signal received: SIGTERM
Dec 27 09:28:32 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 27 09:28:32 archtop sddm[944]: Socket server stopping...
Dec 27 09:28:32 archtop sddm[944]: Socket server stopped.
Dec 27 09:28:32 archtop sddm[944]: Display server stopping...
Dec 27 09:28:34 archtop sddm[944]: Display server stopped.
Dec 27 09:28:34 archtop sddm[944]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 27 09:28:34 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 27 09:28:34 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 27 09:28:34 archtop systemd[1]: sddm.service: Consumed 14.463s CPU time, 385.9M memory peak.
-- Boot fa6455bc055f4910ad44a8ce9ee4126a --
Dec 27 10:55:41 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 27 10:55:41 archtop sddm[947]: Initializing...
Dec 27 10:55:41 archtop sddm[947]: Starting...
Dec 27 10:55:41 archtop sddm[947]: Logind interface found
Dec 27 10:55:41 archtop sddm[947]: Adding new display...
Dec 27 10:55:41 archtop sddm[947]: Loaded empty theme configuration
Dec 27 10:55:41 archtop sddm[947]: Xauthority path: "/run/sddm/xauth_oYbCqT"
Dec 27 10:55:41 archtop sddm[947]: Using VT 2
Dec 27 10:55:41 archtop sddm[947]: Display server starting...
Dec 27 10:55:41 archtop sddm[947]: Writing cookie to "/run/sddm/xauth_oYbCqT"
Dec 27 10:55:41 archtop sddm[947]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_oYbCqT -noreset -displayfd 16
Dec 27 10:55:45 archtop sddm[947]: Setting default cursor
Dec 27 10:55:45 archtop sddm[947]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 27 10:55:45 archtop sddm[947]: Display server started.
Dec 27 10:55:45 archtop sddm[947]: Socket server starting...
Dec 27 10:55:45 archtop sddm[947]: Socket server started.
Dec 27 10:55:45 archtop sddm[947]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 27 10:55:45 archtop sddm[947]: Greeter starting...
Dec 27 10:55:45 archtop sddm-helper[964]: [PAM] Starting...
Dec 27 10:55:45 archtop sddm-helper[964]: [PAM] Authenticating...
Dec 27 10:55:45 archtop sddm-helper[964]: [PAM] returning.
Dec 27 10:55:45 archtop sddm-helper[964]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 27 10:55:45 archtop sddm-helper[964]: Writing cookie to "/tmp/xauth_ifrHoN"
Dec 27 10:55:45 archtop sddm-helper[964]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-VybOWs --theme /usr/share/sddm/themes/breath"
Dec 27 10:55:45 archtop sddm[947]: Greeter session started successfully
Dec 27 10:55:45 archtop sddm[947]: Message received from greeter: Connect
Dec 27 10:55:58 archtop sddm[947]: Message received from greeter: Login
Dec 27 10:55:58 archtop sddm[947]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 27 10:55:58 archtop sddm[947]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 27 10:55:59 archtop sddm-helper[1001]: [PAM] Starting...
Dec 27 10:55:59 archtop sddm-helper[1001]: [PAM] Authenticating...
Dec 27 10:55:59 archtop sddm-helper[1001]: [PAM] Preparing to converse...
Dec 27 10:55:59 archtop sddm-helper[1001]: [PAM] Conversation with 1 messages
Dec 27 10:55:59 archtop sddm-helper[1001]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 27 10:55:59 archtop sddm-helper[1001]: [PAM] returning.
Dec 27 10:55:59 archtop sddm[947]: Authentication for user  "zmoon"  successful
Dec 27 10:55:59 archtop sddm-helper[1001]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 27 10:55:59 archtop sddm-helper[1001]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 27 10:55:59 archtop sddm[947]: Auth: sddm-helper exited successfully
Dec 27 10:55:59 archtop sddm[947]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 27 10:55:59 archtop sddm-helper[1001]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 27 10:55:59 archtop sddm-helper[1001]: Writing cookie to "/tmp/xauth_vcGevV"
Dec 27 10:55:59 archtop sddm-helper[1001]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 27 10:55:59 archtop sddm[947]: Session started true
Dec 27 12:32:00 archtop sddm[947]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 27 12:32:00 archtop sddm[947]: Auth: sddm-helper (--socket /tmp/sddm-auth-14ed80bc-dfaa-4346-9e07-cd0ff1ac944c --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 27 12:32:00 archtop sddm[947]: Auth: sddm-helper exited with 1
Dec 27 12:32:00 archtop sddm[947]: Signal received: SIGTERM
Dec 27 12:32:00 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 27 12:32:00 archtop sddm[947]: Socket server stopping...
Dec 27 12:32:00 archtop sddm[947]: Socket server stopped.
Dec 27 12:32:00 archtop sddm[947]: Display server stopping...
Dec 27 12:32:01 archtop sddm[947]: Display server stopped.
Dec 27 12:32:01 archtop sddm[947]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 27 12:32:01 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 27 12:32:01 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 27 12:32:01 archtop systemd[1]: sddm.service: Consumed 1min 28.384s CPU time, 361.8M memory peak.
-- Boot 19bf98da34fa4d149ea9dbe90a07a393 --
Dec 27 12:33:18 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 27 12:33:18 archtop sddm[957]: Initializing...
Dec 27 12:33:18 archtop sddm[957]: Starting...
Dec 27 12:33:18 archtop sddm[957]: Logind interface found
Dec 27 12:33:18 archtop sddm[957]: Adding new display...
Dec 27 12:33:18 archtop sddm[957]: Loaded empty theme configuration
Dec 27 12:33:18 archtop sddm[957]: Xauthority path: "/run/sddm/xauth_qsYwRZ"
Dec 27 12:33:18 archtop sddm[957]: Using VT 2
Dec 27 12:33:18 archtop sddm[957]: Display server starting...
Dec 27 12:33:18 archtop sddm[957]: Writing cookie to "/run/sddm/xauth_qsYwRZ"
Dec 27 12:33:18 archtop sddm[957]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_qsYwRZ -noreset -displayfd 16
Dec 27 12:33:21 archtop sddm[957]: Setting default cursor
Dec 27 12:33:21 archtop sddm[957]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 27 12:33:21 archtop sddm[957]: Display server started.
Dec 27 12:33:21 archtop sddm[957]: Socket server starting...
Dec 27 12:33:21 archtop sddm[957]: Socket server started.
Dec 27 12:33:21 archtop sddm[957]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 27 12:33:21 archtop sddm[957]: Greeter starting...
Dec 27 12:33:21 archtop sddm-helper[973]: [PAM] Starting...
Dec 27 12:33:21 archtop sddm-helper[973]: [PAM] Authenticating...
Dec 27 12:33:21 archtop sddm-helper[973]: [PAM] returning.
Dec 27 12:33:21 archtop sddm-helper[973]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 27 12:33:22 archtop sddm-helper[973]: Writing cookie to "/tmp/xauth_agtuaD"
Dec 27 12:33:22 archtop sddm-helper[973]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-UdiwEg --theme /usr/share/sddm/themes/breath"
Dec 27 12:33:22 archtop sddm[957]: Greeter session started successfully
Dec 27 12:33:22 archtop sddm[957]: Message received from greeter: Connect
Dec 27 12:33:29 archtop sddm[957]: Message received from greeter: Login
Dec 27 12:33:29 archtop sddm[957]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 27 12:33:29 archtop sddm[957]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 27 12:33:29 archtop sddm-helper[1010]: [PAM] Starting...
Dec 27 12:33:29 archtop sddm-helper[1010]: [PAM] Authenticating...
Dec 27 12:33:29 archtop sddm-helper[1010]: [PAM] Preparing to converse...
Dec 27 12:33:29 archtop sddm-helper[1010]: [PAM] Conversation with 1 messages
Dec 27 12:33:29 archtop sddm-helper[1010]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 27 12:33:29 archtop sddm-helper[1010]: [PAM] returning.
Dec 27 12:33:29 archtop sddm[957]: Authentication for user  "zmoon"  successful
Dec 27 12:33:29 archtop sddm-helper[1010]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 27 12:33:29 archtop sddm-helper[1010]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 27 12:33:29 archtop sddm[957]: Auth: sddm-helper exited successfully
Dec 27 12:33:29 archtop sddm[957]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 27 12:33:29 archtop sddm-helper[1010]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 27 12:33:29 archtop sddm-helper[1010]: Writing cookie to "/tmp/xauth_fZTOfh"
Dec 27 12:33:29 archtop sddm-helper[1010]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 27 12:33:29 archtop sddm[957]: Session started true
Dec 27 12:34:05 archtop sddm[957]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 27 12:34:05 archtop sddm[957]: Auth: sddm-helper (--socket /tmp/sddm-auth-b14ba3ed-d5f6-446f-b895-cb7e303e4a66 --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 27 12:34:05 archtop sddm[957]: Auth: sddm-helper exited with 1
Dec 27 12:34:05 archtop sddm[957]: Signal received: SIGTERM
Dec 27 12:34:05 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 27 12:34:05 archtop sddm[957]: Socket server stopping...
Dec 27 12:34:05 archtop sddm[957]: Socket server stopped.
Dec 27 12:34:05 archtop sddm[957]: Display server stopping...
Dec 27 12:34:07 archtop sddm[957]: Display server stopped.
Dec 27 12:34:07 archtop sddm[957]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 27 12:34:07 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 27 12:34:07 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 27 12:34:07 archtop systemd[1]: sddm.service: Consumed 2.898s CPU time, 355.5M memory peak.
-- Boot ec27b7521b404286a47d19f064087fb1 --
Dec 27 12:35:23 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 27 12:35:23 archtop sddm[955]: Initializing...
Dec 27 12:35:23 archtop sddm[955]: Starting...
Dec 27 12:35:23 archtop sddm[955]: Logind interface found
Dec 27 12:35:23 archtop sddm[955]: Adding new display...
Dec 27 12:35:23 archtop sddm[955]: Loaded empty theme configuration
Dec 27 12:35:23 archtop sddm[955]: Xauthority path: "/run/sddm/xauth_mVOIkK"
Dec 27 12:35:23 archtop sddm[955]: Using VT 2
Dec 27 12:35:23 archtop sddm[955]: Display server starting...
Dec 27 12:35:23 archtop sddm[955]: Writing cookie to "/run/sddm/xauth_mVOIkK"
Dec 27 12:35:23 archtop sddm[955]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_mVOIkK -noreset -displayfd 16
Dec 27 12:35:25 archtop sddm[955]: Setting default cursor
Dec 27 12:35:25 archtop sddm[955]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Dec 27 12:35:25 archtop sddm[955]: Display server started.
Dec 27 12:35:25 archtop sddm[955]: Socket server starting...
Dec 27 12:35:25 archtop sddm[955]: Socket server started.
Dec 27 12:35:25 archtop sddm[955]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Dec 27 12:35:25 archtop sddm[955]: Greeter starting...
Dec 27 12:35:25 archtop sddm-helper[979]: [PAM] Starting...
Dec 27 12:35:25 archtop sddm-helper[979]: [PAM] Authenticating...
Dec 27 12:35:25 archtop sddm-helper[979]: [PAM] returning.
Dec 27 12:35:25 archtop sddm-helper[979]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=960) by (uid=0)
Dec 27 12:35:25 archtop sddm-helper[979]: Writing cookie to "/tmp/xauth_IGBudr"
Dec 27 12:35:25 archtop sddm-helper[979]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-njbwMT --theme /usr/share/sddm/themes/breath"
Dec 27 12:35:25 archtop sddm[955]: Greeter session started successfully
Dec 27 12:35:25 archtop sddm[955]: Message received from greeter: Connect
Dec 27 12:35:31 archtop sddm[955]: Message received from greeter: Login
Dec 27 12:35:31 archtop sddm[955]: Reading from "/usr/share/xsessions/plasma.desktop"
Dec 27 12:35:31 archtop sddm[955]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 2
Dec 27 12:35:31 archtop sddm-helper[1026]: [PAM] Starting...
Dec 27 12:35:31 archtop sddm-helper[1026]: [PAM] Authenticating...
Dec 27 12:35:31 archtop sddm-helper[1026]: [PAM] Preparing to converse...
Dec 27 12:35:31 archtop sddm-helper[1026]: [PAM] Conversation with 1 messages
Dec 27 12:35:31 archtop sddm-helper[1026]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Dec 27 12:35:31 archtop sddm-helper[1026]: [PAM] returning.
Dec 27 12:35:31 archtop sddm[955]: Authentication for user  "zmoon"  successful
Dec 27 12:35:31 archtop sddm-helper[1026]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Dec 27 12:35:31 archtop sddm-helper[1026]: pam_unix(sddm:session): session opened for user zmoon(uid=1000) by zmoon(uid=0)
Dec 27 12:35:32 archtop sddm[955]: Auth: sddm-helper exited successfully
Dec 27 12:35:32 archtop sddm[955]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Dec 27 12:35:32 archtop sddm-helper[1026]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Dec 27 12:35:32 archtop sddm-helper[1026]: Writing cookie to "/tmp/xauth_HYDiyl"
Dec 27 12:35:32 archtop sddm-helper[1026]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Dec 27 12:35:32 archtop sddm[955]: Session started true
Dec 27 12:37:46 archtop sddm[955]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 27 12:37:46 archtop sddm[955]: Auth: sddm-helper (--socket /tmp/sddm-auth-4bcb33c4-c7d6-49f4-bb2f-f946ed45a61c --id 1 --start /usr/bin/startplasma-x11 --user zmoon) crashed (exit code 1)
Dec 27 12:37:46 archtop sddm[955]: Auth: sddm-helper exited with 1
Dec 27 12:37:46 archtop sddm[955]: Signal received: SIGTERM
Dec 27 12:37:46 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 27 12:37:46 archtop sddm[955]: Socket server stopping...
Dec 27 12:37:46 archtop sddm[955]: Socket server stopped.
Dec 27 12:37:46 archtop sddm[955]: Display server stopping...
Dec 27 12:37:48 archtop sddm[955]: Display server stopped.
Dec 27 12:37:48 archtop sddm[955]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Dec 27 12:37:48 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 27 12:37:48 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 27 12:37:48 archtop systemd[1]: sddm.service: Consumed 4.292s CPU time, 385.5M memory peak.
-- Boot 39f333590f894aa2906a19e45597a3f5 --
Dec 27 12:39:04 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 27 12:39:04 archtop sddm[955]: Initializing...
Dec 27 12:39:04 archtop sddm[955]: Starting...
Dec 27 12:39:04 archtop sddm[955]: Logind interface found
Dec 27 12:39:04 archtop sddm[955]: Adding new display...
Dec 27 12:39:04 archtop sddm[955]: Loaded empty theme configuration
Dec 27 12:39:04 archtop sddm[955]: Xauthority path: "/run/sddm/xauth_porbmb"
Dec 27 12:39:04 archtop sddm[955]: Using VT 2
Dec 27 12:39:04 archtop sddm[955]: Display server starting...
Dec 27 12:39:04 archtop sddm[955]: Writing cookie to "/run/sddm/xauth_porbmb"
Dec 27 12:39:04 archtop sddm[955]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_porbmb -noreset -displayfd 16
-- Boot 89aeb98b28054783b64efc7dd78b4fb3 --
Dec 27 12:42:30 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 27 12:42:31 archtop sddm[954]: Initializing...
Dec 27 12:42:31 archtop sddm[954]: Starting...
Dec 27 12:42:31 archtop sddm[954]: Logind interface found
Dec 27 12:42:31 archtop sddm[954]: Adding new display...
Dec 27 12:42:31 archtop sddm[954]: Loaded empty theme configuration
Dec 27 12:42:31 archtop sddm[954]: Xauthority path: "/run/sddm/xauth_dExcLv"
Dec 27 12:42:31 archtop sddm[954]: Using VT 2
Dec 27 12:42:31 archtop sddm[954]: Display server starting...
Dec 27 12:42:31 archtop sddm[954]: Writing cookie to "/run/sddm/xauth_dExcLv"
Dec 27 12:42:31 archtop sddm[954]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_dExcLv -noreset -displayfd 16
Dec 27 12:43:42 archtop sddm[954]: Failed to read display number from pipe
Dec 27 12:43:42 archtop sddm[954]: Display server stopping...
Dec 27 12:43:42 archtop sddm[954]: Attempt 1 starting the Display server on vt 2 failed
Dec 27 12:43:44 archtop sddm[954]: Display server starting...
Dec 27 12:43:44 archtop sddm[954]: Writing cookie to "/run/sddm/xauth_dExcLv"
Dec 27 12:43:44 archtop sddm[954]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_dExcLv -noreset -displayfd 16
Dec 27 12:43:45 archtop sddm[954]: Failed to read display number from pipe
Dec 27 12:43:45 archtop sddm[954]: Display server stopping...
Dec 27 12:43:45 archtop sddm[954]: Attempt 2 starting the Display server on vt 2 failed
Dec 27 12:43:47 archtop sddm[954]: Display server starting...
Dec 27 12:43:47 archtop sddm[954]: Writing cookie to "/run/sddm/xauth_dExcLv"
Dec 27 12:43:47 archtop sddm[954]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_dExcLv -noreset -displayfd 16
Dec 27 12:43:48 archtop sddm[954]: Failed to read display number from pipe
Dec 27 12:43:48 archtop sddm[954]: Display server stopping...
Dec 27 12:43:48 archtop sddm[954]: Attempt 3 starting the Display server on vt 2 failed
Dec 27 12:43:48 archtop sddm[954]: Could not start Display server on vt 2
Dec 27 12:44:01 archtop sddm[954]: Signal received: SIGTERM
Dec 27 12:44:01 archtop systemd[1]: Stopping Simple Desktop Display Manager...
Dec 27 12:44:01 archtop systemd[1]: sddm.service: Deactivated successfully.
Dec 27 12:44:01 archtop systemd[1]: Stopped Simple Desktop Display Manager.
Dec 27 12:44:01 archtop systemd[1]: sddm.service: Consumed 1.024s CPU time, 334.3M memory peak.
-- Boot 62c15970fb674a15b198474bba04c5e7 --
Dec 27 12:45:29 archtop systemd[1]: Started Simple Desktop Display Manager.
Dec 27 12:45:29 archtop sddm[945]: Initializing...
Dec 27 12:45:29 archtop sddm[945]: Starting...
Dec 27 12:45:29 archtop sddm[945]: Logind interface found
Dec 27 12:45:29 archtop sddm[945]: Adding new display...
Dec 27 12:45:29 archtop sddm[945]: Loaded empty theme configuration
Dec 27 12:45:29 archtop sddm[945]: Xauthority path: "/run/sddm/xauth_WDruhJ"
Dec 27 12:45:29 archtop sddm[945]: Using VT 2
Dec 27 12:45:29 archtop sddm[945]: Display server starting...
Dec 27 12:45:29 archtop sddm[945]: Writing cookie to "/run/sddm/xauth_WDruhJ"
Dec 27 12:45:29 archtop sddm[945]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_WDruhJ -noreset -displayfd 16
Dec 27 12:46:40 archtop sddm[945]: Failed to read display number from pipe
Dec 27 12:46:40 archtop sddm[945]: Display server stopping...
Dec 27 12:46:40 archtop sddm[945]: Attempt 1 starting the Display server on vt 2 failed
Dec 27 12:46:42 archtop sddm[945]: Display server starting...
Dec 27 12:46:42 archtop sddm[945]: Writing cookie to "/run/sddm/xauth_WDruhJ"
Dec 27 12:46:42 archtop sddm[945]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_WDruhJ -noreset -displayfd 16
Dec 27 12:46:43 archtop sddm[945]: Failed to read display number from pipe
Dec 27 12:46:43 archtop sddm[945]: Display server stopping...
Dec 27 12:46:43 archtop sddm[945]: Attempt 2 starting the Display server on vt 2 failed
Dec 27 12:46:45 archtop sddm[945]: Display server starting...
Dec 27 12:46:45 archtop sddm[945]: Writing cookie to "/run/sddm/xauth_WDruhJ"
Dec 27 12:46:45 archtop sddm[945]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_WDruhJ -noreset -displayfd 16
Dec 27 12:46:46 archtop sddm[945]: Failed to read display number from pipe
Dec 27 12:46:46 archtop sddm[945]: Display server stopping...
Dec 27 12:46:46 archtop sddm[945]: Attempt 3 starting the Display server on vt 2 failed
Dec 27 12:46:46 archtop sddm[945]: Could not start Display server on vt 2
inxi -zv8 (Had to make this another response due to character count)
  Kernel: 6.13.0-rc2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    avail: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.13-x86_64
    root=UUID=4a7af4d7-44c1-4ce6-bd53-34f832a3d94b rw rootflags=subvol=@ quiet
    acpi_backlight=native
    cryptdevice=UUID=8d119e22-5b55-46b4-a00f-19668e5e896a:luks-8d119e22-5b55-46b4-a00f-19668e5e896a
    root=/dev/mapper/luks-8d119e22-5b55-46b4-a00f-19668e5e896a splash
    resume=/dev/mapper/luks-5eb3a645-1889-4293-b4a2-14c47c7b3640 udev.log_priority=3
  Console: tty 2 DM: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G16 GU603VV v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: GU603VV v: 1.0 serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends LLC. v: GU603VV.314 date: 09/07/2023
  ID-1: BAT0 charge: 74.6 Wh (96.0%) condition: 77.7/90.0 Wh (86.4%) power: 20.2 W volts: 16.5
    min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown serial: <filter> status: discharging
  System RAM: total: 32 GiB available: 30.96 GiB used: 983.8 MiB (3.1%)
  Array-1: capacity: 64 GiB slots: 2 modules: 2 EC: None max-module-size: 32 GiB note: est.
  Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 16 GiB speed: 3200 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: ATF2G64AZ-3G2F1 serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Crucial Technology part-no: CT16G4SFRA32A.C8FE serial: <filter>
  Info: model: 13th Gen Intel Core i7-13620H bits: 64 type: MST AMCP arch: Raptor Lake
    gen: core 13 level: v3 note: check built: 2022+ process: Intel 7 (10nm) family: 6
    model-id: 0xBA (186) stepping: 2 microcode: 0x4123
  Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2 st: 4 smt: enabled
    cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB L2: 9.5 MiB
    desc: 6x1.2 MiB, 1x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 400 min/max: 400/4700:4900:3600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400
    10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400 bogomips: 93424
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_lbr
    arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts clflush clflushopt clwb cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
    flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid lahf_lm lm mca mce
    md_clear mmx monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
    pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional; RSB filling;
    PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: ASUSTeK driver: i915 v: kernel
    alternate: xe arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports: active: eDP-1
    empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:a7a8 class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK driver: nvidia
    v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-09)
    arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s ports: active: none empty: DP-3,HDMI-A-1,eDP-2
    bus-ID: 01:00.0 chip-ID: 10de:28e0 class-ID: 0300
  Device-3: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 0408:30c3 class-ID: fe01 serial: <filter>
  Display: unspecified server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4 driver: X:
    loaded: modesetting unloaded: nvidia alternate: fbdev,nouveau,nv,vesa dri: iris,nouveau
    gpu: i915 tty: 240x75
  Monitor-1: eDP-1 model: ChiMei InnoLux N160JME_GE1 built: 2022 res: 1920x1200 dpi: 142
    gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059
    white: x: 0.314 y: 0.329 size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
    modes: 1920x1200
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 1
    drv: iris device: 3 drv: swrast gbm: drv: iris surfaceless: drv: nvidia
    inactive: wayland,x11,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.2.8-arch1.1 note: console (EGL sourced)
    renderer: Mesa Intel Graphics (RPL-P), NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2, llvmpipe
    (LLVM 18.1.8 256 bits)
  API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 4060
    Laptop GPU driver: N/A device-ID: 10de:28e0 surfaces: N/A
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0403
  Device-2: NVIDIA AD107 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
  API: ALSA v: k6.13.0-rc2-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-2: PipeWire v: 1.2.7 status: off with: 1: pipewire-pulse status: off 2: wireplumber
    status: off 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:51f1 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3a:00.0
  IF: enp58s0 state: down mac: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033 class-ID: e001
  Device-1: luks-8d119e22-5b55-46b4-a00f-19668e5e896a maj-min: 254:0 type: LUKS dm: dm-0
  Components:
  p-1: nvme0n1p2 maj-min: 259:7 size: 442.58 GiB
  Device-2: luks-5eb3a645-1889-4293-b4a2-14c47c7b3640 maj-min: 254:1 type: LUKS dm: dm-1
  Components:
  p-1: nvme0n1p3 maj-min: 259:8 size: 34.06 GiB
  Local Storage: total: 1.38 TiB used: 41.81 GiB (3.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Micron model: 2400 MTFDKBA512QFM size: 476.94 GiB
    block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: V3MA003 temp: 36.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK SN770 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
    serial: <filter> fw-rev: 731100WD temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 442.58 GiB size: 442.58 GiB (100.00%) used: 41.81 GiB (9.4%) fs: btrfs
    dev: /dev/dm-0 maj-min: 254:0 mapped: luks-8d119e22-5b55-46b4-a00f-19668e5e896a label: N/A
    uuid: 4a7af4d7-44c1-4ce6-bd53-34f832a3d94b
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 728 KiB (0.2%) fs: vfat
    dev: /dev/nvme0n1p1 maj-min: 259:6 label: N/A uuid: 0A55-B944
  ID-3: /home raw-size: 442.58 GiB size: 442.58 GiB (100.00%) used: 41.81 GiB (9.4%) fs: btrfs
  ID-4: /var/cache raw-size: 442.58 GiB size: 442.58 GiB (100.00%) used: 41.81 GiB (9.4%)
    fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-8d119e22-5b55-46b4-a00f-19668e5e896a
    label: N/A uuid: 4a7af4d7-44c1-4ce6-bd53-34f832a3d94b
  ID-5: /var/log raw-size: 442.58 GiB size: 442.58 GiB (100.00%) used: 41.81 GiB (9.4%)
  ID-1: swap-1 type: partition size: 34.06 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
    maj-min: 254:1 mapped: luks-5eb3a645-1889-4293-b4a2-14c47c7b3640 label: swap
    uuid: bc574cdb-1ab2-4f96-9059-f024391cc265
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A uuid: 0266-1E44
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 930.43 GiB fs: bitlocker label: N/A uuid: N/A
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 994 MiB fs: ntfs label: N/A uuid: 787258197257DB08
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s (2.33 GiB/s) lanes: 2
    mode: 3.2 gen-2x2 chip-ID: 1d6b:0003 class-ID: 0900
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Device-1: 3-3:2 info: ASUSTek N-KEY Device type: keyboard driver: asus,usbhid interfaces: 1
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:19b6
    class-ID: 0301
  Device-2: 3-7:3 info: Quanta USB2.0 HD UVC WebCam type: video driver: uvcvideo interfaces: 5
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:30c3
  Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA chip-ID: 8087:0033
    class-ID: e001
  Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 chip-ID: 1d6b:0003 class-ID: 0900
  System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 40 C
  Fan Speeds (rpm): cpu: 2200
  Packages: pm: pacman pkgs: 1707 libs: 502 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    3: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    4: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    5: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    6: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    7: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    8: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 318
  1: cpu: 0.4% command: init pid: 1 mem: 13.1 MiB (0.0%)
  2: cpu: 0.2% command: systemd-logind pid: 775 mem: 7.46 MiB (0.0%)
  3: cpu: 0.1% command: [kworker/0:1-events] pid: 10 mem: 0.00 MiB (0.0%)
  4: cpu: 0.1% command: [irq/9-acpi] pid: 128 mem: 0.00 MiB (0.0%)
  5: cpu: 0.1% command: NetworkManager pid: 769 mem: 22.5 MiB (0.0%)
  Memory top: 5 of 318
  1: mem: 23.7 MiB (0.0%) command: sddm pid: 945 cpu: 0.0%
  2: mem: 22.5 MiB (0.0%) command: NetworkManager pid: 769 cpu: 0.1%
  3: mem: 15.7 MiB (0.0%) command: systemd-journald pid: 491 cpu: 0.0%
  4: mem: 13.1 MiB (0.0%) command: init pid: 1 cpu: 0.4%
  5: mem: 11.3 MiB (0.0%) command: ModemManager pid: 849 cpu: 0.0%
  Processes: 318 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle avail: deep wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.35 GiB Init: systemd
    v: 256 default: graphical tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Bash (login) v: 5.2.37 running-in: tty 2 inxi: 3.3.36
Thanks! I’m afraid I’m out of ideas here at the moment. I guess you’ve tried different Nvidia drivers though?
I hope someone with Nvidia experience sees this thread. :wink:
I may give that a shot. Thank you for your assistance! Hopefully, someone has a fix for this. It’s just not doable to have dedicated mode on. Gets too hot and battery life is awful. At least with working Hybrid, I can get 5 to 6 hours of use. With dedicated, it’s more like 1 to 2 hours if I am lucky.
I’d like to report that the Nouveau drivers have no issues. I am able to use dynamic GPU (hybrid) and constantly boot without issues and have no issues with Wayland. It isn’t the ideal solution since I would like to use this computer for gaming.
So does this mean that besides BIOS options to enable or disable the dGPU you are using some sort of switcher utility to select ā€˜dGPU’ or ā€˜hybrid’ modes?
What tool?
Can we also check on mhwd profile(s) used;
mhwd -li -l
No, I myself am only changing between dGPU and Dynamic (hybrid) in the UEFI. Otherwise, I have the ROG Control Center package which in itself doesn’t have a manual way of changing but does have a neat status indicator informing you if you are using hybrid or nvidia. Although, indicator aside, you can physically feel if switching is working. When I have my computer in dGPU mode the computer gets quite hot in silent mode via KDE whereas if I have it in Dynamic mode and at least on the first boot, it’s substantially cooler on silent and would switch to GPU if and when need be.
And here is the output:
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
> 0000:3a:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2023.09.12                true            PCI
> 0000:01:00.0 (0300:10de:28e0) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2023.03.23               false            PCI
          video-nvidia            2024.05.03               false            PCI
> 0000:00:02.0 (0300:8086:a7a8) Display controller Intel Corporation:
Well … you dont appear to have the PRIME (hybrid) profile installed … so I am a bit at a loss as to what you think may have been switching (or how).
Please make sure your dGPU is not disabled, and that no other extra configurations are at play.
Then make sure you are up to date.
sudo pacman -Syu
Then install the correct mhwd profile
sudo mhwd -i pci video-hybrid-intel-nvidia-prime
Afterwards reboot.
Then we may check on the function.
Now not only should this properly boot, but running the following
glxinfo | grep 'renderer string'
prime-run glxinfo | grep 'renderer string'
the first should return the iGPU (intel), and the second the dGPU (nvidia).
I did have video-hybrid-intel-nvidia-prime installed, my original issues are with that installed. I just recently uninstalled that for Nouveau in about the last 30 minutes or so to narrow down the problem.
I should have provided this earlier, but I provided my mhwd -li -l output for both GPU modes.
This is dedicated GPU option in my UEFI
> 0000:00:02.0 (0380:8086:a7a8) Display controller Intel Corporation:
This is with hybrid mode selected in my UEFI
I’d also like to add some more findings. When I run ā€œmhwd-gpu --statusā€ I get:
:: status
warning: could not find '/etc/X11/xorg.conf.d/90-mhwd.conf'!
I also noticed ā€œ/mwhd.d/nvidia.confā€ was missing. From my research, this appears important.
I am going to try reinstalling ā€œvideo-hybrid-intel-nvidia-primeā€ and see if that makes a difference. I will edit this post with my findings.
EDIT:
Reinstalled ā€œvideo-hybrid-intel-nvidia-primeā€ and modeset with no luck. Same issues as beginning of this response and same issues as beginning of this thread.
