I have dual boot Ubuntu and Manjaro and very new to Manjaro.
I have a black screen issue after yay -Syyu. Actually it’s booting but only the cursor is there.
I tried
creating a new usb stick to boot but manjaro-chroot operation is returning
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
==>Mounting (Ubuntu) [/dev/nvme0n1p90]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
mount /mnt/etc/resolv.conf: mount point is a symbolic link to nowhere
I really don’t know what do I have to share with you. Could you help me about this issue
I tried it but it didn’t work. BTW If it help I’m sharing xinit and mhwd outputs below.
I tried to fix xf86EnableIOPorts issue but I couldn’t achieved yet.
[ 11.464]
X.Org X Server 1.20.10
[ 11.464] Build Operating System: Linux Manjaro Linux
[ 11.464] Current Operating System: Linux berat 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64
[ 11.464] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=5eb4f497-bc6a-45b3-98c4-1659169f580f ro quiet apparmor=1 security=apparmor udev.log_priority=3
[ 11.465] Build Date: 16 December 2020 10:33:32PM
[ 11.465]
[ 11.465] Current version of pixman: 0.40.0
[ 11.465] Before reporting problems, check http://wiki.x.org
[ 11.465] Markers: (--) probed, (**) from config file, (==) default setting,
[ 11.465] (==) Log file: "/home/berat/.local/share/xorg/Xorg.0.log", Time: Sat Apr 3 01:23:08 2021
[ 11.467] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 11.467] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 11.468] (==) No Layout section. Using the first Screen section.
[ 11.468] (==) No screen section available. Using defaults.
[ 11.468] (**) |-->Screen "Default Screen Section" (0)
[ 11.468] (**) | |-->Monitor "<default monitor>"
[ 11.468] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 11.468] (**) | |-->Device "Device0"
[ 11.468] (==) No monitor specified for screen "Default Screen Section".
[ 11.468] (==) Automatically adding devices
[ 11.468] (==) Automatically enabling devices
[ 11.468] (==) Automatically adding GPU devices
[ 11.468] (==) Automatically binding GPU devices
[ 11.468] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 11.469] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 11.469] Entry deleted from font path.
[ 11.469] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 11.469] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 11.469] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 11.469] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 11.469] (**) Extension "Composite" is enabled
[ 11.469] (**) Extension "RENDER" is enabled
[ 11.469] (II) The server relies on udev to provide the list of input devices.
[ 11.469] (II) Module ABI versions:
[ 11.469] X.Org ANSI C Emulation: 0.4
[ 11.469] X.Org Video Driver: 24.1
[ 11.469] X.Org XInput driver : 24.1
[ 11.469] X.Org Server Extension : 10.0
[ 11.470] (++) using VT number 1
[ 11.472] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 11.472] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 11.473] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[ 11.475] (--) PCI:*(0@0:2:0) 8086:9b41:1028:0962 rev 2, Mem @ 0x604a000000/16777216, 0x4000000000/268435456, I/O @ 0x00003000/64, BIOS @ 0x????????/131072
[ 11.475] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 11.475] (II) LoadModule: "glx"
[ 11.476] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.481] (II) Module glx: vendor="X.Org Foundation"
[ 11.481] compiled for 1.20.10, module version = 1.0.0
[ 11.481] ABI class: X.Org Server Extension, version 10.0
[ 11.481] (II) LoadModule: "vesa"
[ 11.482] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 11.482] (II) Module vesa: vendor="X.Org Foundation"
[ 11.482] compiled for 1.20.9, module version = 2.5.0
[ 11.482] Module class: X.Org Video Driver
[ 11.482] ABI class: X.Org Video Driver, version 24.1
[ 11.482] (II) VESA: driver for VESA chipsets: vesa
[ 11.482] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[ 11.482] vesa: Refusing to run on UEFI
[ 11.482] (EE) No devices detected.
[ 11.482] (EE)
Fatal server error:
[ 11.482] (EE) no screens found(EE)
[ 11.482] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 11.482] (EE) Please also check the log file at "/home/berat/.local/share/xorg/Xorg.0.log" for additional information.
[ 11.482] (EE)
[ 11.525] (EE) Server terminated with error (1). Closing log file.```
So sorry about this, I’m really newbie. I noted this, thank you! I’ll let you know after Im gonna try this tomorrow, I’ve been trying more than 7 hours, I need some rest.
