After updating my Manjaro system to the latest version, Iam encountering [a black screen] during boot. The system seems to start, but the display remains blank, and I cannot access the desktop environment.
Here is what I have tried so far:
Booting into an older kernel version.
Accessing a TTY session using Ctrl + Alt + F2, but no response.
Using a live USB to chroot into the system and update all packages.
Iam running Manjaro GNOME with an Intel integrated GPU. Could this be a graphics driver issue, or is there something else I need to check?
Any suggestions or troubleshooting tips would be greatly appreciated.
Most likely you have not switched in time to a still supported kernel. linux610 and linux611 are EOL/dead. Updating the systen with a dead kernel leads to situations as described by you. You can avoid this by following the Announcements for your branch.
Manjaro-chroot into your system from a live ISO and install a kernel still being supported (e.g. 6.12 or 6.6), e.g. with following command for 6.12:
mhwd-kernel -i linux612
Sometimes the command mhwd-kernel does not work within chroot environment, in this case use:
pacman -S linux612
After installing the new kernel, reboot (using the grub boot menu entry for the newly installed kernel) and remove the old unsupported kernel(s).
