Help, when i logged in to my manjaro user it showed only a black screen with the default cursor, even if i changed the cursor, no shortcut works, i have a lenovo legion 5 with ryzen 7, nvidia geforce rtx and amd radeon graphics.
Can you post some more system information ?
inxi -Fza
what informations?
On console
inxi -Fza
and post the output here.
no console appears
Ctrl+Alt+F2, login and show inxi -Fza output. You can also show us journalctl -b -p 0..3
it asks me the password and when i introduce my login password it says that is incorrect
You need to use the root password and not the one for “normal” login.
AAAH ok
but i forgot it
now i remember it
too much informations, what information do i give?
Give all informations
it worked to login as root, but my user doesen’t work, and creating a new user doesen’t work too
Why to the hell you do it, you don’t need create new user or something, you need only provide output of inxi -Fza and journalctl -b -p 0..3 commands.
i cant write that much
Or make a screen shot.
ok i will make screenshot
Can you update the system via console (TTY2 - CTRL+ALT+F2) ?
pacman -Syyu
and
mhwd -l (post the ouput here)
