I’ve a problem for a while, the login didn’t seem to work using the standard greeter.
The system boots up and the greeter shows login and the system seems to accept the username/password but the screen goes black.
Shifting TTY and login and starting X by commands have been working all the time.
First I thought it was the LightLocker not working since it generated a lot of errors during boot up and people seemed to have the same kind of errors but I uninstalled it and the problems persisted.
Until a couples of days ago I found that if I let the black screen be for about 10 min I get logged in as it should.
Log for a ‘ordinary’ boot up is here: https://pastebin.com/9n9Qy8Ef
I would say at row 1551 is the last before it pause and then after about 10 min something happens:
Aug 23 08:53:29 kernel: audit: type=1131 audit(1598165609.520:103): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 23 09:01:01 CROND[1270]: (root) CMD (run-parts /etc/cron.hourly)
Aug 23 09:01:01 anacron[1275]: Anacron started on 2020-08-23
Aug 23 09:01:01 anacron[1275]: Will run job `cron.daily' in 45 min.
Aug 23 09:01:01 anacron[1275]: Jobs will be executed sequentially
Aug 23 09:46:01 anacron[1275]: Job `cron.daily' started
Aug 23 09:46:01 anacron[1275]: Job `cron.daily' terminated
Aug 23 09:46:01 anacron[1275]: Normal exit (1 job run)
I’ve tried reinstalling and swapping greeter
Reinstalling and swapping graphic drivers
Changing between several kernels
I am currently running
Linux kappa 5.7.15-1-MANJARO #1 SMP PREEMPT Tue Aug 11 15:00:37 UTC 2020 x86_64 GNU/Linux
and
xfce4-about 4.14.1 (Xfce 4.14)
I feel it might be a XFCE error but I might be wrong
Any clues?
What about the folders /etc/X11/mhwd.d/ and /etc/X11/xorg.conf.d/ ?
Is there a symlink from /etc/X11/mhwd.d/nvidia.conf to /etc/X11/xorg.conf.d/90-mhwd.conf ?
Do not think I’ve done it myself but maybe something has altered it while installing a new driver and using nvidia own config generator.
I see that mhwd says I have version 430 but nvidia says I have 440.
I will try to get them to be the same.
I discovered now, which is a bit embarrassing, that the default run level is TTY7.
So once I enter the correct password and login, the screen goes black but shifting to another TTY-level and back it works.
Its just a matter of removing the ‘black screen’ now.
If I just login, the screen goes black for more then 10 minutes then it works BUT if I shift TTY from 7 to something else then back it works.
Sorry, the title might be a bit misleading.
