[update] I tried to use proprietary drivers again and fix the issue without success, here is some additional information :
@autotech thanks but do you think this will work for Xorg users ? or is it only for Wayland ?
@Tommey223 I think it lags because it doesn’t use the dedicated GPU but the integrated one, what is the output of mhwd -li ? I think the free drivers are installed and used
@wolfman mee too, help is welcome
I’m Python dev and have basic knowledge in Linux / Sys Admin
journalctl --boot=-1 --priority=4 -n 100 --no-pager
juin 10 19:02:10 flo-asus kwin_x11[1069]: kwin_core: XCB error: 152 (BadDamage), sequence: 28466, resource id: 21790126, major code: 143 (DAMAGE), minor code: 3 (Subtract)
juin 10 19:02:54 flo-asus kwin_x11[1069]: kwin_core: XCB error: 152 (BadDamage), sequence: 63512, resource id: 21790382, major code: 143 (DAMAGE), minor code: 3 (Subtract)
juin 10 19:06:44 flo-asus sddm[855]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
juin 10 19:06:44 flo-asus sddm[855]: Auth: sddm-helper (--socket /tmp/sddm-auth-522864ce-b321-4e9a-8aa8-8697db982ea4 --id 1 --start /usr/bin/startplasma-x11 --user flo) crashed (exit code 1)
juin 10 19:06:44 flo-asus sddm[855]: Auth: sddm-helper exited with 1
juin 10 19:06:44 flo-asus pulseaudio[1351]: X11 I/O error handler called
juin 10 19:06:44 flo-asus pulseaudio[1351]: X11 I/O error exit handler called, preparing to tear down X11 modules
juin 10 19:06:44 flo-asus sddm[855]: Signal received: SIGTERM
juin 10 19:06:44 flo-asus (modprobe)[197027]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
juin 10 19:06:44 flo-asus baloorunner[2230]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus plasmashell[1117]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus kglobalacceld[1022]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus ksmserver[1066]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus kglobalacceld[1022]: The X11 connection broke: I/O error (code 1)
juin 10 19:06:44 flo-asus kwin_x11[1069]: The X11 connection broke: I/O error (code 1)
juin 10 19:06:44 flo-asus kded6[1068]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus kded6[1068]: kf.notifications: Playing audio notification failed: Destroyed
juin 10 19:06:44 flo-asus pulseaudio[1351]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.NoReply:Remote peer disconnected
juin 10 19:06:44 flo-asus gmenudbusmenuproxy[1170]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus DesktopVideoUpdater[1292]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus kdeconnectd[1304]: 2024-06-10T19:06:44 default: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus kaccess[1326]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus xdg-desktop-portal-kde[1173]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus polkit-kde-authentication-agent-1[1171]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus xembedsniproxy[1174]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus chromium[88622]: The X11 connection broke: I/O error (code 1)
juin 10 19:06:44 flo-asus systemd[972]: plasma-ksmserver.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus systemd[972]: dbus-:1.47-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus konsole[84670]: The X11 connection broke: I/O error (code 1)
juin 10 19:06:44 flo-asus dolphin[2939]: The X11 connection broke: I/O error (code 1)
juin 10 19:06:44 flo-asus systemd[972]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus kscreen_backend_launcher[1209]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus kactivitymanagerd[1169]: The X11 connection broke (error 1). Did the X11 server die?
juin 10 19:06:44 flo-asus keepassxc[2922]: The X11 connection broke: I/O error (code 1)
juin 10 19:06:44 flo-asus systemd[972]: app-DesktopVideoUpdaterAutoStart@autostart.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus systemd[972]: app-org.moson.matray@autostart.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus systemd[972]: plasma-gmenudbusmenuproxy.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus systemd[972]: app-redshift\x2dgtk@autostart.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus systemd[972]: plasma-kded6.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus systemd[972]: app-mullvad\x2dvpn@autostart.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus systemd[972]: plasma-kwin_x11.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus systemd[972]: plasma-plasmashell.service: Failed with result 'exit-code'.
juin 10 19:06:44 flo-asus dbus-broker-launch[710]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
juin 10 19:06:45 flo-asus pulseaudio[1351]: Error opening PCM device front:0: No such file or directory
juin 10 19:06:45 flo-asus dbus-broker-launch[710]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
juin 10 19:07:38 flo-asus systemd-logind[720]: Failed to start autovt@tty2.service: Transaction for getty@tty2.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
juin 10 19:07:47 flo-asus systemd-logind[720]: Failed to start autovt@tty2.service: Transaction for getty@tty2.service/start is destructive (systemd-reboot.service has 'start' job queued, but 'stop' is included in transaction).
juin 10 19:07:47 flo-asus systemd-logind[720]: Failed to start autovt@tty2.service: Transaction for getty@tty2.service/start is destructive (reboot.target has 'start' job queued, but 'stop' is included in transaction).
juin 10 19:07:48 flo-asus systemd-logind[720]: Failed to start autovt@tty2.service: Transaction for getty@tty2.service/start is destructive (systemd-reboot.service has 'start' job queued, but 'stop' is included in transaction).
juin 10 19:07:48 flo-asus systemd-logind[720]: Failed to start autovt@tty4.service: Transaction for getty@tty4.service/start is destructive (reboot.target has 'start' job queued, but 'stop' is included in transaction).
juin 10 19:07:50 flo-asus systemd-logind[720]: Failed to start autovt@tty2.service: Transaction for getty@tty2.service/start is destructive (sysinit.target has 'stop' job queued, but 'start' is included in transaction).
juin 10 19:07:50 flo-asus systemd-logind[720]: Failed to start autovt@tty2.service: Transaction for getty@tty2.service/start is destructive (systemd-reboot.service has 'start' job queued, but 'stop' is included in transaction).
juin 10 19:07:51 flo-asus systemd-logind[720]: Failed to start autovt@tty4.service: Transaction for getty@tty4.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
juin 10 19:07:51 flo-asus systemd-logind[720]: Failed to start autovt@tty4.service: Transaction for getty@tty4.service/start is destructive (systemd-reboot.service has 'start' job queued, but 'stop' is included in transaction).
juin 10 19:07:52 flo-asus systemd-logind[720]: Failed to start autovt@tty4.service: Transaction for getty@tty4.service/start is destructive (sysinit.target has 'stop' job queued, but 'start' is included in transaction).
juin 10 19:07:52 flo-asus systemd-logind[720]: Failed to start autovt@tty2.service: Transaction for getty@tty2.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Xorg log (after startx fail in tty2) :
[ 1193.404]
X.Org X Server 1.21.1.13
[ 1193.404] Current Operating System: Linux flo-asus 6.1.92-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon May 27 03:37:00 UTC 2024 x86_64
[ 1193.404] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=78a3e24b-f79f-4a66-a34d-0a32a85d813a rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 1193.404]
[ 1193.404] Current version of pixman: 0.43.4
[ 1193.404] Before reporting problems, check http://wiki.x.org
[ 1193.404] Markers: (--) probed, (**) from config file, (==) default setting,
[ 1193.404] (==) Log file: "/home/flo/.local/share/xorg/Xorg.0.log", Time: Mon Jun 10 19:28:07 2024
[ 1193.404] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 1193.405] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 1193.405] (==) ServerLayout "layout"
[ 1193.405] (==) No screen section available. Using defaults.
[ 1193.405] (**) |-->Screen "Default Screen Section" (0)
[ 1193.405] (**) | |-->Monitor "<default monitor>"
[ 1193.405] (==) No monitor specified for screen "Default Screen Section".
[ 1193.405] (**) Allowing byte-swapped clients
[ 1193.405] (==) Automatically adding devices
[ 1193.405] (==) Automatically enabling devices
[ 1193.405] (==) Automatically adding GPU devices
[ 1193.405] (==) Automatically binding GPU devices
[ 1193.405] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 1193.405] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 1193.405] Entry deleted from font path.
[ 1193.405] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 1193.405] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 1193.405] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 1193.405] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 1193.405] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 1193.405] (II) The server relies on udev to provide the list of input devices.
[ 1193.405] (II) Module ABI versions:
[ 1193.405] X.Org ANSI C Emulation: 0.4
[ 1193.405] X.Org Video Driver: 25.2
[ 1193.405] X.Org XInput driver : 24.4
[ 1193.405] X.Org Server Extension : 10.0
[ 1193.405] (++) using VT number 2
[ 1193.406] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 1193.407] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 1193.407] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[ 1193.407] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[ 1193.407] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 1193.407] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 1193.408] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
[ 1193.409] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 1193.409] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 1194.925] (--) PCI:*(0@0:2:0) 8086:9bc4:1043:177f rev 5, Mem @ 0xc3000000/16777216, 0xa0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 1194.925] (--) PCI: (1@0:0:0) 10de:1f99:1043:177f rev 161, Mem @ 0xc4000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 1194.925] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 1194.925] (II) LoadModule: "glx"
[ 1194.925] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 1194.926] (II) Module glx: vendor="X.Org Foundation"
[ 1194.926] compiled for 1.21.1.13, module version = 1.0.0
[ 1194.926] ABI class: X.Org Server Extension, version 10.0
[ 1194.926] (II) Applying OutputClass "intel" to /dev/dri/card0
[ 1194.926] loading driver: modesetting
[ 1194.926] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[ 1194.926] loading driver: nvidia
[ 1195.376] (==) Matched modesetting as autoconfigured driver 0
[ 1195.376] (==) Matched nvidia as autoconfigured driver 1
[ 1195.376] (==) Matched nouveau as autoconfigured driver 2
[ 1195.376] (==) Matched nv as autoconfigured driver 3
[ 1195.376] (==) Matched fbdev as autoconfigured driver 4
[ 1195.376] (==) Matched vesa as autoconfigured driver 5
[ 1195.376] (==) Assigned the driver to the xf86ConfigLayout
[ 1195.376] (II) LoadModule: "modesetting"
[ 1195.376] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 1195.377] (II) Module modesetting: vendor="X.Org Foundation"
[ 1195.377] compiled for 1.21.1.13, module version = 1.21.1
[ 1195.377] Module class: X.Org Video Driver
[ 1195.377] ABI class: X.Org Video Driver, version 25.2
[ 1195.377] (II) LoadModule: "nvidia"
[ 1195.377] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 1195.377] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 1195.377] compiled for 1.6.99.901, module version = 1.0.0
[ 1195.377] (II) LoadModule: "nouveau"
[ 1195.377] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 1195.377] (II) Module nouveau: vendor="X.Org Foundation"
[ 1195.377] compiled for 1.21.1.11, module version = 1.0.17
[ 1195.377] (II) LoadModule: "nv"
[ 1195.377] (WW) Warning, couldn't open module nv
[ 1195.377] (EE) Failed to load module "nv" (module does not exist, 0)
[ 1195.377] (II) LoadModule: "fbdev"
[ 1195.377] (WW) Warning, couldn't open module fbdev
[ 1195.377] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 1195.377] (II) LoadModule: "vesa"
[ 1195.378] (WW) Warning, couldn't open module vesa
[ 1195.378] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 1195.378] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 1195.378] (II) NVIDIA dlloader X Driver 550.90.07 Fri May 31 09:34:34 UTC 2024
[ 1195.378] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 1195.378] (II) NOUVEAU driver
[ 1195.378] (II) NOUVEAU driver for NVIDIA chipset families :
[ 1195.378] RIVA TNT (NV04)
[ 1195.378] RIVA TNT2 (NV05)
[ 1195.378] GeForce 256 (NV10)
[ 1195.378] GeForce 2 (NV11, NV15)
[ 1195.378] GeForce 4MX (NV17, NV18)
[ 1195.378] GeForce 3 (NV20)
[ 1195.378] GeForce 4Ti (NV25, NV28)
[ 1195.378] GeForce FX (NV3x)
[ 1195.378] GeForce 6 (NV4x)
[ 1195.378] GeForce 7 (G7x)
[ 1195.378] GeForce 8 (G8x)
[ 1195.378] GeForce 9 (G9x)
[ 1195.378] GeForce GTX 2xx/3xx (GT2xx)
[ 1195.378] GeForce GTX 4xx/5xx (GFxxx)
[ 1195.378] GeForce GTX 6xx/7xx (GKxxx)
[ 1195.378] GeForce GTX 9xx (GMxxx)
[ 1195.378] GeForce GTX 10xx (GPxxx)
[ 1195.378] (II) modeset(0): using drv /dev/dri/card0
[ 1195.378] (II) modeset(G0): using drv /dev/dri/card1
[ 1195.378] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 1195.378] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 1195.378] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 1195.378] (==) modeset(0): RGB weight 888
[ 1195.378] (==) modeset(0): Default visual is TrueColor
[ 1195.378] (II) Loading sub module "glamoregl"
[ 1195.378] (II) LoadModule: "glamoregl"
[ 1195.378] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 1195.380] (II) Module glamoregl: vendor="X.Org Foundation"
[ 1195.380] compiled for 1.21.1.13, module version = 1.0.1
[ 1195.380] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1195.404] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics (CML GT2)
[ 1195.404] (II) modeset(0): glamor initialized
[ 1195.404] (==) modeset(0): VariableRefresh: disabled
[ 1195.404] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 1195.406] (II) modeset(0): Output eDP-1 has no monitor section
[ 1195.408] (II) modeset(0): EDID for output eDP-1
[ 1195.408] (II) modeset(0): Manufacturer: NCP Model: 4d Serial#: 0
[ 1195.408] (II) modeset(0): Year: 2019 Week: 51
[ 1195.408] (II) modeset(0): EDID Version: 1.4
[ 1195.408] (II) modeset(0): Digital Display Input
[ 1195.408] (II) modeset(0): 8 bits per channel
[ 1195.408] (II) modeset(0): Digital interface is DisplayPort
[ 1195.408] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 1195.408] (II) modeset(0): Gamma: 2.20
[ 1195.408] (II) modeset(0): No DPMS capabilities specified
[ 1195.408] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 1195.408] (II) modeset(0): First detailed timing is preferred mode
[ 1195.408] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 1195.408] (II) modeset(0): Display is continuous-frequency
[ 1195.408] (II) modeset(0): redX: 0.595 redY: 0.361 greenX: 0.346 greenY: 0.555
[ 1195.408] (II) modeset(0): blueX: 0.157 blueY: 0.106 whiteX: 0.312 whiteY: 0.328
[ 1195.408] (II) modeset(0): Manufacturer's mask: 0
[ 1195.408] (II) modeset(0): Supported detailed timing:
[ 1195.408] (II) modeset(0): clock: 354.7 MHz Image Size: 344 x 194 mm
[ 1195.408] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2180 h_border: 0
[ 1195.408] (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1130 v_border: 0
[ 1195.408] (II) modeset(0): clock: 147.8 MHz Image Size: 344 x 194 mm
[ 1195.408] (II) modeset(0): Ranges: V min: 48 V max: 144 Hz, H min: 154 H max: 154 kHz, PixClock max 355 MHz
[ 1195.408] (II) modeset(0): LM156LF-2F01
[ 1195.408] (II) modeset(0): EDID (in hex):
[ 1195.408] (II) modeset(0): 00ffffffffffff0038704d0000000000
[ 1195.408] (II) modeset(0): 331d0104a5221378036850985c588e28
[ 1195.408] (II) modeset(0): 1b505400000001010101010101010101
[ 1195.408] (II) modeset(0): 010101010101918a8004713832403020
[ 1195.408] (II) modeset(0): 350058c21000001abd39800471383240
[ 1195.408] (II) modeset(0): 3020350058c21000001a000000fd0030
[ 1195.408] (II) modeset(0): 909a9a23010a202020202020000000fe
[ 1195.408] (II) modeset(0): 004c4d3135364c462d324630310a0049
[ 1195.408] (II) modeset(0): Printing probed modes for output eDP-1
[ 1195.408] (II) modeset(0): Modeline "1920x1080"x144.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
[ 1195.408] (II) modeset(0): Modeline "1920x1080"x60.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1920x1080"x60.0 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1920x1080"x60.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
[ 1195.408] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1600x900"x60.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x1024"x85.0 157.50 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x960"x85.0 148.50 1280 1344 1504 1728 960 961 964 1011 +hsync +vsync (85.9 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x768"x85.0 194.02 1024 1108 1220 1416 768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x768i"x87.0 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "960x720"x85.0 170.68 960 1036 1144 1328 720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 1195.408] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 1195.408] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 1195.408] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 1195.408] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
[ 1195.408] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 1195.408] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 1195.408] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x600"x85.0 114.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 1195.408] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 1195.408] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 1195.408] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 1195.408] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 1195.408] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 1195.408] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 1195.408] (II) modeset(0): Modeline "640x512"x85.0 78.75 640 672 752 864 512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
[ 1195.408] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 1195.408] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 1195.409] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 1195.409] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x480"x85.1 74.25 640 672 752 864 480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 1195.409] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 1195.409] (II) modeset(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 1195.409] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 1195.409] (II) modeset(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "512x384"x85.0 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
[ 1195.409] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 1195.409] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 1195.409] (II) modeset(0): Modeline "512x384i"x87.1 22.45 512 516 604 632 384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 1195.409] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 1195.409] (II) modeset(0): Modeline "400x300"x85.3 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
[ 1195.409] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 1195.409] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 1195.409] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 1195.409] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 1195.409] (II) modeset(0): Modeline "320x240"x85.2 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
[ 1195.409] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 1195.409] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 1195.409] (II) modeset(0): Modeline "360x200"x85.0 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "320x200"x85.3 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
[ 1195.409] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 1195.409] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 1195.409] (II) modeset(0): Modeline "320x175"x85.3 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
[ 1195.409] (II) modeset(0): Output eDP-1 connected
[ 1195.409] (II) modeset(0): Using exact sizes for initial modes
[ 1195.409] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 1195.409] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 1195.409] (==) modeset(0): DPI set to (96, 96)
[ 1195.409] (II) Loading sub module "fb"
[ 1195.409] (II) LoadModule: "fb"
[ 1195.409] (II) Module "fb" already built-in
[ 1195.409] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 1195.409] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 1195.409] (==) modeset(G0): RGB weight 888
[ 1195.409] (==) modeset(G0): Default visual is TrueColor
[ 1195.409] (II) Loading sub module "glamoregl"
[ 1195.409] (II) LoadModule: "glamoregl"
[ 1195.410] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 1195.410] (II) Module glamoregl: vendor="X.Org Foundation"
[ 1195.410] compiled for 1.21.1.13, module version = 1.0.1
[ 1195.410] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1195.431] (II) modeset(G0): glamor X acceleration enabled on NVIDIA GeForce GTX 1650/PCIe/SSE2
[ 1195.431] (II) modeset(G0): glamor initialized
[ 1195.435] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 1195.435] (II) modeset(G0): Output DP-1-1 has no monitor section
[ 1195.435] (II) modeset(G0): EDID for output HDMI-1-1
[ 1195.435] (II) modeset(G0): EDID for output DP-1-1
[ 1195.436] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 1195.436] (==) modeset(G0): DPI set to (96, 96)
[ 1195.436] (II) Loading sub module "fb"
[ 1195.436] (II) LoadModule: "fb"
[ 1195.436] (II) Module "fb" already built-in
[ 1195.436] (II) UnloadModule: "nvidia"
[ 1195.436] (II) Unloading nvidia
[ 1195.436] (II) UnloadModule: "nouveau"
[ 1195.436] (II) Unloading nouveau
[ 1195.459] (==) modeset(0): Backing store enabled
[ 1195.459] (==) modeset(0): Silken mouse enabled
[ 1195.500] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 1195.500] (==) modeset(0): DPMS enabled
[ 1195.500] (II) modeset(0): [DRI2] Setup complete
[ 1195.500] (II) modeset(0): [DRI2] DRI driver: iris
[ 1195.500] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 1195.503] (==) modeset(G0): Backing store enabled
[ 1195.503] (==) modeset(G0): Silken mouse enabled
[ 1195.503] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 1195.503] (==) modeset(G0): DPMS enabled
[ 1195.503] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[ 1195.504] (II) modeset(G0): [DRI2] Setup complete
[ 1195.504] (II) modeset(G0): [DRI2] DRI driver: nouveau
[ 1195.504] (II) modeset(G0): [DRI2] VDPAU driver: nouveau
[ 1195.504] (II) Initializing extension Generic Event Extension
[ 1195.504] (II) Initializing extension SHAPE
[ 1195.504] (II) Initializing extension MIT-SHM
[ 1195.504] (II) Initializing extension XInputExtension
[ 1195.504] (II) Initializing extension XTEST
[ 1195.504] (II) Initializing extension BIG-REQUESTS
[ 1195.504] (II) Initializing extension SYNC
[ 1195.504] (II) Initializing extension XKEYBOARD
[ 1195.504] (II) Initializing extension XC-MISC
[ 1195.504] (II) Initializing extension SECURITY
[ 1195.504] (II) Initializing extension XFIXES
[ 1195.504] (II) Initializing extension RENDER
[ 1195.505] (II) Initializing extension RANDR
[ 1195.505] (II) Initializing extension COMPOSITE
[ 1195.505] (II) Initializing extension DAMAGE
[ 1195.505] (II) Initializing extension MIT-SCREEN-SAVER
[ 1195.505] (II) Initializing extension DOUBLE-BUFFER
[ 1195.505] (II) Initializing extension RECORD
[ 1195.505] (II) Initializing extension DPMS
[ 1195.505] (II) Initializing extension Present
[ 1195.505] (II) Initializing extension DRI3
[ 1195.505] (II) Initializing extension X-Resource
[ 1195.505] (II) Initializing extension XVideo
[ 1195.506] (II) Initializing extension XVideo-MotionCompensation
[ 1195.506] (II) Initializing extension GLX
[ 1195.511] (II) AIGLX: Loaded and initialized iris
[ 1195.511] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 1195.511] (II) Initializing extension XFree86-VidModeExtension
[ 1195.511] (II) Initializing extension XFree86-DGA
[ 1195.511] (II) Initializing extension XFree86-DRI
[ 1195.511] (II) Initializing extension DRI2
[ 1195.512] (EE) modeset(G0): Failed to create pixmap
[ 1195.512] (EE)
Fatal server error:
[ 1195.512] (EE) failed to create screen resources(EE)
[ 1195.512] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 1195.512] (EE) Please also check the log file at "/home/flo/.local/share/xorg/Xorg.0.log" for additional information.
[ 1195.512] (EE)
[ 1195.512] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 1195.516] (EE) Server terminated with error (1). Closing log file.
