After swapping my GPU from a GTX 1060 to an RTX 3060 and unplugging then re-plugging my 2 ssd’s I am unable to access manjaro. when trying to boot it just takes me to a black screen with a white underscore on top. So I thought it was the gpu so I swapped the GTX 1060 back, but the issue stayed.
The nvme has manjaro on it. While the 2 ssd have windows on it, only one works (crucial works, but the kingston one does not it was a failed attemp at a windows installation I think). I can still boot on windows with the RTX 3060. Also previously I had another RTX 3060, but with 3 fans this is one is 2 fans (for a future small build) and it worked fine.
Right now I booted from a live USB. I tried to reinstall grub with these 2 commands I mounted my nvme, -p /mnt/boot/efi
and my sdc1 or windows ssd.
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck --no-nvram
grub-mkconfig -o /boot/grub/grub.cfg
but it didn’t work. The output
sudo: unable to allocate pty: No space left on device
Installing for x86_64-efi platform.
Installation finished. No error reported.
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda
└─sda1 ntfs 0A1836E558CB39BF
sdb
├─sdb1 exfat 1.0 Ventoy CE72-295B
│ └─ventoy iso9660 Joliet Extension MANJARO_KDE_2421 2024-12-16-11-21-39-00 0 100% /run/miso/bootmnt
└─sdb2 vfat FAT16 VTOYEFI 223C-F3F8
sdc
├─sdc1 vfat FAT32 0002-DBC1 69.3M 28% /mnt/boot/efi
│ /mnt/boot/efi
│ /mnt/boot/efi
│ /mnt/boot/efi
│ /mnt/boot/efi
├─sdc2
├─sdc3 ntfs 820A0B7A0A0B6A8D
└─sdc4 ntfs 7838A51338A4D204
nvme0n1
└─nvme0n1p2 ext4 1.0 8e0e212d-3399-41b6-9b0f-83f4032ed28f 352G 56% /mnt
/mnt
/mnt
/mnt
/mnt
inxi -Fazy
inxi -Fazy ✔
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2421 quiet systemd.show_status=1
splash driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: ASRock model: B550M Steel Legend
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: L3.46 date: 08/20/2024
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1740 min/max: 550/4663 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1740 2: 1740 3: 1740
4: 1740 5: 1740 6: 1740 7: 1740 8: 1740 9: 1740 10: 1740 11: 1740 12: 1740
13: 1740 14: 1740 15: 1740 16: 1740 bogomips: 108643
affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nvidia
v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia gpu: nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: Unknown-1 mapped: DP-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") modes: 1024x768
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 6GB driver: N/A device-ID: 10de:1c03 surfaces: xcb,xlib
Device-1: NVIDIA GP106 High Definition Audio vendor: ZOTAC
bus-ID: 06:00.1 chip-ID: 10de:10f1 class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8125
class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
chip-ID: 8086:2725 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:8 chip-ID: 8087:0032
class-ID: e001
Local Storage: total: 2.31 TiB used: 517.3 GiB (21.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 39.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0102 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: USB 3.2Gen1
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 061 scheme: GPT
Message: No partition data found.
System Temperatures: cpu: 34.2 C mobo: 33.5 C gpu: nvidia temp: 37 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 40%
Memory: total: 20 GiB available: 19.46 GiB used: 6.17 GiB (31.7%)
Processes: 333 Power: uptime: 1h 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 7.74 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1242 libs: 323 tools: pamac pm: flatpak pkgs: 0
Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.36
fdisk -l
Disk /dev/sda: 447.13 GiB, 480103981056 bytes, 937703088 sectors
Disk model: KINGSTON SA400S3
Disklabel type: gpt
Disk identifier: 4987D8A8-A794-1B43-9111-0BD26A15FD7F
Device Start End Sectors Size Type
/dev/sda1 2048 937701375 937699328 447.1G Microsoft basic data
Disk /dev/nvme0n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Samsung SSD 980 1TB
I/O size (minimum/optimal): 16384 bytes / 131072 bytes
Disklabel type: gpt
Disk identifier: 3B14A996-5D4E-4734-81AF-A0F0E1595CDA
/dev/nvme0n1p2 2048 1953523711 1953521664 931.5G Linux filesystem
Disk /dev/sdb: 57.3 GiB, 61524148224 bytes, 120164352 sectors
Disk model: SanDisk 3.2Gen1
Disklabel type: dos
Disk identifier: 0x704e76c9
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 2048 120098815 120096768 57.3G 7 HPFS/NTFS/exFAT
/dev/sdb2 120098816 120164351 65536 32M ef EFI (FAT-12/16/32)
Disk /dev/mapper/ventoy: 4.03 GiB, 4327022592 bytes, 8451216 sectors
Disklabel type: dos
Disk identifier: 0x00000000
/dev/mapper/ventoy-part1 * 64 8443023 8442960 4G 0 Empty
/dev/mapper/ventoy-part2 8443024 8451215 8192 4M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 90.12 MiB, 94494720 bytes, 184560 sectors
Disk /dev/loop1: 1.13 GiB, 1213464576 bytes, 2370048 sectors
Disk /dev/loop2: 1.84 GiB, 1972195328 bytes, 3851944 sectors
Disk /dev/loop3: 858.86 MiB, 900575232 bytes, 1758936 sectors
Disk /dev/sdc: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: CT1000BX500SSD1
Disklabel type: gpt
Disk identifier: 3D8CE3E2-DD50-47C3-A34F-10B85B0421C9
/dev/sdc1 2048 206847 204800 100M EFI System
/dev/sdc2 206848 239615 32768 16M Microsoft reserved
/dev/sdc3 239616 1952002047 1951762432 930.7G Microsoft basic data
/dev/sdc4 1952002048 1953521663 1519616 742M Windows recovery environment
