Thanks.
Kernel: 5.19.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=9a713eb6-3b19-4e57-96d2-46e15d2a47d4 ro quiet apparmor=1
security=apparmor resume=UUID=fc2be996-aac5-49bf-8ff3-07e101a56602
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Convertible System: LENOVO product: 82BH v: Yoga 7 14ITL5
serial: <superuser required> Chassis: type: 31 v: Yoga 7 14ITL5
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: F5CN38WW date: 10/26/2020
ID-1: BAT0 charge: 53.2 Wh (73.4%) condition: 72.5/71.0 Wh (102.0%)
volts: 16.0 min: 15.4 model: LGC L19L4PDC type: Li-poly serial: <filter>
status: discharging cycles: 154
Device-1: wacom_battery_0 model: Wacom HID 5252 serial: N/A charge: 0%
rechargeable: yes status: N/A
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2400 min/max: 400/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 2400 2: 2400 3: 2400 4: 2400 5: 2400 6: 2400
7: 2400 8: 2400 bogomips: 38720
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2,
HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-8:2 chip-ID: 174f:243f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1402 built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.19.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 705.8 GiB (74.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-1T00-1101 size: 953.87 GiB block-size: physical: 512 B
rev: 11170001 temp: 25.9 C scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 62.35 GiB
(65.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 836.18 GiB size: 821.98 GiB (98.30%) used: 643.46
GiB (78.3%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 28.0 C mobo: N/A
Processes: 315 Uptime: 1h 9m wakeups: 233 Memory: 15.43 GiB used: 3.02 GiB
(19.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1740 pm: pacman pkgs: 1733
libs: 465 tools: pamac pm: flatpak pkgs: 0 pm: snap pkgs: 7 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
sept. 21 14:28:49 pc-name kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
sept. 21 14:28:49 pc-name kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
sept. 21 14:28:49 pc-name kernel: pci 0000:00:07.1: DPC: RP PIO log size 0 is invalid
sept. 21 14:28:49 pc-name kernel: pci 0000:00:07.2: DPC: RP PIO log size 0 is invalid
sept. 21 14:28:49 pc-name kernel: pci 0000:00:07.3: DPC: RP PIO log size 0 is invalid
sept. 21 14:28:49 pc-name kernel: pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
sept. 21 14:28:49 pc-name kernel: hpet_acpi_add: no address or irqs in _CRS
sept. 21 14:28:49 pc-name kernel: integrity: Problem loading X.509 certificate -65
sept. 21 14:28:49 pc-name kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
sept. 21 14:28:49 pc-name kernel: vboxdrv: loading out-of-tree module taints kernel.
sept. 21 14:28:49 pc-name kernel: VBoxNetAdp: Successfully started.
sept. 21 14:28:49 pc-name kernel: VBoxNetFlt: Successfully started.
sept. 21 14:28:49 pc-name systemd-udevd[302]: /etc/udev/rules.d/20-hw1.rules:2 Unknown user '<fabien>', ignoring
sept. 21 14:28:49 pc-name systemd-udevd[302]: /etc/udev/rules.d/20-hw1.rules:4 Unknown user '<fabien>', ignoring
sept. 21 14:28:49 pc-name systemd-udevd[302]: /etc/udev/rules.d/20-hw1.rules:6 Unknown user '<fabien>', ignoring
sept. 21 14:28:49 pc-name systemd-udevd[302]: /etc/udev/rules.d/20-hw1.rules:8 Unknown user '<fabien>', ignoring
sept. 21 14:28:49 pc-name systemd-udevd[302]: /etc/udev/rules.d/20-hw1.rules:10 Unknown user '<fabien>', ignoring
sept. 21 14:28:49 pc-name systemd-udevd[302]: /etc/udev/rules.d/20-hw1.rules:12 Unknown user '<fabien>', ignoring
sept. 21 14:28:49 pc-name kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
sept. 21 14:28:49 pc-name kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
sept. 21 14:28:49 pc-name kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
sept. 21 14:28:49 pc-name kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
sept. 21 14:28:49 pc-name kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
sept. 21 14:28:50 pc-name kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-72.ucode failed with error -2
sept. 21 14:28:50 pc-name kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
sept. 21 14:28:50 pc-name kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
sept. 21 14:28:50 pc-name kernel: caller __uncore_imc_init_box+0xc4/0x120 [intel_uncore] mapping multiple BARs
sept. 21 14:28:50 pc-name kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
sept. 21 14:28:50 pc-name kernel: i801_smbus 0000:00:1f.4: Transaction timeout
sept. 21 14:28:50 pc-name kernel: i801_smbus 0000:00:1f.4: Failed terminating the transaction
sept. 21 14:28:50 pc-name kernel: i801_smbus 0000:00:1f.4: SMBus is busy, can't use it!
sept. 21 14:28:51 pc-name kernel: mtd: partition "BIOS" extends beyond the end of device "0000:00:1f.5" -- size truncated to 0x1000000
sept. 21 14:28:51 pc-name tlp[1020]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
sept. 21 14:28:51 pc-name tlp[1020]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
sept. 21 14:28:51 pc-name tlp[1020]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
sept. 21 14:28:51 pc-name tlp[1020]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
sept. 21 14:28:51 pc-name tlp[1059]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
sept. 21 14:28:51 pc-name tlp[1059]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
sept. 21 14:28:51 pc-name systemd[1088]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
sept. 21 14:28:51 pc-name kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: FW ABI is more recent than kernel
sept. 21 14:28:51 pc-name tlp[1059]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
sept. 21 14:28:51 pc-name tlp[1059]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
sept. 21 14:28:51 pc-name kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: warn: topology ABI is more recent than kernel
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
sept. 21 14:28:51 pc-name kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
sept. 21 14:28:51 pc-name kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
sept. 21 14:28:51 pc-name kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
sept. 21 14:28:51 pc-name tlp[1112]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
sept. 21 14:28:51 pc-name tlp[1112]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
sept. 21 14:28:51 pc-name tlp[1112]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
sept. 21 14:28:51 pc-name tlp[1112]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
sept. 21 14:28:52 pc-name sddm-greeter[1165]: QFont::fromString: Invalid description '(empty)'
sept. 21 14:28:52 pc-name sddm-greeter[1165]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffe64ef4f80), parent's thread is QThread(0x56042270e450), current thread is QThread(0x56042282f570)
sept. 21 14:28:52 pc-name sddm-greeter[1165]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
sept. 21 14:28:52 pc-name kernel: kauditd_printk_skb: 266 callbacks suppressed
sept. 21 14:28:53 pc-name upowerd[1198]: energy_full (72,450000) is greater than energy_full_design (71,000000)
sept. 21 14:28:53 pc-name sddm-greeter[1165]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
sept. 21 14:28:53 pc-name sddm-greeter[1165]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
sept. 21 14:28:53 pc-name sddm-greeter[1165]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
sept. 21 14:28:53 pc-name kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
sept. 21 14:28:53 pc-name bluetoothd[1088]: Failed to set mode: Failed (0x03)
sept. 21 14:28:53 pc-name sddm-greeter[1165]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
sept. 21 14:28:53 pc-name sddm-greeter[1165]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.34'
sept. 21 14:28:57 pc-name NetworkManager[590]: <warn> [1663763337.8283] device (wlp0s20f3): no secrets: No agents were available for this request.
sept. 21 14:28:57 pc-name NetworkManager[590]: <warn> [1663763337.8288] device (wlp0s20f3): Activation: failed for connection 'Livebox-1160-Bureau'
sept. 21 14:28:57 pc-name systemd-xdg-autostart-generator[1227]: Configuration file /home/fabien/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
sept. 21 14:28:57 pc-name NetworkManager[590]: <warn> [1663763337.9146] device (wlp0s20f3): no secrets: No agents were available for this request.
sept. 21 14:28:57 pc-name NetworkManager[590]: <warn> [1663763337.9502] device (wlp0s20f3): Activation: failed for connection 'Livebox-1160'
sept. 21 14:28:57 pc-name kernel: kauditd_printk_skb: 11 callbacks suppressed
sept. 21 14:28:58 pc-name systemd-xdg-autostart-generator[1256]: Configuration file /home/fabien/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
sept. 21 14:28:58 pc-name ksplashqml[1247]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
sept. 21 14:28:58 pc-name ksplashqml[1247]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
sept. 21 14:28:58 pc-name ksmserver[1282]: Qt: Session management error: networkIdsList argument is NULL
sept. 21 14:28:58 pc-name kglobalaccel5[1297]: kf.globalaccel.kglobalacceld: No desktop file found for service "org.kde.spectacle.desktop"
sept. 21 14:28:58 pc-name kwin_x11[1285]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
sept. 21 14:28:58 pc-name kwin_x11[1285]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
sept. 21 14:28:58 pc-name ksmserver[1282]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
sept. 21 14:28:58 pc-name kwin_x11[1285]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
sept. 21 14:28:58 pc-name plasmashell[1323]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
sept. 21 14:28:58 pc-name plasmashell[1323]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
sept. 21 14:28:59 pc-name plasmashell[1323]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
sept. 21 14:28:59 pc-name plasmashell[1323]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
sept. 21 14:28:59 pc-name kded5[1284]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
sept. 21 14:28:59 pc-name kded5[1284]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Impossible de charger la bibliothèque /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so : (libgps.so.29: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
sept. 21 14:28:59 pc-name kded5[1284]: kscreen.kded: PowerDevil SuspendSession action not available!
sept. 21 14:28:59 pc-name kded5[1284]: org.kde.plasma.dataengine.geolocation: error: "Hôte location.services.mozilla.com: Hôte introuvable inconnu"
sept. 21 14:28:59 pc-name org_kde_powerdevil[1358]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
sept. 21 14:28:59 pc-name plasmashell[1323]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
sept. 21 14:28:59 pc-name plasmashell[1323]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
sept. 21 14:28:59 pc-name plasmashell[1323]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
sept. 21 14:28:59 pc-name plasmashell[1323]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
sept. 21 14:28:59 pc-name org_kde_powerdevil[1358]: org.kde.powerdevil: Handle button events action could not check for screen configuration
sept. 21 14:28:59 pc-name systemd[1221]: app-ulauncher@autostart.service: Failed with result 'exit-code'.
sept. 21 14:28:59 pc-name systemd[1221]: Failed to start Ulauncher.
sept. 21 14:28:59 pc-name plasmashell[1323]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
sept. 21 14:28:59 pc-name plasmashell[1323]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
sept. 21 14:28:59 pc-name flameshot[1462]: Failed to get information about the latest version. "L'hôte api.github.com est introuvable"
sept. 21 14:28:59 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1792, resource id: 16777335, major code: 3 (GetWindowAttributes), minor code: 0
sept. 21 14:28:59 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1793, resource id: 16777335, major code: 14 (GetGeometry), minor code: 0
sept. 21 14:28:59 pc-name plasmashell[1323]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
sept. 21 14:28:59 pc-name plasmashell[1323]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
sept. 21 14:29:00 pc-name kded5[1284]: kf.bluezqt: PendingCall Error: ""
sept. 21 14:29:00 pc-name plasmashell[1323]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
sept. 21 14:29:00 pc-name plasmashell[1323]: org.kde.plasma.kicker: Entry is not valid "kde4-digikam.desktop" QSharedPointer(0x55e8f8a75c60)
sept. 21 14:29:00 pc-name plasmashell[1323]: org.kde.plasma.kicker: Entry is not valid "pamac-manager.desktop" QSharedPointer(0x55e8f8a2b060)
sept. 21 14:29:00 pc-name plasmashell[1323]: org.kde.plasma.kicker: Entry is not valid "pamac-updater.desktop" QSharedPointer(0x55e8f8a75c60)
sept. 21 14:29:00 pc-name plasmashell[1323]: org.kde.plasma.kicker: Entry is not valid "kde4-digikam.desktop" QSharedPointer(0x55e8f8a76340)
sept. 21 14:29:00 pc-name plasmashell[1323]: org.kde.plasma.kicker: Entry is not valid "pamac-manager.desktop" QSharedPointer(0x55e8f8a75c60)
sept. 21 14:29:00 pc-name plasmashell[1323]: org.kde.plasma.kicker: Entry is not valid "pamac-updater.desktop" QSharedPointer(0x55e8f8a76340)
sept. 21 14:29:00 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
sept. 21 14:29:00 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
sept. 21 14:29:00 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
sept. 21 14:29:00 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
sept. 21 14:29:00 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
sept. 21 14:29:00 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
sept. 21 14:29:00 pc-name plasmashell[1323]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
sept. 21 14:29:00 pc-name plasmashell[1323]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
sept. 21 14:29:00 pc-name pulseaudio[1629]: stat('/etc/pulse/default.pa.d'): Aucun fichier ou dossier de ce type
sept. 21 14:29:00 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
sept. 21 14:29:00 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:17:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
sept. 21 14:29:01 pc-name plasmashell[1323]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
sept. 21 14:29:01 pc-name plasmashell[1323]: Both point size and pixel size set. Using pixel size.
sept. 21 14:29:01 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:55:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
sept. 21 14:29:01 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2848, resource id: 4194351, major code: 18 (ChangeProperty), minor code: 0
sept. 21 14:29:01 pc-name plasmashell[1323]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
sept. 21 14:29:01 pc-name plasmashell[1323]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
sept. 21 14:29:05 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3745, resource id: 69206022, major code: 18 (ChangeProperty), minor code: 0
sept. 21 14:29:06 pc-name kded5[1284]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
sept. 21 14:29:06 pc-name kscreenlocker_greet[1735]: Qt: Session management error: networkIdsList argument is NULL
sept. 21 14:29:07 pc-name kscreenlocker_greet[1735]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:43:9: Unable to assign [undefined] to bool
sept. 21 14:29:07 pc-name kscreenlocker_greet[1735]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "fr_FR" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
sept. 21 14:29:07 pc-name kscreenlocker_greet[1735]: QXcbClipboard: SelectionRequest too old
sept. 21 14:29:07 pc-name plasmashell[1323]: QXcbClipboard::setMimeData: Cannot set X11 selection owner
sept. 21 14:29:11 pc-name kded5[1284]: kf.bluezqt: PendingCall Error: ""
sept. 21 14:29:14 pc-name kwin_x11[1285]: kwin_core: XCB error: 3 (BadWindow), sequence: 5249, resource id: 69206044, major code: 129 (SHAPE), minor code: 6 (Input)
sept. 21 14:29:14 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5250, resource id: 69206044, major code: 2 (ChangeWindowAttributes), minor code: 0
sept. 21 14:29:14 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5256, resource id: 69206064, major code: 18 (ChangeProperty), minor code: 0
sept. 21 14:29:15 pc-name kded5[1284]: kf.service.services: The desktop entry file "/usr/share/applications/kcm_krunnersettings.desktop" has Type= "Application" but no Exec line
sept. 21 14:29:15 pc-name kded5[1284]: kf.service.sycoca: Invalid Service : "/usr/share/applications/kcm_krunnersettings.desktop"
sept. 21 14:29:15 pc-name kded5[1284]: kf.config.core: "KConfigIni: In file /usr/share/applications/electrum.desktop, line 6: " "Invalid escape sequence \"\\\"\"."
sept. 21 14:29:15 pc-name kded5[1284]: kf.config.core: "KConfigIni: In file /usr/share/applications/electrum.desktop, line 21: " "Invalid escape sequence \"\\\"\"."
sept. 21 14:29:16 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6200, resource id: 29360242, major code: 18 (ChangeProperty), minor code: 0
sept. 21 14:29:16 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
sept. 21 14:29:17 pc-name firefox[2051]: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
sept. 21 14:29:17 pc-name pipewire[2132]: mod.rt: Can't find xdg-portal: (null)
sept. 21 14:29:17 pc-name pipewire[2132]: mod.rt: found session bus but no portal
sept. 21 14:29:17 pc-name pipewire-media-session[2133]: mod.rt: Can't find xdg-portal: (null)
sept. 21 14:29:17 pc-name pipewire-media-session[2133]: mod.rt: found session bus but no portal
sept. 21 14:29:17 pc-name pipewire-media-session[2133]: mod.rt: RTKit error: org.freedesktop.DBus.Error.AccessDenied
sept. 21 14:29:17 pc-name pipewire-media-session[2133]: mod.rt: could not make thread 2134 realtime using RTKit: Permission denied
sept. 21 14:29:17 pc-name pipewire[2132]: mod.rt: RTKit error: org.freedesktop.DBus.Error.AccessDenied
sept. 21 14:29:17 pc-name pipewire[2132]: mod.rt: could not make thread 2137 realtime using RTKit: Permission non accordée
sept. 21 14:29:17 pc-name firefox[2051]: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
sept. 21 14:29:17 pc-name firefox[2051]: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
sept. 21 14:29:17 pc-name firefox[2051]: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
sept. 21 14:29:17 pc-name firefox[2051]: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
sept. 21 14:29:22 pc-name plasmashell[1323]: kf.sonnet.core: No language dictionaries for the language: "en_US"
sept. 21 14:29:25 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11570, resource id: 16778244, major code: 3 (GetWindowAttributes), minor code: 0
sept. 21 14:29:25 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 11571, resource id: 16778244, major code: 14 (GetGeometry), minor code: 0
sept. 21 14:29:25 pc-name systemsettings[2587]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:189:9: QML MouseArea: Binding loop detected for property "width"
sept. 21 14:29:25 pc-name systemsettings[2587]: QFSFileEngine::open: No file name specified
sept. 21 14:29:25 pc-name systemsettings[2587]: kf.coreaddons.desktopparser: Error: Failed to open ""
sept. 21 14:29:25 pc-name systemsettings[2587]: QFileDevice::seek: IODevice is not open
sept. 21 14:29:54 pc-name kwin_x11[1285]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
sept. 21 14:29:54 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15793, resource id: 16778658, major code: 3 (GetWindowAttributes), minor code: 0
sept. 21 14:29:54 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 15794, resource id: 16778658, major code: 14 (GetGeometry), minor code: 0
sept. 21 14:29:54 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15797, resource id: 16778658, major code: 3 (GetWindowAttributes), minor code: 0
sept. 21 14:29:54 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 15798, resource id: 16778658, major code: 14 (GetGeometry), minor code: 0
sept. 21 14:30:03 pc-name kioslave5[1401]: kf.kio.core: timeoutSpecialCommand() did not call finished() or error()! Please fix the kio_http KIO slave
sept. 21 14:30:03 pc-name kioslave5[1412]: kf.kio.core: timeoutSpecialCommand() did not call finished() or error()! Please fix the kio_http KIO slave
sept. 21 14:30:17 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18626, resource id: 16778978, major code: 20 (GetProperty), minor code: 0
sept. 21 14:30:26 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19510, resource id: 16779064, major code: 20 (GetProperty), minor code: 0
sept. 21 14:33:33 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23314, resource id: 4194315, major code: 18 (ChangeProperty), minor code: 0
sept. 21 14:45:36 pc-name kded5[1284]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
sept. 21 14:45:36 pc-name kscreenlocker_greet[2735]: Qt: Session management error: networkIdsList argument is NULL
sept. 21 14:45:38 pc-name kscreenlocker_greet[2735]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:43:9: Unable to assign [undefined] to bool
sept. 21 14:45:38 pc-name kscreenlocker_greet[2735]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "fr_FR" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
sept. 21 14:45:38 pc-name kscreenlocker_greet[2735]: QXcbClipboard: SelectionRequest too old
sept. 21 14:45:38 pc-name plasmashell[1323]: QXcbClipboard::setMimeData: Cannot set X11 selection owner
sept. 21 14:52:30 pc-name kded5[1284]: kf.bluezqt: PendingCall Error: ""
sept. 21 14:52:33 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26201, resource id: 4194352, major code: 18 (ChangeProperty), minor code: 0
sept. 21 14:52:33 pc-name kwin_x11[1285]: kwin_core: XCB error: 3 (BadWindow), sequence: 26221, resource id: 14680078, major code: 129 (SHAPE), minor code: 6 (Input)
sept. 21 14:52:33 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26222, resource id: 14680078, major code: 2 (ChangeWindowAttributes), minor code: 0
sept. 21 14:53:25 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
sept. 21 14:53:25 pc-name plasmashell[1323]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
sept. 21 14:53:25 pc-name plasmashell[1323]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
sept. 21 14:53:25 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29071, resource id: 29360312, major code: 14 (GetGeometry), minor code: 0
sept. 21 14:54:50 pc-name kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
sept. 21 14:55:05 pc-name NetworkManager[590]: <warn> [1663764905.9736] device (wlp0s20f3): link timed out.
sept. 21 14:55:06 pc-name plasmashell[1323]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55e8fac5c5b0) QQmlContext(0x55e8f94453b0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
sept. 21 14:55:06 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
sept. 21 14:55:06 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
sept. 21 14:55:06 pc-name plasmashell[1323]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55e8f9fe3610) QQmlContext(0x55e8f94453b0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
sept. 21 14:55:06 pc-name NetworkManager[590]: <warn> [1663764906.0792] device (wlp0s20f3): Activation: failed for connection 'Livebox-1160-Bureau'
sept. 21 14:55:06 pc-name plasmashell[1323]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55e8faeef540) QQmlContext(0x55e8f94453b0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
sept. 21 14:55:10 pc-name kwin_x11[1285]: kwin_core: XCB error: 152 (BadDamage), sequence: 40214, resource id: 16780581, major code: 143 (DAMAGE), minor code: 3 (Subtract)
sept. 21 14:55:32 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
sept. 21 14:55:32 pc-name plasmashell[1323]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
sept. 21 14:55:32 pc-name plasmashell[1323]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
sept. 21 14:55:32 pc-name NetworkManager[590]: <warn> [1663764932.9737] device (wlp0s20f3): Activation: (wifi) association took too long, failing activation
sept. 21 14:55:32 pc-name plasmashell[1323]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55e8fadf9d90) QQmlContext(0x55e8f94453b0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
sept. 21 14:55:32 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
sept. 21 14:55:32 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
sept. 21 14:55:33 pc-name NetworkManager[590]: <warn> [1663764933.0088] device (wlp0s20f3): Activation: failed for connection 'Livebox-1160'
sept. 21 14:55:33 pc-name plasmashell[1323]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55e8fac5c5b0) QQmlContext(0x55e8f94453b0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
sept. 21 14:55:33 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
sept. 21 14:55:33 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
sept. 21 14:55:37 pc-name plasmashell[1323]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x7f60a80872f0) QQmlContext(0x55e8f94453b0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
sept. 21 14:55:37 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
sept. 21 14:55:37 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
sept. 21 14:55:37 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65521, resource id: 29360363, major code: 20 (GetProperty), minor code: 0
sept. 21 14:55:37 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65522, resource id: 29360363, major code: 15 (QueryTree), minor code: 0
sept. 21 14:55:37 pc-name kwin_x11[1285]: kwin_core: XCB error: 152 (BadDamage), sequence: 66, resource id: 16784194, major code: 143 (DAMAGE), minor code: 3 (Subtract)
sept. 21 14:55:38 pc-name kwin_x11[1285]: kwin_core: XCB error: 152 (BadDamage), sequence: 1041, resource id: 16784207, major code: 143 (DAMAGE), minor code: 3 (Subtract)
sept. 21 14:55:42 pc-name kwin_x11[1285]: kwin_core: XCB error: 152 (BadDamage), sequence: 3874, resource id: 16785045, major code: 143 (DAMAGE), minor code: 3 (Subtract)
sept. 21 14:55:50 pc-name kded5[1284]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
sept. 21 14:55:50 pc-name kscreenlocker_greet[3125]: Qt: Session management error: networkIdsList argument is NULL
sept. 21 14:55:50 pc-name plasmashell[1323]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
sept. 21 14:55:51 pc-name kscreenlocker_greet[3125]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:43:9: Unable to assign [undefined] to bool
sept. 21 14:55:51 pc-name kscreenlocker_greet[3125]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "fr_FR" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
sept. 21 14:55:51 pc-name kscreenlocker_greet[3125]: QXcbClipboard: SelectionRequest too old
sept. 21 14:55:51 pc-name plasmashell[1323]: QXcbClipboard::setMimeData: Cannot set X11 selection owner
sept. 21 15:37:41 pc-name kernel: done.
sept. 21 15:37:41 pc-name kded5[1284]: kf.bluezqt: PendingCall Error: ""
sept. 21 15:37:44 pc-name kwin_x11[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6208, resource id: 4194352, major code: 18 (ChangeProperty), minor code: 0
sept. 21 15:37:45 pc-name plasmashell[1323]: trying to show an empty dialog
sept. 21 15:37:59 pc-name plasmashell[1323]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
