Hi !
After an update (i think since 1 month) my screen is going black after 30s (exactly).
I’ve search in gnome configuration and dconf but founded nothing. I’m not on a laptop (desktop computer).
If you’ve any idea about this problem, thank you for sharing ![]()
Power Saving, and/or Screensaver settings will likely have what you’re looking for; but you’ll have to look for it yourself. ![]()
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes more indepth information is usually needed;
It’s best to ask your system directly. ![]()
Output of the inxi command with appropriate parameters will achieve this (naturally, formatted according to forum requirements) and will generally be more useful for those wishing to help:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
- inxi man pages (Arch Manual)
Required reading
Resources
Ok, thanks !
I’ve resolve my problem by switching to wayland
(My manjaro is up since 2019 !).
Thanks for your work !
