Hello,
im a new linux user, having a little experience with ubuntu but very new to manjaro.
I just installed manjaro with XFCE and noticed that im having a black flickering from time to time. Usually after booting it occurs some times. When using the system it occurs unregularly. It sometimes happens 3 times in a row, and sometimes doesn’t occur for 10 minutes.
I dont really know how to describe the problem… it looks like the screen is turning black for a split second.
My primary screen is a 144hz screen (2560x1440, DisplayPort) and it feels like the problem doesnt occur when i set it to 60hz.
I have a secondary screen connected (1920x1080, HDMI).
On installation i selected to use NVIDIA drivers.
In NVIDIA X Server Settings i tried selecting “Force Composition Pipeline” or “Force Full Composition Pipeline”, but after that it doesn’t look and feel like it is 144hz.
When I select “Save to X Configuration File” and then select “Show Preview…” it shows this:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 460.39
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "LG Electronics LG ULTRAGEAR"
HorizSync 230.0 - 230.0
VertRefresh 48.0 - 144.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 1080"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-6"
Option "metamodes" "DP-4: nvidia-auto-select +0+0, DP-3: nvidia-auto-select +2560+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Here is the output of inxi -Fazy:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=4334f469-c036-44c9-860a-4690adf9d0d8 ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <filter> UEFI: American Megatrends v: 3.40 date: 10/25/2019
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701013
L2 cache: 4 MiB
bogomips: 115232
Speed: 3596 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3596 2: 2057 3: 2125 4: 2131 5: 2123 6: 2127 7: 2121 8: 3992 9: 2055
10: 2054 11: 2057 12: 2055 13: 2054 14: 3743 15: 4095 16: 2112
conditional, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Micro-Star MSI
driver: nvidia v: 460.39 alternate: nouveau,nvidia_drm bus ID: 26:00.0
chip ID: 10de:1b80 class ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: DP-3 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
Monitor-2: DP-4 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 26:00.1 chip ID: 10de:10f0
class ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 28:00.4 chip ID: 1022:1487
class ID: 0403
Device-3: Logitech G930 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-8:2 chip ID: 046d:0a1f class ID: 0300
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus ID: 22:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.59 TiB used: 21.87 GiB (1.3%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 2B2QEXM7 temp: 31.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 250GB
size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: BB0Q scheme: MBR
ID-1: / raw size: 465.46 GiB size: 457.16 GiB (98.22%)
used: 21.87 GiB (4.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 43.9 C mobo: N/A gpu: nvidia temp: 45 C
Processes: 314 Uptime: 7m wakeups: 0 Memory: 31.37 GiB used: 1.82 GiB (5.8%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1197 pacman: 1184
lib: 399 flatpak: 7 snap: 6 Shell: Bash v: 5.1.0 running in: xfce4-terminal
inxi: 3.3.01
Also I just found out that im seeing this in very often when im reading this logfile:
cat /var/log/Xorg.0.log
[ 168.259] (--) NVIDIA(GPU-0):
[ 168.261] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 168.261] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 168.261] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 458.682] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 458.682] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 458.682] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 458.682] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 458.682] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 458.682] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 458.682] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 458.682] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 458.682] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 458.682] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 458.682] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 458.682] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 458.682] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 458.682] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 458.682] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 458.746] (--) NVIDIA(GPU-0): Acer S242HL (DFP-5): connected
[ 458.746] (--) NVIDIA(GPU-0): Acer S242HL (DFP-5): Internal TMDS
[ 458.746] (--) NVIDIA(GPU-0): Acer S242HL (DFP-5): 300.0 MHz maximum pixel clock
[ 458.746] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAGEAR (DFP-6): connected
[ 458.746] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAGEAR (DFP-6): Internal DisplayPort
[ 458.746] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAGEAR (DFP-6): 1440.0 MHz maximum pixel clock
[ 458.747] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 458.747] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 458.747] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 993.822] (EE) event20 - HID 046a:0023: client bug: event processing lagging behind by 12ms, your system is too slow
But this doesn’t seem to be the problem. I tried to convert the timestamp with date -d “-458.747 seconds” and this is no time when there was a flickering.
Id be very thankful if someone could help me here.
