Black_cache_virtual_box
Hello, I wanted to go on to detail the problem that is happening to me:
Ambient:
virtualbox 6.1.12-3
virtualbox-ext-oracle 6.1.13.139853-1
Kernel 5.7.14-1
When I create a virtual machine with Windows 10 pro stored the VDI on a different disk than where Manjaro is installed, during the installation progress I received a window with the error BLACK_CACHE. I tried to vary the configurations, for example in storage, leave the I / O option checked, put USB 1.0. And I was unsuccessful.
I also tried creating the machine on the Primary Disk (where Manjaro is installed) and it installed fine. Then I imported that virtual machine into Virtualbox but stored on another hard drive and I got the BLACK_CACHE problem again.
Do you know if the problem is related to some additional configuration that I am missing because I store the VDI on a disk other than manjaro? the secondary disk is correctly mounted.
Thanks a lot
There is currently a bug in this package. You either use USB 1.0, install the previous version or don’t use it at all.
ok, I see that there is a new package called “manjaro” released 1 week ago. will it be the solution? aur.archlinux.org/packages/virtualbox-ext-oracle-manjaro
It sows my mistrust as it isn’t the official procedure.
I see that there are differences between the supported versions of virtualbox 6.1.12 and ext-oracle 6.1.13.
Thanks
virtualbox-ext-oracle was never in the repos. So the procedure for this package is the same. It is in AUR!
virtualbox-ext-oracle-manjaro downloads version 6.1.12, so it should solve your problem.
I uninstalled virtualbox-ext-oracle 6.1.13 and installed virtualbox-ext-oracle-manjaro 6.1.12 according to my version of virtualbox 6.1.12 but I still have the same problem. Will anyone have the reason for the error?
Did you reinstall VB additions in the VM?
I already reinstalled.
I tried uninstalling virtualbox and ext-oracle. Then, I installed the latest version 6.1.14 and the problem continues.
The last stable update solves the problem for me. I 'm currently using version 6.1.14 of virtualbox-ext-oracle.
Update your system and check if virtualbox-ext-oracleis the last version. The reboot and reinstall VB additions in your VM’s.
I try to import an .ova on a secondary disk and a windows appears saying “time remaining: 50 hours”
I tried importing to another disk (they are mounted correctly) and the same window appears.
Please post the output of sudo fdisk -l and lsblk -f
sudo fdisk -l
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 1953521663 1953519616 931.5G 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: gpt
Device Start End Sectors Size Type
/dev/sdb1 4096 618495 614400 300M EFI System
/dev/sdb2 618496 976768064 976149569 465.5G Linux filesystem
Disk /dev/sdc: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
/dev/sdc1 2048 976773119 976771072 465.8G 7 HPFS/NTFS/exFAT
Disk /dev/sdd: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
/dev/sdd1 63 976771119 976771057 465.8G 42 SFS
Disk /dev/loop0: 57.99 MiB, 60805120 bytes, 118760 sectors
Disk /dev/loop1: 55.32 MiB, 58007552 bytes, 113296 sectors
Disk /dev/loop2: 29.89 MiB, 31342592 bytes, 61216 sectors
Disk /dev/loop3: 57.9 MiB, 60715008 bytes, 118584 sectors
Disk /dev/loop4: 143.21 MiB, 150163456 bytes, 293288 sectors
Disk /dev/loop5: 143.21 MiB, 150163456 bytes, 293288 sectors
sudo lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0 squashfs 4.0 0 100% /var/lib/snapd/snap/jdownloader2/12
loop1 squashfs 4.0 0 100% /var/lib/snapd/snap/core18/1885
loop2 squashfs 4.0 0 100% /var/lib/snapd/snap/snapd/8790
loop3 squashfs 4.0 0 100% /var/lib/snapd/snap/jdownloader2/10
loop4 squashfs 4.0 0 100% /var/lib/snapd/snap/zoom-client/97
loop5 squashfs 4.0 0 100% /var/lib/snapd/snap/zoom-client/98
sda
-sda1 ntfs Documents 242.6G 74% /run/media/user/Documents sdb |-sdb1 vfat FAT32 299.1M 0% /boot/efi -sdb2 ext4 1.0 13.2G 92% /run/timeshift/backup
sdc
-sdc1 ntfs VMs 238G 49% /run/media/user/VMs sdd -sdd1 ntfs Downloads 1.7G 100% /run/media/user/Downloads
Please edit your post and enclose the terminal output with the button </> or within three backticks.
So you are trying to install a VM in a ntfs filesystem under Linux? Why? I don’t know if it has anything to do with it, but that’s the first thing I’d try to change.
Another thing I noticed is that you have a mix of DOS and GPT partitioning. But since you don’t seem to be having any issued with it, let it be.
