Hey. Some time ago, seemingly randomly, my system started exhibiting this weird behavior.
- Whenever it automatically suspends after a set amount of time, it then wakes up immediately, and shuffles all my windows to one screen, which is not even the primary one.
- If I suspend using
systemctl suspend
it goes to a black screen and freezes completely. Not even REISUB helped. - Similar thing happens with
systemctl hibernate
, but instead of freezing at the black screen, it wakes up immediately after, and only then freezes completely. - However, when I suspend it using the KDE power menu, it goes down just fine in a couple of seconds, and I can resume from suspend at any point without issues.
- If this happens few too many times in the same session, my system starts lagging, get high GPU usage, and if I try to launch any gui app, I get the following X error:
Maximum number of clients reachedqt.qpa.xcb: could not connect to display :0
On another system, running same version of Manjaro and Linux kernel, this doesnβt happen. This persisted through several updates.
Iβm using Manjaro KDE running 5.16 kernel, RX 580 on amdgpu, and i7-10700K.
inxi -Fxzd
Kernel: 5.16.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: KDE Plasma v: 5.24.4 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z490 UD v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z490 UD serial: <superuser required>
UEFI: American Megatrends v: F21 date: 11/23/2021
Device-1: gip0.0 model: Microsoft X-Box One pad
charge: 50% (should be ignored) status: not charging
Info: 8-core model: Intel Core i7-10700K bits: 64 type: MT MCP
arch: Comet Lake rev: 5 cache: L1: 512 KiB L2: 2 MiB L3: 16 MiB
Speed (MHz): avg: 800 min/max: 800/5100 cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 bogomips: 121639
Device-1: AMD Polaris 20 XL [Radeon RX 580 2048SP] driver: amdgpu v: kernel
bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu
gpu: amdgpu resolution: 1: 1280x1024~60Hz 2: 1366x768~60Hz
3: 2560x1440~60Hz
OpenGL: renderer: AMD Radeon RX 580 2048SP (POLARIS10 DRM 3.44.0
5.16.18-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: M-Audio Keystation 88 type: USB driver: snd-usb-audio
bus-ID: 1-3:3
Device-3: ASUSTek STRIX SOUND CARD type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2
Sound Server-1: ALSA v: k5.16.18-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.20 running: yes
Sound Server-4: PipeWire v: 0.3.49 running: no
vendor: Gigabyte driver: r8169 v: kernel port: 3000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wgcf-profile state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:4
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 2.96 TiB used: 408.58 GiB (13.5%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX6000PNP size: 238.47 GiB
temp: 46.9 C
ID-2: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
ID-3: /dev/sdb vendor: Western Digital model: WD1003FBYX-01Y7B1
ID-1: / size: 42.95 GiB used: 31.38 GiB (73.0%) fs: ext4
dev: /dev/nvme0n1p7
ID-2: /boot/efi size: 499 MiB used: 25.5 MiB (5.1%) fs: vfat
dev: /dev/nvme0n1p6
ID-3: /home size: 120.07 GiB used: 92.29 GiB (76.9%) fs: ext4
dev: /dev/nvme0n1p8
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p5
System Temperatures: cpu: 16.8 C pch: 50.0 C mobo: 16.8 C gpu: amdgpu
temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1017
Processes: 405 Uptime: 5m Memory: 15.55 GiB used: 3.3 GiB (21.2%)
Init: systemd Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1835
Shell: Zsh v: 5.8.1 inxi: 3.3.15
journalctl -xe (right after one such incident)
May 19 16:05:25 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:26 desktop warp-svc[775]: 2022-05-19T08:05:26.077Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:05:26 desktop warp-svc[775]: 2022-05-19T08:05:26.078Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:05:26 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:05:26 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:27 desktop warp-svc[775]: 2022-05-19T08:05:27.087Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:05:27 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:28 desktop warp-svc[775]: 2022-05-19T08:05:28.268Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:05:28 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:05:29 desktop warp-svc[775]: 2022-05-19T08:05:29.277Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:05:31 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:33 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:34 desktop tlp[4736]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:05:34 desktop tlp[4736]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:05:34 desktop tlp[4736]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:05:34 desktop tlp[4736]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:05:34 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:36 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:37 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:38 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:40 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:41 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:42 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:43 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:46 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:46 desktop warp-svc[775]: 2022-05-19T08:05:46.401Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:05:46 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:05:47 desktop warp-svc[775]: 2022-05-19T08:05:47.405Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:05:47 desktop warp-svc[775]: 2022-05-19T08:05:47.405Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:05:47 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:05:48 desktop warp-svc[775]: 2022-05-19T08:05:48.414Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:05:49 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:50 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:52 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:53 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:54 desktop tlp[4818]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:05:54 desktop tlp[4818]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:05:54 desktop tlp[4818]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:05:54 desktop tlp[4818]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:05:55 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:56 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:57 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:05:59 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:02 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:02 desktop warp-svc[775]: 2022-05-19T08:06:02.401Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:02 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:06:03 desktop warp-svc[775]: 2022-05-19T08:06:03.411Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:05 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:05 desktop warp-svc[775]: 2022-05-19T08:06:05.815Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:05 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:06:06 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:06 desktop warp-svc[775]: 2022-05-19T08:06:06.824Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:07 desktop warp-svc[775]: 2022-05-19T08:06:07.735Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:07 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:06:08 desktop warp-svc[775]: 2022-05-19T08:06:08.744Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:08 desktop warp-svc[775]: 2022-05-19T08:06:08.744Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:08 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:06:09 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:09 desktop warp-svc[775]: 2022-05-19T08:06:09.753Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:10 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:13 desktop warp-svc[775]: 2022-05-19T08:06:13.495Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:13 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:06:14 desktop tlp[4966]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:06:14 desktop tlp[4966]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:06:14 desktop tlp[4966]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:06:14 desktop tlp[4966]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:06:14 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:14 desktop warp-svc[775]: 2022-05-19T08:06:14.504Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:14 desktop warp-svc[775]: 2022-05-19T08:06:14.504Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:14 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:06:15 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:15 desktop warp-svc[775]: 2022-05-19T08:06:15.507Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:16 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:20 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:21 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:23 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:25 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:26 desktop warp-svc[775]: 2022-05-19T08:06:26.295Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:26 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:06:27 desktop warp-svc[775]: 2022-05-19T08:06:27.304Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:27 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:31 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:32 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:34 desktop tlp[5051]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:06:34 desktop tlp[5051]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:06:34 desktop tlp[5051]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:06:34 desktop tlp[5051]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:06:39 desktop warp-svc[775]: 2022-05-19T08:06:39.308Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:39 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:06:40 desktop warp-svc[775]: 2022-05-19T08:06:40.317Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:40 desktop warp-svc[775]: 2022-05-19T08:06:40.317Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:40 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:06:41 desktop warp-svc[775]: 2022-05-19T08:06:41.326Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:48 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:48 desktop warp-svc[775]: 2022-05-19T08:06:48.481Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:48 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:06:49 desktop warp-svc[775]: 2022-05-19T08:06:49.490Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:51 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:06:53 desktop warp-svc[775]: 2022-05-19T08:06:53.601Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:53 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:06:54 desktop tlp[5135]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:06:54 desktop tlp[5135]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:06:54 desktop tlp[5135]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:06:54 desktop tlp[5135]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:06:54 desktop warp-svc[775]: 2022-05-19T08:06:54.610Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:58 desktop warp-svc[775]: 2022-05-19T08:06:58.721Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:58 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:06:59 desktop warp-svc[775]: 2022-05-19T08:06:59.730Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:06:59 desktop warp-svc[775]: 2022-05-19T08:06:59.730Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:06:59 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:07:00 desktop warp-svc[775]: 2022-05-19T08:07:00.739Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:07:09 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:11 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:13 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:14 desktop tlp[5260]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:07:14 desktop tlp[5260]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:07:14 desktop tlp[5260]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:07:14 desktop tlp[5260]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:07:15 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:16 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:18 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:19 desktop warp-svc[775]: 2022-05-19T08:07:19.201Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:07:19 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:07:20 desktop warp-svc[775]: 2022-05-19T08:07:20.210Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:07:22 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:23 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:24 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:28 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:30 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:34 desktop tlp[5342]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:07:34 desktop tlp[5342]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:07:34 desktop tlp[5342]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:07:34 desktop tlp[5342]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:07:37 desktop warp-svc[775]: 2022-05-19T08:07:37.761Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:07:37 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:07:38 desktop warp-svc[775]: 2022-05-19T08:07:38.770Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:07:38 desktop warp-svc[775]: 2022-05-19T08:07:38.770Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:07:38 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:07:39 desktop warp-svc[775]: 2022-05-19T08:07:39.779Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:07:39 desktop warp-svc[775]: 2022-05-19T08:07:39.779Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:07:39 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:07:40 desktop warp-svc[775]: 2022-05-19T08:07:40.789Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:07:42 desktop warp-svc[775]: 2022-05-19T08:07:42.668Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:07:42 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:07:43 desktop warp-svc[775]: 2022-05-19T08:07:43.677Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:07:43 desktop warp-svc[775]: 2022-05-19T08:07:43.677Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:07:43 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:07:44 desktop warp-svc[775]: 2022-05-19T08:07:44.686Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:07:46 desktop warp-svc[775]: 2022-05-19T08:07:46.935Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:07:46 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:07:47 desktop warp-svc[775]: 2022-05-19T08:07:47.944Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:07:47 desktop warp-svc[775]: 2022-05-19T08:07:47.944Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:07:47 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:07:48 desktop warp-svc[775]: 2022-05-19T08:07:48.953Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:07:52 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:54 desktop tlp[5469]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:07:54 desktop tlp[5469]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:07:54 desktop tlp[5469]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:07:54 desktop tlp[5469]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:07:54 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:07:58 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:00 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:01 desktop dbus-daemon[769]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.10' (uid=0 pid=773 comm="/usr/lib/snapd/snapd")
May 19 16:08:01 desktop audit: BPF prog-id=22 op=LOAD
May 19 16:08:01 desktop audit: BPF prog-id=23 op=LOAD
May 19 16:08:01 desktop audit: BPF prog-id=24 op=LOAD
May 19 16:08:01 desktop systemd[1]: Starting Time & Date Service...
ββ Subject: A start job for unit systemd-timedated.service has begun execution
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ
ββ A start job for unit systemd-timedated.service has begun execution.
ββ
ββ The job identifier is 1971.
May 19 16:08:01 desktop kernel: audit: type=1334 audit(1652947681.517:103): prog-id=22 op=LOAD
May 19 16:08:01 desktop kernel: audit: type=1334 audit(1652947681.517:104): prog-id=23 op=LOAD
May 19 16:08:01 desktop kernel: audit: type=1334 audit(1652947681.517:105): prog-id=24 op=LOAD
May 19 16:08:01 desktop dbus-daemon[769]: [system] Successfully activated service 'org.freedesktop.timedate1'
May 19 16:08:01 desktop systemd[1]: Started Time & Date Service.
ββ Subject: A start job for unit systemd-timedated.service has finished successfully
ββ
ββ A start job for unit systemd-timedated.service has finished successfully.
ββ
May 19 16:08:01 desktop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 19 16:08:01 desktop kernel: audit: type=1130 audit(1652947681.543:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 19 16:08:02 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:02 desktop polkitd[771]: Registered Authentication Agent for unix-process:5677:32482 (system bus name :1.84 [/sbin/flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
May 19 16:08:02 desktop polkitd[771]: Unregistered Authentication Agent for unix-process:5677:32482 (system bus name :1.84, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
May 19 16:08:03 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:04 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:05 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:07 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:12 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:14 desktop tlp[5753]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:08:14 desktop tlp[5753]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:08:14 desktop tlp[5753]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:08:14 desktop tlp[5753]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:08:14 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:16 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:17 desktop polkitd[771]: Registered Authentication Agent for unix-process:5947:33913 (system bus name :1.88 [/sbin/flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
May 19 16:08:17 desktop polkitd[771]: Unregistered Authentication Agent for unix-process:5947:33913 (system bus name :1.88, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
May 19 16:08:17 desktop warp-svc[775]: 2022-05-19T08:08:17.228Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:08:17 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:08:17 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:18 desktop warp-svc[775]: 2022-05-19T08:08:18.231Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:08:20 desktop plasmashell[1853]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:366: Unable to assign [undefined] to QString
May 19 16:08:20 desktop kwin_x11[1789]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39919, resource id: 29360402, major code: 18 (ChangeProperty), minor code: 0
May 19 16:08:20 desktop systemd[1667]: Started Dolphin - File Manager.
ββ Subject: A start job for unit UNIT has finished successfully
ββ
ββ A start job for unit UNIT has finished successfully.
ββ
ββ The job identifier is 241.
May 19 16:08:20 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:20 desktop kwin_x11[1789]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
May 19 16:08:20 desktop kwin_x11[1789]: qt.svg: link #g1000 is undefined!
May 19 16:08:20 desktop kioslave5[6030]: Qt: Session management error: networkIdsList argument is NULL
May 19 16:08:21 desktop kioslave5[6062]: Qt: Session management error: networkIdsList argument is NULL
May 19 16:08:21 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:22 desktop kioslave5[6093]: Qt: Session management error: networkIdsList argument is NULL
May 19 16:08:22 desktop warp-svc[775]: 2022-05-19T08:08:22.348Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:08:22 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:08:22 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:22 desktop kioslave5[6133]: Qt: Session management error: networkIdsList argument is NULL
May 19 16:08:22 desktop kioslave5[6180]: Qt: Session management error: networkIdsList argument is NULL
May 19 16:08:22 desktop kioslave5[6204]: Qt: Session management error: networkIdsList argument is NULL
May 19 16:08:22 desktop dolphin[5976]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
May 19 16:08:22 desktop kwin_x11[1789]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43830, resource id: 96469013, major code: 18 (ChangeProperty), minor code: 0
May 19 16:08:22 desktop kwin_x11[1789]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43835, resource id: 96469014, major code: 18 (ChangeProperty), minor code: 0
May 19 16:08:22 desktop systemd[1667]: Started Kate - Advanced Text Editor.
ββ
ββ
ββ The job identifier is 245.
May 19 16:08:23 desktop ntfs-3g[754]: Could not load plugin /usr/lib/ntfs-3g/ntfs-plugin-80000017.so: Can not access a needed shared library
May 19 16:08:23 desktop ntfs-3g[754]: Hint /usr/lib/ntfs-3g/ntfs-plugin-80000017.so: cannot open shared object file: No such file or directory
May 19 16:08:23 desktop kate[6231]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so: (libaspell.so.15: cannot open shared object file: No such file or directory)"
May 19 16:08:23 desktop kate[6231]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so: (libhspell.so.0: cannot open shared object file: No such file or directory)"
May 19 16:08:23 desktop kate[6231]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so: (libvoikko.so.1: cannot open shared object file: No such file or directory)"
May 19 16:08:23 desktop kwin_x11[1789]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44940, resource id: 10506451, major code: 3 (GetWindowAttributes), minor code: 0
May 19 16:08:23 desktop kwin_x11[1789]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 44941, resource id: 10506451, major code: 14 (GetGeometry), minor code: 0
May 19 16:08:23 desktop warp-svc[775]: 2022-05-19T08:08:23.350Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:08:23 desktop warp-svc[775]: 2022-05-19T08:08:23.351Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:08:23 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:08:23 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:23 desktop kioslave5[6266]: Qt: Session management error: networkIdsList argument is NULL
May 19 16:08:24 desktop warp-svc[775]: 2022-05-19T08:08:24.355Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:08:24 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:26 desktop kioslave5[6297]: Qt: Session management error: networkIdsList argument is NULL
May 19 16:08:26 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:28 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:28 desktop kioslave5[6342]: Qt: Session management error: networkIdsList argument is NULL
May 19 16:08:30 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:31 desktop systemd[1]: systemd-timedated.service: Deactivated successfully.
ββ Subject: Unit succeeded
ββ
ββ The unit systemd-timedated.service has successfully entered the 'dead' state.
May 19 16:08:31 desktop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 19 16:08:31 desktop kernel: audit: type=1131 audit(1652947711.576:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 19 16:08:31 desktop audit: BPF prog-id=0 op=UNLOAD
May 19 16:08:31 desktop kernel: audit: type=1334 audit(1652947711.606:108): prog-id=0 op=UNLOAD
May 19 16:08:31 desktop kernel: audit: type=1334 audit(1652947711.606:109): prog-id=0 op=UNLOAD
May 19 16:08:31 desktop kernel: audit: type=1334 audit(1652947711.606:110): prog-id=0 op=UNLOAD
May 19 16:08:32 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:34 desktop tlp[6385]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:08:34 desktop tlp[6385]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:08:34 desktop tlp[6385]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:08:34 desktop tlp[6385]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:08:34 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:36 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:38 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:39 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:40 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:41 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:43 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:44 desktop warp-svc[775]: 2022-05-19T08:08:44.535Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:08:44 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:08:45 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:45 desktop warp-svc[775]: 2022-05-19T08:08:45.539Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:08:47 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:48 desktop warp-svc[775]: 2022-05-19T08:08:48.378Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:08:48 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:08:48 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:49 desktop warp-svc[775]: 2022-05-19T08:08:49.387Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:08:49 desktop warp-svc[775]: 2022-05-19T08:08:49.387Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:08:49 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:08:50 desktop warp-svc[775]: 2022-05-19T08:08:50.396Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:08:50 desktop warp-svc[775]: 2022-05-19T08:08:50.396Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:08:50 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:08:51 desktop warp-svc[775]: 2022-05-19T08:08:51.399Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:08:52 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:53 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:53 desktop kwin_x11[1789]: kwin_core: Failed to focus 0x2c00007 (error 8)
May 19 16:08:54 desktop tlp[6504]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:08:54 desktop tlp[6504]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:08:54 desktop tlp[6504]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:08:54 desktop tlp[6504]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:08:54 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:55 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:08:56 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:01 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:03 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:04 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:08 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:09 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:14 desktop tlp[6589]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:09:14 desktop tlp[6589]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:09:14 desktop tlp[6589]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:09:14 desktop tlp[6589]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:09:14 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:16 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:17 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:18 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:19 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:20 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:22 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:23 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:24 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:26 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:27 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:28 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:28 desktop kwin_x11[1789]: file:///usr/share/kwin/tabbox/informative/contents/ui/main.qml:123: TypeError: Cannot call method 'longestCaption' of null
May 19 16:09:28 desktop warp-svc[775]: 2022-05-19T08:09:28.911Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:09:28 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:09:29 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:29 desktop warp-svc[775]: 2022-05-19T08:09:29.920Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:09:30 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:30 desktop warp-svc[775]: 2022-05-19T08:09:30.618Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:09:30 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:09:31 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:31 desktop warp-svc[775]: 2022-05-19T08:09:31.625Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:09:33 desktop dbus-daemon[1702]: [session uid=1000 pid=1702] Activating via systemd: service name='org.kde.krunner' unit='plasma-krunner.service' requested by ':1.15' (uid=1000 pid=1838 comm="/usr/bin/kglobalaccel5")
May 19 16:09:33 desktop systemd[1667]: Starting KRunner...
ββ Subject: A start job for unit UNIT has begun execution
ββ
ββ A start job for unit UNIT has begun execution.
ββ
ββ The job identifier is 249.
May 19 16:09:33 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:33 desktop dbus-daemon[1702]: [session uid=1000 pid=1702] Successfully activated service 'org.kde.krunner'
May 19 16:09:33 desktop systemd[1667]: Started KRunner.
ββ
ββ
May 19 16:09:33 desktop krunner[6715]: QCommandLineParser: argument list cannot be empty, it should contain at least the executable name
May 19 16:09:33 desktop krunner[6715]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so: (libaspell.so.15: cannot open shared object file: No such file or directory)"
May 19 16:09:33 desktop krunner[6715]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so: (libhspell.so.0: cannot open shared object file: No such file or directory)"
May 19 16:09:33 desktop krunner[6715]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so: (libvoikko.so.1: cannot open shared object file: No such file or directory)"
May 19 16:09:33 desktop krunner[6715]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
May 19 16:09:33 desktop dbus-daemon[1702]: [session uid=1000 pid=1702] Activating via systemd: service name='org.kde.runners.baloo' unit='plasma-baloorunner.service' requested by ':1.141' (uid=1000 pid=6715 comm="/usr/bin/krunner")
May 19 16:09:33 desktop systemd[1667]: Starting KRunner provider for baloo file indexer...
ββ
ββ
ββ The job identifier is 268.
May 19 16:09:33 desktop dbus-daemon[1702]: [session uid=1000 pid=1702] Successfully activated service 'org.kde.runners.baloo'
May 19 16:09:33 desktop systemd[1667]: Started KRunner provider for baloo file indexer.
ββ
ββ
May 19 16:09:34 desktop tlp[6684]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:09:34 desktop tlp[6684]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:09:34 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:34 desktop tlp[6684]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:09:34 desktop tlp[6684]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:09:35 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:35 desktop systemd[1667]: Started systemsettings.
ββ
ββ
ββ The job identifier is 287.
May 19 16:09:35 desktop systemsettings[6830]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
May 19 16:09:35 desktop systemsettings[6830]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
May 19 16:09:35 desktop systemsettings[6830]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PageRow.qml:674:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
May 19 16:09:35 desktop systemsettings[6830]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PageRow.qml:670:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
May 19 16:09:35 desktop systemsettings[6830]: QFSFileEngine::open: No file name specified
May 19 16:09:35 desktop systemsettings[6830]: kf.coreaddons.desktopparser: Error: Failed to open ""
May 19 16:09:35 desktop systemsettings[6830]: QFileDevice::seek: IODevice is not open
May 19 16:09:35 desktop systemsettings[6830]: qml: The item SubCategoryPage_QMLTYPE_78(0x55f3de32d600) is already in the PageRow
May 19 16:09:36 desktop warp-svc[775]: 2022-05-19T08:09:36.375Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:09:36 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:09:37 desktop warp-svc[775]: 2022-05-19T08:09:37.384Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:09:37 desktop warp-svc[775]: 2022-05-19T08:09:37.385Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:09:37 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:09:37 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:37 desktop systemsettings[6830]: qml: The item SubCategoryPage_QMLTYPE_78(0x55f3de32d600) is already in the PageRow
May 19 16:09:38 desktop warp-svc[775]: 2022-05-19T08:09:38.394Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:09:38 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:38 desktop systemsettings[6830]: qml: The item SubCategoryPage_QMLTYPE_78(0x55f3de32d600) is already in the PageRow
May 19 16:09:38 desktop dbus-daemon[769]: [system] Activating service name='org.kde.powerdevil.chargethresholdhelper' requested by ':1.93' (uid=1000 pid=6830 comm="/usr/bin/systemsettings kcm_powerdevilprofilesconf") (using servicehelper)
May 19 16:09:38 desktop dbus-daemon[769]: [system] Successfully activated service 'org.kde.powerdevil.chargethresholdhelper'
May 19 16:09:38 desktop systemsettings[6830]: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
May 19 16:09:39 desktop systemsettings[6830]: qml: The item SubCategoryPage_QMLTYPE_78(0x55f3de32d600) is already in the PageRow
May 19 16:09:40 desktop systemsettings[6830]: qml: The item SubCategoryPage_QMLTYPE_78(0x55f3de32d600) is already in the PageRow
May 19 16:09:40 desktop systemsettings[6830]: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
May 19 16:09:42 desktop warp-svc[775]: 2022-05-19T08:09:42.561Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:09:42 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:09:43 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:43 desktop warp-svc[775]: 2022-05-19T08:09:43.570Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:09:47 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:51 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:51 desktop org_kde_powerdevil[1855]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
May 19 16:09:51 desktop dbus-daemon[769]: [system] Activating service name='org.kde.powerdevil.chargethresholdhelper' requested by ':1.22' (uid=1000 pid=1855 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
May 19 16:09:51 desktop dbus-daemon[769]: [system] Successfully activated service 'org.kde.powerdevil.chargethresholdhelper'
May 19 16:09:51 desktop org_kde_powerdevil[1855]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
May 19 16:09:52 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:53 desktop warp-svc[775]: 2022-05-19T08:09:53.015Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:09:53 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:09:53 desktop systemsettings[6830]: qml: The item SubCategoryPage_QMLTYPE_78(0x55f3de32d600) is already in the PageRow
May 19 16:09:54 desktop warp-svc[775]: 2022-05-19T08:09:54.024Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:09:54 desktop warp-svc[775]: 2022-05-19T08:09:54.024Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:09:54 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:09:54 desktop tlp[6889]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:09:54 desktop tlp[6889]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:09:54 desktop tlp[6889]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:09:54 desktop tlp[6889]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:09:54 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:55 desktop warp-svc[775]: 2022-05-19T08:09:55.033Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:09:56 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:56 desktop kded5[1786]:
May 19 16:09:56 desktop systemd[1667]: Started flameshot.
ββ
ββ
ββ The job identifier is 291.
May 19 16:09:58 desktop warp-svc[775]: 2022-05-19T08:09:58.348Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:09:58 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:09:58 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:09:59 desktop warp-svc[775]: 2022-05-19T08:09:59.358Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:09:59 desktop warp-svc[775]: 2022-05-19T08:09:59.358Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:09:59 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:09:59 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:00 desktop warp-svc[775]: 2022-05-19T08:10:00.367Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:10:04 desktop systemd[1667]: app-flameshot-ea03a16b614843fdabcb3129d92bf89a.scope: Consumed 1.256s CPU time.
ββ Subject: Resources consumed by unit runtime
ββ
ββ The unit UNIT completed and consumed the indicated resources.
May 19 16:10:07 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:11 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:13 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:14 desktop tlp[7035]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:10:14 desktop tlp[7035]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:10:14 desktop tlp[7035]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:10:14 desktop tlp[7035]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:10:15 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:16 desktop warp-svc[775]: 2022-05-19T08:10:16.695Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:10:16 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:10:17 desktop warp-svc[775]: 2022-05-19T08:10:17.698Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:10:18 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:20 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:22 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:24 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:26 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:27 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:28 desktop warp-svc[775]: 2022-05-19T08:10:28.215Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:10:28 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:10:29 desktop warp-svc[775]: 2022-05-19T08:10:29.224Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:10:29 desktop warp-svc[775]: 2022-05-19T08:10:29.224Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:10:29 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:10:29 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:30 desktop warp-svc[775]: 2022-05-19T08:10:30.232Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:10:31 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:32 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:34 desktop tlp[7130]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:10:34 desktop tlp[7130]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:10:34 desktop tlp[7130]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:10:34 desktop tlp[7130]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:10:38 desktop warp-svc[775]: 2022-05-19T08:10:38.881Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:10:38 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:10:39 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:39 desktop warp-svc[775]: 2022-05-19T08:10:39.884Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:10:41 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:44 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:45 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:47 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:49 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:53 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:54 desktop tlp[7212]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:10:54 desktop tlp[7212]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:10:54 desktop tlp[7212]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:10:54 desktop tlp[7212]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:10:55 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:56 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:56 desktop org_kde_powerdevil[1855]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
May 19 16:10:56 desktop dbus-daemon[769]: [system] Activating service name='org.kde.powerdevil.chargethresholdhelper' requested by ':1.22' (uid=1000 pid=1855 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
May 19 16:10:56 desktop dbus-daemon[769]: [system] Successfully activated service 'org.kde.powerdevil.chargethresholdhelper'
May 19 16:10:56 desktop org_kde_powerdevil[1855]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
May 19 16:10:57 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:10:59 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:01 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:03 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:05 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:07 desktop warp-svc[775]: 2022-05-19T08:11:07.895Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:11:07 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:11:08 desktop warp-svc[775]: 2022-05-19T08:11:08.905Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:11:09 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:09 desktop warp-svc[775]: 2022-05-19T08:11:09.601Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:11:09 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:11:10 desktop warp-svc[775]: 2022-05-19T08:11:10.611Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:11:10 desktop warp-svc[775]: 2022-05-19T08:11:10.611Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:11:10 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:11:11 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:11 desktop warp-svc[775]: 2022-05-19T08:11:11.613Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:11:13 desktop warp-svc[775]: 2022-05-19T08:11:13.015Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:11:13 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:11:13 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:14 desktop warp-svc[775]: 2022-05-19T08:11:14.024Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:11:14 desktop warp-svc[775]: 2022-05-19T08:11:14.024Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:11:14 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:11:14 desktop tlp[7333]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:11:14 desktop tlp[7333]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:11:14 desktop tlp[7333]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:11:14 desktop tlp[7333]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:11:15 desktop warp-svc[775]: 2022-05-19T08:11:15.027Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:11:15 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:15 desktop kwin_x11[1789]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62282, resource id: 10486668, major code: 3 (GetWindowAttributes), minor code: 0
May 19 16:11:15 desktop kwin_x11[1789]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 62283, resource id: 10486668, major code: 14 (GetGeometry), minor code: 0
May 19 16:11:17 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:18 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:23 desktop kwin_x11[1789]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2729, resource id: 102760459, major code: 18 (ChangeProperty), minor code: 0
May 19 16:11:24 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:26 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:28 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:32 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:34 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:34 desktop tlp[7419]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:11:34 desktop tlp[7419]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:11:34 desktop tlp[7419]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:11:34 desktop tlp[7419]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:11:38 desktop warp-svc[775]: 2022-05-19T08:11:38.401Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:11:38 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:11:39 desktop warp-svc[775]: 2022-05-19T08:11:39.408Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:11:39 desktop warp-svc[775]: 2022-05-19T08:11:39.408Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:11:39 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:11:40 desktop warp-svc[775]: 2022-05-19T08:11:40.413Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:11:45 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:50 desktop warp-svc[775]: 2022-05-19T08:11:50.561Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:11:50 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:11:51 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:11:51 desktop warp-svc[775]: 2022-05-19T08:11:51.569Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:11:53 desktop warp-svc[775]: 2022-05-19T08:11:53.975Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:11:53 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:11:54 desktop tlp[7503]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:11:54 desktop tlp[7503]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:11:54 desktop tlp[7503]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:11:54 desktop tlp[7503]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:11:54 desktop warp-svc[775]: 2022-05-19T08:11:54.979Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:11:59 desktop warp-svc[775]: 2022-05-19T08:11:59.308Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:11:59 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:12:00 desktop warp-svc[775]: 2022-05-19T08:12:00.318Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:12:00 desktop warp-svc[775]: 2022-05-19T08:12:00.318Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:12:00 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:12:01 desktop warp-svc[775]: 2022-05-19T08:12:01.327Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:12:05 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:06 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:14 desktop tlp[7622]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:12:14 desktop tlp[7622]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:12:14 desktop tlp[7622]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:12:14 desktop tlp[7622]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:12:17 desktop warp-svc[775]: 2022-05-19T08:12:17.868Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:12:17 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:12:18 desktop warp-svc[775]: 2022-05-19T08:12:18.877Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:12:18 desktop warp-svc[775]: 2022-05-19T08:12:18.877Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:12:18 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:12:19 desktop warp-svc[775]: 2022-05-19T08:12:19.880Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:12:22 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:24 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:25 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:27 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:29 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:30 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:34 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:34 desktop tlp[7706]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:12:34 desktop tlp[7706]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:12:34 desktop tlp[7706]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:12:34 desktop tlp[7706]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:12:38 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:40 desktop warp-svc[775]: 2022-05-19T08:12:40.055Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:12:40 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:12:41 desktop warp-svc[775]: 2022-05-19T08:12:41.064Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:12:42 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:44 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:46 desktop warp-svc[775]: 2022-05-19T08:12:46.668Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:12:46 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:12:47 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:47 desktop warp-svc[775]: 2022-05-19T08:12:47.676Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:12:47 desktop warp-svc[775]: 2022-05-19T08:12:47.677Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:12:47 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:12:48 desktop warp-svc[775]: 2022-05-19T08:12:48.686Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:12:51 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:53 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:54 desktop tlp[7794]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:12:54 desktop tlp[7794]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:12:54 desktop tlp[7794]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:12:54 desktop tlp[7794]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:12:58 desktop warp-svc[775]: 2022-05-19T08:12:58.828Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:12:58 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:12:59 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:12:59 desktop warp-svc[775]: 2022-05-19T08:12:59.832Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:13:03 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:08 desktop warp-svc[775]: 2022-05-19T08:13:08.428Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:13:08 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:13:09 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:09 desktop warp-svc[775]: 2022-05-19T08:13:09.436Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:13:09 desktop warp-svc[775]: 2022-05-19T08:13:09.436Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:13:09 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:13:10 desktop warp-svc[775]: 2022-05-19T08:13:10.445Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:13:11 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:13 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:14 desktop tlp[7928]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:13:14 desktop tlp[7928]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:13:14 desktop tlp[7928]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:13:14 desktop tlp[7928]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:13:15 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:23 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:24 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:24 desktop warp-svc[775]: 2022-05-19T08:13:24.641Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:13:24 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:13:25 desktop warp-svc[775]: 2022-05-19T08:13:25.648Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:13:25 desktop warp-svc[775]: 2022-05-19T08:13:25.648Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:13:25 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:13:26 desktop warp-svc[775]: 2022-05-19T08:13:26.657Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:13:31 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:33 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:34 desktop tlp[8016]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:13:34 desktop tlp[8016]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:13:34 desktop tlp[8016]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:13:34 desktop tlp[8016]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:13:35 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:43 desktop warp-svc[775]: 2022-05-19T08:13:43.201Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:13:43 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:13:44 desktop warp-svc[775]: 2022-05-19T08:13:44.208Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:13:45 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:46 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:48 desktop warp-svc[775]: 2022-05-19T08:13:48.321Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:13:48 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:13:48 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:49 desktop warp-svc[775]: 2022-05-19T08:13:49.324Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:13:49 desktop warp-svc[775]: 2022-05-19T08:13:49.324Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:13:49 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:13:49 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:13:50 desktop warp-svc[775]: 2022-05-19T08:13:50.326Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:13:50 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:52 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:54 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:54 desktop tlp[8182]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:13:54 desktop tlp[8182]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:13:54 desktop tlp[8182]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:13:54 desktop tlp[8182]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:13:56 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:57 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:13:59 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:00 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:02 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:05 desktop warp-svc[775]: 2022-05-19T08:14:05.391Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:14:05 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:14:06 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:06 desktop warp-svc[775]: 2022-05-19T08:14:06.400Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:14:07 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:11 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:14 desktop tlp[8275]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:14:14 desktop tlp[8275]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:14:14 desktop tlp[8275]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:14:14 desktop tlp[8275]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:14:25 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:27 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:29 desktop warp-svc[775]: 2022-05-19T08:14:29.281Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:14:29 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:14:30 desktop warp-svc[775]: 2022-05-19T08:14:30.291Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:14:31 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:34 desktop warp-svc[775]: 2022-05-19T08:14:34.401Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:14:34 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:14:34 desktop tlp[8356]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:14:34 desktop tlp[8356]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:14:34 desktop tlp[8356]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:14:34 desktop tlp[8356]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:14:35 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:35 desktop warp-svc[775]: 2022-05-19T08:14:35.411Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:14:35 desktop warp-svc[775]: 2022-05-19T08:14:35.411Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:14:35 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:14:36 desktop warp-svc[775]: 2022-05-19T08:14:36.420Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:14:36 desktop warp-svc[775]: 2022-05-19T08:14:36.748Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:14:36 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:14:37 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:37 desktop warp-svc[775]: 2022-05-19T08:14:37.757Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:14:37 desktop warp-svc[775]: 2022-05-19T08:14:37.757Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:14:37 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:14:38 desktop warp-svc[775]: 2022-05-19T08:14:38.764Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:14:38 desktop warp-svc[775]: 2022-05-19T08:14:38.764Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:14:38 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:14:39 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:39 desktop warp-svc[775]: 2022-05-19T08:14:39.772Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:14:41 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:49 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:50 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:51 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:52 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:54 desktop tlp[8445]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:14:54 desktop tlp[8445]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:14:54 desktop tlp[8445]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:14:54 desktop tlp[8445]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:14:58 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:14:59 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:00 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:01 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:06 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:07 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:08 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:09 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:11 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:12 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:13 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:14 desktop tlp[8555]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:15:14 desktop tlp[8555]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:15:14 desktop tlp[8555]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:15:14 desktop tlp[8555]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:15:15 desktop warp-svc[775]: 2022-05-19T08:15:15.361Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:15:15 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:15:16 desktop warp-svc[775]: 2022-05-19T08:15:16.371Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:15:16 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:17 desktop warp-svc[775]: 2022-05-19T08:15:17.071Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:15:17 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:15:17 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:18 desktop warp-svc[775]: 2022-05-19T08:15:18.079Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:15:18 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:18 desktop warp-svc[775]: 2022-05-19T08:15:18.775Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:15:18 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:15:19 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:19 desktop warp-svc[775]: 2022-05-19T08:15:19.784Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:15:20 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:20 desktop warp-svc[775]: 2022-05-19T08:15:20.695Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:15:20 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:15:21 desktop warp-svc[775]: 2022-05-19T08:15:21.704Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:15:21 desktop warp-svc[775]: 2022-05-19T08:15:21.704Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:15:21 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:15:22 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:22 desktop warp-svc[775]: 2022-05-19T08:15:22.712Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:15:25 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:27 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:28 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:29 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:30 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:31 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:32 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:34 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:34 desktop tlp[8645]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:15:34 desktop tlp[8645]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:15:34 desktop tlp[8645]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:15:34 desktop tlp[8645]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:15:35 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:36 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:38 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:39 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:40 desktop kwin_x11[1789]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7944, resource id: 10527691, major code: 3 (GetWindowAttributes), minor code: 0
May 19 16:15:40 desktop kwin_x11[1789]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 7945, resource id: 10527691, major code: 14 (GetGeometry), minor code: 0
May 19 16:15:41 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:42 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:44 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:45 desktop warp-svc[775]: 2022-05-19T08:15:45.015Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:15:45 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:15:45 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:46 desktop warp-svc[775]: 2022-05-19T08:15:46.019Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:15:46 desktop warp-svc[775]: 2022-05-19T08:15:46.019Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:15:46 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:15:47 desktop warp-svc[775]: 2022-05-19T08:15:47.028Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:15:48 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:49 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:50 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:51 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:52 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:53 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:15:54 desktop tlp[8760]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:15:54 desktop tlp[8760]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:15:54 desktop tlp[8760]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:15:54 desktop tlp[8760]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:15:56 desktop warp-svc[775]: 2022-05-19T08:15:56.321Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:15:56 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:15:57 desktop warp-svc[775]: 2022-05-19T08:15:57.331Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:15:57 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:01 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:02 desktop warp-svc[775]: 2022-05-19T08:16:02.295Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:16:02 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:16:02 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:03 desktop warp-svc[775]: 2022-05-19T08:16:03.304Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:16:03 desktop warp-svc[775]: 2022-05-19T08:16:03.304Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:16:03 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:16:03 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:04 desktop warp-svc[775]: 2022-05-19T08:16:04.313Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:16:05 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:07 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:08 desktop warp-svc[775]: 2022-05-19T08:16:08.268Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:16:08 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:16:08 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:09 desktop warp-svc[775]: 2022-05-19T08:16:09.276Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:16:09 desktop warp-svc[775]: 2022-05-19T08:16:09.277Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:16:09 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:16:10 desktop warp-svc[775]: 2022-05-19T08:16:10.286Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:16:11 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:12 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:13 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:14 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:14 desktop tlp[8848]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:16:14 desktop tlp[8848]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:16:14 desktop tlp[8848]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:16:14 desktop tlp[8848]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:16:15 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:16 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:17 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:18 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:20 desktop warp-svc[775]: 2022-05-19T08:16:20.215Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:16:20 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:16:20 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:21 desktop warp-svc[775]: 2022-05-19T08:16:21.217Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:16:22 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:23 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:27 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:28 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:31 desktop rtkit-daemon[2795]: Supervising 4 threads of 4 processes of 1 users.
May 19 16:16:32 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:34 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:34 desktop tlp[9001]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:16:34 desktop tlp[9001]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:16:34 desktop tlp[9001]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:16:34 desktop tlp[9001]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:16:36 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:37 desktop warp-svc[775]: 2022-05-19T08:16:37.281Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:16:37 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:16:37 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:38 desktop warp-svc[775]: 2022-05-19T08:16:38.286Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:16:39 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:40 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:42 desktop warp-svc[775]: 2022-05-19T08:16:42.401Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:16:42 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:16:43 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:43 desktop warp-svc[775]: 2022-05-19T08:16:43.407Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:16:43 desktop warp-svc[775]: 2022-05-19T08:16:43.407Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:16:43 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:16:44 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:44 desktop warp-svc[775]: 2022-05-19T08:16:44.416Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:16:46 desktop warp-svc[775]: 2022-05-19T08:16:46.668Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:16:46 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:16:47 desktop warp-svc[775]: 2022-05-19T08:16:47.677Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:16:47 desktop warp-svc[775]: 2022-05-19T08:16:47.677Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:16:47 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:16:48 desktop warp-svc[775]: 2022-05-19T08:16:48.685Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:16:50 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:52 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:54 desktop tlp[9092]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:16:54 desktop tlp[9092]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:16:54 desktop tlp[9092]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:16:54 desktop tlp[9092]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:16:56 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:16:58 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:00 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:02 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:03 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:04 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:06 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:09 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:10 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:13 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:14 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:14 desktop tlp[9203]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:17:14 desktop tlp[9203]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:17:14 desktop tlp[9203]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:17:14 desktop tlp[9203]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:17:16 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:17 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:18 desktop warp-svc[775]: 2022-05-19T08:17:18.241Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:17:18 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:17:18 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:19 desktop warp-svc[775]: 2022-05-19T08:17:19.249Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:17:19 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:21 desktop warp-svc[775]: 2022-05-19T08:17:21.655Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:17:21 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:17:22 desktop warp-svc[775]: 2022-05-19T08:17:22.662Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:17:23 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:24 desktop warp-svc[775]: 2022-05-19T08:17:24.641Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:17:24 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:17:25 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:25 desktop warp-svc[775]: 2022-05-19T08:17:25.650Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:17:25 desktop warp-svc[775]: 2022-05-19T08:17:25.650Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:17:25 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:17:26 desktop warp-svc[775]: 2022-05-19T08:17:26.659Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:17:27 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:27 desktop warp-svc[775]: 2022-05-19T08:17:27.415Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:17:27 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:17:28 desktop warp-svc[775]: 2022-05-19T08:17:28.424Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:17:28 desktop warp-svc[775]: 2022-05-19T08:17:28.424Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:17:28 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:17:29 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:29 desktop warp-svc[775]: 2022-05-19T08:17:29.433Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:17:30 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:31 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:32 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:33 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:34 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:34 desktop tlp[9294]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:17:34 desktop tlp[9294]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:17:34 desktop tlp[9294]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:17:34 desktop tlp[9294]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:17:35 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:37 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:38 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:38 desktop warp-svc[775]: 2022-05-19T08:17:38.721Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:17:38 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:17:39 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:39 desktop warp-svc[775]: 2022-05-19T08:17:39.730Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:17:39 desktop warp-svc[775]: 2022-05-19T08:17:39.730Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:17:39 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:17:40 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:40 desktop warp-svc[775]: 2022-05-19T08:17:40.739Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:17:42 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:43 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:44 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:45 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:45 desktop systemd[1]: Starting Cleanup of Temporary Directories...
ββ Subject: A start job for unit systemd-tmpfiles-clean.service has begun execution
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ
ββ A start job for unit systemd-tmpfiles-clean.service has begun execution.
ββ
ββ The job identifier is 2102.
May 19 16:17:45 desktop systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
ββ Subject: Unit succeeded
ββ
ββ The unit systemd-tmpfiles-clean.service has successfully entered the 'dead' state.
May 19 16:17:45 desktop systemd[1]: Finished Cleanup of Temporary Directories.
ββ Subject: A start job for unit systemd-tmpfiles-clean.service has finished successfully
ββ
ββ A start job for unit systemd-tmpfiles-clean.service has finished successfully.
ββ
May 19 16:17:45 desktop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 19 16:17:45 desktop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 19 16:17:45 desktop kernel: audit: type=1130 audit(1652948265.474:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 19 16:17:45 desktop kernel: audit: type=1131 audit(1652948265.474:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 19 16:17:46 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:47 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:49 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:50 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:51 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:52 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:53 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:54 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:54 desktop tlp[9379]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:17:54 desktop tlp[9379]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:17:54 desktop tlp[9379]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:17:54 desktop tlp[9379]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:17:56 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:58 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:17:59 desktop warp-svc[775]: 2022-05-19T08:17:59.201Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:17:59 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:18:00 desktop warp-svc[775]: 2022-05-19T08:18:00.209Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:18:00 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:01 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:02 desktop warp-svc[775]: 2022-05-19T08:18:02.615Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:18:02 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:18:03 desktop warp-svc[775]: 2022-05-19T08:18:03.624Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:18:04 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:05 desktop warp-svc[775]: 2022-05-19T08:18:05.815Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:18:05 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.1;
May 19 16:18:06 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:06 desktop warp-svc[775]: 2022-05-19T08:18:06.824Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:18:07 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:10 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:12 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:12 desktop warp-svc[775]: 2022-05-19T08:18:12.855Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:18:12 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.14;
May 19 16:18:13 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:13 desktop warp-svc[775]: 2022-05-19T08:18:13.864Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:18:14 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:14 desktop tlp[9498]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:18:14 desktop tlp[9498]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:18:14 desktop tlp[9498]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:18:14 desktop tlp[9498]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
May 19 16:18:15 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:19 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:20 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:22 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:24 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:25 desktop warp-svc[775]: 2022-05-19T08:18:25.441Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:18:25 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:18:26 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:26 desktop warp-svc[775]: 2022-05-19T08:18:26.450Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:18:26 desktop warp-svc[775]: 2022-05-19T08:18:26.450Z DEBUG main_loop: warp::warp_service: Routes changed:
May 19 16:18:26 desktop warp-svc[775]: NewNeighbour; Destination: 192.168.0.4;
May 19 16:18:27 desktop warp-svc[775]: 2022-05-19T08:18:27.459Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="route_change"
May 19 16:18:28 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:29 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:31 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:32 desktop kioslave5[9629]: Qt: Session management error: networkIdsList argument is NULL
May 19 16:18:33 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:34 desktop plasmashell[1853]: qml: temp unit: 0
May 19 16:18:34 desktop tlp[9657]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
May 19 16:18:34 desktop tlp[9657]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
May 19 16:18:34 desktop tlp[9657]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
May 19 16:18:34 desktop tlp[9657]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Any ideas on what might cause this are appreciated, thank.
