I want to install the Biktorgj’s firmware but I am afraid of making some mistake.
From what I found online this seems the best explaining way:
sudo pacman -S fastboot adb
wget https://github.com/Biktorgj/pinephone_modem_sdk/releases/download/0.4.2/package.tar.gz
# any other temporary directory name/place will do below
mkdir firmware
tar xvzf package.tar.gz -C firmware
cd firmware
sudo ./flashall
# took less than 30 seconds: last lines output was: "Finished, if everything went well, run fastboot reboot to restart the modem."
# Do not reboot the modem before flashing the recommended DSP upgrade though)
wget https://github.com/Biktorgj/quectel_eg25_recovery/raw/EG25GGBR07A08M2G_01.003.01.003/update/NON-HLOS.ubi
# you only need to flash the newer DSP blob once, not on every future upgrade...
sudo fastboot flash modem NON-HLOS.ubi
fastboot reboot
source: Flashing the FOSS modem firmware on the Pinephone | Spaetzblog
(I updated the things that were outdated)
How safe is this tutorial?
