Hi,
I have a problem with icons in quick menu after Gnome upgrade. I used Loginized to change wallpaper on log screen. After restarting, I have these big white icons in quick menu:
Thanks for help.
Hi,
Thanks for help.
Try to run the following
sudo pacman -S manjaro-gnome-settings manjaro-settings-manager
In my case, there was an old gdm package which is in the conflict with recent gnome packages
I appreciate your effort to help. But unfortunately, it doesnt work in my case.
Thank you for the tip, that solved it for me ![]()
The issue was using an incompatible theme months ago with the launch of GNOME 42. We’re almost two versions behind that now.
Please do not necrobump.
