Biber and biblatex versions are incompatible
I recently updated my system and now I can’t compile latex documents anymore.
enddocument/afterlastpage: lastpage setting LastPage.
(./document.aux) ) )</usr/share/texmf-dist/fonts/type1/urw/helvetic/uhvb8a.
pfb></usr/share/texmf-dist/fonts/type1/urw/helvetic/uhvr8a.pfb>
Output written on document.pdf (3 pages, 148140 bytes).
Transcript written on document.log.
INFO - This is Biber 2.19
INFO - Logfile is 'document.blg'
INFO - Reading 'document.bcf'
ERROR - Error: Found biblatex control file version 3.8, expected version 3.10.
This means that your biber (2.19) and biblatex (3.17) versions are incompatible.
See compat matrix in biblatex or biber PDF documentation.
INFO - ERRORS: 1
When I search for biblatex, I end up with biber as a result. So this is confusing to me. Where am I going wrong?
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Remove the intermediate files like aux and probably bbl, bcf, and basically everything exept the tex file.
It seems you created the bbl with the old biblatex version which is now not supported by the new biber version.
Ahhh that was it!! From the error output I assumed it was two software versions on my system that were incompatible!
So you do seem to know everything :wink:
Thanks for the help!
