*Hi, first, thank you for your work, your project is really appreciated to get a… good alternative to proprietary streaming solutions. Secondly, all my apologizes if I'm wrong, I've read all issues concerning similar problem, but I'm not really sure if it's really the same problem or not, that's way, I've opened a new issue. Third, as the problem seems to be the same when using as source or using as sink, so I've decided to post both into the same issue because I believe that they are related.*
## Devices Specifications
### Laptop
**OS:** Arch Linux x86_64
**Host:** XPS 13 9380
**Kernel:** 5.12.4-arch1-2
**Shell:** bash 5.1.8
**WM:** i3
**DE:** None
**Terminal:** urxvt
**CPU:** Intel i7-8565U (8) @ 4.600GHz
**GPU:** Intel UHD Graphics 620
**Memory:** 2258MiB / 15650MiB
**MAC Address:** 9c:b6:d0:97:ea:78
**IPv4 Address:** 192.168.50.1
**MiracleCast version:** *Installed successfully with AUR* miraclecast-git 221.36be37e-2 (+51 0.30)
### TV
**Manufacturer:** Samsung
**Type:** Smart TV and Miracast reciever capable
**Serie:** 5
**Model:** UN50M5300AF
**Version No:** DA01
**MAC Address:** 66:1c:b0:89:a7:6b
**IPv4 Address:** 192.168.50.100
### Phone
**Type:** Android
**Version:** 9 *Modified - /e/ OS (Lineage OS based)*
**Manufacturer:** Fairphone
**Model:** 3
**MAC Address:** 86:cf:bf:8f:bd:f7
**Misc:** Has already a native implementation of WFD working out of the box
## Test capabilities results
### test-hardware-capabilities
`wlan0 supports P2P`
### test-viewer
testing plugins required:
test udpsrc... (passed)
test rtpjitterbuffer... (passed)
test rtpmp2tdepay... (passed)
test tsdemux... (passed)
test h264parse... (passed)
test avdec_h264... (passed)
test autovideosink... (passed)
everything installed
## Description
### Laptop as source with TV as sink
I stop services, `NetworkManager`, `wpa_supplicant`, I disable firewall, `ufw`, try to kill existing WPA Supplicant instances that could be left.
I start `miracle-wifid` in a shell, I start `miracle-wifictl` in another shell, I select a link, set a friendly name to that link, I scan to find the MAC Address of my TV, it finds it, and I try to connect to it.
Until here, everything seems working well, my TV asks me to allow the connection, I press allow, and my TV advises me that it's connected, but on the other side, I can see in `miracle-wifictl` it's not connected, rarely, an error occurs: `[FAIL] Peer: 66:1c:b0:89:a7:6b@2 Reason: group owner negotiation failed`, but really rarely, and usually, it just notifies nothing, no success, no fail, if I list, it's not connected but it's like nothing went wrong, like I didn't try to connect, if I'm waiting for it fails to get an error occured, nothing will come, it will stays like this.
My knowledge about that protocol is pretty low, but as I can read into the output of `miracle-wifid`, I notice `CTRL-EVENT-EAP-FAILURE 66:1c:b0:89:a7:6b` just before `dhcpd` acts, and in the `journalctl`, I notice another problem with `dhcpd` this time, that I don't really know if it's impacting the connection attempt: `dhcpcd[574]: p2p-wlan0-0: IAID conflicts with one assigned to wlan0`.
Otherwise, there is not really some informations that could let me think something went wrong.
If I try to stream something to it throught `gstreamer`, `ffmpeg` or `cvlc` with the right protocol (rtp) onto the right port (19000), nothing happens. (I've checked protocol and port with a packet capture app onto my phone as it works properly with it)
When I quit everything, in the right way of course, at the end, my TV advises me my laptop is disconnected, so it was still connected to it..
As I'm not really sure, above, you will find both `miracle-*` commands logs run with `--log-level trace`, the `journalctl` log, and in case that it would be related, my `dhcpd.conf`.
#### group owner negociation fail case
<details><summary>miracle-wifid output</summary>
INFO: miracle-wifid - revision 1.0 May 31 2021 03:06:20
DEBUG: friendly-name from local hostname: acomputer (manager_read_name() in wifid.c:389)
DEBUG: link: new link: wlan0 (2) (link_new() in wifid-link.c:71)
DEBUG: supplicant: new supplicant for wlan0 (supplicant_new() in wifid-supplicant.c:2102)
INFO: link: add link: wlan0
INFO: link: manage link wlan0
DEBUG: supplicant: start supplicant of wlan0 (supplicant_start() in wifid-supplicant.c:2636)
DEBUG: supplicant: spawn supplicant of wlan0 (supplicant_spawn() in wifid-supplicant.c:2482)
INFO: supplicant: wpa_supplicant found: /usr/bin/wpa_supplicant
INFO: supplicant: wpas spawned as pid:3396
DEBUG: supplicant: open supplicant of wlan0 (supplicant_open() in wifid-supplicant.c:2268)
TRACE: wpa: raw message: OK
TRACE: wpa: raw message: p2p_device_address=9c:b6:d0:97:ea:78
p2p_state=IDLE
wifi_display=1
ifname=p2p-dev-wlan0
ifname=wlan0
DEBUG: supplicant: local p2p-address is: 9c:b6:d0:97:ea:78 (supplicant_status_fn() in wifid-supplicant.c:1822)
TRACE: wpa: raw message: FAIL
DEBUG: supplicant: send 'SET device_name acomputer' to wpas on wlan0 (supplicant_set_friendly_name() in wifid-supplicant.c:1950)
DEBUG: supplicant: sent P2P_FIND to wpas on wlan0 (supplicant_p2p_start_scan() in wifid-supplicant.c:2035)
DEBUG: supplicant: p2p-scanning now active on wlan0 (supplicant_p2p_find_fn() in wifid-supplicant.c:1916)
TRACE: wpa: raw message: IFNAME=p2p-dev-wlan0 <3>CTRL-EVENT-SCAN-STARTED
TRACE: wpa: raw message: <3>CTRL-EVENT-SCAN-STARTED
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
TRACE: wpa: raw message: <3>P2P-DEVICE-FOUND 66:1c:b0:89:a7:6b p2p_dev_addr=66:1c:b0:89:a7:6b pri_dev_type=7-0050F204-1 name='[TV] Samsung 5' config_methods=0x188 dev_capab=0x21 group_capab=0x0 wfd_dev_info=0x01131c440036 vendor_elems=1 new=1
DEBUG: peer: new peer: 66:1c:b0:89:a7:6b @ wlan0 (peer_new() in wifid-peer.c:52)
INFO: peer: add peer: 66:1c:b0:89:a7:6b
DEBUG: peer: peer 66:1c:b0:89:a7:6b @ wlan0 started (peer_supplicant_started() in wifid-peer.c:162)
DEBUG: supplicant: requesting data for new peer 66:1c:b0:89:a7:6b (supplicant_event_p2p_device_found() in wifid-supplicant.c:962)
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 0 a0:8e:78:ed:d9:df
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 1 a0:8e:78:ed:d9:dd
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 2 a6:8e:78:ed:d9:dd
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 3 84:1b:5e:3b:6d:ef
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 4 1c:5f:2b:fa:37:c2
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 5 b8:ec:a3:d3:21:59
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 6 3c:17:10:1f:99:d5
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 7 26:17:10:1f:99:d5
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 8 3c:17:10:1f:99:d7
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 9 a0:8e:78:ed:d9:de
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 10 3c:17:10:1f:99:d6
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 11 3c:17:10:21:43:6e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 12 18:d6:c7:a6:f0:14
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 13 c0:c9:e3:8c:03:0e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 14 86:1b:5e:3b:6d:ef
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 15 84:1b:5e:3b:6d:ee
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 16 1c:5f:2b:fa:37:c0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 17 b8:ec:a3:d3:21:58
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 18 a0:ff:70:d8:b8:0a
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 19 a0:ff:70:d8:b8:0e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 20 a0:ff:70:d8:b8:09
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 21 e6:bf:fa:7b:7e:51
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 22 e4:bf:fa:7a:7e:54
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 23 4e:84:6a:a9:c3:a0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 24 74:da:88:85:bc:a8
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 25 e6:bf:fa:7b:7e:55
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 26 fa:5e:42:56:1c:38
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 27 f8:5e:42:4e:1c:3b
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 28 62:45:b6:6d:25:05
TRACE: wpa: raw message: 66:1c:b0:89:a7:6b
device_name=[TV] Samsung 5
manufacturer=SAMSUNG_ELECTRONICS
model_name=
model_number=
serial_number=
dev_capab=0x21
group_capab=0x0
level=-48
age=5
listen_freq=2412
wps_method=not-ready
interface_addr=00:00:00:00:00:00
member_in_go_dev=00:00:00:00:00:00
member_in_go_iface=00:00:00:00:00:00
go_neg_req_sent=0
go_state=unknown
dialog_token=0
intended_addr=00:00:00:00:00:00
country=__
oper_freq=0
req_config_methods=0x0
flags=[REPORTED]
status=0
invitation_reqs=0
wfd_subelems=00000601131c440036
vendor_elems=dd080000f00c00000101dd080000f00f00020601
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 29 a0:ff:70:d8:b8:0c
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 30 fa:5e:42:4f:1c:3f
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 31 3c:17:10:25:70:b6
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 32 fa:5e:42:4f:1c:3d
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 33 3e:17:10:25:71:b7
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 34 44:e9:dd:4d:89:6a
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 35 b8:ec:a3:37:9a:b0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 36 44:ad:b1:64:1d:0e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 37 00:23:cd:20:a3:aa
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 38 40:f2:01:ec:fd:43
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 39 34:49:5b:22:e0:fe
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 40 3c:17:10:23:af:e6
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 41 e6:bf:fa:7b:7e:57
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 42 3c:84:6a:a9:c3:a0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 43 44:ad:b1:63:33:3e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 44 60:31:97:fc:b1:80
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 45 f8:5e:42:4e:1c:3a
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 46 a0:8e:78:f1:ec:3e
DEBUG: supplicant: sent P2P_STOP_FIND to wpas on wlan0 (supplicant_p2p_stop_scan() in wifid-supplicant.c:2069)
TRACE: wpa: raw message: <3>P2P-FIND-STOPPED
DEBUG: supplicant: p2p-scanning stopped on wlan0 (supplicant_event_p2p_find_stopped() in wifid-supplicant.c:904)
DEBUG: supplicant: connect to 66:1c:b0:89:a7:6b via pbc/(null) (supplicant_peer_connect() in wifid-supplicant.c:739)
TRACE: wpa: raw message: <3>P2P-GO-NEG-FAILURE status=-1
DEBUG: supplicant: peer [TV] Samsung 5 group owner negotiation failed (supplicant_event_p2p_go_neg_failure() in wifid-supplicant.c:1301)
TRACE: wpa: raw message: <3>P2P-DEVICE-LOST p2p_dev_addr=66:1c:b0:89:a7:6b
DEBUG: supplicant: lost peer 66:1c:b0:89:a7:6b (supplicant_event_p2p_device_lost() in wifid-supplicant.c:986)
DEBUG: peer: peer 66:1c:b0:89:a7:6b @ wlan0 stopped (peer_supplicant_stopped() in wifid-peer.c:172)
DEBUG: peer: free peer: 66:1c:b0:89:a7:6b @ wlan0 (peer_free() in wifid-peer.c:90)
INFO: peer: remove peer: 66:1c:b0:89:a7:6b
</details>
<details><summary>miracle-wifictl output</summary>
[miraclectl] #
[ADD] Link: 2
[miraclectl] # select 2
link 2 selected
[miraclectl] # set-friendly-name 2 acomputer
[miraclectl] # p2p-scan
[miraclectl] #
[ADD] Peer: 66:1c:b0:89:a7:6b@2
[miraclectl] # p2p-scan stop
[miraclectl] # list
LINK INTERFACE FRIENDLY-NAME MANAGED
2 wlan0 acomputer yes
LINK PEER-ID FRIENDLY-NAME CONNECTED
2 66:1c:b0:89:a7:6b@2 [TV] Samsung 5 no
1 peers and 1 links listed.
[miraclectl] # show 66:1c:b0:89:a7:6b@2
Peer=66:1c:b0:89:a7:6b@2
P2PMac=66:1c:b0:89:a7:6b
FriendlyName=[TV] Samsung 5
Connected=0
WfdSubelements=00000601131c440036
[miraclectl] # connect 66:1c:b0:89:a7:6b@2
[miraclectl] #
[miraclectl] #
[REMOVE] Peer: 66:1c:b0:89:a7:6b@2
[miraclectl] # exit
[miraclectl] #
[miraclectl] #
link 2 deselected
</details>
<details><summary>journalctl output</summary>
-- Journal begins at Fri 2021-02-05 09:33:16 EST. --
jun 02 14:42:49 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.61' (uid=0 pid=3387 comm="sudo journalctl -f ")
jun 02 14:42:49 acomputer kernel: audit: type=1101 audit(1622659369.775:350): pid=3387 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:42:49 acomputer kernel: audit: type=1110 audit(1622659369.775:351): pid=3387 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:42:49 acomputer kernel: audit: type=1105 audit(1622659369.778:352): pid=3387 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:42:49 acomputer audit[3387]: USER_ACCT pid=3387 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:42:49 acomputer audit[3387]: CRED_REFR pid=3387 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:42:49 acomputer audit[3387]: USER_START pid=3387 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:42:49 acomputer dbus-daemon[567]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:42:49 acomputer sudo[3387]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:42:49 acomputer sudo[3387]: nico : TTY=pts/0 ; PWD=/home/nico ; USER=root ; COMMAND=/usr/bin/journalctl -f
jun 02 14:42:49 acomputer sudo[3387]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
jun 02 14:42:56 acomputer audit[3391]: USER_AUTH pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:42:56 acomputer kernel: audit: type=1100 audit(1622659376.451:353): pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:42:56 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.62' (uid=0 pid=3391 comm="sudo miracle-wifid --log-level trace ")
jun 02 14:42:56 acomputer dbus-daemon[567]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:42:56 acomputer sudo[3391]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:42:56 acomputer audit[3391]: USER_ACCT pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:42:56 acomputer sudo[3391]: nico : TTY=pts/1 ; PWD=/home/nico ; USER=root ; COMMAND=/usr/bin/miracle-wifid --log-level trace
jun 02 14:42:56 acomputer audit[3391]: CRED_REFR pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:42:56 acomputer kernel: audit: type=1101 audit(1622659376.454:354): pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:42:56 acomputer kernel: audit: type=1110 audit(1622659376.454:355): pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:42:56 acomputer kernel: audit: type=1105 audit(1622659376.457:356): pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:42:56 acomputer audit[3391]: USER_START pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:42:56 acomputer sudo[3391]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
jun 02 14:42:56 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.63' (uid=0 pid=3394 comm="miracle-wifid --log-level trace ")
jun 02 14:42:56 acomputer audit: BPF prog-id=31 op=LOAD
jun 02 14:42:56 acomputer audit: BPF prog-id=32 op=LOAD
jun 02 14:42:56 acomputer audit: BPF prog-id=33 op=LOAD
jun 02 14:42:56 acomputer kernel: audit: type=1334 audit(1622659376.494:357): prog-id=31 op=LOAD
jun 02 14:42:56 acomputer kernel: audit: type=1334 audit(1622659376.494:358): prog-id=32 op=LOAD
jun 02 14:42:56 acomputer kernel: audit: type=1334 audit(1622659376.494:359): prog-id=33 op=LOAD
jun 02 14:42:56 acomputer systemd[1]: Starting Hostname Service...
jun 02 14:42:56 acomputer dbus-daemon[567]: [system] Successfully activated service 'org.freedesktop.hostname1'
jun 02 14:42:56 acomputer systemd[1]: Started Hostname Service.
jun 02 14:42:56 acomputer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:42:56 acomputer kernel: audit: type=1130 audit(1622659376.564:360): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:42:56 acomputer miracle-wifid-wlan0-2[3396]: Successfully initialized wpa_supplicant
jun 02 14:43:02 acomputer audit[3399]: USER_AUTH pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:43:02 acomputer kernel: audit: type=1100 audit(1622659382.883:361): pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:43:02 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.65' (uid=0 pid=3399 comm="sudo miracle-wifictl --log-level trace ")
jun 02 14:43:02 acomputer dbus-daemon[567]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:43:02 acomputer audit[3399]: USER_ACCT pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:43:02 acomputer audit[3399]: CRED_REFR pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:43:02 acomputer sudo[3399]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:43:02 acomputer sudo[3399]: nico : TTY=pts/2 ; PWD=/home/nico ; USER=root ; COMMAND=/usr/bin/miracle-wifictl --log-level trace
jun 02 14:43:02 acomputer kernel: audit: type=1101 audit(1622659382.886:362): pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:43:02 acomputer kernel: audit: type=1110 audit(1622659382.886:363): pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:43:02 acomputer kernel: audit: type=1105 audit(1622659382.890:364): pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:43:02 acomputer audit[3399]: USER_START pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:43:02 acomputer sudo[3399]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
jun 02 14:43:26 acomputer systemd[1]: systemd-hostnamed.service: Deactivated successfully.
jun 02 14:43:26 acomputer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:43:26 acomputer kernel: audit: type=1131 audit(1622659406.597:365): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:43:26 acomputer audit: BPF prog-id=33 op=UNLOAD
jun 02 14:43:26 acomputer audit: BPF prog-id=32 op=UNLOAD
jun 02 14:43:26 acomputer audit: BPF prog-id=31 op=UNLOAD
jun 02 14:43:26 acomputer kernel: audit: type=1334 audit(1622659406.770:366): prog-id=33 op=UNLOAD
jun 02 14:43:26 acomputer kernel: audit: type=1334 audit(1622659406.770:367): prog-id=32 op=UNLOAD
jun 02 14:43:26 acomputer kernel: audit: type=1334 audit(1622659406.770:368): prog-id=31 op=UNLOAD
jun 02 14:43:30 acomputer miracle-wifid-wlan0-2[3396]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
jun 02 14:43:33 acomputer miracle-wifid-wlan0-2[3396]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
jun 02 14:43:34 acomputer miracle-wifid-wlan0-2[3396]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
jun 02 14:43:34 acomputer miracle-wifid-wlan0-2[3396]: P2P-DEVICE-FOUND 66:1c:b0:89:a7:6b p2p_dev_addr=66:1c:b0:89:a7:6b pri_dev_type=7-0050F204-1 name='[TV] Samsung 5' config_methods=0x188 dev_capab=0x21 group_capab=0x0 wfd_dev_info=0x01131c440036 vendor_elems=1 new=1
jun 02 14:43:37 acomputer miracle-wifid-wlan0-2[3396]: P2P-FIND-STOPPED
jun 02 14:44:04 acomputer systemd-udevd[3452]: Using default interface naming scheme 'v247'.
jun 02 14:44:04 acomputer systemd-udevd[3452]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
jun 02 14:44:04 acomputer dhcpcd[574]: p2p-wlan0-0: waiting for carrier
jun 02 14:44:04 acomputer dhcpcd[574]: p2p-wlan0-0: carrier acquired
jun 02 14:44:04 acomputer dhcpcd[574]: p2p-wlan0-0: IAID d0:97:ea:67
jun 02 14:44:04 acomputer dhcpcd[574]: p2p-wlan0-0: IAID conflicts with one assigned to wlan0
jun 02 14:44:04 acomputer dhcpcd[574]: p2p-wlan0-0: adding address fe80::3c63:9527:8bc8:3a0d
jun 02 14:44:04 acomputer dhcpcd[574]: p2p-wlan0-0: carrier lost
jun 02 14:44:04 acomputer dhcpcd[574]: p2p-wlan0-0: deleting address fe80::3c63:9527:8bc8:3a0d
jun 02 14:44:43 acomputer miracle-wifid-wlan0-2[3396]: P2P-GO-NEG-FAILURE status=-1
jun 02 14:44:43 acomputer dhcpcd[574]: p2p-wlan0-0: removing interface
jun 02 14:44:46 acomputer miracle-wifid-wlan0-2[3396]: P2P-DEVICE-LOST p2p_dev_addr=66:1c:b0:89:a7:6b
jun 02 14:44:59 acomputer sudo[3399]: pam_unix(sudo:session): session closed for user root
jun 02 14:44:59 acomputer audit[3399]: USER_END pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:44:59 acomputer audit[3399]: CRED_DISP pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:44:59 acomputer kernel: audit: type=1106 audit(1622659499.571:369): pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:44:59 acomputer kernel: audit: type=1104 audit(1622659499.571:370): pid=3399 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:45:03 acomputer miracle-wifid-wlan0-2[3396]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
jun 02 14:45:03 acomputer kernel: audit: type=1106 audit(1622659503.290:371): pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:45:03 acomputer kernel: audit: type=1104 audit(1622659503.294:372): pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:45:03 acomputer audit[3391]: USER_END pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:45:03 acomputer audit[3391]: CRED_DISP pid=3391 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:45:03 acomputer sudo[3391]: pam_unix(sudo:session): session closed for user root
jun 02 14:45:03 acomputer miracle-wifid-wlan0-2[3396]: p2p-dev-wlan0: CTRL-EVENT-TERMINATING
jun 02 14:45:03 acomputer miracle-wifid-wlan0-2[3396]: CTRL_IFACE: Detach monitor that cannot receive messages: /tmp/.miracle-wpas-3394-2\x00
jun 02 14:45:03 acomputer miracle-wifid-wlan0-2[3396]: CTRL_IFACE: Detach monitor that cannot receive messages: /tmp/.miracle-wpas-3394-1\x00
jun 02 14:45:03 acomputer miracle-wifid-wlan0-2[3396]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
jun 02 14:45:03 acomputer miracle-wifid-wlan0-2[3396]: wlan0: CTRL-EVENT-TERMINATING
</details>
#### other case
INFO: supplicant: wpas spawned as pid:3716
p2p_state=IDLE
wifi_display=1
ifname=wlan0
TRACE: wpa: raw message: <3>P2P-DEVICE-FOUND 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7 pri_dev_type=10-0050F204-5 name='FP3-Nico' config_methods=0x188 dev_capab=0x25 group_capab=0x0 wfd_dev_info=0x00101c440032 new=1
DEBUG: peer: new peer: 86:cf:bf:8f:bd:f7 @ wlan0 (peer_new() in wifid-peer.c:52)
INFO: peer: add peer: 86:cf:bf:8f:bd:f7
DEBUG: peer: peer 86:cf:bf:8f:bd:f7 @ wlan0 started (peer_supplicant_started() in wifid-peer.c:162)
DEBUG: supplicant: requesting data for new peer 86:cf:bf:8f:bd:f7 (supplicant_event_p2p_device_found() in wifid-supplicant.c:962)
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 0 a0:8e:78:ed:d9:dd
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 1 a0:8e:78:ed:d9:df
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 10 00:23:cd:20:a3:aa
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 11 44:e9:dd:46:6c:1a
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 12 40:f2:01:ec:fd:43
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 13 44:ad:b1:63:33:3e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 14 1c:5f:2b:fa:37:c0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 16 86:1b:5e:3b:6d:ef
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 18 74:da:88:85:bc:a8
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 19 3e:17:10:25:71:b7
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 20 fa:5e:42:56:1c:38
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 21 f8:5e:42:4e:1c:3b
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 22 62:45:b6:6d:25:05
model_name=
model_number=
serial_number=
dev_capab=0x21
group_capab=0x0
level=-54
age=4
listen_freq=2412
go_neg_req_sent=0
go_state=unknown
dialog_token=0
country=__
oper_freq=0
flags=[REPORTED]
status=0
invitation_reqs=0
TRACE: wpa: raw message: 86:cf:bf:8f:bd:f7
device_name=FP3-Nico
manufacturer=
model_name=
model_number=
serial_number=
dev_capab=0x25
group_capab=0x0
level=-54
age=4
listen_freq=2437
go_neg_req_sent=0
go_state=unknown
dialog_token=0
country=__
oper_freq=0
flags=[REPORTED]
status=0
invitation_reqs=0
wfd_subelems=00000600101c440032
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 23 3c:17:10:1f:99:d6
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 24 fa:5e:42:4f:1c:3b
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 25 f8:5e:42:4e:1c:3a
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 26 fa:5e:42:4f:1c:3d
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 27 a0:ff:70:d8:b8:0e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 28 a0:ff:70:d8:b8:0c
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 29 fa:5e:42:4f:1c:3f
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 30 a0:ff:70:d8:b8:0a
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 31 04:bf:6d:57:3c:c0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 32 10:33:bf:aa:a1:b0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 33 b8:ec:a3:37:9a:b0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 34 b8:d9:4d:f2:c2:76
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 35 3c:17:10:21:43:6e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 36 e6:bf:fa:7b:7e:55
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 37 e6:bf:fa:7b:7e:57
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 38 e4:bf:fa:7a:7e:54
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 39 10:33:bf:aa:a1:b2
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 40 18:d6:c7:a6:f0:14
TRACE: wpa: raw message: <3>P2P-GO-NEG-SUCCESS role=GO freq=2437 ht40=0 peer_dev=66:1c:b0:89:a7:6b peer_iface=66:1c:b0:89:a7:6b wps_method=PBC
DEBUG: supplicant: set STA-MAC for 66:1c:b0:89:a7:6b from <none> to 66:1c:b0:89:a7:6b (via GO-NEG-SUCCESS) (supplicant_event_p2p_go_neg_success() in wifid-supplicant.c:1194)
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>AP-ENABLED
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>CTRL-EVENT-CONNECTED - Connection to 9e:b6:d0:97:ea:78 completed [id=0 id_str=]
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>WPS-PBC-ACTIVE
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>WPS-ENROLLEE-SEEN 66:1c:b0:89:a7:6b d2534620-364d-59f0-9da7-0186c408fd61 7-0050F204-1 0x4388 4 1 [[TV] Samsung 5]
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=66:1c:b0:89:a7:6b signal=-58
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=66:1c:b0:89:a7:6b signal=-56
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=66:1c:b0:89:a7:6b signal=-57
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>CTRL-EVENT-EAP-STARTED 66:1c:b0:89:a7:6b
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=1
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=254
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>WPS-REG-SUCCESS 66:1c:b0:89:a7:6b d2534620-364d-59f0-9da7-0186c408fd61
TRACE: wpa: raw message: <3>P2P-GROUP-FORMATION-SUCCESS
TRACE: wpa: raw message: <3>P2P-GROUP-STARTED p2p-wlan0-0 GO ssid="DIRECT-11" freq=2437 passphrase="M2Qg7l2C" go_dev_addr=9c:b6:d0:97:ea:78
DEBUG: supplicant: ssid: DIRECT-11 (supplicant_event_p2p_group_started() in wifid-supplicant.c:1220)
DEBUG: supplicant: new group: p2p-wlan0-0 (supplicant_group_new() in wifid-supplicant.c:489)
DEBUG: supplicant: start local group on new group p2p-wlan0-0 as GO/1 (supplicant_event_p2p_group_started() in wifid-supplicant.c:1254)
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>WPS-PBC-DISABLE
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>WPS-SUCCESS
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>CTRL-EVENT-EAP-FAILURE 66:1c:b0:89:a7:6b
DEBUG: supplicant: dhcp-comm-p2p-wlan0-0: L:192.168.50.1 (supplicant_group_comm_fn() in wifid-supplicant.c:254)
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-55
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-56
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>AP-STA-CONNECTED 66:1c:b0:89:a7:6b p2p_dev_addr=66:1c:b0:89:a7:6b
TRACE: wpa: raw message: <3>AP-STA-CONNECTED 66:1c:b0:89:a7:6b p2p_dev_addr=66:1c:b0:89:a7:6b
DEBUG: supplicant: no ifname in AP-STA-CONNECTED: <3>AP-STA-CONNECTED 66:1c:b0:89:a7:6b p2p_dev_addr=66:1c:b0:89:a7:6b (supplicant_event_ap_sta_connected() in wifid-supplicant.c:1376)
DEBUG: supplicant: dhcp-comm-p2p-wlan0-0: R:66:1c:b0:89:a7:6b 192.168.50.100 (supplicant_group_comm_fn() in wifid-supplicant.c:254)
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-54
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-53
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-52
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-60
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-57
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-58
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-59
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-75
TRACE: wpa: raw message: <3>P2P-DEVICE-LOST p2p_dev_addr=86:cf:bf:8f:bd:f7
DEBUG: supplicant: lost peer 86:cf:bf:8f:bd:f7 (supplicant_event_p2p_device_lost() in wifid-supplicant.c:986)
DEBUG: peer: peer 86:cf:bf:8f:bd:f7 @ wlan0 stopped (peer_supplicant_stopped() in wifid-peer.c:172)
DEBUG: peer: free peer: 86:cf:bf:8f:bd:f7 @ wlan0 (peer_free() in wifid-peer.c:90)
INFO: peer: remove peer: 86:cf:bf:8f:bd:f7
DEBUG: supplicant: disconnect from 66:1c:b0:89:a7:6b (supplicant_peer_disconnect() in wifid-supplicant.c:794)
</details>
[miraclectl] #
[ADD] Link: 2
link 2 selected
[ADD] Peer: 86:cf:bf:8f:bd:f7@2
Connected=0
[miraclectl] #
[REMOVE] Peer: 86:cf:bf:8f:bd:f7@2
[miraclectl] # list
[miraclectl] # disconnect 66:1c:b0:89:a7:6b@2
[miraclectl] # exit
[miraclectl] #
[miraclectl] #
link 2 deselected
</details>
jun 02 14:53:35 acomputer dbus-daemon[567]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:53:35 acomputer audit[3709]: USER_ACCT pid=3709 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:53:35 acomputer sudo[3709]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:53:35 acomputer sudo[3709]: nico : TTY=pts/0 ; PWD=/home/nico ; USER=root ; COMMAND=/usr/bin/journalctl -f
jun 02 14:53:35 acomputer audit[3709]: CRED_REFR pid=3709 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:53:35 acomputer sudo[3709]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
jun 02 14:53:35 acomputer kernel: audit: type=1101 audit(1622660015.733:430): pid=3709 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:53:35 acomputer kernel: audit: type=1110 audit(1622660015.733:431): pid=3709 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:53:35 acomputer kernel: audit: type=1105 audit(1622660015.733:432): pid=3709 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:53:35 acomputer audit[3709]: USER_START pid=3709 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:53:38 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.80' (uid=0 pid=3712 comm="sudo miracle-wifid --log-level trace ")
jun 02 14:53:38 acomputer dbus-daemon[567]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:53:38 acomputer sudo[3712]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:53:38 acomputer audit[3712]: USER_ACCT pid=3712 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:53:38 acomputer sudo[3712]: nico : TTY=pts/1 ; PWD=/home/nico ; USER=root ; COMMAND=/usr/bin/miracle-wifid --log-level trace
jun 02 14:53:38 acomputer audit[3712]: CRED_REFR pid=3712 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:53:38 acomputer kernel: audit: type=1101 audit(1622660018.739:433): pid=3712 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:53:38 acomputer kernel: audit: type=1110 audit(1622660018.739:434): pid=3712 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:53:38 acomputer sudo[3712]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
jun 02 14:53:38 acomputer audit[3712]: USER_START pid=3712 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:53:38 acomputer kernel: audit: type=1105 audit(1622660018.743:435): pid=3712 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:53:38 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.81' (uid=0 pid=3714 comm="miracle-wifid --log-level trace ")
jun 02 14:53:38 acomputer audit: BPF prog-id=40 op=LOAD
jun 02 14:53:38 acomputer audit: BPF prog-id=41 op=LOAD
jun 02 14:53:38 acomputer audit: BPF prog-id=42 op=LOAD
jun 02 14:53:38 acomputer systemd[1]: Starting Hostname Service...
jun 02 14:53:38 acomputer kernel: audit: type=1334 audit(1622660018.753:436): prog-id=40 op=LOAD
jun 02 14:53:38 acomputer kernel: audit: type=1334 audit(1622660018.753:437): prog-id=41 op=LOAD
jun 02 14:53:38 acomputer kernel: audit: type=1334 audit(1622660018.753:438): prog-id=42 op=LOAD
jun 02 14:53:38 acomputer dbus-daemon[567]: [system] Successfully activated service 'org.freedesktop.hostname1'
jun 02 14:53:38 acomputer systemd[1]: Started Hostname Service.
jun 02 14:53:38 acomputer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:53:38 acomputer kernel: audit: type=1130 audit(1622660018.836:439): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:53:38 acomputer miracle-wifid-wlan0-2[3716]: Successfully initialized wpa_supplicant
jun 02 14:53:41 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.83' (uid=0 pid=3720 comm="sudo miracle-wifictl --log-level trace ")
jun 02 14:53:41 acomputer dbus-daemon[567]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:53:41 acomputer sudo[3720]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:53:41 acomputer audit[3720]: USER_ACCT pid=3720 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:53:41 acomputer sudo[3720]: nico : TTY=pts/2 ; PWD=/home/nico ; USER=root ; COMMAND=/usr/bin/miracle-wifictl --log-level trace
jun 02 14:53:41 acomputer audit[3720]: CRED_REFR pid=3720 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:53:41 acomputer kernel: audit: type=1101 audit(1622660021.699:440): pid=3720 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:53:41 acomputer kernel: audit: type=1110 audit(1622660021.699:441): pid=3720 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:53:41 acomputer kernel: audit: type=1105 audit(1622660021.702:442): pid=3720 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:53:41 acomputer audit[3720]: USER_START pid=3720 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:53:41 acomputer sudo[3720]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
jun 02 14:54:08 acomputer systemd[1]: systemd-hostnamed.service: Deactivated successfully.
jun 02 14:54:08 acomputer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:54:08 acomputer kernel: audit: type=1131 audit(1622660048.872:443): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:54:09 acomputer audit: BPF prog-id=42 op=UNLOAD
jun 02 14:54:09 acomputer audit: BPF prog-id=41 op=UNLOAD
jun 02 14:54:09 acomputer audit: BPF prog-id=40 op=UNLOAD
jun 02 14:54:09 acomputer kernel: audit: type=1334 audit(1622660049.072:444): prog-id=42 op=UNLOAD
jun 02 14:54:09 acomputer kernel: audit: type=1334 audit(1622660049.072:445): prog-id=41 op=UNLOAD
jun 02 14:54:09 acomputer kernel: audit: type=1334 audit(1622660049.072:446): prog-id=40 op=UNLOAD
jun 02 14:54:16 acomputer miracle-wifid-wlan0-2[3716]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
jun 02 14:54:19 acomputer miracle-wifid-wlan0-2[3716]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
jun 02 14:54:19 acomputer miracle-wifid-wlan0-2[3716]: P2P-DEVICE-FOUND 66:1c:b0:89:a7:6b p2p_dev_addr=66:1c:b0:89:a7:6b pri_dev_type=7-0050F204-1 name='[TV] Samsung 5' config_methods=0x188 dev_capab=0x21 group_capab=0x0 wfd_dev_info=0x01131c440036 vendor_elems=1 new=1
jun 02 14:54:19 acomputer miracle-wifid-wlan0-2[3716]: P2P-DEVICE-FOUND 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7 pri_dev_type=10-0050F204-5 name='FP3-Nico' config_methods=0x188 dev_capab=0x25 group_capab=0x0 wfd_dev_info=0x00101c440032 new=1
jun 02 14:54:21 acomputer miracle-wifid-wlan0-2[3716]: P2P-FIND-STOPPED
jun 02 14:54:31 acomputer systemd-udevd[3740]: Using default interface naming scheme 'v247'.
jun 02 14:54:31 acomputer systemd-udevd[3740]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
jun 02 14:54:31 acomputer dhcpcd[574]: p2p-wlan0-0: waiting for carrier
jun 02 14:54:31 acomputer dhcpcd[574]: p2p-wlan0-0: carrier acquired
jun 02 14:54:31 acomputer dhcpcd[574]: p2p-wlan0-0: IAID d0:97:ea:67
jun 02 14:54:31 acomputer dhcpcd[574]: p2p-wlan0-0: IAID conflicts with one assigned to wlan0
jun 02 14:54:31 acomputer dhcpcd[574]: p2p-wlan0-0: adding address fe80::3c63:9527:8bc8:3a0d
jun 02 14:54:31 acomputer dhcpcd[574]: p2p-wlan0-0: carrier lost
jun 02 14:54:31 acomputer dhcpcd[574]: p2p-wlan0-0: deleting address fe80::3c63:9527:8bc8:3a0d
jun 02 14:54:36 acomputer miracle-wifid-wlan0-2[3716]: P2P-GO-NEG-SUCCESS role=GO freq=2437 ht40=0 peer_dev=66:1c:b0:89:a7:6b peer_iface=66:1c:b0:89:a7:6b wps_method=PBC
jun 02 14:54:36 acomputer miracle-wifid-wlan0-2[3716]: Using interface p2p-wlan0-0 with hwaddr 9e:b6:d0:97:ea:78 and ssid "DIRECT-11"
jun 02 14:54:36 acomputer dhcpcd[574]: p2p-wlan0-0: carrier acquired
jun 02 14:54:36 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: interface state UNINITIALIZED->ENABLED
jun 02 14:54:36 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: AP-ENABLED
jun 02 14:54:36 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: CTRL-EVENT-CONNECTED - Connection to 9e:b6:d0:97:ea:78 completed [id=0 id_str=]
jun 02 14:54:36 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: WPS-PBC-ACTIVE
jun 02 14:54:36 acomputer kernel: IPv6: ADDRCONF(NETDEV_CHANGE): p2p-wlan0-0: link becomes ready
jun 02 14:54:36 acomputer dhcpcd[574]: p2p-wlan0-0: IAID d0:97:ea:67
jun 02 14:54:36 acomputer dhcpcd[574]: p2p-wlan0-0: IAID conflicts with one assigned to wlan0
jun 02 14:54:36 acomputer dhcpcd[574]: p2p-wlan0-0: adding address fe80::3c63:9527:8bc8:3a0d
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: CTRL-EVENT-EAP-STARTED 66:1c:b0:89:a7:6b
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=1
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=254
jun 02 14:54:37 acomputer dhcpcd[574]: p2p-wlan0-0: soliciting an IPv6 router
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: WPS-REG-SUCCESS 66:1c:b0:89:a7:6b d2534620-364d-59f0-9da7-0186c408fd61
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: P2P-GROUP-FORMATION-SUCCESS
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: P2P-GROUP-STARTED p2p-wlan0-0 GO ssid="DIRECT-11" freq=2437 go_dev_addr=9c:b6:d0:97:ea:78
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: WPS-PBC-DISABLE
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: WPS-SUCCESS
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: CTRL-EVENT-EAP-FAILURE 66:1c:b0:89:a7:6b
jun 02 14:54:37 acomputer miracle-dhcp-p2p-wlan0-0[3757]: INFO: miracle-dhcp - revision 1.0 May 31 2021 03:06:20
jun 02 14:54:37 acomputer miracle-dhcp-p2p-wlan0-0[3757]: INFO: dhcp: flushing local if-addr
jun 02 14:54:37 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: dhcp: successfully flushed local if-addr via /bin/ip (flush_if_addr() in dhcp.c:186)
jun 02 14:54:37 acomputer miracle-dhcp-p2p-wlan0-0[3757]: INFO: dhcp: adding local if-addr 192.168.50.1/255.255.255.0
jun 02 14:54:37 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: dhcp: successfully set local if-addr 192.168.50.1/255.255.255.0 via /bin/ip (add_if_addr() in dhcp.c:240)
jun 02 14:54:37 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: option_code 1 option_value 255.255.255.0 (<unknown>() in <unknown>:0)
jun 02 14:54:37 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: option_code 3 option_value 192.168.50.1 (<unknown>() in <unknown>:0)
jun 02 14:54:37 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: option_code 6 option_value 192.168.50.1 (<unknown>() in <unknown>:0)
jun 02 14:54:37 acomputer miracle-dhcp-p2p-wlan0-0[3757]: INFO: dhcp: running dhcp server on p2p-wlan0-0 via '/bin/ip'
jun 02 14:54:37 acomputer dhcpcd[574]: p2p-wlan0-0: soliciting a DHCP lease
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: AP-STA-CONNECTED 66:1c:b0:89:a7:6b p2p_dev_addr=66:1c:b0:89:a7:6b
jun 02 14:54:37 acomputer miracle-wifid-wlan0-2[3716]: AP-STA-CONNECTED 66:1c:b0:89:a7:6b p2p_dev_addr=66:1c:b0:89:a7:6b
jun 02 14:54:38 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: Received DISCOVER (<unknown>() in <unknown>:0)
jun 02 14:54:38 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: find yiaddr 1681041600 (<unknown>() in <unknown>:0)
jun 02 14:54:38 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: lease_mac (nil) lease_nip (nil) (<unknown>() in <unknown>:0)
jun 02 14:54:38 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: Sending OFFER of 192.168.50.100 (<unknown>() in <unknown>:0)
jun 02 14:54:38 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: Broadcasting packet to client (<unknown>() in <unknown>:0)
jun 02 14:54:38 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: Received REQUEST NIP -1062718876 (<unknown>() in <unknown>:0)
jun 02 14:54:38 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: Sending ACK (<unknown>() in <unknown>:0)
jun 02 14:54:38 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: Sending ACK to 192.168.50.100 (<unknown>() in <unknown>:0)
jun 02 14:54:38 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: gdhcp: lease_mac 0x5587c1074db0 lease_nip 0x5587c1074db0 (<unknown>() in <unknown>:0)
jun 02 14:54:38 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: dhcp: remote lease: 66:1c:b0:89:a7:6b 192.168.50.100 (server_event_fn() in dhcp.c:372)
jun 02 14:56:18 acomputer miracle-wifid-wlan0-2[3716]: P2P-DEVICE-LOST p2p_dev_addr=86:cf:bf:8f:bd:f7
jun 02 14:57:09 acomputer sudo[3720]: pam_unix(sudo:session): session closed for user root
jun 02 14:57:09 acomputer kernel: audit: type=1106 audit(1622660229.658:447): pid=3720 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:57:09 acomputer kernel: audit: type=1104 audit(1622660229.658:448): pid=3720 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:57:09 acomputer audit[3720]: USER_END pid=3720 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:57:09 acomputer audit[3720]: CRED_DISP pid=3720 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:57:15 acomputer miracle-dhcp-p2p-wlan0-0[3757]: NOTICE: dhcp: received signal 2: Interrupt
jun 02 14:57:15 acomputer miracle-wifid-wlan0-2[3716]: P2P-GROUP-REMOVED p2p-wlan0-0 GO reason=REQUESTED
jun 02 14:57:15 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: interface state ENABLED->DISABLED
jun 02 14:57:15 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: AP-STA-DISCONNECTED 66:1c:b0:89:a7:6b p2p_dev_addr=66:1c:b0:89:a7:6b
jun 02 14:57:15 acomputer miracle-wifid-wlan0-2[3716]: AP-STA-DISCONNECTED 66:1c:b0:89:a7:6b p2p_dev_addr=66:1c:b0:89:a7:6b
jun 02 14:57:15 acomputer miracle-wifid-wlan0-2[3716]: CTRL_IFACE: Detach monitor that cannot receive messages: /tmp/.miracle-wpas-3714-2\x00
jun 02 14:57:15 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: AP-DISABLED
jun 02 14:57:15 acomputer audit[3712]: USER_END pid=3712 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:57:15 acomputer audit[3712]: CRED_DISP pid=3712 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:57:15 acomputer miracle-dhcp-p2p-wlan0-0[3757]: INFO: dhcp: flushing local if-addr
jun 02 14:57:15 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: dhcp: successfully flushed local if-addr via /bin/ip (flush_if_addr() in dhcp.c:186)
jun 02 14:57:15 acomputer miracle-dhcp-p2p-wlan0-0[3757]: DEBUG: dhcp: exiting.. (main() in dhcp.c:937)
jun 02 14:57:15 acomputer kernel: audit: type=1106 audit(1622660235.977:449): pid=3712 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:57:15 acomputer kernel: audit: type=1104 audit(1622660235.977:450): pid=3712 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:57:15 acomputer miracle-dhcp[3757]: Source ID 1 was not found when attempting to remove it
jun 02 14:57:15 acomputer dhcpcd[574]: p2p-wlan0-0: carrier lost
jun 02 14:57:15 acomputer sudo[3712]: pam_unix(sudo:session): session closed for user root
jun 02 14:57:16 acomputer miracle-wifid-wlan0-2[3716]: p2p-wlan0-0: CTRL-EVENT-DISCONNECTED bssid=9e:b6:d0:97:ea:78 reason=3 locally_generated=1
jun 02 14:57:16 acomputer miracle-wifid-wlan0-2[3716]: nl80211: deinit ifname=p2p-wlan0-0 disabled_11b_rates=0
jun 02 14:57:16 acomputer dhcpcd[574]: p2p-wlan0-0: removing interface
jun 02 14:57:16 acomputer miracle-wifid-wlan0-2[3716]: P2P-DEVICE-LOST p2p_dev_addr=66:1c:b0:89:a7:6b
jun 02 14:57:16 acomputer miracle-wifid-wlan0-2[3716]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
jun 02 14:57:16 acomputer miracle-wifid-wlan0-2[3716]: p2p-dev-wlan0: CTRL-EVENT-TERMINATING
jun 02 14:57:16 acomputer miracle-wifid-wlan0-2[3716]: CTRL_IFACE: Detach monitor that cannot receive messages: /tmp/.miracle-wpas-3714-1\x00
jun 02 14:57:16 acomputer miracle-wifid-wlan0-2[3716]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
jun 02 14:57:16 acomputer miracle-wifid-wlan0-2[3716]: wlan0: CTRL-EVENT-TERMINATING
</details>
<details><summary>dhcpd.conf</summary>
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for detailss.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
#hostname
# Use the hardware address of the interface for the Client ID.
#clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
duid
# Persist interface configuration when dhcpcd exits.
persistent
# vendorclassid is set to blank to avoid sending the default of
# dhcpcd-<version>:<os>:<machine>:<platform>
vendorclassid
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search
option classless_static_routes
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# Request a hostname from the network
option host_name
# Most distributions have NTP support.
#option ntp_servers
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
# OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
noipv4ll
</details>
### Phone as source with Laptop as sink
Same, I stop concerned services, I disable firewall. I start `miracle-wifid` in a shell, I start `miracle-sinkctl` in another shell, I run a link.
From my phone, Miracle appears in the cast setting, I tap on it, it try to connect until a timeout occured I guess, so with no success.
On the other side, into the `miracle-sinkctl` shell, it add peer, go to negociation, and fail with: `[FAIL] Peer: 86:cf:bf:8f:bd:f7@2 Reason: disconnected`. Into the `miracle-wifid` the same error happens than when I used it as source: `CTRL-EVENT-EAP-FAILURE 86:cf:bf:8f:bd:f7`, and also the same notification into `journalctl`: `dhcpcd[574]: p2p-wlan0-0: IAID conflicts with one assigned to wlan0`.
You will find above the related output for this situation.
INFO: supplicant: wpas spawned as pid:3623
p2p_state=IDLE
wifi_display=1
ifname=wlan0
DEBUG: supplicant: send 'WFD_SUBELEM_SET 0 000600111c4400c8' to wpas on wlan0 (supplicant_set_wfd_subelements() in wifid-supplicant.c:1989)
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 3 b8:ec:a3:d3:21:59
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 4 a0:8e:78:ed:d9:de
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 5 40:f2:01:ec:fd:43
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 6 3c:17:10:21:43:6e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 7 44:ad:b1:63:33:3e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 8 c0:c9:e3:8c:03:0e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 9 a0:8e:78:f1:ec:3e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 10 86:1b:5e:3b:6d:ef
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 11 84:1b:5e:3b:6d:ee
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 12 1c:5f:2b:fa:37:c0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 13 b8:ec:a3:d3:21:58
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 14 4e:84:6a:a9:c3:a0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 15 74:da:88:85:bc:a8
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 16 fa:5e:42:56:1c:38
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 17 e4:bf:fa:7a:7e:54
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 18 e6:bf:fa:7b:7e:51
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 19 e6:bf:fa:7b:7e:57
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 20 3c:17:10:1f:99:d6
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 21 a0:ff:70:d8:b8:0a
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 22 a0:ff:70:d8:b8:0c
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 23 a0:ff:70:d8:b8:0e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 24 b8:d9:4d:f2:c2:76
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 25 3e:17:10:25:71:b7
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 26 44:ad:b1:64:1d:0e
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 27 18:d6:c7:a6:f0:14
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 28 b8:ec:a3:ca:bc:80
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 29 3c:84:6a:a9:c3:a0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 30 3c:17:10:23:af:e6
manufacturer=
model_name=
model_number=
serial_number=
dev_capab=0x25
group_capab=0x0
level=-37
age=0
listen_freq=2437
go_neg_req_sent=0
go_state=unknown
dialog_token=0
country=__
oper_freq=0
flags=[REPORTED]
status=0
invitation_reqs=0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 31 34:49:5b:22:e0:fe
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 32 a0:e4:cb:f6:0e:24
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 33 fa:5e:42:4f:1c:3d
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 34 fa:5e:42:4f:1c:3f
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 35 3c:17:10:25:70:b6
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 36 00:23:cd:20:a3:aa
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 37 e6:bf:fa:7b:7e:55
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 38 f8:5e:42:4e:1c:3a
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 39 a0:ff:70:d8:b8:09
TRACE: wpa: raw message: <3>P2P-PROV-DISC-PBC-REQ 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7 pri_dev_type=10-0050F204-5 name='FP3-Nico' config_methods=0x188 dev_capab=0x25 group_capab=0x0
TRACE: wpa: raw message: <3>P2P-GO-NEG-REQUEST 86:cf:bf:8f:bd:f7 dev_passwd_id=4 go_intent=0
DEBUG: supplicant: GO Negotiation Request from 86:cf:bf:8f:bd:f7 (supplicant_event_p2p_go_neg_request() in wifid-supplicant.c:1065)
DEBUG: supplicant: connect to 86:cf:bf:8f:bd:f7 via pbc/(null) (supplicant_peer_connect() in wifid-supplicant.c:739)
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 40 44:e9:dd:4d:89:6a
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 41 fa:5e:42:4f:1c:3b
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 42 ec:08:6b:4f:59:cd
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 43 10:33:bf:aa:a1:af
TRACE: wpa: raw message: <3>P2P-GO-NEG-SUCCESS role=GO freq=2437 ht40=0 peer_dev=86:cf:bf:8f:bd:f7 peer_iface=86:cf:bf:8f:bd:f7 wps_method=PBC
DEBUG: supplicant: set STA-MAC for 86:cf:bf:8f:bd:f7 from <none> to 86:cf:bf:8f:bd:f7 (via GO-NEG-SUCCESS) (supplicant_event_p2p_go_neg_success() in wifid-supplicant.c:1194)
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>WPS-ENROLLEE-SEEN 86:cf:bf:8f:bd:f7 1a950087-8293-5dcc-8b1a-b1de7b8f86be 10-0050F204-5 0x4388 4 1 [FP3-Nico]
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-48
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-49
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>CTRL-EVENT-EAP-STARTED 86:cf:bf:8f:bd:f7
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>WPS-REG-SUCCESS 86:cf:bf:8f:bd:f7 1a950087-8293-5dcc-8b1a-b1de7b8f86be
TRACE: wpa: raw message: <3>P2P-GROUP-STARTED p2p-wlan0-0 GO ssid="DIRECT-Lj" freq=2437 passphrase="DlWsCf0V" go_dev_addr=9c:b6:d0:97:ea:78
DEBUG: supplicant: ssid: DIRECT-Lj (supplicant_event_p2p_group_started() in wifid-supplicant.c:1220)
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>CTRL-EVENT-EAP-FAILURE 86:cf:bf:8f:bd:f7
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>AP-STA-CONNECTED 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7
TRACE: wpa: raw message: <3>AP-STA-CONNECTED 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7
DEBUG: supplicant: no ifname in AP-STA-CONNECTED: <3>AP-STA-CONNECTED 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7 (supplicant_event_ap_sta_connected() in wifid-supplicant.c:1376)
DEBUG: supplicant: dhcp-comm-p2p-wlan0-0: R:86:cf:bf:8f:bd:f7 192.168.50.100 (supplicant_group_comm_fn() in wifid-supplicant.c:254)
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>AP-STA-DISCONNECTED 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7
TRACE: wpa: raw message: <3>AP-STA-DISCONNECTED 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7
DEBUG: supplicant: unbind peer 86:cf:bf:8f:bd:f7 from its group (supplicant_event_ap_sta_disconnected() in wifid-supplicant.c:1421)
TRACE: wpa: raw message: OK
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-61
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-62
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 44 1c:5f:2b:fa:37:c2
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 45 3c:17:10:1f:99:d5
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 46 26:17:10:1f:99:d5
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 47 3c:17:10:1f:99:d7
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 48 44:e9:dd:46:6c:1a
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 49 b8:ec:a3:37:9a:b0
TRACE: wpa: raw message: IFNAME=wlan0 <3>CTRL-EVENT-BSS-ADDED 50 00:cb:51:fd:97:e6
TRACE: wpa: raw message: IFNAME=p2p-dev-wlan0 <3>CTRL-EVENT-SCAN-STARTED
TRACE: wpa: raw message: <3>CTRL-EVENT-SCAN-STARTED
TRACE: wpa: raw message: IFNAME=p2p-wlan0-0 <3>RX-PROBE-REQUEST sa=86:cf:bf:8f:bd:f7 signal=-65
</details>
<details><summary>miracle-sinkctl output</summary>
[miraclectl] #
[ADD] Link: 2
[miraclectl] # run 2
now running on link 2
[miraclectl] #
[miraclectl] #
[PROV] Peer: 86:cf:bf:8f:bd:f7@2 Type: pbc PIN:
[miraclectl] #
[miraclectl] #
[GO NEG] Peer: 86:cf:bf:8f:bd:f7@2 Type: pbc PIN:
[miraclectl] #
[miraclectl] #
[miraclectl] # exit
[miraclectl] #
[miraclectl] #
ERROR: cannot change p2p-scanning state on link 2 to 0: Noeud final de transport n'est pas connecté (ctl_link_set_p2p_scanning()
no longer waiting for peer FP3-Nico (86:cf:bf:8f:bd:f7@2)
no longer running on link
</details>
jun 02 14:50:27 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.73' (uid=0 pid=3615 comm="sudo journalctl -f ")
jun 02 14:50:27 acomputer dbus-daemon[567]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:50:27 acomputer sudo[3615]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:50:27 acomputer kernel: audit: type=1101 audit(1622659827.681:407): pid=3615 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:50:27 acomputer kernel: audit: type=1110 audit(1622659827.681:408): pid=3615 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:50:27 acomputer kernel: audit: type=1105 audit(1622659827.684:409): pid=3615 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:50:27 acomputer audit[3615]: USER_ACCT pid=3615 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:50:27 acomputer audit[3615]: CRED_REFR pid=3615 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:50:27 acomputer audit[3615]: USER_START pid=3615 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
jun 02 14:50:27 acomputer sudo[3615]: nico : TTY=pts/0 ; PWD=/home/nico ; USER=root ; COMMAND=/usr/bin/journalctl -f
jun 02 14:50:27 acomputer sudo[3615]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
jun 02 14:50:31 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.74' (uid=0 pid=3619 comm="sudo miracle-wifid --log-level trace ")
jun 02 14:50:31 acomputer dbus-daemon[567]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:50:31 acomputer sudo[3619]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:50:31 acomputer audit[3619]: USER_ACCT pid=3619 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:50:31 acomputer sudo[3619]: nico : TTY=pts/1 ; PWD=/home/nico ; USER=root ; COMMAND=/usr/bin/miracle-wifid --log-level trace
jun 02 14:50:31 acomputer audit[3619]: CRED_REFR pid=3619 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:50:31 acomputer sudo[3619]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
jun 02 14:50:31 acomputer kernel: audit: type=1101 audit(1622659831.820:410): pid=3619 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:50:31 acomputer kernel: audit: type=1110 audit(1622659831.820:411): pid=3619 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:50:31 acomputer kernel: audit: type=1105 audit(1622659831.820:412): pid=3619 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:50:31 acomputer audit[3619]: USER_START pid=3619 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:50:31 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.75' (uid=0 pid=3621 comm="miracle-wifid --log-level trace ")
jun 02 14:50:31 acomputer audit: BPF prog-id=37 op=LOAD
jun 02 14:50:31 acomputer audit: BPF prog-id=38 op=LOAD
jun 02 14:50:31 acomputer audit: BPF prog-id=39 op=LOAD
jun 02 14:50:31 acomputer systemd[1]: Starting Hostname Service...
jun 02 14:50:31 acomputer kernel: audit: type=1334 audit(1622659831.834:413): prog-id=37 op=LOAD
jun 02 14:50:31 acomputer kernel: audit: type=1334 audit(1622659831.834:414): prog-id=38 op=LOAD
jun 02 14:50:31 acomputer kernel: audit: type=1334 audit(1622659831.834:415): prog-id=39 op=LOAD
jun 02 14:50:31 acomputer dbus-daemon[567]: [system] Successfully activated service 'org.freedesktop.hostname1'
jun 02 14:50:31 acomputer systemd[1]: Started Hostname Service.
jun 02 14:50:31 acomputer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:50:31 acomputer kernel: audit: type=1130 audit(1622659831.924:416): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:50:31 acomputer miracle-wifid-wlan0-2[3623]: Successfully initialized wpa_supplicant
jun 02 14:50:38 acomputer dbus-daemon[567]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.77' (uid=0 pid=3627 comm="sudo miracle-sinkctl --log-level trace ")
jun 02 14:50:38 acomputer dbus-daemon[567]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:50:38 acomputer sudo[3627]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jun 02 14:50:38 acomputer audit[3627]: USER_ACCT pid=3627 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:50:38 acomputer sudo[3627]: nico : TTY=pts/2 ; PWD=/home/nico ; USER=root ; COMMAND=/usr/bin/miracle-sinkctl --log-level trace
jun 02 14:50:38 acomputer audit[3627]: CRED_REFR pid=3627 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:50:38 acomputer kernel: audit: type=1101 audit(1622659838.766:417): pid=3627 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="nico" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:50:38 acomputer kernel: audit: type=1110 audit(1622659838.766:418): pid=3627 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:50:38 acomputer sudo[3627]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
jun 02 14:50:38 acomputer audit[3627]: USER_START pid=3627 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:50:38 acomputer kernel: audit: type=1105 audit(1622659838.770:419): pid=3627 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:50:50 acomputer miracle-wifid-wlan0-2[3623]: P2P-DEVICE-FOUND 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7 pri_dev_type=10-0050F204-5 name='FP3-Nico' config_methods=0x188 dev_capab=0x25 group_capab=0x0 wfd_dev_info=0x00101c440032 new=1
jun 02 14:50:55 acomputer miracle-wifid-wlan0-2[3623]: P2P-PROV-DISC-PBC-REQ 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7 pri_dev_type=10-0050F204-5 name='FP3-Nico' config_methods=0x188 dev_capab=0x25 group_capab=0x0
jun 02 14:50:56 acomputer miracle-wifid-wlan0-2[3623]: P2P-GO-NEG-REQUEST 86:cf:bf:8f:bd:f7 dev_passwd_id=4 go_intent=0
jun 02 14:50:56 acomputer miracle-wifid-wlan0-2[3623]: P2P-FIND-STOPPED
jun 02 14:50:56 acomputer systemd-udevd[3634]: Using default interface naming scheme 'v247'.
jun 02 14:50:56 acomputer systemd-udevd[3634]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
jun 02 14:50:56 acomputer dhcpcd[574]: p2p-wlan0-0: waiting for carrier
jun 02 14:50:56 acomputer dhcpcd[574]: p2p-wlan0-0: carrier acquired
jun 02 14:50:56 acomputer dhcpcd[574]: p2p-wlan0-0: IAID d0:97:ea:67
jun 02 14:50:56 acomputer dhcpcd[574]: p2p-wlan0-0: IAID conflicts with one assigned to wlan0
jun 02 14:50:56 acomputer dhcpcd[574]: p2p-wlan0-0: adding address fe80::3c63:9527:8bc8:3a0d
jun 02 14:50:56 acomputer dhcpcd[574]: p2p-wlan0-0: carrier lost
jun 02 14:50:56 acomputer dhcpcd[574]: p2p-wlan0-0: deleting address fe80::3c63:9527:8bc8:3a0d
jun 02 14:50:56 acomputer miracle-wifid-wlan0-2[3623]: P2P-GO-NEG-SUCCESS role=GO freq=2437 ht40=0 peer_dev=86:cf:bf:8f:bd:f7 peer_iface=86:cf:bf:8f:bd:f7 wps_method=PBC
jun 02 14:50:56 acomputer miracle-wifid-wlan0-2[3623]: Using interface p2p-wlan0-0 with hwaddr 9e:b6:d0:97:ea:78 and ssid "DIRECT-Lj"
jun 02 14:50:56 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: interface state UNINITIALIZED->ENABLED
jun 02 14:50:56 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: AP-ENABLED
jun 02 14:50:56 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: CTRL-EVENT-CONNECTED - Connection to 9e:b6:d0:97:ea:78 completed [id=0 id_str=]
jun 02 14:50:56 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: WPS-PBC-ACTIVE
jun 02 14:50:56 acomputer kernel: IPv6: ADDRCONF(NETDEV_CHANGE): p2p-wlan0-0: link becomes ready
jun 02 14:50:56 acomputer dhcpcd[574]: p2p-wlan0-0: soliciting an IPv6 router
jun 02 14:50:57 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: CTRL-EVENT-EAP-STARTED 86:cf:bf:8f:bd:f7
jun 02 14:50:57 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=1
jun 02 14:50:57 acomputer dhcpcd[574]: p2p-wlan0-0: soliciting a DHCP lease
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: CTRL-EVENT-EAP-STARTED 86:cf:bf:8f:bd:f7
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=1
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=254
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: WPS-REG-SUCCESS 86:cf:bf:8f:bd:f7 1a950087-8293-5dcc-8b1a-b1de7b8f86be
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: P2P-GROUP-FORMATION-SUCCESS
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: P2P-GROUP-STARTED p2p-wlan0-0 GO ssid="DIRECT-Lj" freq=2437 go_dev_addr=9c:b6:d0:97:ea:78
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: WPS-PBC-DISABLE
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: WPS-SUCCESS
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: CTRL-EVENT-EAP-FAILURE 86:cf:bf:8f:bd:f7
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: INFO: miracle-dhcp - revision 1.0 May 31 2021 03:06:20
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: INFO: dhcp: flushing local if-addr
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: dhcp: successfully flushed local if-addr via /bin/ip (flush_if_addr() in dhcp.c:186)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: INFO: dhcp: adding local if-addr 192.168.50.1/255.255.255.0
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: dhcp: successfully set local if-addr 192.168.50.1/255.255.255.0 via /bin/ip (add_if_addr() in dhcp.c:240)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: option_code 1 option_value 255.255.255.0 (<unknown>() in <unknown>:0)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: option_code 3 option_value 192.168.50.1 (<unknown>() in <unknown>:0)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: option_code 6 option_value 192.168.50.1 (<unknown>() in <unknown>:0)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: INFO: dhcp: running dhcp server on p2p-wlan0-0 via '/bin/ip'
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: AP-STA-CONNECTED 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7
jun 02 14:50:59 acomputer miracle-wifid-wlan0-2[3623]: AP-STA-CONNECTED 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: Received DISCOVER (<unknown>() in <unknown>:0)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: find yiaddr 1681041600 (<unknown>() in <unknown>:0)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: lease_mac (nil) lease_nip (nil) (<unknown>() in <unknown>:0)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: Sending OFFER of 192.168.50.100 (<unknown>() in <unknown>:0)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: Broadcasting packet to client (<unknown>() in <unknown>:0)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: Received REQUEST NIP -1062718876 (<unknown>() in <unknown>:0)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: Sending ACK (<unknown>() in <unknown>:0)
jun 02 14:50:59 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: Sending ACK to 192.168.50.100 (<unknown>() in <unknown>:0)
jun 02 14:51:00 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: lease_mac 0x558657741db0 lease_nip 0x558657741db0 (<unknown>() in <unknown>:0)
jun 02 14:51:00 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: dhcp: remote lease: 86:cf:bf:8f:bd:f7 192.168.50.100 (server_event_fn() in dhcp.c:372)
jun 02 14:51:01 acomputer systemd[1]: systemd-hostnamed.service: Deactivated successfully.
jun 02 14:51:01 acomputer kernel: audit: type=1131 audit(1622659861.940:420): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:51:01 acomputer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 14:51:02 acomputer audit: BPF prog-id=39 op=UNLOAD
jun 02 14:51:02 acomputer audit: BPF prog-id=38 op=UNLOAD
jun 02 14:51:02 acomputer audit: BPF prog-id=37 op=UNLOAD
jun 02 14:51:02 acomputer kernel: audit: type=1334 audit(1622659862.103:421): prog-id=39 op=UNLOAD
jun 02 14:51:02 acomputer kernel: audit: type=1334 audit(1622659862.103:422): prog-id=38 op=UNLOAD
jun 02 14:51:02 acomputer kernel: audit: type=1334 audit(1622659862.103:423): prog-id=37 op=UNLOAD
jun 02 14:51:02 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: Received REQUEST NIP -1062718876 (<unknown>() in <unknown>:0)
jun 02 14:51:02 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: Sending ACK (<unknown>() in <unknown>:0)
jun 02 14:51:02 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: Sending ACK to 192.168.50.100 (<unknown>() in <unknown>:0)
jun 02 14:51:02 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: Broadcasting packet to client (<unknown>() in <unknown>:0)
jun 02 14:51:02 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: gdhcp: lease_mac 0x558657741db0 lease_nip 0x558657741db0 (<unknown>() in <unknown>:0)
jun 02 14:51:02 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: dhcp: remote lease: 86:cf:bf:8f:bd:f7 192.168.50.100 (server_event_fn() in dhcp.c:372)
jun 02 14:51:32 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: AP-STA-DISCONNECTED 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7
jun 02 14:51:32 acomputer miracle-wifid-wlan0-2[3623]: AP-STA-DISCONNECTED 86:cf:bf:8f:bd:f7 p2p_dev_addr=86:cf:bf:8f:bd:f7
jun 02 14:51:46 acomputer sudo[3627]: pam_unix(sudo:session): session closed for user root
jun 02 14:51:46 acomputer kernel: audit: type=1106 audit(1622659906.007:424): pid=3627 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:51:46 acomputer kernel: audit: type=1104 audit(1622659906.007:425): pid=3627 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:51:46 acomputer audit[3627]: USER_END pid=3627 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:51:46 acomputer audit[3627]: CRED_DISP pid=3627 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
jun 02 14:51:51 acomputer miracle-dhcp-p2p-wlan0-0[3652]: NOTICE: dhcp: received signal 2: Interrupt
jun 02 14:51:51 acomputer miracle-wifid-wlan0-2[3623]: P2P-GROUP-REMOVED p2p-wlan0-0 GO reason=REQUESTED
jun 02 14:51:51 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: interface state ENABLED->DISABLED
jun 02 14:51:51 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: AP-DISABLED
jun 02 14:51:51 acomputer audit[3619]: USER_END pid=3619 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:51:51 acomputer audit[3619]: CRED_DISP pid=3619 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:51:51 acomputer dhcpcd[574]: p2p-wlan0-0: carrier lost
jun 02 14:51:51 acomputer miracle-dhcp-p2p-wlan0-0[3652]: INFO: dhcp: flushing local if-addr
jun 02 14:51:51 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: dhcp: successfully flushed local if-addr via /bin/ip (flush_if_addr() in dhcp.c:186)
jun 02 14:51:51 acomputer miracle-dhcp-p2p-wlan0-0[3652]: DEBUG: dhcp: exiting.. (main() in dhcp.c:937)
jun 02 14:51:51 acomputer kernel: audit: type=1106 audit(1622659911.787:426): pid=3619 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:51:51 acomputer kernel: audit: type=1104 audit(1622659911.787:427): pid=3619 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
jun 02 14:51:51 acomputer miracle-dhcp[3652]: Source ID 1 was not found when attempting to remove it
jun 02 14:51:51 acomputer sudo[3619]: pam_unix(sudo:session): session closed for user root
jun 02 14:51:51 acomputer miracle-wifid-wlan0-2[3623]: p2p-wlan0-0: CTRL-EVENT-DISCONNECTED bssid=9e:b6:d0:97:ea:78 reason=3 locally_generated=1
jun 02 14:51:51 acomputer miracle-wifid-wlan0-2[3623]: nl80211: deinit ifname=p2p-wlan0-0 disabled_11b_rates=0
jun 02 14:51:52 acomputer dhcpcd[574]: p2p-wlan0-0: removing interface
jun 02 14:51:52 acomputer miracle-wifid-wlan0-2[3623]: P2P-FIND-STOPPED
jun 02 14:51:52 acomputer miracle-wifid-wlan0-2[3623]: CTRL_IFACE: Detach monitor that cannot receive messages: /tmp/.miracle-wpas-3621-2\x00
jun 02 14:51:52 acomputer miracle-wifid-wlan0-2[3623]: P2P-DEVICE-LOST p2p_dev_addr=86:cf:bf:8f:bd:f7
jun 02 14:51:52 acomputer miracle-wifid-wlan0-2[3623]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
jun 02 14:51:52 acomputer miracle-wifid-wlan0-2[3623]: p2p-dev-wlan0: CTRL-EVENT-TERMINATING
jun 02 14:51:52 acomputer miracle-wifid-wlan0-2[3623]: CTRL_IFACE: Detach monitor that cannot receive messages: /tmp/.miracle-wpas-3621-1\x00
jun 02 14:51:52 acomputer miracle-wifid-wlan0-2[3623]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
jun 02 14:51:52 acomputer miracle-wifid-wlan0-2[3623]: wlan0: CTRL-EVENT-TERMINATING
</details>
## Question
Is my `dhcpd` misconfigurated for `miraclecast`? If yes, what would be your recommendations about it? Thanks to have taken the time to read this issue and for any help you could give me to make it work as expected.
