Hello,
I’ve noticed that there are two main way to install a python module:
- Use
pacman -S <python-module> - Use
pip install <module>
In my little experience I notice that the second option cause less problem with installation, but it will not update py-modules automatically, right?
Also, This link sustain pip is the best way to achieve that.
Anyway, my primary question is: so why are there manjaro py-packages? What’s the pros&cons of the two option?
Thank you for bearing my “noob-ness”.
